[AG-TECH] VRVS via AG
Kun Wei
weikun at caltech.edu
Thu Jan 6 10:49:11 CST 2005
You are correct.
Access Grid room is based on a pair of multicast IP address/ports. VRVS
room is based on virtual room number, not related to any IP address or port.
You can either create a AG venue, and ask VRVS to add it VRVS AG
gateway. Or simple ask AG user to join Fog room, the steps are simple.
Thanks
Kun
Andrew Rowley wrote:
> Hi,
> I would imagine that the H.323 VRVS users would be able to connect to the
> Access Grid in one of these bridged rooms. The page
> http://www.vrvs.org/Documentation/VAG/#chap3 describes how to set up an
> H.323 client to connect to an Access Grid room using VRVS.
> I would not think that is was possible to connect Access Grid users to a
> VRVS only room. In this case, I would advise choosing one of the Access
> Grid - VRVS rooms instead.
> Andrew :)
> Access Grid Support Centre,
> RSS Group,
> Manchester Computing,
> Kilburn Building,
> University of Manchester,
> Oxford Road,
> Manchester,
> M13 9PL,
> UK
> Tel: +44(0)161-275 0685
> Email: Andrew.Rowley at manchester.ac.uk
> -----Original Message-----
> From: Jeffrey Bary [mailto:Jeffrey.Bary at nyu.edu]
> Sent: 06 January 2005 13:23
> To: Bob Riddle; Andrew Rowley
> Cc: ag-tech at mcs.anl.gov; Jeffrey.Bary at nyu.edu
> Subject: Re: [AG-TECH] VRVS via AG
> I'm interested in bridging a VRVS room into the AG rather than an AG
> room into VRVS. I believe that (e.g.) the Fog Room in VRVS is not
> available to AG only attendees.
> Also, any thoughts on H.323 VRVS users using one of these bridged
> rooms. I'm going to give it a try later today time permitting.
> We've been asked to support a physics event in one of our buildings
> that is not multicast ready and the group appears to be VRVS users.
> -Jeff
>>all you need to do is tell support at vrvs.org which room(s) you would
>>like to be bridged. For example, all of the "rooms" in the
>>Internet2 "Community" are bridged and you are welcome to make use of
>>these - juts remember to send me a note!
>>>Hi,
>>>I don't think that this is a VRVS-Access Grid room. To see the list of
> VRVS
>>>rooms that can be used with Access Grid, go to http://www.vrvs.org/ and
>>>login, then click on "Enter" on the left menu bar and select the
>>>"VAccessGrid" in the top right hand corner (quite small, above options).
>>>This lists the Virtual Venues that can be used for Access Grid - VRVS
>>>interaction.
>>>I am guessing that there might be a way to add to this list of venues. I
>>>would be interested in knowing how this might be done...
>>>Andrew
>>>RSS Group,
>>>Kilburn Building,
>>>Oxford Road,
>>>Manchester, M13 9PL, UK
>>>From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
> Behalf
>>>Of Jeffrey Bary
>>>Sent: 05 January 2005 22:20
>>>To: ag-tech at mcs.anl.gov
>>>Subject: [AG-TECH] VRVS via AG
>>>Can I get to a VRVS venue via the AG ? In particular the Fog Room.
>>>It has a couple of H.323 sources. Will that work ?
>>>-Jeff
>>Bob Riddle (bdr at internet2.edu) Technologist,Internet2
>>1000 Oakbrook Drive, Suite 300 Ann Arbor, Michigan 48104
>>Business Phone: 734.913.4257 Fax Number: 734.913.4255
>>"Math illiteracy affects 7 out of every 5 people"
