[AG-TECH] Starting OSX VenueServers or ServiceManagers (typo)
Eric Olson
eolson at mcs.anl.gov
Tue Feb 8 16:54:49 CST 2005
Minor correction:
On Tue, 8 Feb 2005, Eric Olson wrote:
> Just a note to help anybody who is starting a VenueServer or standalone
> ServiceManager on OSX.
> If you're getting an error that says "ImportError: Failure linking new
> module...libglobus_io_gcc32dbgpthr.0.dylib", you can work around it one of
> the following two ways.
> 1. If you want it to work when clicking on the AG application icon:
> Modify the preferences for OSX's "Terminal" application:
> - Run the Terminal application from the Applications/Terminal folder.
> - Select Terminal->Preferences from the menu, and select the first option
This should have said to select the _second_ option, not the first.
> "Execute this command" (the command reads /bin/bash) instead of "Execute
> the default login shell".
> The VenueServer and ServiceManager services should now start correctly
> after clicking the AccessGridToolkit icon and selecting them from the
> menu.
> OR
> 2. If you don't mind starting the VenueServer from a terminal yourself:
> - Run the Terminal application from the Applications/Utilities folder.
> - Source the AGTk environment setup script:
> . /Applications/AccessGridToolkit.app/Contents/Resources/setupenv.sh
> (there is also a csh script if you've modified the default shell to
> use a c-shell)
> - Run the application:
> /Applications/AccessGridToolkit.app/Contents/Resources/bin/VenueServer.py
> Eric
