[AG-TECH] Hardware concern ...
Tom Oinn
tmo at ebi.ac.uk
Mon May 22 18:30:40 CDT 2006
Claus Endres wrote:
> Due to the very high CPU demands, H.264 cannot be used at full
> resolution at frame rates greater than about 5 fps. This is a
> single CPU limitation, having multiple CPUs will not help with
> the current X264 encoder. H.264 works very well at 2 fps or so
> for a document camera where motion is not an issue but high
> resolution is required. Using H.264 at 20 fps and PAL resolution
> is a while away.
http://www.dspr.com/www/products/video/compression/pci_encoder/4_channel_h264_pci_encoder.htm
Hardware accelerated realtime h.264 encoder with support for 4 30fps
streams, sounds promising for this kind of setup. This is a google
search rather than a personal recommendation though, anyone played with
something like this?
Tom
