AG Port issues (was Re: [AG-TECH] Access Grid 3.0 beta1 available !)
Ivan R. Judson
judson at mcs.anl.gov
Tue Jan 31 13:37:15 CST 2006
Hi Rick,
I agree, I think my point was more a clarification of what we want than a
recommendation for action. I suspect what we (the ag community) need is a
node local solution that can do the tunneling required. Ideally, it would be
a model of what we want firewalls to behave like -- reporting traffic,
having alarms, etc.
It's not a trivial task, but it might significantly improve life.
--Ivan
> -----Original Message-----
> From: R. P. Channing ["Rick"] Rodgers [mailto:rodgers at nlm.nih.gov]
> Sent: Tuesday, January 31, 2006 12:59 PM
> To: ag-tech at mcs.anl.gov
> Cc: fs at wpi.edu; johnh at comp.leeds.ac.uk; judson at mcs.anl.gov;
> csp at csperkins.org; rodgers at nlm.nih.gov
> Subject: AG Port issues (was Re: [AG-TECH] Access Grid 3.0 beta1 available
> All of these points are well made. I certainly subscribe to the "one
> port, one
> service" line of thought, but the underlying problem remains, that to
> actually
> deploy AG in most locations today, one has to deal with network
> administrators
> and the policies they are required to implement (and it's pointless to
> villify either), and we can not even hand these administrators a simple
> printed
> list of ports to open.
> I made a stab at this some weeks back, starting with the document created
> by Javier Gomez Alonso of Manchester (see
> http://www.accessgrid.org/agdp/guide/ports.html).
> David E. Bernholdt of Oak Ridge National Laboratory then recast my ASCII
> table
> in the form of a Excel spreadsheet, which I attach, as I can not find my
> ASCII original now. There are glaring holes for rat anc vic, among
> others.
> We really, really, *really* need to create such a list, minimizing the
> number
> of ports as far as is possible, consistent with clean engineering and
> adequate
> functionality. Or, better yet, have three such lists with varying numbers
> of ports that are required to be opened, based on the level of
> functionality
> required. In any event, the list would have to be kept in synchrony with
> the
> development of AG. Having such a list is going to be an important as
> having
> AG software, if we want the community to grow.
> Best Regards, Rick Rodgers
> > From: Colin Perkins <csp at csperkins.org>
> > Subject: Re: [AG-TECH] Access Grid 3.0 beta1 available !
> > Date: Tue, 31 Jan 2006 16:51:31 +0000
> > To: "Ivan R.Judson" <judson at mcs.anl.gov>
> > On 31 Jan 2006, at 16:28, Ivan R. Judson wrote:
> > > I think the interesting question from a user perspective is:
> > > Would you rather open one port and we tunnel all traffic through it
> > > (and
> > > you'll never know about all the types or kinds of traffic) or make
> > > it easy
> > > to have one tunnel per type of data/connection that's easier to
> > > open/close
> > > and audit based on actual use?
> > > I *think* the future is in the latter, because you can easily see a
> > > manageable system being built that allows programmatic (with
> > > authentication
> > > obviously) access for dynamically opening and closing tunnels based on
> > > specific "contracts" about usage, data, src/destination, duration,
> > > etc.
> > And, if you have well defined (narrow) port ranges for each media,
> > makes it easy to firewall off specific media, or to assign varying
> > QoS for each media.
> > > I can't see any good way to justify "opaque aggregate tunnels" that
> > > hide the
> > > fact a break-in occurred in a mess of other data.
> > Indeed.
> > Colin
> R. P. C. Rodgers, M.D. * rodgers at nlm.nih.gov * (301)435-3267 (voice, fax)
> OHPCC, LHNCBC, U.S. National Library of Medicine, NIH
> Bldg 38, Rm. B1N-30F2, 8600 Rockville Pike, Bethesda MD 20894 USA
> http://lhc.nlm.nih.gov/staff/rodgers/rodgers.html
