[AG-TECH] Debugging network problems in new AG setup
R. P. Channing ["Rick"] Rodgers
rodgers at nlm.nih.gov
Mon Dec 19 18:48:59 CST 2005
Dear AG Colleagues,
I am trying to establish a small AG setup at UCSF, on two Dell XPS Gen 4 PCs
running Windows XP. We have installed AGTk 2.4, started the server on one of
the machines, configured nodes on both, and started the AG client on both.
We seem to be able to enter the venues we created, and each machine sees the
other in the list of participants. However, no chat, no video, and no audio
seems to travel between the two machines (although vic and rat do come up on
each machine, and appear to be operating properly). Although both
machines are on the same subnet, this smells like some kind of traffic filtering
problem to me. I append all of the log files (realizing that not all of them
may be useful, and having pared them down a bit to the more recent entries).
Someone versed in interpreting these may find that we have made some error in
setting up the server/node/services though I think not.
We have disabled some Norton software that might have geen
responsible, and ensured that the built-in firewall in XP is inactive,
but that did not solve the problem. Could there be a bridge or other device
between the hosts that is causing the problem? Would a reasonable starting
point in debugging this be to connect the two machines together using a
cross-over cable (eliminating the network as a variable) -- or would that be
an inadequate test for the problem being in the network rather then in our AG
setup on the PCs? Another group on the
campus is in charge of the network, so if we can establish that the problem is
network-related, we can punt the problem to them -- though the better we can
characterize what is wrong, the faster it is likely to get fixed. Any
suggestions about debugging strategies? I'm a UNIX guy and feel completely
out of water working with PCs ;) I suppose we could use netcat and/or etherial
as aids -- is there any kind of troubleshooting guide for this sort of problem?
Sorry to couch this question at a rather high level. Many thanks in advance
for any helpful pointers.
Best Regards, Rick Rodgers
R. P. C. Rodgers, M.D. * rodgers at nlm.nih.gov * (301)435-3267 (voice, fax)
OHPCC, LHNCBC, U.S. National Library of Medicine, NIH
Bldg 38, Rm. B1N-30F2, 8600 Rockville Pike, Bethesda MD 20894 USA
http://lhc.nlm.nih.gov/staff/rodgers/rodgers.html
12/14/05 16:33:28 3904 Toolkit toolkit.py:96 DEBUG Initializing AG Toolkit version 2.4 (build 1)
12/14/05 16:33:28 3904 Toolkit toolkit.py:138 INFO Logfile Name: AudioService.log
12/14/05 16:33:28 3904 Toolkit toolkit.py:205 WARNING Toolkit.__CheckForValidClock: The machine clock is incorrect on
your computer: it is 33 seconds fast with respect
to the time server at ntp-1.accessgrid.org.
12/14/05 16:33:28 3904 Toolkit toolkit.py:709 INFO Service init: have profile None
12/14/05 16:33:28 3904 Toolkit config.py:196 DEBUG Using GLOBUS_HOSTNAME=64.54.29.247 as set in the environment
12/14/05 16:33:28 3904 CertificateManager certificatemanager.py:269 DEBUG Opened repository C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo
12/14/05 16:33:28 3904 Toolkit toolkit.py:738 INFO Initialized cert mgmt.
12/14/05 16:33:28 3904 Toolkit toolkit.py:753 INFO Loaded profile and configured with it.
12/14/05 16:33:28 3904 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
12/14/05 16:33:28 3904 CertificateManager certificatemanager.py:827 DEBUG Using default identity /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:33:28 3904 CertificateManager certificatemanager.py:1083 DEBUG Initializing environment with unencrypted cert /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:33:28 3904 CertificateManager certificatemanager.py:1098 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\191c8500c5d893d758250b70098c95ce\38d6622212820902ad92145aa0bb0932\cert.pem to 644
12/14/05 16:33:28 3904 CertificateManager certificatemanager.py:1109 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\privatekeys\60fef24d87f80145a55c7bb89691fde6.pem to 600
12/14/05 16:33:28 3904 CertificateManager certificatemanager.py:1572 DEBUG done, success=1
12/14/05 16:33:28 3904 Toolkit toolkit.py:764 INFO Initialized Globus.
12/14/05 16:33:28 3904 Toolkit toolkit.py:782 INFO Service Initialization Complete.
12/14/05 16:33:28 3904 Toolkit agservice.py:442 INFO Starting Service URI: https://64.54.29.247:65113/Service
12/14/05 16:34:10 3048 Toolkit audioservice.py:339 INFO SetIdentity: UCSF China Basin Microbilogy terrazas at labmed2.ucsf.edu
12/14/05 16:34:13 3544 Toolkit agservice.py:136 INFO ConfigureStream: audio 224.2.154.2 55730
12/14/05 16:34:13 3544 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat-kill.exe
Traceback (most recent call last):
File "C:\Python23\Lib\site-packages\AccessGrid\Platform\win32\Config.py", line 1087, in __AppFirewallConfig
_winreg.KEY_ALL_ACCESS)
WindowsError: [Errno 5] Access is denied
12/14/05 16:34:13 3544 Toolkit audioservice.py:285 INFO Stop service
12/14/05 16:34:13 3544 Toolkit audioservice.py:296 INFO Executing rat-kill
12/14/05 16:34:13 3544 ProcessManager processmanager.py:59 DEBUG Creating process: .\rat-kill.exe
12/14/05 16:34:13 3544 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x017D2ED4>, <PyHANDLE object at 0x00FA32AC>, 3580, 3492)
12/14/05 16:34:13 3544 ProcessManager processmanager.py:135 ERROR couldn't shutdown process <PyHANDLE:772>: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
File "C:\Python23\Lib\site-packages\AccessGrid\Platform\win32\ProcessManager.py", line 128, in TerminateProcess
win32api.PostThreadMessage(self.threadid[pid], 18, 0, 0)
error: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
12/14/05 16:34:13 3544 ProcessManager processmanager.py:142 ERROR couldn't terminate process <PyHANDLE:772>: (5, 'TerminateProcess', 'Access is denied.')
File "C:\Python23\Lib\site-packages\AccessGrid\Platform\win32\ProcessManager.py", line 139, in TerminateProcess
win32process.TerminateProcess(pid, 0)
error: (5, 'TerminateProcess', 'Access is denied.')
12/14/05 16:34:13 3544 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat.exe
12/14/05 16:34:13 3544 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\ratmedia.exe
12/14/05 16:34:13 3544 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat-ui.exe
12/14/05 16:34:13 3544 Toolkit audioservice.py:270 INFO Starting AudioService
12/14/05 16:34:13 3544 Toolkit audioservice.py:271 INFO executable = C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat.exe
12/14/05 16:34:13 3544 Toolkit audioservice.py:273 INFO options = ['-C', 'UCSF Lab Med Lobby', '-f', 'L16-16K-Mono', '-t', '127', '224.2.154.2/55730']
12/14/05 16:34:13 3544 ProcessManager processmanager.py:59 DEBUG Creating process: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat.exe -C "UCSF Lab Med Lobby" -f L16-16K-Mono -t 127 224.2.154.2/55730
12/14/05 16:34:13 3544 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x017D2ED4>, <PyHANDLE object at 0x00FA32AC>, 3572, 2692)
12/14/05 16:56:41 2796 Toolkit audioservice.py:285 INFO Stop service
12/14/05 16:56:41 2796 Toolkit audioservice.py:296 INFO Executing rat-kill
12/14/05 16:56:41 2796 ProcessManager processmanager.py:59 DEBUG Creating process: .\rat-kill.exe
12/14/05 16:56:41 2796 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x0189E00C>, <PyHANDLE object at 0x0097E46C>, 664, 2732)
12/14/05 16:56:41 2796 ProcessManager processmanager.py:135 ERROR couldn't shutdown process <PyHANDLE:748>: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
12/14/05 16:56:41 2796 ProcessManager processmanager.py:142 ERROR couldn't terminate process <PyHANDLE:748>: (5, 'TerminateProcess', 'Access is denied.')
12/14/05 16:56:41 2796 ProcessManager processmanager.py:135 ERROR couldn't shutdown process <PyHANDLE:784>: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
12/14/05 16:56:41 2796 ProcessManager processmanager.py:142 ERROR couldn't terminate process <PyHANDLE:784>: (5, 'TerminateProcess', 'Access is denied.')
12/14/05 16:56:41 2796 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat.exe
12/14/05 16:56:41 2796 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\ratmedia.exe
12/14/05 16:56:41 2796 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat-ui.exe
12/14/05 16:56:41 2796 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat-kill.exe
12/14/05 16:56:43 1636 Toolkit agservice.py:190 INFO Shut service down
12/14/05 16:56:43 1636 Toolkit audioservice.py:285 INFO Stop service
12/14/05 16:56:43 1636 Toolkit audioservice.py:296 INFO Executing rat-kill
12/14/05 16:56:43 1636 ProcessManager processmanager.py:59 DEBUG Creating process: .\rat-kill.exe
12/14/05 16:56:43 1636 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x008CCB14>, <PyHANDLE object at 0x0182C0FC>, 3040, 2240)
12/14/05 16:56:43 1636 ProcessManager processmanager.py:135 ERROR couldn't shutdown process <PyHANDLE:756>: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
12/14/05 16:56:43 1636 ProcessManager processmanager.py:142 ERROR couldn't terminate process <PyHANDLE:756>: (5, 'TerminateProcess', 'Access is denied.')
12/14/05 16:56:43 1636 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat.exe
12/14/05 16:56:43 1636 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\ratmedia.exe
12/14/05 16:56:43 1636 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat-ui.exe
12/14/05 16:56:43 1636 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat-kill.exe
12/15/05 15:02:04 3288 Toolkit toolkit.py:96 DEBUG Initializing AG Toolkit version 2.4 (build 1)
12/15/05 15:02:04 3288 Toolkit toolkit.py:138 INFO Logfile Name: AudioService.log
12/15/05 15:02:04 3288 Toolkit toolkit.py:205 WARNING Toolkit.__CheckForValidClock: The machine clock is incorrect on
your computer: it is 34 seconds fast with respect
12/15/05 15:02:04 3288 Toolkit toolkit.py:709 INFO Service init: have profile None
12/15/05 15:02:04 3288 Toolkit config.py:196 DEBUG Using GLOBUS_HOSTNAME=64.54.29.247 as set in the environment
12/15/05 15:02:04 3288 CertificateManager certificatemanager.py:269 DEBUG Opened repository C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo
12/15/05 15:02:04 3288 Toolkit toolkit.py:738 INFO Initialized cert mgmt.
12/15/05 15:02:04 3288 Toolkit toolkit.py:753 INFO Loaded profile and configured with it.
12/15/05 15:02:04 3288 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
12/15/05 15:02:04 3288 CertificateManager certificatemanager.py:827 DEBUG Using default identity /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:02:04 3288 CertificateManager certificatemanager.py:1083 DEBUG Initializing environment with unencrypted cert /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:02:04 3288 CertificateManager certificatemanager.py:1098 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\191c8500c5d893d758250b70098c95ce\38d6622212820902ad92145aa0bb0932\cert.pem to 644
12/15/05 15:02:04 3288 CertificateManager certificatemanager.py:1109 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\privatekeys\60fef24d87f80145a55c7bb89691fde6.pem to 600
12/15/05 15:02:04 3288 CertificateManager certificatemanager.py:1572 DEBUG done, success=1
12/15/05 15:02:04 3288 Toolkit toolkit.py:764 INFO Initialized Globus.
12/15/05 15:02:04 3288 Toolkit toolkit.py:782 INFO Service Initialization Complete.
12/15/05 15:02:04 3288 Toolkit agservice.py:442 INFO Starting Service URI: https://64.54.29.247:59454/Service
12/15/05 15:02:25 1784 Toolkit audioservice.py:339 INFO SetIdentity: UCSF China Basin Microbilogy terrazas at labmed2.ucsf.edu
12/15/05 15:02:26 3512 Toolkit agservice.py:136 INFO ConfigureStream: audio 224.2.175.110 54798
12/15/05 15:02:26 3512 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat-kill.exe
12/15/05 15:02:26 3512 Toolkit audioservice.py:285 INFO Stop service
12/15/05 15:02:26 3512 Toolkit audioservice.py:296 INFO Executing rat-kill
12/15/05 15:02:26 3512 ProcessManager processmanager.py:59 DEBUG Creating process: .\rat-kill.exe
12/15/05 15:02:26 3512 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x017D2ED4>, <PyHANDLE object at 0x00FA32DC>, 2908, 2904)
12/15/05 15:02:27 3512 ProcessManager processmanager.py:135 ERROR couldn't shutdown process <PyHANDLE:772>: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
12/15/05 15:02:27 3512 ProcessManager processmanager.py:142 ERROR couldn't terminate process <PyHANDLE:772>: (5, 'TerminateProcess', 'Access is denied.')
12/15/05 15:02:27 3512 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat.exe
12/15/05 15:02:27 3512 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\ratmedia.exe
12/15/05 15:02:27 3512 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat-ui.exe
12/15/05 15:02:27 3512 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat-kill.exe
12/15/05 15:02:27 3512 Toolkit audioservice.py:270 INFO Starting AudioService
12/15/05 15:02:27 3512 Toolkit audioservice.py:271 INFO executable = C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat.exe
12/15/05 15:02:27 3512 Toolkit audioservice.py:273 INFO options = ['-C', 'UCSF Lab Med Lobby', '-f', 'L16-16K-Mono', '-t', '127', '224.2.175.110/54798']
12/15/05 15:02:27 3512 ProcessManager processmanager.py:59 DEBUG Creating process: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat.exe -C "UCSF Lab Med Lobby" -f L16-16K-Mono -t 127 224.2.175.110/54798
12/15/05 15:02:27 3512 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x017D2ED4>, <PyHANDLE object at 0x00FA32DC>, 2004, 2856)
12/15/05 15:10:46 2740 Toolkit audioservice.py:285 INFO Stop service
12/15/05 15:10:46 2740 Toolkit audioservice.py:296 INFO Executing rat-kill
12/15/05 15:10:46 2740 ProcessManager processmanager.py:59 DEBUG Creating process: .\rat-kill.exe
12/15/05 15:10:46 2740 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x01894ECC>, <PyHANDLE object at 0x00F85C24>, 2108, 3584)
12/15/05 15:10:46 2740 ProcessManager processmanager.py:135 ERROR couldn't shutdown process <PyHANDLE:748>: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
12/15/05 15:10:46 2740 ProcessManager processmanager.py:142 ERROR couldn't terminate process <PyHANDLE:748>: (5, 'TerminateProcess', 'Access is denied.')
