[AG-TECH] AG3 ftp
Thomas D. Uram
turam at mcs.anl.gov
Thu Oct 26 08:28:55 CDT 2006
Hi Javi:
Here are details regarding the use of FTP in AG3:
- passive mode is used
- by default, the port range for incoming data transfer connections is
50000-50020
(this is configurable in VenueServer.cfg with the dataPortRangeStart and
dataPortRangeEnd options)
- in passive mode, the ftp protocol specifies that the server tells the
client which port to connect to
- SSL is used for both control and data connections
If you have other questions on this, let me know.
Tom
On 10/20/06 6:17 AM, Javier Gomez Alonso wrote:
> Hi,
> I guess AG3 servers use ftp for file sharing in the venues. The question is, does it use passive or active ftp? Does it use secure ftp? Can you determine which ports to use (if passive ftp)? Any help will be appreciated. Cheers,
> - Javi
> __________________________________________________
> Javier Gomez Alonso
> Collaborative Working Developments
> RSS Group (Research Support Services)
> Manchester Computing, Kilburn Building,
> University of Manchester, Manchester M13 9PL, UK
> Tel: +44 (0) 161 275 0584
> E-mail: javier.gomez-alonso at manchester.ac.uk
> http://www.sve.man.ac.uk/General/Staff/gomez_alonso
