[AG-TECH] AGtk 3 beta1: venue server troubleshooting under Windows XP
Thomas D. Uram
turam at mcs.anl.gov
Wed Feb 22 01:11:37 CST 2006
Fabrizio:
This issue was addressed in other mail on the list. Have you resolved it?
AG3 will use the VenueServer.cfg and VenueServer.dat files in the current
directory;
if those files are from AG2, they will still be used. You can avoid this by
starting
from a different directory, or by moving these files to another directory.
If you have any more trouble, please do let me know.
Grazie,
Tom
On 2/16/06 10:42 AM, Fabrizio.Berdondini at prototipo.it wrote:
> I completely removed a previuous installation of AGtk-2.4 from the
> machine (win2k) that hosted the venueserver, then installed AGtk 3
> beta1. When I launched the Venue Server and the Venue Management Tool it
> showed the same venues configuration I had under AG 2.4... Where is this
> information stored? How can I remove it?
> owner-ag-tech at mcs.anl.gov scritti il 16/02/2006 15.45.18
> > By the way, it seems that something's started "moving" on my AGtk 3
> > server: I removed my certificated user (globus Identity Certificate)
> > and installed a "service" certificate. Now I can finally reach my
> > VenueServer via the VenueManagementTool. However there's still
> > something strange: I went to the "manage security" tag of my default
> > lobby venue in order to check the status of allowed and disallowed
> > people/actions: in fact the section is empty, there's only a
> > "Registered people" entry which contains nothing (no ppl, no
> > actions). I tried to add some persons but no luck: I can only add
> > roles but cannot fill them and so I cannot configure any
> > people/action... maybe this is the reason why I cannot enter the
> > venue with my client...
> > I'll try to "reset" the server configuration and restart the
> > service... stay tuned ;-)
> > Thanx again for your attention and support,
> > Faber B.
> > "Thomas D. Uram" <turam at mcs.anl.gov> scritti il 16/02/2006 15.10.45
> > > I'm not sure why it didn't get forwarded, but will check. Meanwhile,
> > > you can put them in web space and point at them with a url.
> > > Tom
> > > On 2/16/06 7:57 AM, Fabrizio.Berdondini at prototipo.it wrote:
> > > > It seems I'm no more able to send messages to the mailing list... or
> > > > maybe I cannot send it with an attachment. How can I post my
> server logs
> > > > with a message on the ml? Is there some restriction?
> > > > Thanx for suggestions
> > > > Faber B.
> > > > owner-ag-tech at mcs.anl.gov scritti il 15/02/2006 16.29.18
> > > > > Helllo Fabrizio:
> > > > > Can you send more of your logfile? (Send to me personally if
> it's
> > > > very big.)
> > > > > This error should not be happening, and I suspect it is somehow
> > > > related to
> > > > > server initialization that would be reflected earlier in the
> logfile.
> > > > > Since you also had trouble with VenueManagement, you could
> also include
> > > > > that logfile.
> > > > > Grazie,
> > > > > Tom
> > > > > On 2/15/06 9:15 AM, Fabrizio.Berdondini at prototipo.it wrote:
> > > > > > Hello all,
> > > > > > I'm trying to configure venueserver and client on a WinXP
> machine in
> > > > > > order to have a look to the new release of AGtk (for future
> > > > migration of
> > > > > > our current server/clients). I installed all the packages
> > indicated on
> > > > > > the download link but I'm not able to connect my client to
> the local
> > > > > > venueserver: the server rejects the connection with the
> following
> > > > message:
> > > > > > 02/15/06 16:11:51 3576 Security
> authorizationmanager.py:216 DEBUG
> > > > > > Rejecting access from unidentified user as part of Everybody
> role
> > > > > > 02/15/06 16:11:51 3576 Hosting servicecontainer.py:16
> ERROR Not
> > > > > > authorized None
> > > > > > 02/15/06 16:12:01 3572 VenueServer venue.py:235 DEBUG
> Client
> > > > Timeout
> > > > > > Check: 1140016326 vs 1140016321
> > > > > > I tried to modify the default venue settings/permissions,
> > but I wasn't
> > > > > > able to connect to the venueserver via the
> VenueManagementTool: it
> > > > > > simply tells me that it cannot connect to the venueserver
> located at
> > > > > > https://localhost:8000/VenueServer (the address is correct
> and if I
> > > > try
> > > > > > to reference the venueserver with its IP or its full network
> name the
> > > > > > VenueManagementTools hangs).
> > > > > > Any suggestion?
> > > > > > Thanx,
> > > > > > Faber B.
