[AG-TECH] wxPython 2.6 with AG2.4
Fred Dech
fdech at uchicago.edu
Mon Apr 24 09:15:35 CDT 2006
On Mon, Apr 24, 2006 at 09:29PM, Douglas Kosovic said:
> Hi Fred,
> On Fri, 2006-04-21 at 10:08 -0500, Fred Dech wrote:
> > Since yesterday, I've been wondering what the incompatibility is between
> > wxPython 2.5 and AG3.0b2. I've had AG2.4 and AG3.0b2 installed on the same
> > WinXP node for some time with no problems.
> wxPython 2.5 is from the unstable wxPython release series, see:
> http://wiki.wxpython.org/index.cgi/ReleaseSeries
> so effectively the latest wxPython 2.5.x is a pre-release of the stable
> wxPython 2.6.0.
> > As was posted a while back, wxPython 2.6 isn't completely
> > compatible with AG2.4. I'd not run into this first hand until we were
> > doing some shared-app tests yesterday and, as was posted, the Win Shared
> > Web Browser (IE) did not work for AG2.4 with wxPython2.6. The browser works
> > fine with AG3.0b2/wxPython2.6. It also works fine for both AG2.4 and AG3.0b2
> > with wxPython2.5.
> The change happened sometime in the wxPython 2.5.x series, you are most
> likely using a earlier version of wxPython 2.5 which supports both
> wx.iewin and wx.lib.iewin modules.
> See the "SharedBrowser broken with wxPython 2.6" bugzilla report:
> http://bugzilla.mcs.anl.gov/accessgrid/show_bug.cgi?id=1450
Hi Doug.
I'll take a look at that. My previous email may not have been as clear
as I'd intended it to be. wxPython 2.6 (spec'd for AG3.0bx) doesn't work
with the AG2.4 Shared Browser. But wxPython 2.5 works for both AG2.4 and
AG3.0b2 Shared Browser.
So, I'll install the latest version of wxPython 2.5.x. My concern is the
issue of AG3.0 not working correctly in some ways with wxPython 2.5 or 2.5.x.
I'm pretty sure that Tom explained that at some point when discussing the move
from wxPython 2.5 to wxPython 2.6 for AG3.0.
Thanks.
--fred
