[AG-TECH] IVS down?
Thomas D. Uram
turam at mcs.anl.gov
Wed Sep 21 12:39:19 CDT 2005
Hi Steven:
When I saw your mail and tried connecting to the server, it had apparently
already been restarted by my colleague. This is also borne out by the log
messages you sent. Sorry for the confusion.
Tom
On 9/19/05 3:24 PM, Steven Eggerling wrote:
> Well, it was not just me that had the problem connecting. My associate
> in Lincoln, NE also had the same problem.
> Here is my error log from the VenueClient:
> 09/19/05 13:41:37 2256 VenueClient venueclient.py:809 DEBUG
> EnterVenue;
> url=https://ivs.mcs.anl.gov:9000/Venues/000001059d2e6d69008c00dd000a005a0d3
> 09/19/05 13:41:37 2256 CertificateManager certificatemanager.py:1011
> INFO Verifying local proxy cert
> 09/19/05 13:41:37 2256 CertificateManager certificatemanager.py:663
> DEBUG HaveValidProxy: found proxy ident /O=Access
> Grid/OU=agdev-ca.mcs.anl.gov/OU=unomaha.edu/CN=Steven Eggerling/CN=proxy
> <http://agdev-ca.mcs.anl.gov/OU=unomaha.edu/CN=StevenEggerling/CN=proxy>
> 09/19/05 13:41:37 2344 NodeService agnodeservice.py:714 INFO
> NodeService.GetCapabilities
> 09/19/05 13:41:37 2344 NodeService agnodeservice.py:255 INFO
> NodeService.GetServices
> 09/19/05 13:41:40 2760 ServiceManager agservicemanager.py:399 INFO
> AGServiceManager.GetServices
> 09/19/05 13:41:56 2256 VenueClient venueclient.py:705 DEBUG
> EnterVenue: Invoke venue enter
> 09/19/05 13:41:57 2256 VenueClient venueclient.py:670 DEBUG SOAP
> FAULT:
> httpg://ivs.mcs.anl.gov:9000/Venues/000001059d2e6d69008c00dd000a005a0d3
> a system call failed (Invalid argument)
> 09/19/05 13:41:57 2256 VenueClient venueclient.py:672 ERROR SOAP
> fault occurred
> Traceback (most recent call last):
> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 347, in __call
> config = self.config)
> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 187, in call
> r.endheaders()
> File "C:\Python23\lib\httplib.py", line 712, in endheaders
> self._send_output()
> File "C:\Python23\lib\httplib.py", line 597, in _send_output
> self.send(msg)
> File "C:\Python23\lib\httplib.py", line 564, in send
> self.connect()
> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1093, in connect
> self.sock.connect(self.host, self.port, self.io_attr)
> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 671, in connect
> raise ex
> GSITCPSocketException: a system call failed (Invalid argument)
> 09/19/05 13:41:57 2256 VenueClient venueclient.py:857 ERROR
> EnterVenue: globus tcp exception: ('a system call failed (Invalid
> argument)',)
> 09/19/05 13:41:57 2256 VenueClient venueclient.py:864 ERROR
> EnterVenue: failed
> File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line
> 840, in EnterVenue
> self.__EnterVenue(URL)
> 706, in __EnterVenue
> (venueState, self.privateId, self.streamDescList ) =
> self.__venueProxy.Enter( self.profile )
> File "C:\Python23\Lib\site-packages\AccessGrid\Venue.py", line 3492,
> in Enter
> (r1, r2, r3) = self.proxy.Enter(profile)
> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453, in
> __call__
> return self.__r_call(*args, **kw)
> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475, in
> __r_call
> self.__hd, self.__ma)
> r.endheaders()
> self._send_output()
> self.send(msg)
> self.connect()
> raise ex
> On 9/19/05, *Thomas D. Uram* <turam at mcs.anl.gov
> <mailto:turam at mcs.anl.gov>> wrote:
> I've just entered the ivs lobby
> (https://ivs.mcs.anl.gov:9000/Venues/default)
> with no trouble. If you describe the symptoms that you're running
> into, we can
> try to help resolve the problem.
> Tom
> On 9/19/05 1:43 PM, Steven Eggerling wrote:
> > Does it happen to be down again today?
> > On 9/12/05, *Thomas D. Uram* < turam at mcs.anl.gov
> > <mailto:turam at mcs.anl.gov <mailto:turam at mcs.anl.gov>>> wrote:
> > The IVS was down. I have restarted it. I'm looking into the
> cause,
> > which
> > appears to be related to runs of the backup software.
> > Thanks for letting us know.
> > Tom
> > On 9/12/05 12:59 PM, Steven Eggerling wrote:
> > > Hi,
> > > Is IVS down right now or is it just me?
> > > Steven J. Eggerling
> > > Access Grid/IT Administrator
> > > UNL Department of Computer & Electronics Engineering
> > > Web: http://ceen.unomaha.edu/
> > Steven J. Eggerling
> Steven J. Eggerling
