[AG-TECH] Windows Bridge Server Question
Thomas D. Uram
turam at mcs.anl.gov
Tue Sep 27 21:27:02 CDT 2005
Hi John:
Such a difference in the behavior of the BridgeServer between 2.3 and 2.4 would
surprise me.
I can't be sure what's going on without more information. Are the logfiles
(VenueServer.log, BridgeServer.log) any help to you? (Logfiles can be found
on Windows in %APPDATA%\AccessGrid\Logs). If you don't see anything
in the logfiles that indicates a problem, you could forward them to ag-info and
I'll take a look.
Tom
On 9/21/05 5:37 PM, Casagrande, John wrote:
> I have used AGTK 2.4 to install a Venue Server on a Windows 2003 Server.
> I have also installed a Bridge Server on the same machine. When I use a
> Venue Client to connect to this server, the Unicast option under the
> Preferences menu seems to "flicker" from an available to an unavailable
> state. Is this a display phenomenon or is the Bridge rely going away and
> coming back?
> I had previously had AGTK 2.3 installed on the same machine and did not
> observe this behavior.
> Any ideas, or suggestions would be appreciated. Thanks.
