[AG-TECH] Combining 2.4 and 3.0 venue servers
Thomas D. Uram
turam at mcs.anl.gov
Mon Feb 5 12:44:45 CST 2007
The multicast ports are not actually used by the VenueServer
machine. They are just passed to the clients who actually
use the ports.
Bridges for the two versions should be separated between
two machines, because I haven't seen reliable transmission of
content between two bridges running on the same machine.
On 2/5/07 12:41 PM, Jeremy Mann wrote:
> Using this method, the 3.0 server would have to be on a seperate
> machine because I can't start the 3.0 server with the same Multicast
> ports used with the 2.4 server.
> On 2/5/07, Thomas D. Uram <turam at mcs.anl.gov> wrote:
>> The solution we have used for this (and NCSA is using) is to mirror
>> the Venues across the 2.4 and 3.0 servers. 'Mirroring', in this case,
>> refers only to the Venue names and structure, and audio/video multicast
>> addresses; shared applications and data can not be shared between 2.4
>> and 3.0 clients.
>> Tom
>> On 2/5/07 12:01 PM, Jeremy Mann wrote:
>> > Is there currently a way to have 2.4 and 3.0 clients connect to the
>> > same virtual venue? The Mac users on campus have upgraded their
>> > machines and they are all the new duo core Intels which means they can
>> > only install and run the 3.0.x AG client. We still have a majority of
>> > 2.4 users so telling everybody to upgrade to 3.0.x is pretty much out
>> > of the question, at least for now.
