[AG-TECH] AG2 and AG3 venue servers on one machine
Thomas D. Uram
turam at mcs.anl.gov
Mon Aug 7 14:24:52 CDT 2006
Using an AG2 VenueServer.dat will work fine, with one revision: You
should remove the 'authorizationPolicy' lines
from VenueServer.dat. AG3 runs into trouble with those existing lines.
This should be filed as a bug.
Tom
On 8/7/06 2:17 PM, Derek Piper wrote:
> Thanks, Tom, for the clarification. I've tried again this time
> running AG2 as 900x and AG3 as 800x. I have both of them running, AG2
> clients can connect (I realized my problem before was that the AG3
> Venue Server just wouldn't die until it was sent a -9). The AG3 venue
> server config has 5223 in its 'textPort' field now.
> AG3 clients however still cannot connect, even with its default
> settings (which seems that my problems are somewhere else). I get a
> 'HTTP Digest Authorization Failed' error from the AG3 venue client
> when trying to connect to it. Both machines are using AG 3.0.1 (the
> Fedora Core 5 venue server machine, and the Windows client machine).
> In starting the AG3 venue server, I copied the previous venue
> server (2.4) data to a new directory and the AG3 venue server is
> started from there. Is that a good idea? Will that work to recreate
> the same setup that I have with the 2.x venue server?
> Derek
> Thomas D. Uram wrote:
>> A little clarification:
>> - the --port argument only specifies the main port, not the related
>> (event,data,text) ports (unfrotunately)
>> - the event,data,text ports are specified only in the cfg file
>> - text does _not_ use 9004 or similar in AG3; instead, textHost and
>> textPort point at a
>> Jabber server (using jabber.mcs.anl.gov:5223 by default)
>> Derek:
>> I'd suggest you modify the AG3 venueserver.cfg to specify:
>> textHost = jabber.mcs.anl.gov
>> textPort = 5223
>> and then try to start it. If you want to use your own jabber server
>> instead,
>> you would modify textHost accordingly.
>> Tom
>> On 8/7/06 12:58 PM, Derek Piper wrote:
>>> Yes, I originally had my 2.x server at port 8000, apparently the
>>> default. So.. now we have two incompatible venue servers that all
>>> want to be the same default? That was a smart idea :>
>>> Since I already have 2.x installations around that use the one
>>> on port 8000 as a default/home venue, I thought I'd just add AG3 on
>>> as port 9000. Now, I guess it's possible to try it the other way and
>>> just run to all my installations and change them. In trying to run
>>> the AG2 venue server on port 900x, it doesn't start its text chat
>>> thing on port 9004 either. Nothing's running on that port. And, just
>>> like it was with AG3, a venue client can't connect to it.
>>> I have the ports specified in VenueServer.cfg. All, but the
>>> 'textPort' one seem to work. The text chat thing isn't even trying
>>> to bind to port 8004 either, so I'm not sure what's up with that. Do
>>> I have to redo my venue server from scratch if I change the port?
>>> I was specifying the text, event and date ports for AG3, yes. I
>>> had them set to the 900x equivalants and a venue client couldn't
>>> connect to it.
>>> Derek
>>> Michael Miller wrote:
>>>> Derek,
>>>> I run AG2 on port 900x and AG3 on 800x. I specify the text, event
>>>> and data ports for AG2 in VenueServer.cfg and everything seems to
>>>> work fine. Are you specifying the text,event and data ports for AG3?
>>>> myk
>>>> Derek Piper wrote:
>>>>> Hi,
>>>>> I've installed AG2 and AG3 venue servers on one machine, with
>>>>> the idea of having them co-exist but running on different ports. I
>>>>> noticed that even if I specify a port of 9000 to the AG3 venue
>>>>> server, it still wants to listen on 8002 etc. That seems a bit
>>>>> unhelpful. I've been able to get both of them running by having a
>>>>> VenueServer.cfg file but, but the AG3 VenueServer isn't listening
>>>>> for its text chat port of 9004. Does the AG3 VenueServer have to
>>>>> listen on port 8000? I don't really want to have yet another box
>>>>> just to run the venue server, but is that the only recommended way
>>>>> of setting them up?
>>>>> Another question related to this is about keeping the two
>>>>> venue servers synchronized. For the time being, it's going to be
>>>>> likely to have to run both side by side. It would be nice if the
>>>>> configuration from one could be mirrored from another and
>>>>> synchronized either by a manual or automatic operation without
>>>>> having to perform the same edits in each.
>>>>> Hints are appreciated. Thanks,
>>>>> Derek
