[AG-TECH] AG (PIG) setup using DSL Modem and vendor router
Mike Daley
Mike.W.Daley at cs.cardiff.ac.uk
Thu Nov 3 06:05:04 CST 2005
Hi Alison
Yes I have successfully used AG Pig from home via DSL modem.
I did get it working once with multicast but in general you have to use
unicast bridges. If your link is less than 1 meg then I found that the
video streams get dropped. My line currently only runs at 512.
The best solution I've found is to use AGConnector (The multicast tunnel
software).
This for some reason handles the data really well and I have had 10 - 12
video streams coming in with no problems)
Hope this is helpful
Mike
Alson Been wrote:
>Hello,
>This may have been asked before but has anyone here setup a PIG using
>the AG toolkit software at their home or other location using a DSL
>Modem with a T1 connection and a vendor router?
>If you have were you able to receive audio and video and transmit the
>same?
>Did you have to use Multicast or Unicast?
>How was the response time?
>Thanks,
>-Alson
