[AG-TECH] Troubles entering the venues...
Fabrizio.Berdondini at prototipo.it
Fri May 19 04:10:19 CDT 2006
The solution of setting the GLOBUS_HOSTNAME variable solved the problem
for the WindowsXP VenueServer but not for the SUSE 10 one. I tried to set
it for the bash (opening a konsole and typing the "export" command) but
nothing changed.
Is there some other way to set that system var that I could try?
Thanx,
Faber B.
> "Thomas D. Uram" <turam at mcs.anl.gov> scritti il 08/05/2006 19.05.53
> > You can also use the IP address. How you set it depends on the shell
> > you use:
> > For bash:
> > export GLOBUS_HOSTNAME=140.10.10.10
> > For csh:
> > set GLOBUS_HOSTNAME 140.10.10.10
> > Tom
> > Fabrizio.Berdondini at prototipo.it wrote:
> > > Thank you Thomas, just 2 questions: our server machine as far as now
> > > doesn't have a public hostname, just a public IP. Could this be a
> > > problem? Second: how can I set the globus_hostname variable for a
SUSE
> > > 10 machine?
> > > Thank you as always for your help.
> > > Bye,
> > > Faber B.
> > > "Thomas D. Uram" <turam at mcs.anl.gov> scritti il 08/05/2006 18.50.55
> > > > Entering a venue requires a SOAP call and an event client
> > > connection. I
> > > > expect that the
> > > > SOAP call is being made to the public hsotname, but the event
client
> > > > connection is
> > > > being attempted on the internal hostname. You can force the use
of a
> > > > particular hostname
> > > > by setting the GLOBUS_HOSTNAME environment variable before running
the
> > > > VenueServer. In your case, I would set it to the public hostname.
> > > > If problems persist, let us know.
> > > > Tom
> > > > > Hello all,
> > > > > i'm having some problems with permissions (i guess so) while
> > > trying to
> > > > > enter the venues on a AG 2.4 VenueServer. I'm going to explain
better
> > > > > what's happening. We had first configurated the venue
server/clients
> > > > > inside our LAN and tested it for quite two months. After that we
put
> > > > > our server onto a public IP (without changing anything in the
server
> > > > > configuration). From this moment onwards we are no more able to
reach
> > > > > the venues: on the client we receive a message saying that we
are not
> > > > > able to connect to the lobby venue. We tried to launch a venue
client
> > > > > onto the same machine running the venueserver and we
successfully
> > > > > connected it to the lobby venue on the server. After this we
tried
> > > > > again to connect the other clients to the lobby on the venue
server:
> > > > > we received the same error, but looking inside the venue with
the
> > > only
> > > > > venueclient connected to it (the one running on the same machine
that
> > > > > runs the venueserver) we saw as many instances of the client as
the
> > > > > number of trials we did to log to that venue.
> > > > > How could we solve this problem?
> > > > > Thank you in advance,
> > > > > Faber B.
> ______________________________________________________________________
> This email has been scanned by the MessageLabs Email Security System.
> For more information please visit http://www.messagelabs.com/email
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060519/c1ea9503/attachment.htm>
