[AG-TECH] Winnov Videum 4400 VO
Thomas D. Uram
turam at mcs.anl.gov
Wed Oct 19 15:42:50 CDT 2005
Doug:
Can you specify which version of the software you're using, which
drivers you have installed (vfw or wdm)? If you're using 2.3 with the
service updates installed, or 2.4, I'd be interested in seeing your
VideoProducerService.log file (by private mail).
Tom
On 10/19/05 2:56 PM, Douglas Baggett wrote:
> I have pretty much the same problem. Starting up the AG causes 3
> identical windows to start up on one input. Changing the input has no
> effect. I'd love to be able to use AG2.x with the Videum card InSors
> installed.
> -Doug B
> CISE/OAD/NSF
> Rosario Lombardo wrote:
>> Just reporting my experience:
>> I had the problems described by Andy which were solved after
>> installing the driver reported below:
>> - VFW drivers
>> ftp://64.62.227.4/drivers/Videum_3_1_Release_NT_W2K_XP.exe found on
>> winnov.com
>> - AGtk2.4
>> - IG2
>> Whichever client is started first, takes over the *two* cameras
>> connected.
>> \\Rosario
>> Thomas D. Uram wrote:
>>> Yes you do; the AG vic does not support the use of WDM drivers,
>>> unfortunately. If anyone has cycles to spend on this, it'd be a big
>>> help to the AG community.
>>> Tom
>>> On 10/19/05 10:02 AM, A Quay wrote:
>>>> Do I have to use the VFW drivers with the Videum 4400 to transmit four
>>>> cameras in AG 2.4?
>>>> Using VFW drivers instead of WDM is a problem since the same
>>>> computer is
>>>> used with our inSORS grid software.
>>>> Andy Quay
>>>> University of Florida
