[AG-TECH] Bridge Server v2.4 does nothing
Michael Groufsky
michael.groufsky at canterbury.ac.nz
Thu Dec 21 18:45:26 CST 2006
So I have tried the compat package and yes, it is the same problem. Has
anyone else seen this?
Michael Groufsky
Michael Groufsky wrote:
> Ah, no. I pulled the archived RPMs from
> http://www.vislab.uq.edu.au/research/accessgrid/software/fedora/ag2/,
> since I had previously had similar troubles with the compat package.
> Not sure if it was the same problem, though, so I will try it again.
> Thanks,
> Michael Groufsky
> Douglas Kosovic wrote:
>> Hi Michael,
>>> I am trying to set up an AG2.4 bridge server, to bridge a single
>>> venue. I am running Fedora core 6, and have created a
>>> BridgeServer.cfg file based on the one provided at the start of the
>>> BridgeServer.py source file. Haven't done any other configuration,
>>> except launching VenueClient to bring in certificate.
>>> When I launch BridgeServer.py, the process starts, but nothing
>>> happens. No output is produced (from what I understand, should see
>>> some info from QuickBridge startup), and the VenueClient 'Use
>>> unicast' option is still unavailable when someone tries to connect
>>> to the venue.
>> Which AGTk 2.4 are you running? It doesn't appear to be the
>> compat-AccessGrid 2.4 FC6 RPMs from:
>> http://www.vislab.uq.edu.au/research/accessgrid/software/fedora/ag3/
>> which has /usr/bin/BridgeServer24 instead of /usr/bin/BridgeServer.py
>> Doug
