{Disarmed} [AG-TECH] connecting venues
Michael Miller
mimiller at ncsa.uiuc.edu
Thu Jan 5 12:09:06 CST 2006
Rosario,
You and anyone else who would like to link to the NCSA Venue Server are
welcome to send me the subject from your cert i.e.:
/O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=ncsa.uiuc.edu/CN=Michael Miller
and I'll add you to the RemoteSites list for our server. Be sure you
send the subject from the cert your server is using.
thanks
Michael Miller
NCSA
Rosario Lombardo wrote:
> Hi all,
> I'm trying to connect our Venue Server to other rooms out there.
> Unfortunately it seems to me that most (each one I tried) servers deny
> accessing the GetVenues() method.
> Is it possible?
> I tried several addresses roughly described by the re:
> https://vv2.mcs.anl.gov(:(8|9)000)?/?(VenueServer)?
> Which is the right one?
> Thanks,
> \\Rosario
> 01/05/06 16:22:43 3320 VenueManagement venuemanagement.py:1611
> ERROR VenueParamFrame.__LoadVenues: Could not load exits from server
> at https://vv2.mcs.anl.gov:9000/VenueServer
> Traceback (most recent call last):
> File "C:\Program Files\AGTk-2.4\bin\VenueManagement.py", line 1590,
> in __loadVenues
> vl = server.GetVenues()
> File "C:\Python23\Lib\site-packages\AccessGrid\VenueServer.py", line
> 1683, in GetVenues
> vl = self.proxy.GetVenues()
> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453, in
> __call__
> return self.__r_call(*args, **kw)
> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475, in
> __r_call
> self.__hd, self.__ma)
> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 347, in
> __call
> config = self.config)
> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 187, in call
> r.endheaders()
> File "C:\Python23\lib\httplib.py", line 712, in endheaders
> self._send_output()
> File "C:\Python23\lib\httplib.py", line 597, in _send_output
> self.send(msg)
> File "C:\Python23\lib\httplib.py", line 564, in send
> self.connect()
> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1093, in
> connect
> self.sock.connect(self.host, self.port, self.io_attr)
> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 671, in
> connect
> raise ex
> GSITCPSocketException: an authentication operation failed
> 01/05/06 16:22:45 3320 VenueManagement venuemanagement.py:1577
> DEBUG VenueParamFrame.LoadRemoteVenues: Append address to combobox:
> Rosario Lombardo
> Information Science and Technology Institute (ISTI) - Cnr, Italy
> rosario.lombardo at isti.cnr.it
> <mailto:rosario.lombardo at isti.cnr.it> *-* http://hpc.isti.cnr.it/~lombardo
> <http://hpc.isti.cnr.it/%7Elombardo>
> phone: +39 050-315-3076
Thanx,
Michael Miller
System Engineer
Video Technology Services
Persistent Infrastructure Directorate
National Center for Supercomputing Applications
University of Illinois - UC
217-649-0747
"If you're clear in your vision and trust the people in your team with clear objectives, they will invariably do their best to achieve everything desired, and usually deliver everything you could have hoped for and even more." -Paul Debevec
