[AG-TECH] osprey 230 suse 10.1
Rene Salmon
rsalmon at tulane.edu
Wed Dec 20 14:04:15 CST 2006
On suse 10.1 I have the same results as you. Can only get cameras 1 and 2
working. Cameras 3 and 4 are just a blue screen. Sometimes I can
physically swap the video cables from camera 1 and 3 and then get 1,2, and 3
working.
Any one have a fix for this?
Thanks
Rene
> I too am having problems with Osprey and Suse10.1, having moved from FC2
> (which worked without a flaw)
> I can get output from 2 of the cards, however the other two cards
> produce the plain blue screen output, this is when using bot AG
> software, xawtv, and gnomemeeting.
> Any advice please ?
> Cheers
> Stuart
> On Thu, 2006-08-24 at 15:20 -0500, Rene Salmon wrote:
>> Hi list,
>> We have some osprey 230 cards on a suse 10.1 box. All the bttv drivers
>> load fine out of the box from suse.
>> The problem is that when I startup the AG toolkit software all I get is
>> a blue screen. I had the same problem in windows and all I did was
>> start up the viewcast sotware and tell it it use the s-video input and
>> everything worked.
>> I tried using the VIC to select s-video but that does not seem to work I
>> still get a blue screen. Is there a way to tell the kernel via a module
>> option to use the s-video input on the cards?
>> thanks.
>> Rene