12/15/05 15:10:46 2740 ProcessManager processmanager.py:135 ERROR couldn't shutdown process <PyHANDLE:784>: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
12/15/05 15:10:46 2740 ProcessManager processmanager.py:142 ERROR couldn't terminate process <PyHANDLE:784>: (5, 'TerminateProcess', 'Access is denied.')
12/15/05 15:10:46 2740 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat.exe
12/15/05 15:10:46 2740 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\ratmedia.exe
12/15/05 15:10:46 2740 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat-ui.exe
12/15/05 15:10:46 2740 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat-kill.exe
12/15/05 15:10:50 3276 Toolkit agservice.py:190 INFO Shut service down
12/15/05 15:10:50 3276 Toolkit audioservice.py:285 INFO Stop service
12/15/05 15:10:50 3276 Toolkit audioservice.py:296 INFO Executing rat-kill
12/15/05 15:10:50 3276 ProcessManager processmanager.py:59 DEBUG Creating process: .\rat-kill.exe
12/15/05 15:10:50 3276 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x018A6E8C>, <PyHANDLE object at 0x018A1E44>, 4020, 988)
12/15/05 15:10:50 3276 ProcessManager processmanager.py:135 ERROR couldn't shutdown process <PyHANDLE:756>: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
12/15/05 15:10:50 3276 ProcessManager processmanager.py:142 ERROR couldn't terminate process <PyHANDLE:756>: (5, 'TerminateProcess', 'Access is denied.')
12/15/05 15:10:50 3276 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat.exe
12/15/05 15:10:50 3276 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\ratmedia.exe
12/15/05 15:10:50 3276 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat-ui.exe
12/15/05 15:10:50 3276 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat-kill.exe
12/15/05 15:10:50 3812 Hosting server.py:65 ERROR Exception in SOAP server main loop
File "C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py", line 63, in Run
self._server.handle_request()
File "C:\Python23\lib\SocketServer.py", line 217, in handle_request
request, client_address = self.get_request()
File "C:\Python23\Lib\site-packages\SOAPpy\GSIServer.py", line 140, in get_request
sock, addr = ThreadingGSITCPSocketServer.get_request(self)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 525, in get_request
self.socket.listen()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 857, in listen
raise ex
GSITCPSocketException: an I/O operation was cancelled
12/15/05 15:11:12 2548 Toolkit toolkit.py:96 DEBUG Initializing AG Toolkit version 2.4 (build 1)
12/15/05 15:11:12 2548 Toolkit toolkit.py:138 INFO Logfile Name: AudioService.log
12/15/05 15:11:12 2548 Toolkit toolkit.py:205 WARNING Toolkit.__CheckForValidClock: The machine clock is incorrect on
12/15/05 15:11:12 2548 Toolkit toolkit.py:709 INFO Service init: have profile None
12/15/05 15:11:12 2548 Toolkit config.py:196 DEBUG Using GLOBUS_HOSTNAME=64.54.29.247 as set in the environment
12/15/05 15:11:12 2548 CertificateManager certificatemanager.py:269 DEBUG Opened repository C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo
12/15/05 15:11:12 2548 Toolkit toolkit.py:738 INFO Initialized cert mgmt.
12/15/05 15:11:12 2548 Toolkit toolkit.py:753 INFO Loaded profile and configured with it.
12/15/05 15:11:12 2548 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
12/15/05 15:11:12 2548 CertificateManager certificatemanager.py:827 DEBUG Using default identity /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:11:12 2548 CertificateManager certificatemanager.py:1083 DEBUG Initializing environment with unencrypted cert /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:11:12 2548 CertificateManager certificatemanager.py:1098 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\191c8500c5d893d758250b70098c95ce\38d6622212820902ad92145aa0bb0932\cert.pem to 644
12/15/05 15:11:12 2548 CertificateManager certificatemanager.py:1109 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\privatekeys\60fef24d87f80145a55c7bb89691fde6.pem to 600
12/15/05 15:11:12 2548 CertificateManager certificatemanager.py:1572 DEBUG done, success=1
12/15/05 15:11:12 2548 Toolkit toolkit.py:764 INFO Initialized Globus.
12/15/05 15:11:12 2548 Toolkit toolkit.py:782 INFO Service Initialization Complete.
12/15/05 15:11:12 2548 Toolkit agservice.py:442 INFO Starting Service URI: https://64.54.29.247:62368/Service
12/15/05 15:11:33 4064 Toolkit audioservice.py:339 INFO SetIdentity: UCSF China Basin Microbilogy terrazas at labmed2.ucsf.edu
12/15/05 15:11:35 1100 Toolkit agservice.py:136 INFO ConfigureStream: audio 224.2.231.110 52066
12/15/05 15:11:35 1100 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat-kill.exe
12/15/05 15:11:35 1100 Toolkit audioservice.py:285 INFO Stop service
12/15/05 15:11:35 1100 Toolkit audioservice.py:296 INFO Executing rat-kill
12/15/05 15:11:35 1100 ProcessManager processmanager.py:59 DEBUG Creating process: .\rat-kill.exe
12/15/05 15:11:35 1100 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x017D2ED4>, <PyHANDLE object at 0x00FA32AC>, 3272, 3844)
12/15/05 15:11:35 1100 ProcessManager processmanager.py:135 ERROR couldn't shutdown process <PyHANDLE:772>: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
12/15/05 15:11:35 1100 ProcessManager processmanager.py:142 ERROR couldn't terminate process <PyHANDLE:772>: (5, 'TerminateProcess', 'Access is denied.')
12/15/05 15:11:35 1100 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat.exe
12/15/05 15:11:35 1100 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\ratmedia.exe
12/15/05 15:11:35 1100 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat-ui.exe
12/15/05 15:11:35 1100 Toolkit audioservice.py:270 INFO Starting AudioService
12/15/05 15:11:35 1100 Toolkit audioservice.py:271 INFO executable = C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat.exe
12/15/05 15:11:35 1100 Toolkit audioservice.py:273 INFO options = ['-C', 'UCSF Lab Med Lobby', '-f', 'L16-16K-Mono', '-t', '127', '224.2.231.110/52066']
12/15/05 15:11:35 1100 ProcessManager processmanager.py:59 DEBUG Creating process: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat.exe -C "UCSF Lab Med Lobby" -f L16-16K-Mono -t 127 224.2.231.110/52066
12/15/05 15:11:35 1100 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x017D2ED4>, <PyHANDLE object at 0x00FA32AC>, 3080, 2632)
12/15/05 15:24:15 3580 Toolkit agservice.py:190 INFO Shut service down
12/15/05 15:24:15 3580 Toolkit audioservice.py:285 INFO Stop service
12/15/05 15:24:15 3580 Toolkit audioservice.py:296 INFO Executing rat-kill
12/15/05 15:24:15 3580 ProcessManager processmanager.py:59 DEBUG Creating process: .\rat-kill.exe
12/15/05 15:24:15 3580 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x0189E00C>, <PyHANDLE object at 0x0097E46C>, 3064, 2984)
12/15/05 15:24:15 3580 ProcessManager processmanager.py:135 ERROR couldn't shutdown process <PyHANDLE:784>: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
12/15/05 15:24:15 3580 ProcessManager processmanager.py:142 ERROR couldn't terminate process <PyHANDLE:784>: (5, 'TerminateProcess', 'Access is denied.')
12/15/05 15:24:15 3580 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat.exe
12/15/05 15:24:15 3580 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\ratmedia.exe
12/15/05 15:24:15 3580 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat-ui.exe
12/15/05 15:24:15 3580 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\rat-kill.exe
09/21/05 15:55:02 3256 Toolkit toolkit.py:96 DEBUG Initializing AG Toolkit version 2.4 (build 1)
09/21/05 15:55:03 3256 Toolkit toolkit.py:138 INFO Logfile Name: NodeManagement.log
09/21/05 15:55:03 3256 Toolkit config.py:219 ERROR Error setting globus hostname.
File "C:\Python23\Lib\site-packages\AccessGrid\Config.py", line 212, in SetHostname
sock.bind((hostname, 0))
File "<string>", line 1, in bind
gaierror: (7, 'getaddrinfo failed')
09/21/05 15:55:03 3256 Toolkit config.py:348 DEBUG retrieved local IP address 64.54.29.247
09/21/05 15:55:03 3256 CertificateManager certificatemanager.py:269 DEBUG Opened repository C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo
09/21/05 15:55:03 3256 Toolkit toolkit.py:404 DEBUG looking in system ca dir: C:\Program Files\AGTk-2.4\Config\CAcertificates
09/21/05 15:55:03 3256 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\1c3f2ca8.0 might be a cert
09/21/05 15:55:03 3256 Toolkit toolkit.py:440 INFO Certificate 1c3f2ca8.0 already in repository
09/21/05 15:55:03 3256 Toolkit toolkit.py:456 INFO Marking cert as CA cert
09/21/05 15:55:03 3256 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\a82c3f1c4b096b896061778ee79efeff\9c8df64aa35ebf832613413527bc073d\user_files\signing_policy
09/21/05 15:55:03 3256 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\45cc9e80.0 might be a cert
09/21/05 15:55:03 3256 Toolkit toolkit.py:440 INFO Certificate 45cc9e80.0 already in repository
09/21/05 15:55:03 3256 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\809ecc45460c1482e61e26bdfbf9e18c\9f380c9a586af2bb913ace809d5badfe\user_files\signing_policy
09/21/05 15:55:03 3256 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\d1b603c3.0 might be a cert
09/21/05 15:55:03 3256 Toolkit toolkit.py:440 INFO Certificate d1b603c3.0 already in repository
09/21/05 15:55:03 3256 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\c303b6d10c962b37482e68ca64d383a0\05a2039fe10ed1b4195d9f9d35b32c68\user_files\signing_policy
09/21/05 15:55:03 3256 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\f18fa857.0 might be a cert
09/21/05 15:55:03 3256 Toolkit toolkit.py:440 INFO Certificate f18fa857.0 already in repository
09/21/05 15:55:03 3256 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\57a88ff1707d87e926f2287c702a8466\eff65f03366cb8e20247f831ccc87fd5\user_files\signing_policy
09/21/05 15:55:03 3256 Toolkit toolkit.py:478 DEBUG Init'ing globus.
09/21/05 15:55:03 3256 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
09/21/05 15:55:03 3256 CertificateManager certificatemanager.py:827 DEBUG Using default identity /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
09/21/05 15:55:03 3256 CertificateManager certificatemanager.py:1083 DEBUG Initializing environment with unencrypted cert /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
09/21/05 15:55:03 3256 CertificateManager certificatemanager.py:1098 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\191c8500c5d893d758250b70098c95ce\38d6622212820902ad92145aa0bb0932\cert.pem to 644
09/21/05 15:55:03 3256 CertificateManager certificatemanager.py:1109 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\privatekeys\60fef24d87f80145a55c7bb89691fde6.pem to 600
09/21/05 15:55:03 3256 CertificateManagerWXGUI certificatemanagerwxgui.py:422 DEBUG done, success=1
09/21/05 15:55:03 3256 Toolkit toolkit.py:482 DEBUG Done with globus.
