[AG-TECH] Venue and Bridge Server specs
Todd Zimmerman
toddz at sfu.ca
Thu Jun 9 11:38:38 CDT 2005
Agreed on the crashing. Our venueserver hasn't had any problems and it
runs 24/7. It usually only needs to be restarted about once ever month or
so...
Concerning configuration and setup, our main venueserver runs on the same
machine as one of our bridges, while a second machine serves mostly as a
second bridge (geographically separated) but can serve as a backup
venueserver in times of crisis.
One machine is a P3 1Ghz, the other a P4 2.8Ghz, both with 2 GB of mem.
Neither has had an issue with performance and we host some fairly large
meetings occassionally...
Todd
Collaboration & Visualization Technician
WestGrid - www.westgrid.ca
IRMACS - www.irmacs.com
Ph. 604.268.6979
Todd Zimmerman - toddz at sfu.ca
Derek Piper wrote:
> Your VenueServer crashes a lot? hmm. I actually run ours on the same
> machine that does our Audio and Video for the node we have here. This
> was simple because when I was installing it last year, it was deemed
> that that was 'the AccessGrid Linux machine'. Whether that's smart or
> not, I don't know, but I've found it to be very stable. It's a single
> P4/3Ghz with 1GB RAM. The machine was recently reformatted and
> reinstalled (now Debian Sarge instead of RedHat 9) because of a failing
> harddrive (Dell and their Maxtors ... sheesh). The VenueServer had to be
> restarted occaisionally, but I'm thinking it was a few months between
> intervals. We have a bridge server on a different machine (another 3Ghz
> P4 that does web stuff), since because of the audio and video VICs on
> the AV machine, they cannot occupy the same machine.
> Derek
> Andrew Rowley wrote:
>> Relating to this, I also wondered if people generally run their bridge
>> server and venue server on the same of separate machines?
>> We currently run ours on the same machine (a P4 1.7Ghz with 512MB
>> RAM). The
>> venueserver crashes fairly often, and I sometimes find that restarting
>> the
>> bridge server helps, so I assume the bridge server sometimes puts a
>> lot of
>> load on the server.
>> Andrew :)
>> Access Grid Support Centre,
>> RSS Group,
>> Manchester Computing,
>> Kilburn Building,
>> University of Manchester,
>> Oxford Road,
>> Manchester,
>> M13 9PL,
>> UK
>> Tel: +44(0)161-275 0685
>> Email: Andrew.Rowley at manchester.ac.uk
>> ________________________________________
>> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
>> Behalf
>> Of Natalia Costas Lago
>> Sent: 09 June 2005 08:39
>> To: ag-tech
>> Subject: [AG-TECH] Venue and Bridge Server specs
>> Dear all,
>> Seeking for some information related to the hardware I need for our own
>> venue/bridge server I found two threads with no answer to this
>> question.
>> It seems to me that the venue server doesnt need heavy resources, but I'm
>> not so sure about the bridge server.
>> I would really appreciate the sites that hold/organise very big
>> meetings (as
>> Argonne with SCGlobal for instance), and have much experience in these
>> matters, give us some guidelines about the specs recommended (or the
>> place/website where I could gather some information).
>> Kind regards,
>> Natalia.
>> Natalia Costas Lago
>> email: natalia at cesga.es
>> Centro de Supercomputacion de Galicia (CESGA)
>> Avenida de Vigo, s/n Campus Sur 15706 Santiago de Compostela - SPAIN
>> Tel: +34 981 56 98 10 Fax: +34 981 59 46 16
>> http://www.cesga.es/
