[AG-TECH]configure the selected service
Thomas D. Uram
turam at mcs.anl.gov
Fri Oct 6 12:23:05 CDT 2006
Hello Liying:
In the services that ship with the software, the configuration options
take effect the next time the service is started (e.g., if you disable
it and then enable it, the new configuration values should be used). A
service developer could choose to have configuration options take effect
immediately by overriding the 'SetConfiguration' method to set the
values and then apply the values to the running application. We don't do
this with vic/rat because that would mean restarting them at every
configuration, which most people would consider disruptive.
Tom
On 10/6/06 5:33 AM, liying wrote:
> hi all,
> i add an service through "manage my node......" window, after it starts up, i want to configure some of its parameters, especially those "optionsetparameter",i changed one of them from the dropdown menu, but this doesn't work. i want to know when the "optionsetparameter" in the configure window works.
> liying
> liying at vrlab.buaa.edu.cn
> 2006-10-06