"1127344130","09/21/05","16:08:50","Enter","/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f","Venue Server Lobby","000001067ae47fbc00400036001d00f70cc"
"1127344802","09/21/05","16:20:01","Enter","/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5e9e362492d49f2bd406c3c980e923f2","Venue Server Lobby","000001067ae47fbc00400036001d00f70cc"
"1127344980","09/21/05","16:22:59","Exit","/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5e9e362492d49f2bd406c3c980e923f2","Venue Server Lobby","000001067ae47fbc00400036001d00f70cc"
"1127344980","09/21/05","16:22:59","RemoveUser","/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5e9e362492d49f2bd406c3c980e923f2","Venue Server Lobby","000001067ae47fbc00400036001d00f70cc"
"1127344982","09/21/05","16:23:01","Enter","/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5e9e362492d49f2bd406c3c980e923f2","Venue Server Lobby","000001067ae47fbc00400036001d00f70cc"
"1127346560","09/21/05","16:49:20","Exit","/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f","UCSF Lab Med Lobby","000001067ae47fbc00400036001d00f70cc"
"1127346560","09/21/05","16:49:20","RemoveUser","/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f","UCSF Lab Med Lobby","000001067ae47fbc00400036001d00f70cc"
"1127346651","09/21/05","16:50:51","Enter","/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f","UCSF Lab Med Lobby","000001067ae47fbc00400036001d00f70cc"
"1127351531","09/21/05","18:12:11","RemoveUser","/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5e9e362492d49f2bd406c3c980e923f2","UCSF Lab Med Lobby","000001067ae47fbc00400036001d00f70cc"
"1134606849","12/14/05","16:34:09","Enter","/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f","UCSF Lab Med Lobby","000001067ae47fbc00400036001d00f70cc"
"1134608203","12/14/05","16:56:43","Exit","/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f","UCSF Lab Med Lobby","000001067ae47fbc00400036001d00f70cc"
"1134608203","12/14/05","16:56:43","RemoveUser","/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f","UCSF Lab Med Lobby","000001067ae47fbc00400036001d00f70cc"
"1134687744","12/15/05","15:02:24","Enter","/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f","UCSF Lab Med Lobby","000001067ae47fbc00400036001d00f70cc"
"1134688250","12/15/05","15:10:49","Exit","/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f","UCSF Lab Med Lobby","000001067ae47fbc00400036001d00f70cc"
"1134688250","12/15/05","15:10:49","RemoveUser","/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f","UCSF Lab Med Lobby","000001067ae47fbc00400036001d00f70cc"
"1134688292","12/15/05","15:11:32","Enter","/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f","UCSF Lab Med Lobby","000001067ae47fbc00400036001d00f70cc"
"1134688795","12/15/05","15:19:54","Enter","/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 2319335ffa01fed460f28b9a13addda4","UCSF Lab Med Lobby","000001067ae47fbc00400036001d00f70cc"
"1134689335","12/15/05","15:28:54","Enter","/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 2319335ffa01fed460f28b9a13addda4","UCSF Lab Med Lobby","000001067ae47fbc00400036001d00f70cc"
"1134689478","12/15/05","15:31:17","Exit","/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 2319335ffa01fed460f28b9a13addda4","UCSF Lab Med Lobby","000001067ae47fbc00400036001d00f70cc"
"1134689478","12/15/05","15:31:17","RemoveUser","/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 2319335ffa01fed460f28b9a13addda4","UCSF Lab Med Lobby","000001067ae47fbc00400036001d00f70cc"
"1134689496","12/15/05","15:31:36","Enter","/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 2319335ffa01fed460f28b9a13addda4","UCSF Lab Med Lobby","000001067ae47fbc00400036001d00f70cc"
12/14/05 16:33:26 3248 Toolkit toolkit.py:96 DEBUG Initializing AG Toolkit version 2.4 (build 1)
12/14/05 16:33:26 3248 Toolkit toolkit.py:138 INFO Logfile Name: VenueClient.log
12/14/05 16:33:26 3248 Toolkit toolkit.py:205 WARNING Toolkit.__CheckForValidClock: The machine clock is incorrect on
12/14/05 16:33:26 3248 Toolkit config.py:219 ERROR Error setting globus hostname.
12/14/05 16:33:26 3248 Toolkit config.py:348 DEBUG retrieved local IP address 64.54.29.247
12/14/05 16:33:26 3248 CertificateManager certificatemanager.py:269 DEBUG Opened repository C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo
12/14/05 16:33:26 3248 Toolkit toolkit.py:404 DEBUG looking in system ca dir: C:\Program Files\AGTk-2.4\Config\CAcertificates
12/14/05 16:33:26 3248 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\1c3f2ca8.0 might be a cert
12/14/05 16:33:26 3248 Toolkit toolkit.py:440 INFO Certificate 1c3f2ca8.0 already in repository
12/14/05 16:33:26 3248 Toolkit toolkit.py:456 INFO Marking cert as CA cert
12/14/05 16:33:26 3248 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\a82c3f1c4b096b896061778ee79efeff\9c8df64aa35ebf832613413527bc073d\user_files\signing_policy
12/14/05 16:33:26 3248 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\45cc9e80.0 might be a cert
12/14/05 16:33:26 3248 Toolkit toolkit.py:440 INFO Certificate 45cc9e80.0 already in repository
12/14/05 16:33:26 3248 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\809ecc45460c1482e61e26bdfbf9e18c\9f380c9a586af2bb913ace809d5badfe\user_files\signing_policy
12/14/05 16:33:26 3248 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\d1b603c3.0 might be a cert
12/14/05 16:33:26 3248 Toolkit toolkit.py:440 INFO Certificate d1b603c3.0 already in repository
12/14/05 16:33:26 3248 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\c303b6d10c962b37482e68ca64d383a0\05a2039fe10ed1b4195d9f9d35b32c68\user_files\signing_policy
12/14/05 16:33:26 3248 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\f18fa857.0 might be a cert
12/14/05 16:33:26 3248 Toolkit toolkit.py:440 INFO Certificate f18fa857.0 already in repository
12/14/05 16:33:26 3248 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\57a88ff1707d87e926f2287c702a8466\eff65f03366cb8e20247f831ccc87fd5\user_files\signing_policy
12/14/05 16:33:26 3248 Toolkit toolkit.py:478 DEBUG Init'ing globus.
12/14/05 16:33:26 3248 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
12/14/05 16:33:26 3248 CertificateManager certificatemanager.py:827 DEBUG Using default identity /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:33:26 3248 CertificateManager certificatemanager.py:1083 DEBUG Initializing environment with unencrypted cert /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:33:26 3248 CertificateManager certificatemanager.py:1098 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\191c8500c5d893d758250b70098c95ce\38d6622212820902ad92145aa0bb0932\cert.pem to 644
12/14/05 16:33:26 3248 CertificateManager certificatemanager.py:1109 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\privatekeys\60fef24d87f80145a55c7bb89691fde6.pem to 600
12/14/05 16:33:26 3248 CertificateManagerWXGUI certificatemanagerwxgui.py:422 DEBUG done, success=1
12/14/05 16:33:26 3248 Toolkit toolkit.py:482 DEBUG Done with globus.
12/14/05 16:33:26 3248 Toolkit venueclient.py:83 INFO wx version is: 2.5.1.5
12/14/05 16:33:26 3248 VenueClient venueclient.py:287 DEBUG __StartWebService: venueclient: https://64.54.29.247:11000/VenueClient
12/14/05 16:33:26 3248 ServiceManager agservicemanager.py:75 INFO Using services dir: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services
12/14/05 16:33:26 3248 ServiceManager agservicemanager.py:424 INFO __DiscoverResources
12/14/05 16:33:26 3248 Toolkit config.py:997 INFO Using vfwscan to get devices
12/14/05 16:33:26 3248 Toolkit config.py:998 DEBUG vfwscanexe = C:\PROGRA~1\AGTk-2.4\bin\vfwscan.exe
12/14/05 16:33:26 3248 Toolkit config.py:1003 DEBUG filelines = ['Microsoft WDM Image Capture (Win32)\n']
12/14/05 16:33:26 3248 Toolkit config.py:1031 INFO GetResources: ['Microsoft WDM Image Capture (Win32)']
12/14/05 16:33:26 3248 VenueClient venueclient.py:296 DEBUG __StartWebService: service manager: https://64.54.29.247:11000/ServiceManager
12/14/05 16:33:26 3248 NodeService agnodeservice.py:756 INFO NodeService.__ReadConfigFile
12/14/05 16:33:26 3248 Toolkit toolkit.py:335 DEBUG Looking for: C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\AGNodeService.cfg
12/14/05 16:33:26 3248 NodeService agnodeservice.py:764 DEBUG DEFAULT NODE SERVICE CONFIG: C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\AGNodeService.cfg
12/14/05 16:33:26 3248 NodeService agnodeservice.py:768 INFO Reading node service config file: C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\AGNodeService.cfg
12/14/05 16:33:26 3248 VenueClient venueclient.py:302 DEBUG __StartWebService: node service: https://64.54.29.247:11000/NodeService
12/14/05 16:33:26 3248 VenueClient venueclient.py:1328 DEBUG SerNodeUrl: Set node service url: https://64.54.29.247:11000/NodeService
12/14/05 16:33:26 3248 NodeService agnodeservice.py:698 INFO NodeService.GetDefaultConfiguration
12/14/05 16:33:26 3248 NodeService agnodeservice.py:581 INFO Migration unnecessary
12/14/05 16:33:26 3248 NodeService agnodeservice.py:374 INFO NodeService.LoadDefaultConfig
12/14/05 16:33:26 3248 NodeService agnodeservice.py:378 INFO Loading default node configuration: UCSF CB Micro Lab
12/14/05 16:33:26 3248 NodeService agnodeservice.py:392 INFO NodeService.LoadConfiguration
12/14/05 16:33:26 3248 NodeService agnodeservice.py:407 INFO Trying to load node configuration from: C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\nodeConfig\UCSF CB Micro Lab
12/14/05 16:33:26 2560 ServiceManager agservicemanager.py:389 INFO AGServiceManager.RemoveServices
12/14/05 16:33:27 3884 ServiceManager agservicemanager.py:115 INFO AGServiceManager.AddService
12/14/05 16:33:27 3884 ServiceManager agservicemanager.py:118 INFO AddService: AudioService v 2.420000 u AudioService.zip
12/14/05 16:33:27 3884 ServiceManager agservicemanager.py:121 INFO resourceToAssign:
12/14/05 16:33:27 3884 ServiceManager agservicemanager.py:147 DEBUG ** Resource does not exist! :
12/14/05 16:33:27 3884 ServiceManager agservicemanager.py:186 INFO Retaining version 2.420000
12/14/05 16:33:27 3884 ServiceManager agservicemanager.py:189 INFO Extracting service package to C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService
12/14/05 16:33:27 3884 ServiceManager agservicemanager.py:237 INFO Running Service; options: C:\Python23\pythonw.exe [u'C:\\Documents and Settings\\mvideo\\Application Data\\AccessGrid\\local_services\\AudioService\\AudioService.py', 65113]
12/14/05 16:33:27 3884 ProcessManager processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\AudioService.py" 65113
12/14/05 16:33:27 3884 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x014C5E24>, <PyHANDLE object at 0x0169BE5C>, 3900, 3904)
12/14/05 16:33:27 3884 ServiceManager agservicemanager.py:258 DEBUG Waiting for service to start: AudioService https://64.54.29.247:65113/Service
12/14/05 16:33:29 3884 ServiceManager agservicemanager.py:265 INFO Service AudioService successfully started
12/14/05 16:33:29 3884 ServiceManager agservicemanager.py:297 INFO Setting service configuration
12/14/05 16:33:29 3884 ServiceManager agservicemanager.py:309 DEBUG Not assigning resource; none given
12/14/05 16:33:29 3248 NodeService agnodeservice.py:515 INFO Not setting identity for service AudioService; no profile
12/14/05 16:33:30 4008 ServiceManager agservicemanager.py:115 INFO AGServiceManager.AddService
12/14/05 16:33:30 4008 ServiceManager agservicemanager.py:118 INFO AddService: VideoConsumerService v 2.330000 u VideoConsumerService.zip
12/14/05 16:33:30 4008 ServiceManager agservicemanager.py:121 INFO resourceToAssign:
12/14/05 16:33:30 4008 ServiceManager agservicemanager.py:147 DEBUG ** Resource does not exist! :
12/14/05 16:33:30 4008 ServiceManager agservicemanager.py:186 INFO Retaining version 2.330000
12/14/05 16:33:30 4008 ServiceManager agservicemanager.py:189 INFO Extracting service package to C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoConsumerService
12/14/05 16:33:30 4008 ServiceManager agservicemanager.py:237 INFO Running Service; options: C:\Python23\pythonw.exe [u'C:\\Documents and Settings\\mvideo\\Application Data\\AccessGrid\\local_services\\VideoConsumerService\\VideoConsumerService.py', 55765]
12/14/05 16:33:30 4008 ProcessManager processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoConsumerService\VideoConsumerService.py" 55765
12/14/05 16:33:30 4008 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x0167794C>, <PyHANDLE object at 0x016EF9CC>, 1684, 4016)
12/14/05 16:33:30 4008 ServiceManager agservicemanager.py:258 DEBUG Waiting for service to start: VideoConsumerService https://64.54.29.247:55765/Service
12/14/05 16:33:32 4008 ServiceManager agservicemanager.py:265 INFO Service VideoConsumerService successfully started
12/14/05 16:33:32 4008 ServiceManager agservicemanager.py:300 DEBUG Not setting service configuration; none given
12/14/05 16:33:32 4008 ServiceManager agservicemanager.py:309 DEBUG Not assigning resource; none given
12/14/05 16:33:32 3248 NodeService agnodeservice.py:515 INFO Not setting identity for service VideoConsumerService; no profile
12/14/05 16:33:33 896 ServiceManager agservicemanager.py:115 INFO AGServiceManager.AddService
12/14/05 16:33:33 896 ServiceManager agservicemanager.py:118 INFO AddService: VideoProducerService v 2.540000 u VideoProducerService.zip
12/14/05 16:33:33 896 ServiceManager agservicemanager.py:121 INFO resourceToAssign: Microsoft WDM Image Capture (Win32)
12/14/05 16:33:33 896 ServiceManager agservicemanager.py:186 INFO Retaining version 2.540000
12/14/05 16:33:33 896 ServiceManager agservicemanager.py:189 INFO Extracting service package to C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoProducerService
12/14/05 16:33:33 896 ServiceManager agservicemanager.py:237 INFO Running Service; options: C:\Python23\pythonw.exe [u'C:\\Documents and Settings\\mvideo\\Application Data\\AccessGrid\\local_services\\VideoProducerService\\VideoProducerService.py', 64606]
12/14/05 16:33:33 896 ProcessManager processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoProducerService\VideoProducerService.py" 64606
12/14/05 16:33:33 896 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x016ECF64>, <PyHANDLE object at 0x016EFB64>, 1992, 472)
12/14/05 16:33:33 896 ServiceManager agservicemanager.py:258 DEBUG Waiting for service to start: VideoProducerService https://64.54.29.247:64606/Service
12/14/05 16:33:35 896 ServiceManager agservicemanager.py:265 INFO Service VideoProducerService successfully started
12/14/05 16:33:35 896 ServiceManager agservicemanager.py:297 INFO Setting service configuration
12/14/05 16:33:35 896 ServiceManager agservicemanager.py:306 INFO Assigning resource to service: Microsoft WDM Image Capture (Win32)
12/14/05 16:33:36 3248 NodeService agnodeservice.py:515 INFO Not setting identity for service VideoProducerService; no profile
12/14/05 16:33:36 2504 ServiceManager agservicemanager.py:115 INFO AGServiceManager.AddService
12/14/05 16:33:36 2504 ServiceManager agservicemanager.py:118 INFO AddService: VideoProducerService v 2.540000 u VideoProducerService.zip
12/14/05 16:33:36 2504 ServiceManager agservicemanager.py:121 INFO resourceToAssign: Microsoft WDM Image Capture (Win32)
12/14/05 16:33:36 2504 ServiceManager agservicemanager.py:186 INFO Retaining version 2.540000
12/14/05 16:33:36 2504 ServiceManager agservicemanager.py:189 INFO Extracting service package to C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoProducerService
12/14/05 16:33:36 2504 ServiceManager agservicemanager.py:237 INFO Running Service; options: C:\Python23\pythonw.exe [u'C:\\Documents and Settings\\mvideo\\Application Data\\AccessGrid\\local_services\\VideoProducerService\\VideoProducerService.py', 52356]
12/14/05 16:33:36 2504 ProcessManager processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoProducerService\VideoProducerService.py" 52356
12/14/05 16:33:36 2504 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x0169DC44>, <PyHANDLE object at 0x0180C554>, 644, 528)
12/14/05 16:33:36 2504 ServiceManager agservicemanager.py:258 DEBUG Waiting for service to start: VideoProducerService https://64.54.29.247:52356/Service
12/14/05 16:33:38 2504 ServiceManager agservicemanager.py:265 INFO Service VideoProducerService successfully started
12/14/05 16:33:38 2504 ServiceManager agservicemanager.py:297 INFO Setting service configuration
12/14/05 16:33:38 2504 ServiceManager agservicemanager.py:306 INFO Assigning resource to service: Microsoft WDM Image Capture (Win32)
12/14/05 16:33:39 3248 NodeService agnodeservice.py:515 INFO Not setting identity for service VideoProducerService; no profile
12/14/05 16:33:39 3248 VenueClient venueclient.py:185 DEBUG __createPersonalDataStore: Creating personal datastore at C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\personalDataStore using prefix personalDataStore and port 0
12/14/05 16:33:39 3248 DataStore datastore.py:1537 DEBUG Creating thread 0
12/14/05 16:33:39 3248 DataStore datastore.py:1542 DEBUG Starting thread 0
12/14/05 16:33:39 1924 DataStore datastore.py:1550 DEBUG Worker 0 starting
12/14/05 16:33:39 3248 DataStore datastore.py:1544 DEBUG Waiting thread 0
12/14/05 16:33:39 3248 DataStore datastore.py:1547 DEBUG Done creating workers
12/14/05 16:33:39 3248 DataStore datastore.py:278 DEBUG Reading persisted data from: C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\personalDataStore\DataStore.dat
12/14/05 16:33:39 3248 VenueClient venueclient.py:210 DEBUG __createPersonalDataStore: Load personal data from file
12/14/05 16:33:39 3248 VenueClientController venueclientcontroller.py:1255 DEBUG There is no personal venues file to load.
