[AG-TECH] VIC won't start and static multicast addresses
Natalia Costas Lago
natalia at cesga.es
Fri Feb 18 02:06:27 CST 2005
Using the VenueManagement tool, connect to your venue server, select the
room, click Modify, and there is an Addressing section where you can
indicate the static addresses (dynamic by default).
----- Original Message -----
To: "Thomas D. Uram" <turam at mcs.anl.gov>; "West Suhanic"
<wsuhanic at alumni.uwaterloo.ca>
Cc: <ag-tech at mcs.anl.gov>
Sent: Friday, February 18, 2005 4:06 AM
Subject: Re: [AG-TECH] VIC won't start and static multicast addresses
> Hi Thomas:
> Thanks very much for your help. I have another question.
> How do I configure the venue to use static multicast addresses
> for audio and video?
> Again thank you for help.
> west
> From: "Thomas D. Uram" <turam at mcs.anl.gov>
> To: "West Suhanic" <wsuhanic at alumni.uwaterloo.ca>
> Sent: Thursday, February 17, 2005 4:12 PM
>> Hi West:
>> The venueserver allocates multicast addresses dynamically by default.
> When someone enters
>> the venue and will be sending video, a multicast address is allocated and
> used. If no one
>> in the venue is sending video, there will be no mcast address for it, so
> when you enter
>> with a consumer-only setup, vic will not start.
>> If you add a producer to your setup, and enter the venue, things should
> work fine.
>> Alternately, you can configure the venue to use static mcast addresses
>> for
> audio and
>> video, and then your consumer vic will start (showing no video streams,
>> of
> course).
>> Tom
>> West Suhanic wrote:
>> > Hi All:
>> > I am running a venue server on a linux machine. I am using my own
>> > certificates-(my own root CA,
>> > which is used to generate a service certificate for the venue server
>> > and
>> > user certificate for the
>> > venue client).
>> > I can successfully log on to the venue server via a venue client.
> However
>> > only RAT will
>> > start. VIC will not start if I enable VideoConsumerService.
>> > I have gone through the logs extensively there is nothing obvious to my
>> > eyes.
>> > Any suggestions would, as usual, be greatly appreciated.
>> > regards,
>> > west
