[AG-TECH] AG2.4 setup error
Zephyr Zhangbo Liu zephyr at cs.ubc.ca
Tue Jun 20 19:18:52 CDT 2006
Hi Doug,
I did what you suggested and then it complained three dependencies needed
which are pyGlobus, pyOpenSSL_AG and SOAPpy. During the rebuild of pyGlobus
with pyGlobus-1.0.10-2.fc3.src.rpm, I found it set the $GLOBUS_LOCATION to
/usr/lib64/globus while I installed it to /usr/lib/globus, so I made a
symbolic link for them. Then it came with the following errors:
+ export GLOBUS_LOCATION=/usr/lib64/globus
+ GLOBUS_LOCATION=/usr/lib64/globus
+ /usr/bin/python setup.py build --flavor=gcc64pthr
Checking for which modules to build
Checking the  util  module
Missing dependency to build the  util  package.
The following is the error message from globus-makefile-header.
('No packages were found that matched your query!\n',)
This package is required to build all of pyGlobus.
Now exiting from the build
error: Bad exit status from /var/tmp/rpm-tmp.42880 (%build)
For the other two components, pyOpenSSL_AG needs elinks and SOAPpy needs
python-abi and the procedure of installing them are both problematic.
If directly build from AccessGrid-2.4-5.i586.rpm, will come with following
Preparing...                ###########################################
[100%]
   1:AccessGrid             ###########################################
[100%]
Traceback (most recent call last):
  File "/usr/bin/agpm.py", line 25, in ?
    from AccessGrid.AppDb import AppDb
ImportError: No module named AccessGrid.AppDb
chmod: cannot access
`/etc/AccessGrid/SharedApplications/VenueVNC/vncviewer': No such file or
directory
error: %post(AccessGrid-2.4-5) scriptlet failed, exit status 1
During the time trying to solve the problem I found it is hard to find rpms
that support SUSE, most of them I've found are for FC. Is it possible that
switch to FC can make it easier to setup the AGTK on Linux. Which
configuration(including Linux version and AGTK version) do you recommend?
Please give some advices on the problem.
Zephyr
On 6/20/06, Douglas Kosovic <douglask at itee.uq.edu.au> wrote:
> Hi Zephyr,
> > I tried to setup AG2.4 on SUSE 10, following the tutorial on:
> > http://www.vislab.uq.edu.au/research/accessgrid/software/suse/
> > building from sourse code, and got the error message below:
> Something has failed to build, the BuildSnapshot.py script continues even
> if
> something has failed earlier on.
> You will have more luck trying to build
> compat-AccessGrid-2.4-5.20060503cvs.fc3.src.rpm from here (which just use
> plain SRPM files):
>    http://www.vislab.uq.edu.au/accessgrid3/fedora/3/SRPMS/
> try:
>   rpm -i compat-AccessGrid-2.4-5.20060503cvs.fc3.src.rpm
>   cd /usr/src/suse/SPECS
> # change the wxPython dependency to python-wxGTK with vi
>   vi compat-AccessGrid.spec
>   rpmbuild -ba compat-AccessGrid.spec
> It will complain about missing dependencies, rebuild any that aren't
> available with SUSE from the SRPMs in the above URL...
> Cheers,
> Doug
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060620/4399383b/attachment.htm>
More information about the ag-tech mailing list