12/14/05 16:34:07 3248 VenueClient venueclient.py:805 DEBUG EnterVenue; url=https://64.54.29.247:8000/Venues/default
12/14/05 16:34:07 2960 NodeService agnodeservice.py:715 INFO NodeService.GetCapabilities
12/14/05 16:34:07 2960 NodeService agnodeservice.py:256 INFO NodeService.GetServices
12/14/05 16:34:07 2972 ServiceManager agservicemanager.py:399 INFO AGServiceManager.GetServices
12/14/05 16:34:08 3248 VenueClient venueclient.py:705 DEBUG EnterVenue: Invoke venue enter
12/14/05 16:34:09 3248 EventClient eventclient.py:158 DEBUG Have callback handle _a8f50302_p_callbackStruct
12/14/05 16:34:09 3248 VenueClient venueclient.py:780 DEBUG Setting isInVenue flag.
12/14/05 16:34:09 3248 VenueClient venueclient.py:999 DEBUG UpdateNodeService: Method UpdateNodeService called
12/14/05 16:34:09 3044 NodeService agnodeservice.py:734 INFO NodeService.SetIdentity UCSF China Basin Microbilogy terrazas at labmed2.ucsf.edu
12/14/05 16:34:09 3044 NodeService agnodeservice.py:256 INFO NodeService.GetServices
12/14/05 16:34:10 2240 ServiceManager agservicemanager.py:399 INFO AGServiceManager.GetServices
12/14/05 16:34:11 3248 VenueClient venueclient.py:1046 DEBUG UpdateStream: Setting stream 000001082bd694b300400036001d00f7724 to multicast
12/14/05 16:34:11 3248 VenueClient venueclient.py:1046 DEBUG UpdateStream: Setting stream 000001082bd694b300400036001d00f779c to multicast
12/14/05 16:34:11 3080 NodeService agnodeservice.py:325 INFO NodeService.SetStreams
12/14/05 16:34:11 3080 NodeService agnodeservice.py:256 INFO NodeService.GetServices
12/14/05 16:34:12 2828 ServiceManager agservicemanager.py:399 INFO AGServiceManager.GetServices
12/14/05 16:34:12 3080 NodeService agnodeservice.py:805 INFO NodeService.__SendStreamsToService
12/14/05 16:34:12 3080 NodeService agnodeservice.py:815 INFO Sending stream (type=audio) to service: https://64.54.29.247:65113/Service
12/14/05 16:34:13 3080 NodeService agnodeservice.py:805 INFO NodeService.__SendStreamsToService
12/14/05 16:34:13 3080 NodeService agnodeservice.py:815 INFO Sending stream (type=video) to service: https://64.54.29.247:55765/Service
12/14/05 16:34:14 3080 NodeService agnodeservice.py:805 INFO NodeService.__SendStreamsToService
12/14/05 16:34:14 3080 NodeService agnodeservice.py:815 INFO Sending stream (type=video) to service: https://64.54.29.247:64606/Service
12/14/05 16:34:15 3080 NodeService agnodeservice.py:805 INFO NodeService.__SendStreamsToService
12/14/05 16:34:15 3080 NodeService agnodeservice.py:815 INFO Sending stream (type=video) to service: https://64.54.29.247:52356/Service
12/14/05 16:34:15 3248 VenueClient venueclient.py:840 DEBUG Updating client profile cache.
12/14/05 16:34:15 3248 VenueClient venueclientui.py:1925 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://64.54.29.247:8000/Venues/default
12/14/05 16:34:15 3248 VenueClient venueclientui.py:2034 DEBUG Entered venue
12/14/05 16:34:15 3248 VenueClient venueclientui.py:2623 DEBUG ContentListPanel.AddParticipant:: AddParticipant UCSF China Basin Microbilogy (called from ('C:\\Python23\\Lib\\site-packages\\wx\\core.py', 9397, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
12/14/05 16:56:40 3248 VenueClient venueclientui.py:1565 INFO --------- END VenueClient
12/14/05 16:56:40 3248 VenueClient venueclient.py:938 INFO ExitVenue
12/14/05 16:56:40 3248 VenueClient venueclient.py:981 INFO ExitVenue: Stopping node services
12/14/05 16:56:40 2928 NodeService agnodeservice.py:301 INFO NodeService.StopServices
12/14/05 16:56:40 2808 ServiceManager agservicemanager.py:409 INFO AGServiceManager.StopServices
12/14/05 16:56:41 3032 NodeService agnodeservice.py:325 INFO NodeService.SetStreams
12/14/05 16:56:41 3032 NodeService agnodeservice.py:256 INFO NodeService.GetServices
12/14/05 16:56:42 2828 ServiceManager agservicemanager.py:399 INFO AGServiceManager.GetServices
12/14/05 16:56:42 3032 NodeService agnodeservice.py:805 INFO NodeService.__SendStreamsToService
12/14/05 16:56:42 3248 VenueClient venueclient.py:895 INFO ExitVenue: Stopping heartbeats
12/14/05 16:56:43 3164 EventClient eventclient.py:177 DEBUG Read Callback called arg=None handle=_20050302_p_globus_io_handle_t result=(-1, 44, 'an end-of-file was reached') n=0
12/14/05 16:56:43 3164 EventClient eventclient.py:180 DEBUG readCallback gets failure in result: -1 44
12/14/05 16:56:43 3248 VenueClient venueclient.py:906 DEBUG ExitVenue: Stop event client obj
12/14/05 16:56:43 3248 EventClient eventclient.py:303 DEBUG Cancel pending callbacks
12/14/05 16:56:43 3248 EventClient eventclient.py:309 DEBUG Free callback _a8f50302_p_callbackStruct
12/14/05 16:56:43 3248 EventClient eventclient.py:315 DEBUG EventClient.Stop: closing socket
12/14/05 16:56:43 3248 EventClient eventclient.py:323 DEBUG EventClient.Stop: closing queue
12/14/05 16:56:43 3248 VenueClient venueclient.py:908 DEBUG ExitVenue: Remove event client reference
12/14/05 16:56:43 3248 VenueClient venueclient.py:913 INFO ExitVenue: Stopping text client
12/14/05 16:56:43 3248 VenueClient venueclient.py:917 DEBUG ExitVenue: Sending client disconnect event.
12/14/05 16:56:43 3248 VenueClient venueclient.py:924 ERROR ExitVenue: On text client exiting
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 919, in __ExitVenue
self.privateId)
File "C:\Python23\Lib\site-packages\AccessGrid\TextClient.py", line 296, in Disconnect
self.textProcessor.Input(DisconnectEvent(venueId, privateId))
File "C:\Python23\Lib\site-packages\AccessGrid\TextClient.py", line 54, in Input
self.textConnection.Write(event)
File "C:\Python23\Lib\site-packages\AccessGrid\TextClient.py", line 173, in Write
self.wfile.write(pdata)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 377, in write
self.sock.write(str, len(str))
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 253, in write
raise ex
IOBaseException: a system call failed (Unknown error)
12/14/05 16:56:43 3248 DataStore datastore.py:1614 DEBUG Quitting thread 0
12/14/05 16:56:43 1924 DataStore datastore.py:1555 DEBUG Worker 0 gets cmd quit
12/14/05 16:56:43 1924 DataStore datastore.py:1568 DEBUG Worker 0 exiting
12/14/05 16:56:43 1572 DataStore datastore.py:1627 INFO GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation, most likely shutting down.
12/14/05 16:56:43 3248 NodeService agnodeservice.py:136 INFO NodeService.Stop
12/14/05 16:56:43 3248 ServiceManager agservicemanager.py:84 INFO AGServiceManager.Shutdown
12/14/05 16:56:43 3248 ServiceManager agservicemanager.py:85 INFO Remove services
12/14/05 16:56:43 3248 ServiceManager agservicemanager.py:389 INFO AGServiceManager.RemoveServices
12/14/05 16:56:43 3248 ServiceManager agservicemanager.py:330 INFO AGServiceManager.RemoveService
12/14/05 16:56:43 3248 ProcessManager processmanager.py:133 WARNING Couldn't terminate process <PyHANDLE:904> cleanly (258)
12/14/05 16:56:44 3248 ServiceManager agservicemanager.py:330 INFO AGServiceManager.RemoveService
12/14/05 16:56:44 3248 ProcessManager processmanager.py:133 WARNING Couldn't terminate process <PyHANDLE:876> cleanly (258)
12/14/05 16:56:45 3248 ServiceManager agservicemanager.py:87 INFO Stop network interface
12/14/05 16:56:45 3880 Hosting server.py:65 ERROR Exception in SOAP server main loop
raise ex
12/14/05 16:56:45 3248 Hosting server.py:97 ERROR server_close() failed
File "C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py", line 95, in Stop
self._server.server_close()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1043, in server_close
self.socket.close()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1020, in close
IOBase.close(self)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 176, in close
raise ex
IOBaseException: an uninitialied data structure was passed as argument 1 to globus_io_register_close
self.socket.close()
IOBase.close(self)
raise ex
12/15/05 15:02:00 956 Toolkit toolkit.py:96 DEBUG Initializing AG Toolkit version 2.4 (build 1)
12/15/05 15:02:01 956 Toolkit toolkit.py:138 INFO Logfile Name: VenueClient.log
12/15/05 15:02:01 956 Toolkit toolkit.py:205 WARNING Toolkit.__CheckForValidClock: The machine clock is incorrect on
12/15/05 15:02:01 956 Toolkit config.py:219 ERROR Error setting globus hostname.
12/15/05 15:02:01 956 Toolkit config.py:348 DEBUG retrieved local IP address 64.54.29.247
12/15/05 15:02:01 956 CertificateManager certificatemanager.py:269 DEBUG Opened repository C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo
12/15/05 15:02:01 956 Toolkit toolkit.py:404 DEBUG looking in system ca dir: C:\Program Files\AGTk-2.4\Config\CAcertificates
12/15/05 15:02:01 956 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\1c3f2ca8.0 might be a cert
12/15/05 15:02:01 956 Toolkit toolkit.py:440 INFO Certificate 1c3f2ca8.0 already in repository
12/15/05 15:02:01 956 Toolkit toolkit.py:456 INFO Marking cert as CA cert
12/15/05 15:02:01 956 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\a82c3f1c4b096b896061778ee79efeff\9c8df64aa35ebf832613413527bc073d\user_files\signing_policy
12/15/05 15:02:01 956 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\45cc9e80.0 might be a cert
12/15/05 15:02:01 956 Toolkit toolkit.py:440 INFO Certificate 45cc9e80.0 already in repository
12/15/05 15:02:01 956 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\809ecc45460c1482e61e26bdfbf9e18c\9f380c9a586af2bb913ace809d5badfe\user_files\signing_policy
12/15/05 15:02:01 956 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\d1b603c3.0 might be a cert
12/15/05 15:02:01 956 Toolkit toolkit.py:440 INFO Certificate d1b603c3.0 already in repository
12/15/05 15:02:01 956 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\c303b6d10c962b37482e68ca64d383a0\05a2039fe10ed1b4195d9f9d35b32c68\user_files\signing_policy
12/15/05 15:02:01 956 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\f18fa857.0 might be a cert
12/15/05 15:02:01 956 Toolkit toolkit.py:440 INFO Certificate f18fa857.0 already in repository
12/15/05 15:02:01 956 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\57a88ff1707d87e926f2287c702a8466\eff65f03366cb8e20247f831ccc87fd5\user_files\signing_policy
12/15/05 15:02:01 956 Toolkit toolkit.py:478 DEBUG Init'ing globus.
