[AG-TECH] Can't connect to video machine service manager
mimiller at ncsa.uiuc.edu
Wed May 18 10:22:52 CDT 2005
We're having trouble getting both our nodes up today. display node service
won't connect to video servicemanager on another machine.
Here's where we try to load the nodeconfig:
05/18/05 10:03:48 3992 CertificateManager certificatemanager.py:907
DEBUG Looking for identity (unused) None
05/18/05 10:03:48 3992 CertificateManager certificatemanager.py:638
DEBUG HaveValidProxy: found proxy ident /O=Access
Grid/OU=agdev-ca.mcs.anl.gov/OU=ncsa.uiuc.edu/CN=Michael Miller/CN=proxy
05/18/05 10:03:48 4092 NodeService agnodeservice.py:175
INFO NodeService.GetServiceManagers
05/18/05 10:03:49 3984 ServiceManager agservicemanager.py:389
INFO AGServiceManager.GetServices
05/18/05 10:04:15 320 ServiceManager agservicemanager.py:389
05/18/05 10:04:40 1496 NodeService agnodeservice.py:123
INFO NodeService.AddServiceManager
05/18/05 10:04:40 1496 NodeService agnodeservice.py:132 INFO service
manager uri = https://rel-ag-video.ncsa.uiuc.edu:12000/ServiceManager
05/18/05 10:04:40 1496 NodeService agnodeservice.py:146 ERROR Failed to
add service manager https://rel-ag-video.ncsa.uiuc.edu:12000/ServiceManager
Traceback (most recent call last):
File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line
133, in AddServiceManager
AGServiceManagerIW( serviceManager.uri ).IsValid()
File "C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPInterface.py",
line 214, in IsValid
return self.proxy.IsValid()
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453, in __call__
return self.__r_call(*args, **kw)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475, in __r_call
self.__hd, self.__ma)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 347, in __call
config = self.config)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 187, in call
r.endheaders()
File "C:\Python23\lib\httplib.py", line 712, in endheaders
self._send_output()
File "C:\Python23\lib\httplib.py", line 597, in _send_output
self.send(msg)
File "C:\Python23\lib\httplib.py", line 564, in send
self.connect()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1093, in connect
self.sock.connect(self.host, self.port, self.io_attr)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 671, in connect
raise ex
GSITCPSocketException: an end-of-file was reached
05/18/05 10:04:40 3992
NodeManagementUIClasses nodemanagementuiclasses.py:758 ERROR Exception
in AddHost
File
"C:\Python23\Lib\site-packages\AccessGrid\NodeManagementUIClasses.py", line
756, in AddHost
self.nodeServiceHandle.AddServiceManager( serviceManagerDesc )
1107, in AddServiceManager
self.proxy.AddServiceManager(serviceManager)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 203, in call
content_type = headers.get("content-type","text/xml")
AttributeError: 'NoneType' object has no attribute 'get'
05/18/05 10:04:43 1512 NodeService agnodeservice.py:175
05/18/05 10:04:44 1176 ServiceManager agservicemanager.py:389
and here's where we try to connect to the video machine's service manager:
<Fault SOAP-ENV:Server: Method Failed: NodeService:AddServiceManager>
*** Method NodeService:AddServiceManager exception *********************
File "C:\Python23\Lib\site-packages\SOAPpy\Server.py", line 407, in do_POST
fr = apply(f, ordered_args, named_args)
832, in
AddServiceManager
self.impl.AddServiceManager(serviceManagerDesc)
133, in
AddServiceManager
line
214, in IsValid
r.endheaders()
self._send_output()
self.send(msg)
self.connect()
raise ex
any ideas?
Obviously something has changed here, but I'm not sure where to
look. Could this be a firewall thing?
Thanx,
Michael Miller
System Engineer
Video Technology Services
Persistent Infrastructure Directorate
National Center for Supercomputing Applications
University of Illinois - UC
217-649-0747
"If you're clear in your vision and trust the people in your team with
clear objectives, they will invariably do their best to achieve everything
desired, and usually deliver everything you could have hoped for and even
more." -Paul Debevec
