[AG-TECH] Video producer not enabled
Jason Bell j.bell at cqu.edu.au
Thu Feb 22 16:23:49 CST 2007
G'day Darin
If you start up your venue Client, select Tools -> Preferences.  Then
select My Node, under the section media, their should be an enable video
Check box.  If it isn't there, increase the size of the window.  Tick
that check box and save.  Your video produces should now start by
default.
Hope this helps.
Cheers,
Jason.
-----Original Message-----
Sent: Friday, 23 February 2007 8:01 AM
To: monika.k.rabarison at jsums.edu
Cc: AG-TECH mailing list
Subject: Re: [AG-TECH] Video producer not enabled
Thanks Monika. Yes, this is the thought. Unfortunately it doesn't
seem to work for me. I also tried saving the configuration as a
different name (not default) and making that configuration the
default. Any other ideas?
Darin
On Feb 22, 2007, at 2:45 PM, monika.k.rabarison at jsums.edu wrote:
> Hi Darin,
> I guess you could add the video producer services and store the
> configuration as default like it is done with 2.4.
> Am I correct?
> Monika
>> Hello,
>> I finally got around to installing AG3 on our main node. Everything
>> seems to work fine, but I can't get the video producer services to be
>> enabled by default. Sorry if I missed any talk about this, but is
>> this normal? If not, anybody know what I can do to fix it?
>> Thanks,
>> Darin
More information about the ag-tech mailing list
