[AG-TECH] AG (PIG) setup using DSL Modem and vendor router
Alson Been
beena at cookman.edu
Thu Nov 3 10:46:37 CST 2005
Thank you Adam!
-Alson
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
Behalf Of Adam Taylor
Sent: Thursday, November 03, 2005 11:02 AM
To: 'ag-tech'
Subject: RE: [AG-TECH] AG (PIG) setup using DSL Modem and vendor router
I have used it with my cable modem without much fuss (unicast only
though).
I have a 6Mb(down)/512Kb(up). As long as I am sending only 1 video and
1
audio everything seems to be happy both ways. More then 1 of each
however
and I get the same problem as Kevin.
Just my 2 cents...
Adam Taylor
Computing Center
University of Louisiana at Monroe
Behalf
Of Kevin Tan
Sent: Thursday, November 03, 2005 9:21 AM
To: Alson Been
Cc: ag-tech
Subject: Re: [AG-TECH] AG (PIG) setup using DSL Modem and vendor router
As what Mike's experience, video stream has no problem for home
broadband, audio stream is a different story...
You might want to know that my experience as following home broadband
specifications, which is quite common these days...
2Mb download speed; 128Kb upload speed
Video stream:
Working perfectly BOTH way, not a problem...
Audio stream:
Works perfect in ONE way only (download)...
You (at home) have no problem hearing the audio from your colleague
(at university), but your colleague on the other side only can hear
you with missing words...
For example, you are saying 1.2.3.4.5.6; your colleague will only hear
you saying as 1...4...6 missed out all others ... where's the rest
gone... I don't know... :)
I have tried with different way include AGConnector, all given me the
same problem... Unless there is problem with my broadband provider,
NTL
Until I can find out why, my current solution:
Video stream: VIC
Audio stream: Skype
I would appreciate if anyone can let me know any solution or why the
audio acting these way ?
On 03/11/05, Mike Daley <Mike.W.Daley at cs.cardiff.ac.uk> wrote:
> Hi Alison
> Yes I have successfully used AG Pig from home via DSL modem.
> I did get it working once with multicast but in general you have to
use
> unicast bridges. If your link is less than 1 meg then I found that
the
> video streams get dropped. My line currently only runs at 512.
> The best solution I've found is to use AGConnector (The multicast
tunnel
> software).
> This for some reason handles the data really well and I have had 10 -
12
> video streams coming in with no problems)
> Hope this is helpful
> Mike
> Alson Been wrote:
> >Hello,
> >This may have been asked before but has anyone here setup a PIG using
> >the AG toolkit software at their home or other location using a DSL
> >Modem with a T1 connection and a vendor router?
> >If you have were you able to receive audio and video and transmit the
> >same?
> >Did you have to use Multicast or Unicast?
> >How was the response time?
> >Thanks,
> >-Alson
Thanks
Kevin Tan
Manchester Materials Science Centre
University of Manchester
