[AG-TECH] vic works on command line but fails to be started via AG
west suhanic
west.suhanic at gmail.com
Tue Jun 21 22:17:05 CDT 2005
Hi All:
vic fails to come up on a Windows XP laptop. However when I
start vic on the command line it shows the video streams. Other
than a re-install, any suggestions?
regards,
west
On 6/21/05, west suhanic <west.suhanic at gmail.com> wrote:
> Hi Thomas:
> I checked the emerge log. I did not see any complaint about or even
> mention of /etc/AccessGrid. I did not see mention of /etc . Also there
> was no
> ~/.AccessGrid created. I am open to any and all suggestions.
> regards,
> west
> On 6/21/05, Thomas D. Uram <turam at mcs.anl.gov> wrote:
> > The complaint is about /etc/AccessGrid/SharedApplications .
> > I expect to see some failure in the emerge output regarding this and other directories.
> > West: Do you see any failures regarding directories in /etc/AccessGrid? Do you see a
> > complaint about configuration files (which reside in /etc)?
> > Tom
> > On 06/20/05 17:22, Douglas Kosovic wrote:
> > > Hi West,
> > >> File
> > >> "/usr/lib/python2.3/site-packages/AccessGrid/Platform/unix/Config.py",
> > >> line 100, in _Initialize
> > >> self.GetSharedAppDir()
> > >> File
> > >> line 208, in GetSharedAppDir
> > >> raise Exception, "AGTkConfig: app dir does not exist."
> > >> Exception: AGTkConfig: app dir does not exist.
> > >> Any suggestions?
> > > I think it's complaining about either one of the following dirs:
> > > ~/.AccessGrid/SharedApplications/
> > > $AGTK_USER/SharedApplications/
> > > The latter only if the AGTK_USER env variable is set.
> > > Check the ownership and permissions of ~/.AccessGrid/ or just issue
> > > something like:
> > > mv ~/.AccessGrid ~/AccessGrid.bak
> > > Cheers,
> > > Doug
