[AG-TECH] Cert Request Server Problem?
Thomas D. Uram
turam at mcs.anl.gov
Wed Mar 22 15:36:10 CST 2006
It did start working again, but was down for some time before it came back.
Attempts to submit a request between 4pm and 9pm (Chicago time) yesterday
likely failed. The AG software would have notified you that the request
failed, so you should
be aware of it if your request failed.
If you had troubles with it yesterday, please submit your request again.
Tom Uram
On 3/21/06 11:57 PM, Rhys Hawkins wrote:
> Hi,
> It just started working again :)
> Cheers,
> Rhys
> On Wed, 2006-03-22 at 16:41 +1100, Rhys Hawkins wrote:
>> Hi,
>> I can't seem to create anonymous certs on a fresh install and I get
>> the following error (outputted to console) when trying to check the
>> status of a cert reques (see below).
>> Is the server just down? (Note the 500 reply)
>> Cheers,
>> Rhys
>> connect: (www-unix.mcs.anl.gov, 80)
>> send: 'POST /fl/research/accessgrid/ca/agdev/certReqServer.cgi HTTP/1.0
>> \r\nHost: www-unix.mcs.anl.gov\r\nUser-Agent: xmlrpclib.py/1.0.1 (by
>> www.pythonware.com)\r\nContent-Type: text/xml\r\nContent-Length: 195\r\n
>> \r\n'
>> send: "<?xml
>> version='1.0'?>\n<methodCall>\n<methodName>RetrieveCertificate</methodName>\n<params>\n<param>\n<value><string>**deleted**</string></value>\n</param>\n</params>\n</methodCall>\n"
>> reply: 'HTTP/1.1 500 Internal Server Error\r\n'
>> header: Date: Wed, 22 Mar 2006 05:37:41 GMT
>> header: Server: Apache
>> header: Last-Modified: Thu, 04 Mar 1999 16:41:56 GMT
>> header: ETag: "74112-127e-36deb7d4"
>> header: Accept-Ranges: bytes
>> header: Content-Length: 4734
>> header: Connection: close
>> header: Content-Type: text/html
>> Format
>> <AccessGrid.Security.wxgui.CertificateStatusBrowser.CertRequestWrapper
>> instance at 0x2aaab4af1fc8>
