[AG-TECH] rat+unicast problem
Michael Miller
mimiller at ncsa.uiuc.edu
Tue Nov 29 16:36:23 CST 2005
Natalia,
If the problem occurs when using unicast, check the bridgeserver.cfg
file here's mine:
[BridgeServer]
name=venuesbridge
location=NCSA
qbexec=/usr/bin/QuickBridge
#port range
portMin = 30000
portMax = 40000
#Bridge local venue server
[https://localhost:9000/VenueServer]
type=VenueServer
The port Min and Max control which ports are used. There was a problem
in 2.3 and earlier where the min/max for an individual venue didn't work
right, but I think that's fixed in 2.4...
hope this helps
MYK
Natalia Costas Lago wrote:
> Multicast addresses are fixed, but unicast ones arent ...
> ----- Original Message ----- From: "Michael Miller"
> <mimiller at ncsa.uiuc.edu>
> To: "Natalia Costas Lago" <natalia at cesga.es>
> Sent: Tuesday, November 29, 2005 8:29 PM
> Subject: Re: [AG-TECH] rat+unicast problem
>> Natalia,
>> Do you know if the venue is using dynamically allocated addresses or
>> statically assigned addresses? If the later, perhaps it's just a
>> typo. Check the settings for the venue and try again.
>> hope this helps
>> MYK
>>> Hi everybody,
>>> Sometimes we have RAT error port must be between 1023 and 65535
>>> when using unicast. Taking a look to the AudioService.Log I saw:
>>> 11/23/05 16:56:47 2660 ProcessManager processmanager.py:59
>>> DEBUG Creating process: C:\Documents and
>>> Settings\Natalia.TORGA1\Datos de
>>> programa\AccessGrid\local_services\AudioService\rat.exe -C "Regional
>>> 2" -f L16-16K-Mono agserver.cesga.es/68498
>>> That means: port 68498!!!!!
>>> can someone tell me how to fix this?
>>> Thanx in advance
>>> Kind regards,
>>> Natalia Costas Lago
>>> email: natalia at cesga.es <mailto:natalia at cesga.es>
>>> Centro de Supercomputacion de Galicia (CESGA)
>>> Avenida de Vigo, s/n Campus Sur
>>> 15706 Santiago de Compostela - SPAIN
>>> Tel: +34 981 56 98 10
>>> Fax: +34 981 59 46 16
>>> http://www.cesga.es/
>> Thanx,
>> Michael Miller
>> System Engineer
>> Video Technology Services
>> Persistent Infrastructure Directorate
>> National Center for Supercomputing Applications
>> University of Illinois - UC
>> 217-649-0747
>> "If you're clear in your vision and trust the people in your team
>> with clear objectives, they will invariably do their best to achieve
>> everything desired, and usually deliver everything you could have
>> hoped for and even more." -Paul Debevec
Thanx,
Michael Miller
System Engineer
217-649-0747
"If you're clear in your vision and trust the people in your team with clear objectives, they will invariably do their best to achieve everything desired, and usually deliver everything you could have hoped for and even more." -Paul Debevec
