[AG-TECH] Firewall and unicast questions
Nagykaldi, Zsolt F. (HSC)
Zsolt-Nagykaldi at ouhsc.edu
Fri Apr 7 11:25:27 CDT 2006
For those of us who are not living in a network dreamland, a feasible solution is to focus on the trusted IPs of the unicast bridges instead of the UDP port range. This is what we did here at OU and it works great for us. While for a small entity it may fly to open UDP ports 30K - 60K (if their ISP does not get a heart attack when you ask), a larger entity (University) may rather want to allow incoming packets through by allowing the distinct IPs of the unicast bridges in the firewall. This is a much better solution. If you use regular PIX firewalls and want to use e.g. the NCSA rooms, the next statement should be added to your firewall protocols:
object-group network video_allowed_inbound
network-object host 141.142.222.31
network-object host 141.142.6.17
These IPs are for venuesbridge and roebridge. For new bridges you will have to ask your IT to add them individually.
I hope this will help.
Zsolt
_ _ _
Zsolt Nagykaldi, PhD
Research Associate, Clinical IT Specialist
University Of Oklahoma Health Sciences Center
Department Of Family And Preventive Medicine
Oklahoma Center For Family Medicine Research
900 NE 10th Street
Oklahoma City, OK 73104
Phone: (405) 271-8000 Ext.:1-32212
Fax: (405) 271-1682
From: owner-ag-tech at mcs.anl.gov on behalf of Andrew A Rowley
Sent: Fri 4/7/2006 3:00 AM
To: Masullo, Chris F; ag-tech at mcs.anl.gov
Subject: RE: [AG-TECH] Firewall and unicast questions
I know of various places that are running AG from behind a firewall using both multicast and unicast.
Using unicast means that you add strain to the bridge for the venue. However, I have not seen any bridges fail under strain so far (others may have seen this). The other problem with unicast and firewalls is the port numbers. The bridges will be assigned random port numbers within a fixed range, so the only way to guarantee that you will be able to use the bridge is to open up the entire range. This range will depend on the venue server. Of course with dynamic multicast venues, you would have the same problem, however, with static venues, you could at least open the fixed port numbers in use. AG Connector can also help with the port number problem, since it only uses a single fixed port.
The only other problem I have seen with firewalls, is when the firewall cannot cope with the amount of traffic passing with large AG meetings. It is worth finding out what bandwidth the firewall can cope with if you regularly join large meetings.
Andrew :)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
> Behalf Of Masullo, Chris F
> Sent: 06 April 2006 17:04
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] Firewall and unicast questions
> Hello All,
> We currently have our AG nodes outside our firewall, however cyber
> security
> has told us that we need to move the systems inside our firewall. The
> last
> time I brought up this issue a number of years ago I was told that
> multicast
> would not get past our firewall. I have some questions regarding this
> issue.
> Has anyone successfully placed an AG VTC system behind a Cisco Firewall?
> Are there any issues using unicast mode for and AG node behind a
> firewall?
> If not then why not run unicast?
> I have looked through the mailer however I do not see any answers to
> these
> Questions.
> Thanks in advance
> Chris Masullo Information Technology Division
> Brookhaven National Laboratory Network Engineering & Operations
> 61 Brookhaven Ave. Phone: (631) 344-2326
> Upton, NY 11973 Fax: (631) 344-7688
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060407/3b322798/attachment.htm>
