[AG-L] Re: [AG-TECH] RAT on 64bit RedHat
Ashley Wright
a2.wright at qut.edu.au
Tue Feb 13 23:41:04 CST 2007
Thanks Doug,
I have recompiled SRPM and it has fixed my problem. Since it has been
compiled on RHEL4, I am not sure if you would like a copy of the RPM?
Ashley
Douglas Kosovic wrote:
> Hi Ashley,
>> $ file rat-4.2.22
>> rat-4.2.22: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV),
>> for GNU/Linux 2.2.5, dynamically linked (uses shared libs), stripped
>> Will I need a 64bit version to fix this issue? And if so is there a
>> good place to get one (maybe FC5 or 6 rpms?)
> The x86-64 FC5 AG3 yum repo comes with a 32bit rat. I just ran it now
> on x86-64 FC5 and don't get the same symptoms. All of the 32bit rat
> RPMs were built on 32bit Fedora and copied across.
> The SRPMs for rat should be the same for FC3, 4 and 5. The FC6 version
> includes ALSA support. Find them under:
> http://www.vislab.uq.edu.au/accessgrid3/fedora/
> If you rebuild the AccessGrid-rat SRPM on x86-64 RHEL, it will apply a
> 64bit patch and build a x86_64 RPM. I don't have a proper install of
> x86-64 FC3 as it was too old to run on the hardware I have, I just
> chroot to a x86-64 FC3 partition that was copied across from
> elsewhere. Perhaps rebuilding rat on RHEL might fix it.
> I think I may have included a 64bit rat with FC6, but that was
> unintentional.
> Cheers,
> Doug
>>> Hi Ashley,
>>>> We are running AG 2 & 3 on a x86_64 RedHat EL4 machine (FC3 RPMS),
>>>> and our RAT displays SSIDs where it should be displaying site names.
>>>> Has anyone come across this before, and know of a solution.
>>> Are you running a 32bit or 64bit rat? You can use 'file
>>> /usr/bin/rat-4.2.22' to check. At one stage I did put up a 64bit rat
>>> in the AG3 x86_64 FC3 yum repository, but it was broken, so replaced
>>> it with the 32bit FC3 version.
>>> Doug
>> Ashley Wright
>> HPC and Research Support Group
>> Queensland University of Technology (QUT)
>> Ph: (07) 3138 9236
>> Mobile: (04) 0531 3124 QUT: #66866
>> Email: a2.wright at qut.edu.au
> accessgrid-l mailing list
> accessgrid-l at lists.grangenet.net
> http://lists.grangenet.net/mailman/listinfo/accessgrid-l
Ashley Wright
Ph: (07) 3138 9236
QUT: #66866
