[AG-TECH] "waiting for video" with unicast
Osland, CD (Chris)
C.D.Osland at rl.ac.uk
Thu Feb 17 03:51:25 CST 2005
Monika
By 'pick up' I just mean that (as someone else said in reply to
you) the incoming streams are seen as thumbnails in the 'outgoing'
(i.e. producer) vic windows, but not in the 'receiver' vic window.
As he says, you need to unmute things.
Re any corruption of the streams, we're run a twin 248 Opteron
system on two machines and twin 2.8 Xeons on another, which may be
why we don't see it - or haven't seen it so far.
Hope that helps
Chris
____________________________________________________________________
Chris Osland Office tel: +44 (0) 1235 446565
Digital Media and Access Grid Medialab tel: +44 (0) 1235 446459
BIT Department Access Grid room tel: +44 (0) 1235 445666
e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0) 1235 445597
CCLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and are for the use of
the intended recipient only. If you are not the intended recipient
do not take any action on it or show it to anyone else,
but return this email to the sender and delete your copy of it.]
> -----Original Message-----
> From: Monika Rabarison [mailto:monika.k.rabarison at ccaix.jsums.edu]
> Sent: 16 February 2005 17:14
> To: Osland, CD (Chris)
> Cc: ag-tech at mcs.anl.gov; Hill, NM (Nick)
> Subject: RE: [AG-TECH] "waiting for video" with unicast
> On Wed, 16 Feb 2005, Osland, CD (Chris) wrote:
> > We found a similar problem, but then found that the incoming
> > video was attached to a randomly chosen 'outgoing' vic; between
> > all the vic's that were started, we could pick up
> Chris,
> what do you mean by *pick up*?
> thanks,
> Monika
> all incoming
> > and outgoing streams. If I've got this wrong, Nick Hill should
> > be able to correct me.
> > Inelegant, but it works!
> > Cheers
> > Chris
> > > From: owner-ag-tech at mcs.anl.gov
[mailto:owner-ag-tech at mcs.anl.gov]On
> > Behalf Of Monika Rabarison
> > Sent: 16 February 2005 15:22
> > To: ag-tech at mcs.anl.gov
> > Subject: [AG-TECH] "waiting for video" with unicast
> > Hi All,
> > Could someone help with the following issue?
> > Multicast is working fine. The problem is when switching to
> > unicast using
> > any bridge. I have tested with a Room Node and a Personal Node (XP).
> > No problem with rat. On the Room Node, vic is "waiting for
> > video" on the Display machine (XP) and shows only the local video
> > streams on the Video Capture machine(FC2). On the Personal
> > Node, vic shows
> > only the local video stream. No video transmission or
> > reception between
> > the Room Node and the Personal Node.
> > When I run vic manually, I'm having the same problem.
> > A remote site using unicast confirmed receiving audio and video
> > from us though.
> > You may wonder why I need to switch to unicast if multicast
> > is working.
> > We have sessions with a site that has to use unicast due to multicast
> > issues. For some reason, when I use multicast,the audio from
> > that site is
> > breaking out.
> > Any help would be most appreciated.
> > Monika
