[AG-TECH] problems with RAT hanging
Niall Moran
niall.moran at ichec.ie
Fri Jun 30 03:20:22 CDT 2006
I regularly experience rat crashing. Sometimes it is worse than others.
Usually after 15-20 minutes. Setup consists of WindowsXP and a sound
blaster audigy 2.
| Niall Moran
| Systems Administrator
| Irish Centre for High-End Computing
\niall dot moran at ichec dot ie
On Fri, Jun 30, 2006 at 08:15:19AM +0100, Paul Hatton wrote:
> I've not really been following this thread, so I'm not sure what the
> platform is (it's not specified in this mail). However. I've had
> problems with on-board RealTek audio under WindowsXP - not tried any
> other platforms on this machine - which were solved by putting a
> cheap-and-cheerful old audio card in the machine and diabling the on-
> board audio - Soundblaster I think but I don't have the machine to
> hand. A Google found
> http://www.vrvs.org/Documentation/faq.html#Mbone01
> which may be relevant.
> From: "John Langkals" <langkals at pacific.mps.ohio-state.edu>
> To: "'Adam Taylor'" <accessgrid at ulm.edu>,
> "'Richard Caladine'" <caladine at uow.edu.au>,
> "'ag-tech'" <ag-tech at mcs.anl.gov>
> Subject: RE: [AG-TECH] problems with RAT hanging
> Date sent: Thu, 29 Jun 2006 17:47:00 -0400
> > This may be an issue with the Realtek AC 97 on board audio. I have
> > experienced the same thing in AG V3.0.1. Are you using an audio
> > card or on
> > board audio?
> > Thanks,
> > John
> > John Langkals
> > Systems Manager
> > OCTS
> > M2021 Physics Research Building
> > 191 West Woodruff Avenue
> > Columbus, Ohio 43210
> > 614.292.6957 Office
> > 614.327.3732 Cell
> > 614.292.7557 FAX
> > www.octs.osu.edu
> > ________________________________________
> > From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]
> > On Behalf
> > Of Adam Taylor
> > Sent: Thursday, June 29, 2006 2:46 PM
> > To: 'Richard Caladine'; 'ag-tech'
> > This is a ditto for me.? I was figuring it was my OS needing to be
> > reinstalled, new drivers, whatever.? I haven?t had time to test it
> > yet
> > however.? Before I started over I was getting about the same exact
> > thing?.?
> > Although mine would start between anywere from 15 min to 3 hours.?
> > Usually
> > however, the 15-20 min as below.? The GUI would keep working but the
> > in and
> > out of the sound, plus the meters on rat, would stop working.? The
> > menus and
> > buttons however kept working?..at least they were clickable..
> > Adam Taylor
> > Computing Center
> > University of Louisiana at Monroe
> > On Behalf
> > Of Richard Caladine
> > Sent: Thursday, June 29, 2006 1:26 AM
> > To: ag-tech
> > Subject: [AG-TECH] problems with RAT hanging
> > Hi All,
> > In the last few AG sessions we have held everything works well for
> > about the
> > first 15-20 minutes. Then RAT stops sending and receiving.
> > The only way I can get audio working again (without exiting and
> > restarting
> > the venue client) is to disable and re-enable audio.
> > However the problem reoccurs at about 5 minute intervals after that
> > ad
> > infinitum!
> > any ideas?
> > I am using V3.0.1
> > Richard
> > Dr Richard Caladine
> > Program Coordinator
> > LIFT (Learning, Innovation and Future Technologies)
> > CEDIR (Centre for Educational Development and Interactive
> > Resources)
> > University of Wollongong
> > NSW 2522
> > Australia
> > phone +61 2 4221 4138
> > fax +61 2 4225 8312
> > http://cedir.uow.edu.au/lift
> Paul Hatton
> High Performance Computing and Visualisation Specialist
> Technical Director, HP Visual and Spatial Technology Centre
> Information Services, Elms Road Computer Centre,
> The University of Birmingham, Birmingham B15 2TT.
> Ph: 0121-414-3994 Fax: 0121-414-3952 M: 07785-977340
Name: not available
Desc: Digital signature
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060630/ccceab70/attachment.pgp>
