[AG-TECH] Bridge server with 2 interface cards
Andrew Rowley
Andrew.Rowley at manchester.ac.uk
Wed Jan 5 04:15:37 CST 2005
Sorry, I misunderstood what was happening here.
What could be happening is that the bridge server is listening to multicast
on the network that does not have multicast enabled. I am not sure how you
would go about doing this, but you need the unicast part of the bridge
server to listen on one network card and the multicast part to listen on the
other network card. So far as I know, the current bridge server
(Quickbridge) only listens on one network card (which this is I am
uncertain). I expect that if you use the multicast card by default, this
might work. Otherwise, it will probably require a modification of the
source code of quickbridge to allow the choosing of a different network card
for the multicast and unicast sockets.
Andrew :-)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
_____
Sent: 23 December 2004 01:07
To: Andrew Rowley
Cc: ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] Bridge server with 2 interface cards
Andrew,
Thanks very much for your help, but I have another question, a reason that I
set up 2 cards.
We have 2 big networks, one is multicast enabled and the other is not, they
are not interconnected. But some users could access both networks, some
users can only access the network that is not multicast enabled. So these 2
interface cards on Bridge server were designed to help connectting those 2
domain users.
Could you see any resolution ?
Jinshung
----- Original Message -----
From: Andrew Rowley <mailto:Andrew.Rowley at manchester.ac.uk>
To: 'Jinshung <mailto:liu at tcrc.edu.tw> Liu' ; ag-tech at mcs.anl.gov
Sent: Wednesday, December 22, 2004 6:27 PM
Subject: RE: [AG-TECH] Bridge server with 2 interface cards
Often Multicast sockets are set up to "not loopback". This means that any
traffic sent from the local computer is not received at the local computer
again. This is typically true of bridges.
I do not think that you need to set up two separate cards to listen in to
multicast and unicast at the same time. You can only set up one unicast
socket listening on a particular port, but you can usually set up any number
of multicast sockets listening on the same port as the unicast socket.
Hope this helps,
Andrew G D Rowley :-)
RSS Group,
Kilburn Building,
Oxford Road,
Manchester,
M13 9PL,
UK
_____
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
Of Jinshung Liu
Sent: 22 December 2004 03:18
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Bridge server with 2 interface cards
Hi
We were trying to build a better AG connection topology, so we intalled 2
network interface cards, where one sits in multicast network domain and the
other in unicast network domain.
But it didn't seem to work, the AG clients from multicast domain can't join
with the AG clients from unicast domain ( the clients using bridge server).
Could you give any suggestion ?
Jinshung Liu
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20050105/24f4ac73/attachment.htm>