12/15/05 15:02:02 956 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
12/15/05 15:02:02 956 CertificateManager certificatemanager.py:827 DEBUG Using default identity /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:02:02 956 CertificateManager certificatemanager.py:1083 DEBUG Initializing environment with unencrypted cert /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:02:02 956 CertificateManager certificatemanager.py:1098 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\191c8500c5d893d758250b70098c95ce\38d6622212820902ad92145aa0bb0932\cert.pem to 644
12/15/05 15:02:02 956 CertificateManager certificatemanager.py:1109 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\privatekeys\60fef24d87f80145a55c7bb89691fde6.pem to 600
12/15/05 15:02:02 956 CertificateManagerWXGUI certificatemanagerwxgui.py:422 DEBUG done, success=1
12/15/05 15:02:02 956 Toolkit toolkit.py:482 DEBUG Done with globus.
12/15/05 15:02:02 956 Toolkit venueclient.py:83 INFO wx version is: 2.5.1.5
12/15/05 15:02:02 956 VenueClient venueclient.py:287 DEBUG __StartWebService: venueclient: https://64.54.29.247:11000/VenueClient
12/15/05 15:02:02 956 ServiceManager agservicemanager.py:75 INFO Using services dir: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services
12/15/05 15:02:02 956 ServiceManager agservicemanager.py:424 INFO __DiscoverResources
12/15/05 15:02:02 956 Toolkit config.py:997 INFO Using vfwscan to get devices
12/15/05 15:02:02 956 Toolkit config.py:998 DEBUG vfwscanexe = C:\PROGRA~1\AGTk-2.4\bin\vfwscan.exe
12/15/05 15:02:02 956 Toolkit config.py:1003 DEBUG filelines = ['Microsoft WDM Image Capture (Win32)\n']
12/15/05 15:02:02 956 Toolkit config.py:1031 INFO GetResources: ['Microsoft WDM Image Capture (Win32)']
12/15/05 15:02:02 956 VenueClient venueclient.py:296 DEBUG __StartWebService: service manager: https://64.54.29.247:11000/ServiceManager
12/15/05 15:02:02 956 NodeService agnodeservice.py:756 INFO NodeService.__ReadConfigFile
12/15/05 15:02:02 956 Toolkit toolkit.py:335 DEBUG Looking for: C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\AGNodeService.cfg
12/15/05 15:02:02 956 NodeService agnodeservice.py:764 DEBUG DEFAULT NODE SERVICE CONFIG: C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\AGNodeService.cfg
12/15/05 15:02:02 956 NodeService agnodeservice.py:768 INFO Reading node service config file: C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\AGNodeService.cfg
12/15/05 15:02:02 956 VenueClient venueclient.py:302 DEBUG __StartWebService: node service: https://64.54.29.247:11000/NodeService
12/15/05 15:02:02 956 VenueClient venueclient.py:1328 DEBUG SerNodeUrl: Set node service url: https://64.54.29.247:11000/NodeService
12/15/05 15:02:02 956 NodeService agnodeservice.py:698 INFO NodeService.GetDefaultConfiguration
12/15/05 15:02:02 956 NodeService agnodeservice.py:581 INFO Migration unnecessary
12/15/05 15:02:02 956 NodeService agnodeservice.py:374 INFO NodeService.LoadDefaultConfig
12/15/05 15:02:02 956 NodeService agnodeservice.py:378 INFO Loading default node configuration: UCSF CB Micro Lab
12/15/05 15:02:02 956 NodeService agnodeservice.py:392 INFO NodeService.LoadConfiguration
12/15/05 15:02:02 956 NodeService agnodeservice.py:407 INFO Trying to load node configuration from: C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\nodeConfig\UCSF CB Micro Lab
12/15/05 15:02:02 1868 ServiceManager agservicemanager.py:389 INFO AGServiceManager.RemoveServices
12/15/05 15:02:03 1644 ServiceManager agservicemanager.py:115 INFO AGServiceManager.AddService
12/15/05 15:02:03 1644 ServiceManager agservicemanager.py:118 INFO AddService: AudioService v 2.420000 u AudioService.zip
12/15/05 15:02:03 1644 ServiceManager agservicemanager.py:121 INFO resourceToAssign:
12/15/05 15:02:03 1644 ServiceManager agservicemanager.py:147 DEBUG ** Resource does not exist! :
12/15/05 15:02:03 1644 ServiceManager agservicemanager.py:186 INFO Retaining version 2.420000
12/15/05 15:02:03 1644 ServiceManager agservicemanager.py:189 INFO Extracting service package to C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService
12/15/05 15:02:03 1644 ServiceManager agservicemanager.py:237 INFO Running Service; options: C:\Python23\pythonw.exe [u'C:\\Documents and Settings\\mvideo\\Application Data\\AccessGrid\\local_services\\AudioService\\AudioService.py', 59454]
12/15/05 15:02:03 1644 ProcessManager processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\AudioService.py" 59454
12/15/05 15:02:03 1644 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x0162D184>, <PyHANDLE object at 0x016A931C>, 3560, 3288)
12/15/05 15:02:03 1644 ServiceManager agservicemanager.py:258 DEBUG Waiting for service to start: AudioService https://64.54.29.247:59454/Service
12/15/05 15:02:05 1644 ServiceManager agservicemanager.py:265 INFO Service AudioService successfully started
12/15/05 15:02:05 1644 ServiceManager agservicemanager.py:297 INFO Setting service configuration
12/15/05 15:02:05 1644 ServiceManager agservicemanager.py:309 DEBUG Not assigning resource; none given
12/15/05 15:02:05 956 NodeService agnodeservice.py:515 INFO Not setting identity for service AudioService; no profile
12/15/05 15:02:05 3896 ServiceManager agservicemanager.py:115 INFO AGServiceManager.AddService
12/15/05 15:02:05 3896 ServiceManager agservicemanager.py:118 INFO AddService: VideoConsumerService v 2.330000 u VideoConsumerService.zip
12/15/05 15:02:05 3896 ServiceManager agservicemanager.py:121 INFO resourceToAssign:
12/15/05 15:02:05 3896 ServiceManager agservicemanager.py:147 DEBUG ** Resource does not exist! :
12/15/05 15:02:05 3896 ServiceManager agservicemanager.py:186 INFO Retaining version 2.330000
12/15/05 15:02:05 3896 ServiceManager agservicemanager.py:189 INFO Extracting service package to C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoConsumerService
12/15/05 15:02:05 3896 ServiceManager agservicemanager.py:237 INFO Running Service; options: C:\Python23\pythonw.exe [u'C:\\Documents and Settings\\mvideo\\Application Data\\AccessGrid\\local_services\\VideoConsumerService\\VideoConsumerService.py', 62117]
12/15/05 15:02:05 3896 ProcessManager processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoConsumerService\VideoConsumerService.py" 62117
12/15/05 15:02:05 3896 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x017C245C>, <PyHANDLE object at 0x01546D8C>, 4012, 4048)
12/15/05 15:02:05 3896 ServiceManager agservicemanager.py:258 DEBUG Waiting for service to start: VideoConsumerService https://64.54.29.247:62117/Service
12/15/05 15:02:08 3896 ServiceManager agservicemanager.py:265 INFO Service VideoConsumerService successfully started
12/15/05 15:02:08 3896 ServiceManager agservicemanager.py:300 DEBUG Not setting service configuration; none given
12/15/05 15:02:08 3896 ServiceManager agservicemanager.py:309 DEBUG Not assigning resource; none given
12/15/05 15:02:08 956 NodeService agnodeservice.py:515 INFO Not setting identity for service VideoConsumerService; no profile
12/15/05 15:02:08 3856 ServiceManager agservicemanager.py:115 INFO AGServiceManager.AddService
12/15/05 15:02:08 3856 ServiceManager agservicemanager.py:118 INFO AddService: VideoProducerService v 2.540000 u VideoProducerService.zip
12/15/05 15:02:08 3856 ServiceManager agservicemanager.py:121 INFO resourceToAssign: Microsoft WDM Image Capture (Win32)
12/15/05 15:02:08 3856 ServiceManager agservicemanager.py:186 INFO Retaining version 2.540000
12/15/05 15:02:08 3856 ServiceManager agservicemanager.py:189 INFO Extracting service package to C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoProducerService
12/15/05 15:02:08 3856 ServiceManager agservicemanager.py:237 INFO Running Service; options: C:\Python23\pythonw.exe [u'C:\\Documents and Settings\\mvideo\\Application Data\\AccessGrid\\local_services\\VideoProducerService\\VideoProducerService.py', 51508]
12/15/05 15:02:08 3856 ProcessManager processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoProducerService\VideoProducerService.py" 51508
12/15/05 15:02:08 3856 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x0163804C>, <PyHANDLE object at 0x0163810C>, 3320, 4008)
12/15/05 15:02:08 3856 ServiceManager agservicemanager.py:258 DEBUG Waiting for service to start: VideoProducerService https://64.54.29.247:51508/Service
12/15/05 15:02:11 3856 ServiceManager agservicemanager.py:265 INFO Service VideoProducerService successfully started
12/15/05 15:02:11 3856 ServiceManager agservicemanager.py:297 INFO Setting service configuration
12/15/05 15:02:11 3856 ServiceManager agservicemanager.py:306 INFO Assigning resource to service: Microsoft WDM Image Capture (Win32)
12/15/05 15:02:11 956 NodeService agnodeservice.py:515 INFO Not setting identity for service VideoProducerService; no profile
12/15/05 15:02:12 3844 ServiceManager agservicemanager.py:115 INFO AGServiceManager.AddService
12/15/05 15:02:12 3844 ServiceManager agservicemanager.py:118 INFO AddService: VideoProducerService v 2.540000 u VideoProducerService.zip
12/15/05 15:02:12 3844 ServiceManager agservicemanager.py:121 INFO resourceToAssign: Microsoft WDM Image Capture (Win32)
12/15/05 15:02:12 3844 ServiceManager agservicemanager.py:186 INFO Retaining version 2.540000
12/15/05 15:02:12 3844 ServiceManager agservicemanager.py:189 INFO Extracting service package to C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoProducerService
12/15/05 15:02:12 3844 ServiceManager agservicemanager.py:237 INFO Running Service; options: C:\Python23\pythonw.exe [u'C:\\Documents and Settings\\mvideo\\Application Data\\AccessGrid\\local_services\\VideoProducerService\\VideoProducerService.py', 59760]
12/15/05 15:02:12 3844 ProcessManager processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoProducerService\VideoProducerService.py" 59760
12/15/05 15:02:12 3844 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x017C9424>, <PyHANDLE object at 0x016ABF24>, 1796, 2560)
12/15/05 15:02:12 3844 ServiceManager agservicemanager.py:258 DEBUG Waiting for service to start: VideoProducerService https://64.54.29.247:59760/Service
12/15/05 15:02:14 3844 ServiceManager agservicemanager.py:265 INFO Service VideoProducerService successfully started
12/15/05 15:02:14 3844 ServiceManager agservicemanager.py:297 INFO Setting service configuration
12/15/05 15:02:14 3844 ServiceManager agservicemanager.py:306 INFO Assigning resource to service: Microsoft WDM Image Capture (Win32)
12/15/05 15:02:14 956 NodeService agnodeservice.py:515 INFO Not setting identity for service VideoProducerService; no profile
12/15/05 15:02:14 956 VenueClient venueclient.py:185 DEBUG __createPersonalDataStore: Creating personal datastore at C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\personalDataStore using prefix personalDataStore and port 0
12/15/05 15:02:14 956 DataStore datastore.py:1537 DEBUG Creating thread 0
12/15/05 15:02:14 956 DataStore datastore.py:1542 DEBUG Starting thread 0
12/15/05 15:02:14 3252 DataStore datastore.py:1550 DEBUG Worker 0 starting
12/15/05 15:02:14 956 DataStore datastore.py:1544 DEBUG Waiting thread 0
12/15/05 15:02:14 956 DataStore datastore.py:1547 DEBUG Done creating workers
12/15/05 15:02:14 956 DataStore datastore.py:278 DEBUG Reading persisted data from: C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\personalDataStore\DataStore.dat
12/15/05 15:02:14 956 VenueClient venueclient.py:210 DEBUG __createPersonalDataStore: Load personal data from file
12/15/05 15:02:14 956 VenueClientController venueclientcontroller.py:1255 DEBUG There is no personal venues file to load.
12/15/05 15:02:22 956 VenueClient venueclient.py:805 DEBUG EnterVenue; url=https://64.54.29.247:8000/Venues/default
12/15/05 15:02:22 2536 NodeService agnodeservice.py:715 INFO NodeService.GetCapabilities
12/15/05 15:02:22 2536 NodeService agnodeservice.py:256 INFO NodeService.GetServices
12/15/05 15:02:22 896 ServiceManager agservicemanager.py:399 INFO AGServiceManager.GetServices
12/15/05 15:02:24 956 VenueClient venueclient.py:705 DEBUG EnterVenue: Invoke venue enter
12/15/05 15:02:24 956 EventClient eventclient.py:158 DEBUG Have callback handle _20690a02_p_callbackStruct
12/15/05 15:02:24 956 VenueClient venueclient.py:780 DEBUG Setting isInVenue flag.
