[AG-TECH] venue lobby's
Michael Emore
MWElmore at lbl.gov
Thu Feb 10 16:25:31 CST 2005
Tom Coffin wrote:
> I had the same issue - The way I worked around
> it was to create 'bookmaks' via [add current venue]
> for the two lobbies - by the way you will also need to add
> text when the venue is saved as a 'bookmark' because
> they have identical names.
> I used anl lobby and institutional lobby
> At 03:03 PM 2/10/2005, you wrote:
>> Hello,
>> I think I might be just a little bit confused and would like some
>> direction. I am trying to navigate between the lobbys. When I start
>> the venue client I am in the venue server lobby. It shows the
>> community lobby etc. However, when I look for the lobby to go to my
>> venue (LBNL) I don't see any door to go to the correct lobby. I
>> know that it is in ivs.mcs.anl.gov instead of vv2. Is there a door
>> that connects the two servers. Just in case I go to a computer that
>> doesn't have this set up in my venues.
>> Thank you,
>> MIke
> ___________________________________________________________
> Tom Coffin .......................... tcoffin at ncsa.uiuc.edu
> NCSA-ACCESS cel: 703-477-5948
> 901 North Stuart Street, #800 tel: 703-248-0105
> Arlington, Virginia 22203 fax: 703-248-0100
> _________________________ http://www.ncsa.uiuc.edu/~tcoffin
