[AG-TECH] notes and thoughts on AG2.1.2b on win32
Thomas D. Uram
turam at mcs.anl.gov
Sun Nov 13 14:25:05 CST 2005
Hi Lewis:
Have you been listening in on the node-related conversations we've been
having here? ;-)
You have successfully identified the bugs and enhancements we've been
talking about lately to make shared nodes more "infrastructurable". We
really want nodes to be always available and require a minimum of user
interaction to function.
Let me pull your points out and discuss them individually:
- Node service does not load the default config on startup
This is a bug that showed up in the 2.1 timeframe. It's very simple
to fix, and will be handled in the next release.
- All users must configure services themselves
In 2.1.2, when a user runs a node service for the first time, the
system node configs are copied to the user space, and the system default
node configuration will be loaded. This allows an admin to build a
default configuration and a set of additional configurations, and have
new users automatically inherit these. (Clearly this is only true when
the node service is run within the venue client, per the point above.)
- Single video producer/consumer service for PIGs
Bug 493 identifies--I think--the issue you are pointing out here. A
combined video producer/consumer service would be nearly trivial to put
together (a one or two line change to the code). This should show up
very soon.
- Autorun services at boot
The node service could run at boot right now. The problem lies with
the service managers: since they start the media tools,. and the media
tools require a display, a user must be logged in to the machine to run
them. We are working to solve this problem with versions of the media
tools that can be controlled via RPC instead of a graphical interface.
- Certificate handling for shared nodes; proxy timeouts
When the services can run at boot, they'll need a certificate with
which to start. This will be a "service certificate" instead of the
identity certificates that we are now issuing. Service certificates
have no passphrase, so there is no proxy to timeout.
Additionally, we've talked about node services and service managers
advertising themselves, so a user can select from a list of those
available. Of course, this should be subject to authorization, so users
can't just control them willy nilly.
Let me know if I've missed anything, or if you have questions beyond
these. Also, be sure to request enhancements for us to consider for the
next-release node software.
Thanks for your comments,
Tom Uram
ANL/FL
Lewis Grantham wrote:
>dear AG
>been working through AG2.1.2 again, and have some more notes and comments for
>you:
>(Bugzilla Bug 742 i guess): defaultWindows configurations for AGServiceManager
>only loaded when using VenueClient --personalNode. (and an ANL/AG issued cert..
>others proxy ok, but you cant manage node)
>Starting AGServiceManager and AGNodeService manually wont load any config, or
>add any services at all.
>Yes, the menu shortcut on windows includes the --personalNode argument, and self
>starts AGServiceMAnager and AGNodeservice on a single machine I presume.
>But what of trying (mistakenly it seems) to test rigs for multimachine set ups
>(i.e. the majority of GRID nodes built to recommended AG specs)?
>how do we fully test a multimachine config and successful (default) service
>loading?
>it is possible to start things manually, add services from the venue client and
>correctly connect to at least the ag2 server it seems, but not something I can
>see catching on for ease of use.
>But a personal node would look wrong too, how to link the producer and consumer
>for example?
>Users will only truly navigate with the one display machine, so am stuck with no
>synchronisation with other servers (our encoder for example).
>and thats my main concern here. how do I establish reliable service placements
>across a multimachine node?
>Seems I cannot autorun services at boot time - they will all eventually fail if
>a short proxy is in use, and with many aspects of node management now in the
>venueclient, these are easily changed by individuals.
>with no grid proxy init, PASSPHRASE and proxy creation is commandline based on a
>variable user ID.. ok - now whos going to bother fixing up the other machines no
>one ever runs the venue client on..
>each facility user must by necessity start and configure all services themselves
>to make sure a valid and consistent proxy is about?
>these points are starting to place VERY high training and staffing requirements
>on any planned (multi machine) node use, and would seem more suited to self
>customisable PIGs and single machine nodes only (say floating, departmental
>laptops or similar).
>I cant visualise this on a multimachine set up at the moment without a lot of
>manual intervention - have I missed a big part or hint here?
>many thanks for your time amnd trouble in this
>lewis