12/15/05 15:02:24 956 VenueClient venueclient.py:999 DEBUG UpdateNodeService: Method UpdateNodeService called
12/15/05 15:02:24 3176 NodeService agnodeservice.py:734 INFO NodeService.SetIdentity UCSF China Basin Microbilogy terrazas at labmed2.ucsf.edu
12/15/05 15:02:24 3176 NodeService agnodeservice.py:256 INFO NodeService.GetServices
12/15/05 15:02:25 1556 ServiceManager agservicemanager.py:399 INFO AGServiceManager.GetServices
12/15/05 15:02:26 956 VenueClient venueclient.py:1046 DEBUG UpdateStream: Setting stream 000001082bd694b300400036001d00f7724 to multicast
12/15/05 15:02:26 956 VenueClient venueclient.py:1046 DEBUG UpdateStream: Setting stream 0000010830a8f10900400036001d00f7284 to multicast
12/15/05 15:02:26 824 NodeService agnodeservice.py:325 INFO NodeService.SetStreams
12/15/05 15:02:26 824 NodeService agnodeservice.py:256 INFO NodeService.GetServices
12/15/05 15:02:26 4092 ServiceManager agservicemanager.py:399 INFO AGServiceManager.GetServices
12/15/05 15:02:26 824 NodeService agnodeservice.py:805 INFO NodeService.__SendStreamsToService
12/15/05 15:02:26 824 NodeService agnodeservice.py:815 INFO Sending stream (type=audio) to service: https://64.54.29.247:59454/Service
12/15/05 15:02:27 824 NodeService agnodeservice.py:805 INFO NodeService.__SendStreamsToService
12/15/05 15:02:27 824 NodeService agnodeservice.py:815 INFO Sending stream (type=video) to service: https://64.54.29.247:62117/Service
12/15/05 15:02:28 824 NodeService agnodeservice.py:805 INFO NodeService.__SendStreamsToService
12/15/05 15:02:28 824 NodeService agnodeservice.py:815 INFO Sending stream (type=video) to service: https://64.54.29.247:51508/Service
12/15/05 15:02:29 824 NodeService agnodeservice.py:815 INFO Sending stream (type=video) to service: https://64.54.29.247:59760/Service
12/15/05 15:02:29 956 VenueClient venueclient.py:840 DEBUG Updating client profile cache.
12/15/05 15:02:29 956 VenueClient venueclientui.py:1925 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://64.54.29.247:8000/Venues/default
12/15/05 15:02:29 956 VenueClient venueclientui.py:2034 DEBUG Entered venue
12/15/05 15:02:29 956 VenueClient venueclientui.py:2623 DEBUG ContentListPanel.AddParticipant:: AddParticipant UCSF China Basin Microbilogy (called from ('C:\\Python23\\Lib\\site-packages\\wx\\core.py', 9397, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
12/15/05 15:10:45 956 VenueClient venueclientui.py:1565 INFO --------- END VenueClient
12/15/05 15:10:45 956 VenueClient venueclient.py:938 INFO ExitVenue
12/15/05 15:10:45 956 VenueClient venueclient.py:981 INFO ExitVenue: Stopping node services
12/15/05 15:10:46 4032 NodeService agnodeservice.py:301 INFO NodeService.StopServices
12/15/05 15:10:46 2084 ServiceManager agservicemanager.py:409 INFO AGServiceManager.StopServices
12/15/05 15:10:48 3460 NodeService agnodeservice.py:325 INFO NodeService.SetStreams
12/15/05 15:10:48 3460 NodeService agnodeservice.py:256 INFO NodeService.GetServices
12/15/05 15:10:48 880 ServiceManager agservicemanager.py:399 INFO AGServiceManager.GetServices
12/15/05 15:10:48 3460 NodeService agnodeservice.py:805 INFO NodeService.__SendStreamsToService
12/15/05 15:10:49 3460 NodeService agnodeservice.py:805 INFO NodeService.__SendStreamsToService
12/15/05 15:10:49 956 VenueClient venueclient.py:895 INFO ExitVenue: Stopping heartbeats
12/15/05 15:10:49 632 EventClient eventclient.py:177 DEBUG Read Callback called arg=None handle=_48fa0502_p_globus_io_handle_t result=(-1, 44, 'an end-of-file was reached') n=0
12/15/05 15:10:49 632 EventClient eventclient.py:180 DEBUG readCallback gets failure in result: -1 44
12/15/05 15:10:49 956 VenueClient venueclient.py:906 DEBUG ExitVenue: Stop event client obj
12/15/05 15:10:49 956 EventClient eventclient.py:303 DEBUG Cancel pending callbacks
12/15/05 15:10:49 956 EventClient eventclient.py:309 DEBUG Free callback _20690a02_p_callbackStruct
12/15/05 15:10:49 956 EventClient eventclient.py:315 DEBUG EventClient.Stop: closing socket
12/15/05 15:10:49 956 EventClient eventclient.py:323 DEBUG EventClient.Stop: closing queue
12/15/05 15:10:49 956 VenueClient venueclient.py:908 DEBUG ExitVenue: Remove event client reference
12/15/05 15:10:49 956 VenueClient venueclient.py:913 INFO ExitVenue: Stopping text client
12/15/05 15:10:49 956 VenueClient venueclient.py:917 DEBUG ExitVenue: Sending client disconnect event.
12/15/05 15:10:49 956 VenueClient venueclient.py:924 ERROR ExitVenue: On text client exiting
Traceback (most recent call last):
self.privateId)
raise ex
12/15/05 15:10:49 956 DataStore datastore.py:1614 DEBUG Quitting thread 0
12/15/05 15:10:49 3252 DataStore datastore.py:1555 DEBUG Worker 0 gets cmd quit
12/15/05 15:10:49 3252 DataStore datastore.py:1568 DEBUG Worker 0 exiting
12/15/05 15:10:49 3408 DataStore datastore.py:1627 INFO GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation, most likely shutting down.
12/15/05 15:10:49 956 NodeService agnodeservice.py:136 INFO NodeService.Stop
12/15/05 15:10:49 956 ServiceManager agservicemanager.py:84 INFO AGServiceManager.Shutdown
12/15/05 15:10:49 956 ServiceManager agservicemanager.py:85 INFO Remove services
12/15/05 15:10:49 956 ServiceManager agservicemanager.py:389 INFO AGServiceManager.RemoveServices
12/15/05 15:10:49 956 ServiceManager agservicemanager.py:330 INFO AGServiceManager.RemoveService
12/15/05 15:10:50 956 ServiceManager agservicemanager.py:330 INFO AGServiceManager.RemoveService
12/15/05 15:10:51 956 ServiceManager agservicemanager.py:330 INFO AGServiceManager.RemoveService
12/15/05 15:10:52 956 ProcessManager processmanager.py:133 WARNING Couldn't terminate process <PyHANDLE:952> cleanly (258)
12/15/05 15:10:52 956 ServiceManager agservicemanager.py:330 INFO AGServiceManager.RemoveService
12/15/05 15:10:52 956 ServiceManager agservicemanager.py:87 INFO Stop network interface
12/15/05 15:10:52 2552 Hosting server.py:65 ERROR Exception in SOAP server main loop
File "C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py", line 63, in Run
self._server.handle_request()
File "C:\Python23\lib\SocketServer.py", line 217, in handle_request
request, client_address = self.get_request()
File "C:\Python23\Lib\site-packages\SOAPpy\GSIServer.py", line 140, in get_request
sock, addr = ThreadingGSITCPSocketServer.get_request(self)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 525, in get_request
self.socket.listen()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 857, in listen
raise ex
GSITCPSocketException: an I/O operation was cancelled
12/15/05 15:10:52 956 Hosting server.py:97 ERROR server_close() failed
self.socket.close()
IOBase.close(self)
raise ex
self.socket.close()
IOBase.close(self)
raise ex
12/15/05 15:11:09 1148 Toolkit toolkit.py:96 DEBUG Initializing AG Toolkit version 2.4 (build 1)
12/15/05 15:11:09 1148 Toolkit toolkit.py:138 INFO Logfile Name: VenueClient.log
12/15/05 15:11:09 1148 Toolkit toolkit.py:205 WARNING Toolkit.__CheckForValidClock: The machine clock is incorrect on
your computer: it is 34 seconds fast with respect
to the time server at ntp-1.accessgrid.org.
12/15/05 15:11:09 1148 Toolkit config.py:219 ERROR Error setting globus hostname.
12/15/05 15:11:09 1148 Toolkit config.py:348 DEBUG retrieved local IP address 64.54.29.247
12/15/05 15:11:09 1148 CertificateManager certificatemanager.py:269 DEBUG Opened repository C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo
12/15/05 15:11:09 1148 Toolkit toolkit.py:404 DEBUG looking in system ca dir: C:\Program Files\AGTk-2.4\Config\CAcertificates
12/15/05 15:11:09 1148 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\1c3f2ca8.0 might be a cert
12/15/05 15:11:09 1148 Toolkit toolkit.py:440 INFO Certificate 1c3f2ca8.0 already in repository
12/15/05 15:11:09 1148 Toolkit toolkit.py:456 INFO Marking cert as CA cert
12/15/05 15:11:09 1148 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\a82c3f1c4b096b896061778ee79efeff\9c8df64aa35ebf832613413527bc073d\user_files\signing_policy
12/15/05 15:11:09 1148 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\45cc9e80.0 might be a cert
12/15/05 15:11:09 1148 Toolkit toolkit.py:440 INFO Certificate 45cc9e80.0 already in repository
12/15/05 15:11:09 1148 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\809ecc45460c1482e61e26bdfbf9e18c\9f380c9a586af2bb913ace809d5badfe\user_files\signing_policy
12/15/05 15:11:09 1148 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\d1b603c3.0 might be a cert
12/15/05 15:11:09 1148 Toolkit toolkit.py:440 INFO Certificate d1b603c3.0 already in repository
12/15/05 15:11:09 1148 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\c303b6d10c962b37482e68ca64d383a0\05a2039fe10ed1b4195d9f9d35b32c68\user_files\signing_policy
12/15/05 15:11:09 1148 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\f18fa857.0 might be a cert
12/15/05 15:11:09 1148 Toolkit toolkit.py:440 INFO Certificate f18fa857.0 already in repository
12/15/05 15:11:09 1148 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\57a88ff1707d87e926f2287c702a8466\eff65f03366cb8e20247f831ccc87fd5\user_files\signing_policy
12/15/05 15:11:09 1148 Toolkit toolkit.py:478 DEBUG Init'ing globus.
12/15/05 15:11:09 1148 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
12/15/05 15:11:09 1148 CertificateManager certificatemanager.py:827 DEBUG Using default identity /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:11:09 1148 CertificateManager certificatemanager.py:1083 DEBUG Initializing environment with unencrypted cert /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:11:09 1148 CertificateManager certificatemanager.py:1098 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\191c8500c5d893d758250b70098c95ce\38d6622212820902ad92145aa0bb0932\cert.pem to 644
12/15/05 15:11:09 1148 CertificateManager certificatemanager.py:1109 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\privatekeys\60fef24d87f80145a55c7bb89691fde6.pem to 600
12/15/05 15:11:09 1148 CertificateManagerWXGUI certificatemanagerwxgui.py:422 DEBUG done, success=1
12/15/05 15:11:09 1148 Toolkit toolkit.py:482 DEBUG Done with globus.
