[AG-TECH] Outside AV not working
Thomas D. Uram
turam at mcs.anl.gov
Mon Feb 21 17:22:32 CST 2005
Hi Don:
I believe (based on other conversations with you) that you're using multicast addresses
similar to 224.0.0.x on your server. This is, apparently, a problem.
From the cisco Guidelines for Enterprise IP Multicast Address Allocation
(http://www.cisco.com/en/US/tech/tk828/technologies_white_paper09186a00802d4643.shtml), it
looks like you should avoid 224.0.0.0-224.0.0.255, which "is used by network protocols on
a local subnet segment".
This same document claims that the 'global' range is 224.1.0.0-238.255.255.255, so
addresses there should work for you. There are more details in RFC3171, if you're interested.
Let us (ag-tech) know if this fixes your problem.
Tom
Donald Roeber wrote:
> We're running the latest AccessGrid Toolkit on MacOS X, as both a
> VenueServer and a UniCast Bridge for that VenueServer. The server is
> multicast enabled, and so are clients on the upenn.edu network. Clients
> on the upenn.edu network can connect to the VenueServer and use RAT and
> VIC just fine. Unfortunately, for people outside of the Penn network,
> audio and video doesn't work, but they can still use the text chat built
> into the VenueClient. We don't have any firewalls or anything like that
> in place. Because of a bug in the MacOS X version of the AGToolKit
> we're using manual multicast addressing for each venue. Each venue is
> assigned a unique IP address for audio and video, and a unique even
> numbered port number for each service as well.
> Any help would be greatly appreciated.
