[AG-TECH] AG3.02 WINNOV 440
Michael Elmore
MWElmore at lbl.gov
Tue Sep 5 13:16:39 CDT 2006
Mike,
I just got this card too. When the card was initially installed we used
the software for direct show. This software looks very good.
However, we had the problem you describe when we tried to use the AG
software. I uninstalled the directshow software and reinstalled the
VFW software. We had to reconfigure the video after doing this. We
have also had some javascript errors. I haven't gotten back to this to
check out the errors. The video did work though. We have separate
selectable inputs for the producer service. I have found in the
documentation that the video sources can be terminated on the card:
video source1 J10
video source2 J12
video source3 J9
video source4 J13
If it is possible, could you terminate these sources and let me know if
the direct show software works with the terminations?
Thank you,
Mike
Mike Daley wrote:
> Hi
> Has anyone got four separate video streams from a WINNOV 440 card ?
> I can see 4 VideoProducerServices listed with 4 separate channels
> labelled
> Videum-4 Chnl 1 Standard VidCap etc up to Chnl 4
> But I get one video stream replicated on all the channels.
> I'm sure I've seen other people with the same problem and I thought
> there was a fix.
> Can anyone help
> Current Driver is 3.1 release (3.1.316.1)
> Card is WINNOV Videum 440 VO
> Running XP Pro full Service pack with latest updates.
> AG 3.0.2 (build 1)
> All the best
> Mike
Type: text/x-vcard
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060905/fe35823c/attachment.vcf>