12/15/05 15:11:09 1148 Toolkit venueclient.py:83 INFO wx version is: 2.5.1.5
12/15/05 15:11:09 1148 VenueClient venueclient.py:287 DEBUG __StartWebService: venueclient: https://64.54.29.247:11000/VenueClient
12/15/05 15:11:09 1148 ServiceManager agservicemanager.py:75 INFO Using services dir: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services
12/15/05 15:11:09 1148 ServiceManager agservicemanager.py:424 INFO __DiscoverResources
12/15/05 15:11:09 1148 Toolkit config.py:997 INFO Using vfwscan to get devices
12/15/05 15:11:09 1148 Toolkit config.py:998 DEBUG vfwscanexe = C:\PROGRA~1\AGTk-2.4\bin\vfwscan.exe
12/15/05 15:11:09 1148 Toolkit config.py:1003 DEBUG filelines = ['Microsoft WDM Image Capture (Win32)\n']
12/15/05 15:11:09 1148 Toolkit config.py:1031 INFO GetResources: ['Microsoft WDM Image Capture (Win32)']
12/15/05 15:11:09 1148 VenueClient venueclient.py:296 DEBUG __StartWebService: service manager: https://64.54.29.247:11000/ServiceManager
12/15/05 15:11:09 1148 NodeService agnodeservice.py:756 INFO NodeService.__ReadConfigFile
12/15/05 15:11:09 1148 Toolkit toolkit.py:335 DEBUG Looking for: C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\AGNodeService.cfg
12/15/05 15:11:09 1148 NodeService agnodeservice.py:764 DEBUG DEFAULT NODE SERVICE CONFIG: C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\AGNodeService.cfg
12/15/05 15:11:09 1148 NodeService agnodeservice.py:768 INFO Reading node service config file: C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\AGNodeService.cfg
12/15/05 15:11:09 1148 VenueClient venueclient.py:302 DEBUG __StartWebService: node service: https://64.54.29.247:11000/NodeService
12/15/05 15:11:09 1148 VenueClient venueclient.py:1328 DEBUG SerNodeUrl: Set node service url: https://64.54.29.247:11000/NodeService
12/15/05 15:11:09 1148 NodeService agnodeservice.py:698 INFO NodeService.GetDefaultConfiguration
12/15/05 15:11:09 1148 NodeService agnodeservice.py:581 INFO Migration unnecessary
12/15/05 15:11:09 1148 NodeService agnodeservice.py:374 INFO NodeService.LoadDefaultConfig
12/15/05 15:11:09 1148 NodeService agnodeservice.py:378 INFO Loading default node configuration: UCSF CB Micro Lab
12/15/05 15:11:09 1148 NodeService agnodeservice.py:392 INFO NodeService.LoadConfiguration
12/15/05 15:11:09 1148 NodeService agnodeservice.py:407 INFO Trying to load node configuration from: C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\nodeConfig\UCSF CB Micro Lab
12/15/05 15:11:10 2332 ServiceManager agservicemanager.py:389 INFO AGServiceManager.RemoveServices
12/15/05 15:11:10 3256 ServiceManager agservicemanager.py:115 INFO AGServiceManager.AddService
12/15/05 15:11:10 3256 ServiceManager agservicemanager.py:118 INFO AddService: AudioService v 2.420000 u AudioService.zip
12/15/05 15:11:10 3256 ServiceManager agservicemanager.py:121 INFO resourceToAssign:
12/15/05 15:11:10 3256 ServiceManager agservicemanager.py:147 DEBUG ** Resource does not exist! :
12/15/05 15:11:10 3256 ServiceManager agservicemanager.py:186 INFO Retaining version 2.420000
12/15/05 15:11:10 3256 ServiceManager agservicemanager.py:189 INFO Extracting service package to C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService
12/15/05 15:11:10 3256 ServiceManager agservicemanager.py:237 INFO Running Service; options: C:\Python23\pythonw.exe [u'C:\\Documents and Settings\\mvideo\\Application Data\\AccessGrid\\local_services\\AudioService\\AudioService.py', 62368]
12/15/05 15:11:10 3256 ProcessManager processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\AudioService\AudioService.py" 62368
12/15/05 15:11:10 3256 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x0165494C>, <PyHANDLE object at 0x01654864>, 3540, 2548)
12/15/05 15:11:10 3256 ServiceManager agservicemanager.py:258 DEBUG Waiting for service to start: AudioService https://64.54.29.247:62368/Service
12/15/05 15:11:12 3256 ServiceManager agservicemanager.py:265 INFO Service AudioService successfully started
12/15/05 15:11:12 3256 ServiceManager agservicemanager.py:297 INFO Setting service configuration
12/15/05 15:11:13 3256 ServiceManager agservicemanager.py:309 DEBUG Not assigning resource; none given
12/15/05 15:11:13 1148 NodeService agnodeservice.py:515 INFO Not setting identity for service AudioService; no profile
12/15/05 15:11:13 3564 ServiceManager agservicemanager.py:115 INFO AGServiceManager.AddService
12/15/05 15:11:13 3564 ServiceManager agservicemanager.py:118 INFO AddService: VideoConsumerService v 2.330000 u VideoConsumerService.zip
12/15/05 15:11:13 3564 ServiceManager agservicemanager.py:121 INFO resourceToAssign:
12/15/05 15:11:13 3564 ServiceManager agservicemanager.py:147 DEBUG ** Resource does not exist! :
12/15/05 15:11:13 3564 ServiceManager agservicemanager.py:186 INFO Retaining version 2.330000
12/15/05 15:11:13 3564 ServiceManager agservicemanager.py:189 INFO Extracting service package to C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoConsumerService
12/15/05 15:11:13 3564 ServiceManager agservicemanager.py:237 INFO Running Service; options: C:\Python23\pythonw.exe [u'C:\\Documents and Settings\\mvideo\\Application Data\\AccessGrid\\local_services\\VideoConsumerService\\VideoConsumerService.py', 52200]
12/15/05 15:11:13 3564 ProcessManager processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoConsumerService\VideoConsumerService.py" 52200
12/15/05 15:11:13 3564 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x016ABA0C>, <PyHANDLE object at 0x016365EC>, 3428, 3412)
12/15/05 15:11:13 3564 ServiceManager agservicemanager.py:258 DEBUG Waiting for service to start: VideoConsumerService https://64.54.29.247:52200/Service
12/15/05 15:11:15 3564 ServiceManager agservicemanager.py:265 INFO Service VideoConsumerService successfully started
12/15/05 15:11:15 3564 ServiceManager agservicemanager.py:300 DEBUG Not setting service configuration; none given
12/15/05 15:11:15 3564 ServiceManager agservicemanager.py:309 DEBUG Not assigning resource; none given
12/15/05 15:11:15 1148 NodeService agnodeservice.py:515 INFO Not setting identity for service VideoConsumerService; no profile
12/15/05 15:11:16 3700 ServiceManager agservicemanager.py:115 INFO AGServiceManager.AddService
12/15/05 15:11:16 3700 ServiceManager agservicemanager.py:118 INFO AddService: VideoProducerService v 2.540000 u VideoProducerService.zip
12/15/05 15:11:16 3700 ServiceManager agservicemanager.py:121 INFO resourceToAssign: Microsoft WDM Image Capture (Win32)
12/15/05 15:11:16 3700 ServiceManager agservicemanager.py:186 INFO Retaining version 2.540000
12/15/05 15:11:16 3700 ServiceManager agservicemanager.py:189 INFO Extracting service package to C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoProducerService
12/15/05 15:11:16 3700 ServiceManager agservicemanager.py:237 INFO Running Service; options: C:\Python23\pythonw.exe [u'C:\\Documents and Settings\\mvideo\\Application Data\\AccessGrid\\local_services\\VideoProducerService\\VideoProducerService.py', 56690]
12/15/05 15:11:16 3700 ProcessManager processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoProducerService\VideoProducerService.py" 56690
12/15/05 15:11:16 3700 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x01656744>, <PyHANDLE object at 0x016547CC>, 496, 4056)
12/15/05 15:11:16 3700 ServiceManager agservicemanager.py:258 DEBUG Waiting for service to start: VideoProducerService https://64.54.29.247:56690/Service
12/15/05 15:11:18 3700 ServiceManager agservicemanager.py:265 INFO Service VideoProducerService successfully started
12/15/05 15:11:18 3700 ServiceManager agservicemanager.py:297 INFO Setting service configuration
12/15/05 15:11:18 3700 ServiceManager agservicemanager.py:306 INFO Assigning resource to service: Microsoft WDM Image Capture (Win32)
12/15/05 15:11:18 1148 NodeService agnodeservice.py:515 INFO Not setting identity for service VideoProducerService; no profile
12/15/05 15:11:19 2648 ServiceManager agservicemanager.py:115 INFO AGServiceManager.AddService
12/15/05 15:11:19 2648 ServiceManager agservicemanager.py:118 INFO AddService: VideoProducerService v 2.540000 u VideoProducerService.zip
12/15/05 15:11:19 2648 ServiceManager agservicemanager.py:121 INFO resourceToAssign: Microsoft WDM Image Capture (Win32)
12/15/05 15:11:19 2648 ServiceManager agservicemanager.py:186 INFO Retaining version 2.540000
12/15/05 15:11:19 2648 ServiceManager agservicemanager.py:189 INFO Extracting service package to C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoProducerService
12/15/05 15:11:19 2648 ServiceManager agservicemanager.py:237 INFO Running Service; options: C:\Python23\pythonw.exe [u'C:\\Documents and Settings\\mvideo\\Application Data\\AccessGrid\\local_services\\VideoProducerService\\VideoProducerService.py', 60536]
12/15/05 15:11:19 2648 ProcessManager processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoProducerService\VideoProducerService.py" 60536
12/15/05 15:11:19 2648 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x016A74C4>, <PyHANDLE object at 0x016A7634>, 3384, 1392)
12/15/05 15:11:19 2648 ServiceManager agservicemanager.py:258 DEBUG Waiting for service to start: VideoProducerService https://64.54.29.247:60536/Service
12/15/05 15:11:21 2648 ServiceManager agservicemanager.py:265 INFO Service VideoProducerService successfully started
12/15/05 15:11:21 2648 ServiceManager agservicemanager.py:297 INFO Setting service configuration
12/15/05 15:11:21 2648 ServiceManager agservicemanager.py:306 INFO Assigning resource to service: Microsoft WDM Image Capture (Win32)
12/15/05 15:11:21 1148 NodeService agnodeservice.py:515 INFO Not setting identity for service VideoProducerService; no profile
12/15/05 15:11:21 1148 VenueClient venueclient.py:185 DEBUG __createPersonalDataStore: Creating personal datastore at C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\personalDataStore using prefix personalDataStore and port 0
12/15/05 15:11:21 1148 DataStore datastore.py:1537 DEBUG Creating thread 0
12/15/05 15:11:21 1148 DataStore datastore.py:1542 DEBUG Starting thread 0
12/15/05 15:11:21 1148 DataStore datastore.py:1544 DEBUG Waiting thread 0
12/15/05 15:11:21 3536 DataStore datastore.py:1550 DEBUG Worker 0 starting
12/15/05 15:11:21 1148 DataStore datastore.py:1547 DEBUG Done creating workers
12/15/05 15:11:21 1148 DataStore datastore.py:278 DEBUG Reading persisted data from: C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\personalDataStore\DataStore.dat
12/15/05 15:11:21 1148 VenueClient venueclient.py:210 DEBUG __createPersonalDataStore: Load personal data from file
12/15/05 15:11:21 1148 VenueClientController venueclientcontroller.py:1255 DEBUG There is no personal venues file to load.
12/15/05 15:11:30 1148 VenueClient venueclient.py:805 DEBUG EnterVenue; url=https://64.54.29.247:8000/Venues/default
12/15/05 15:11:30 3504 NodeService agnodeservice.py:715 INFO NodeService.GetCapabilities
12/15/05 15:11:30 3504 NodeService agnodeservice.py:256 INFO NodeService.GetServices
12/15/05 15:11:31 672 ServiceManager agservicemanager.py:399 INFO AGServiceManager.GetServices
12/15/05 15:11:32 1148 VenueClient venueclient.py:705 DEBUG EnterVenue: Invoke venue enter
12/15/05 15:11:32 1148 EventClient eventclient.py:158 DEBUG Have callback handle _c07f0c02_p_callbackStruct
12/15/05 15:11:32 1148 VenueClient venueclient.py:780 DEBUG Setting isInVenue flag.
12/15/05 15:11:32 1148 VenueClient venueclient.py:999 DEBUG UpdateNodeService: Method UpdateNodeService called
12/15/05 15:11:32 3712 NodeService agnodeservice.py:734 INFO NodeService.SetIdentity UCSF China Basin Microbilogy terrazas at labmed2.ucsf.edu
12/15/05 15:11:32 3712 NodeService agnodeservice.py:256 INFO NodeService.GetServices
12/15/05 15:11:33 1816 ServiceManager agservicemanager.py:399 INFO AGServiceManager.GetServices
12/15/05 15:11:34 1148 VenueClient venueclient.py:1046 DEBUG UpdateStream: Setting stream 000001082bd694b300400036001d00f7724 to multicast
12/15/05 15:11:34 1148 VenueClient venueclient.py:1046 DEBUG UpdateStream: Setting stream 0000010830b14dd800400036001d00f734c to multicast
12/15/05 15:11:34 3340 NodeService agnodeservice.py:325 INFO NodeService.SetStreams
12/15/05 15:11:34 3340 NodeService agnodeservice.py:256 INFO NodeService.GetServices
12/15/05 15:11:34 1872 ServiceManager agservicemanager.py:399 INFO AGServiceManager.GetServices
12/15/05 15:11:34 3340 NodeService agnodeservice.py:805 INFO NodeService.__SendStreamsToService
12/15/05 15:11:34 3340 NodeService agnodeservice.py:815 INFO Sending stream (type=audio) to service: https://64.54.29.247:62368/Service
12/15/05 15:11:35 3340 NodeService agnodeservice.py:805 INFO NodeService.__SendStreamsToService
12/15/05 15:11:35 3340 NodeService agnodeservice.py:815 INFO Sending stream (type=video) to service: https://64.54.29.247:52200/Service
12/15/05 15:11:36 3340 NodeService agnodeservice.py:815 INFO Sending stream (type=video) to service: https://64.54.29.247:56690/Service
12/15/05 15:11:36 3340 NodeService agnodeservice.py:805 INFO NodeService.__SendStreamsToService
12/15/05 15:11:36 3340 NodeService agnodeservice.py:815 INFO Sending stream (type=video) to service: https://64.54.29.247:60536/Service
12/15/05 15:11:37 1148 VenueClient venueclient.py:840 DEBUG Updating client profile cache.
12/15/05 15:11:37 1148 VenueClient venueclientui.py:1925 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://64.54.29.247:8000/Venues/default
12/15/05 15:11:37 1148 VenueClient venueclientui.py:2034 DEBUG Entered venue
12/15/05 15:11:37 1148 VenueClient venueclientui.py:2623 DEBUG ContentListPanel.AddParticipant:: AddParticipant UCSF China Basin Microbilogy (called from ('C:\\Python23\\Lib\\site-packages\\wx\\core.py', 9397, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
12/15/05 15:16:20 1148 CertificateRequestTool certificaterequesttool.py:78 DEBUG __init__:Start Certificate Request Wizard
12/15/05 15:16:20 1148 CertificateRequestTool certificaterequesttool.py:93 DEBUG __init__:Set the initial order of the pages
12/15/05 15:16:20 1148 CertificateRequestTool certificaterequesttool.py:108 DEBUG __init__:Handle arguments for certificate type
12/15/05 15:16:20 1148 CertificateRequestTool certificaterequesttool.py:139 DEBUG __init__:Create the pages
12/15/05 15:16:20 1148 CertificateRequestTool certificaterequesttool.py:144 DEBUG __init__:Run the wizard
12/15/05 15:16:22 1148 CertificateRequestTool certificaterequesttool.py:167 DEBUG ChangingPage: From <class 'AccessGrid.Security.wxgui.CertificateRequestTool.IntroWindow'> to <class 'AccessGrid.Security.wxgui.CertificateRequestTool.SelectCertWindow'>
12/15/05 15:16:22 1148 CertificateRequestTool certificaterequesttool.py:174 DEBUG ChangingPage:Values are correct
12/15/05 15:16:29 1148 CertificateRequestTool certificaterequesttool.py:149 DEBUG CancelPage:Cancel wizard
12/15/05 15:17:00 1148 VenueClient venueclient.py:1256 DEBUG GetPersonalData: I am trying to get my own data
12/15/05 15:19:50 1148 VenueClient venueclientui.py:3871 DEBUG VenueClientUI.py: Set editable in successfully dialog
12/15/05 15:19:50 1148 VenueClient venueclientui.py:3942 DEBUG ProfileDialog.SetProfile: Set profile information successfully in dialog
12/15/05 15:19:54 2980 EventClient eventclient.py:177 DEBUG Read Callback called arg=None handle=_404a0602_p_globus_io_handle_t result=(0, None, None) n=4
12/15/05 15:19:54 2980 EventClient eventclient.py:229 DEBUG Freeing callback _c07f0c02_p_callbackStruct within callback
12/15/05 15:19:54 2980 EventClient eventclient.py:238 DEBUG Have new callback handle _70790502_p_callbackStruct
12/15/05 15:19:54 2980 EventClient eventclient.py:177 DEBUG Read Callback called arg=None handle=_404a0602_p_globus_io_handle_t result=(0, None, None) n=1689
12/15/05 15:19:54 2980 EventClient eventclient.py:218 DEBUG finally read enough data, wait=1689 buflen=1689
12/15/05 15:19:54 2980 EventClient eventclient.py:253 DEBUG Invoking callback <bound method VenueClient.AddUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0x00E6FD50>>...
12/15/05 15:19:54 2980 EventClient eventclient.py:259 DEBUG Invoking callback <bound method VenueClient.AddUserEvent of <AccessGrid.VenueClient.VenueClient instance at 0x00E6FD50>>...done
12/15/05 15:19:54 3208 VenueClient venueclient.py:425 DEBUG AddUserEvent: Got Add User Event
12/15/05 15:19:54 2980 EventClient eventclient.py:261 INFO No callback for Enter!
12/15/05 15:19:54 2980 EventClient eventclient.py:329 INFO Got callback for Enter event!
12/15/05 15:19:54 2980 EventClient eventclient.py:224 DEBUG handleData returns
12/15/05 15:19:54 2980 EventClient eventclient.py:229 DEBUG Freeing callback _70790502_p_callbackStruct within callback
12/15/05 15:19:54 3208 VenueClient venueclientui.py:1647 DEBUG add user: Enrique Terrazas
12/15/05 15:19:54 1148 VenueClient venueclientui.py:2623 DEBUG ContentListPanel.AddParticipant:: AddParticipant Enrique Terrazas (called from ('C:\\Python23\\Lib\\site-packages\\wx\\core.py', 9397, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
12/15/05 15:20:23 2980 VenueClient venueclient.py:654 DEBUG TextEvent: Got Text Event
12/15/05 15:20:33 1148 VenueClient venueclientui.py:3522 DEBUG TextClientPanel.LocalInput: User writes: yes!i see youin the list of participants
12/15/05 15:20:33 2980 VenueClient venueclient.py:654 DEBUG TextEvent: Got Text Event
12/15/05 15:20:38 1148 VenueClient venueclientui.py:3522 DEBUG TextClientPanel.LocalInput: User writes: but no video or audio from you yet...
12/15/05 15:20:38 2980 VenueClient venueclient.py:654 DEBUG TextEvent: Got Text Event
12/15/05 15:20:46 2980 VenueClient venueclient.py:654 DEBUG TextEvent: Got Text Event
12/15/05 15:20:56 1148 VenueClient venueclientui.py:3522 DEBUG TextClientPanel.LocalInput: User writes: ah -- vic did not just start???
12/15/05 15:20:56 2980 VenueClient venueclient.py:654 DEBUG TextEvent: Got Text Event
12/15/05 15:21:01 2980 VenueClient venueclient.py:654 DEBUG TextEvent: Got Text Event
12/15/05 15:21:03 1148 VenueClient venueclientui.py:3522 DEBUG TextClientPanel.LocalInput: User writes: it shoudl just start - as shoudl rat
12/15/05 15:21:03 2980 VenueClient venueclient.py:654 DEBUG TextEvent: Got Text Event
12/15/05 15:21:13 1148 VenueClient venueclientui.py:3522 DEBUG TextClientPanel.LocalInput: User writes: ok we've gotta figure that one out then :)
12/15/05 15:21:13 2980 VenueClient venueclient.py:654 DEBUG TextEvent: Got Text Event
12/15/05 15:21:20 2980 VenueClient venueclient.py:654 DEBUG TextEvent: Got Text Event
12/15/05 15:21:31 1148 VenueClient venueclientui.py:3522 DEBUG TextClientPanel.LocalInput: User writes: do you have 2.4 insdtalle? iwoudl do that for sure
12/15/05 15:21:31 2980 VenueClient venueclient.py:654 DEBUG TextEvent: Got Text Event
12/15/05 15:21:37 1148 VenueClient venueclientui.py:3522 DEBUG TextClientPanel.LocalInput: User writes: but i doubt it will fix this problem
12/15/05 15:21:37 2980 VenueClient venueclient.py:654 DEBUG TextEvent: Got Text Event
12/15/05 15:21:39 2980 VenueClient venueclient.py:654 DEBUG TextEvent: Got Text Event
12/15/05 15:21:47 1148 VenueClient venueclientui.py:3522 DEBUG TextClientPanel.LocalInput: User writes: wanna do 2.4 now?
12/15/05 15:21:47 2980 VenueClient venueclient.py:654 DEBUG TextEvent: Got Text Event
12/15/05 15:22:02 1148 VenueClient venueclientui.py:3522 DEBUG TextClientPanel.LocalInput: User writes: im still stuick with the server config. here
12/15/05 15:22:02 2980 VenueClient venueclient.py:654 DEBUG TextEvent: Got Text Event
12/15/05 15:22:20 1148 VenueClient venueclientui.py:3522 DEBUG TextClientPanel.LocalInput: User writes: seems we are not talking to the server that we configured :)
12/15/05 15:22:20 2980 VenueClient venueclient.py:654 DEBUG TextEvent: Got Text Event
12/15/05 15:22:45 2980 VenueClient venueclient.py:654 DEBUG TextEvent: Got Text Event
12/15/05 15:23:03 1148 VenueClient venueclientui.py:3522 DEBUG TextClientPanel.LocalInput: User writes: www.accessgrid.org - look for software link
12/15/05 15:23:03 2980 VenueClient venueclient.py:654 DEBUG TextEvent: Got Text Event
12/15/05 15:23:49 1148 VenueClient venueclientui.py:3522 DEBUG TextClientPanel.LocalInput: User writes: im going to take server dowm for a min - brb
12/15/05 15:23:49 2980 VenueClient venueclient.py:654 DEBUG TextEvent: Got Text Event
12/15/05 15:24:08 2980 EventClient eventclient.py:177 DEBUG Read Callback called arg=None handle=_404a0602_p_globus_io_handle_t result=(-1, 37, 'a system call failed (Unknown error)') n=0
12/15/05 15:24:08 2980 EventClient eventclient.py:180 DEBUG readCallback gets failure in result: -1 37
12/15/05 15:24:12 1600 EventClient eventclient.py:281 ERROR Attempting to send on a disconnected EventClient
12/15/05 15:24:12 1600 VenueClient venueclient.py:354 ERROR Heartbeat: Heartbeat exception is caught.
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 352, in __Heartbeat
self.privateId))
File "C:\Python23\Lib\site-packages\AccessGrid\EventClient.py", line 282, in Send
raise EventClientWriteDataException
12/15/05 15:24:12 1600 VenueClient venueclient.py:368 INFO Try to reconnect to venue
12/15/05 15:24:12 1600 VenueClient venueclient.py:895 INFO ExitVenue: Stopping heartbeats
12/15/05 15:24:13 1600 VenueClient venueclient.py:670 DEBUG SOAP FAULT: httpg://64.54.29.247:8000/Venues/default a system call failed (Invalid argument)
12/15/05 15:24:13 1600 VenueClient venueclient.py:672 ERROR SOAP fault occurred
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 347, in __call
config = self.config)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 187, in call
r.endheaders()
File "C:\Python23\lib\httplib.py", line 712, in endheaders
self._send_output()
File "C:\Python23\lib\httplib.py", line 597, in _send_output
self.send(msg)
File "C:\Python23\lib\httplib.py", line 564, in send
self.connect()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1093, in connect
self.sock.connect(self.host, self.port, self.io_attr)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 671, in connect
raise ex
GSITCPSocketException: a system call failed (Invalid argument)
12/15/05 15:24:13 1600 VenueClient venueclient.py:902 ERROR ExitVenue: ExitVenue exception
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 899, in __ExitVenue
self.__venueProxy.Exit( self.privateId )
File "C:\Python23\Lib\site-packages\AccessGrid\Venue.py", line 3519, in Exit
return self.proxy.Exit(pid)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453, in __call__
return self.__r_call(*args, **kw)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475, in __r_call
self.__hd, self.__ma)
r.endheaders()
self._send_output()
self.send(msg)
self.connect()
raise ex
12/15/05 15:24:13 1600 VenueClient venueclient.py:906 DEBUG ExitVenue: Stop event client obj
12/15/05 15:24:13 1600 EventClient eventclient.py:303 DEBUG Cancel pending callbacks
12/15/05 15:24:13 1600 EventClient eventclient.py:309 DEBUG Free callback _70790502_p_callbackStruct
12/15/05 15:24:13 1600 EventClient eventclient.py:315 DEBUG EventClient.Stop: closing socket
12/15/05 15:24:13 1600 EventClient eventclient.py:323 DEBUG EventClient.Stop: closing queue
12/15/05 15:24:13 1600 VenueClient venueclient.py:908 DEBUG ExitVenue: Remove event client reference
12/15/05 15:24:13 1600 VenueClient venueclient.py:913 INFO ExitVenue: Stopping text client
12/15/05 15:24:13 1600 VenueClient venueclient.py:917 DEBUG ExitVenue: Sending client disconnect event.
12/15/05 15:24:13 1600 VenueClient venueclient.py:924 ERROR ExitVenue: On text client exiting
self.privateId)
File "C:\Python23\Lib\site-packages\AccessGrid\TextClient.py", line 171, in Write
self.wfile.write(size)
raise ex
IOBaseException: a system call failed (Invalid argument)
12/15/05 15:24:13 1600 VenueClient venueclient.py:705 DEBUG EnterVenue: Invoke venue enter
12/15/05 15:24:14 1600 VenueClient venueclient.py:670 DEBUG SOAP FAULT: httpg://64.54.29.247:8000/Venues/default a system call failed (Invalid argument)
12/15/05 15:24:14 1600 VenueClient venueclient.py:672 ERROR SOAP fault occurred
r.endheaders()
self._send_output()
self.send(msg)
self.connect()
raise ex
12/15/05 15:24:14 1600 VenueClient venueclient.py:392 ERROR Exception reconnecting to venue
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 385, in __Reconnect
self.__EnterVenue(venueUri)
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 706, in __EnterVenue
(venueState, self.privateId, self.streamDescList ) = self.__venueProxy.Enter( self.profile )
File "C:\Python23\Lib\site-packages\AccessGrid\Venue.py", line 3499, in Enter
(r1, r2, r3) = self.proxy.Enter(profile)
r.endheaders()
self._send_output()
self.send(msg)
self.connect()
raise ex
12/15/05 15:24:14 1148 VenueClient venueclientui.py:1565 INFO --------- END VenueClient
12/15/05 15:24:14 1148 DataStore datastore.py:1614 DEBUG Quitting thread 0
12/15/05 15:24:14 3536 DataStore datastore.py:1555 DEBUG Worker 0 gets cmd quit
12/15/05 15:24:14 3536 DataStore datastore.py:1568 DEBUG Worker 0 exiting
12/15/05 15:24:14 776 DataStore datastore.py:1627 INFO GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation, most likely shutting down.
12/15/05 15:24:14 1148 NodeService agnodeservice.py:136 INFO NodeService.Stop
12/15/05 15:24:14 1148 ServiceManager agservicemanager.py:84 INFO AGServiceManager.Shutdown
12/15/05 15:24:14 1148 ServiceManager agservicemanager.py:85 INFO Remove services
12/15/05 15:24:14 1148 ServiceManager agservicemanager.py:389 INFO AGServiceManager.RemoveServices
12/15/05 15:24:14 1148 ServiceManager agservicemanager.py:330 INFO AGServiceManager.RemoveService
12/15/05 15:24:15 1148 ProcessManager processmanager.py:133 WARNING Couldn't terminate process <PyHANDLE:872> cleanly (258)
12/15/05 15:24:15 1148 ServiceManager agservicemanager.py:330 INFO AGServiceManager.RemoveService
12/15/05 15:24:17 1148 ProcessManager processmanager.py:133 WARNING Couldn't terminate process <PyHANDLE:892> cleanly (258)
12/15/05 15:24:17 1148 ServiceManager agservicemanager.py:330 INFO AGServiceManager.RemoveService
12/15/05 15:24:18 1148 ServiceManager agservicemanager.py:87 INFO Stop network interface
12/15/05 15:24:18 2788 Hosting server.py:65 ERROR Exception in SOAP server main loop
raise ex
12/15/05 15:24:18 1148 Hosting server.py:97 ERROR server_close() failed
self.socket.close()
IOBase.close(self)
raise ex
self.socket.close()
IOBase.close(self)
raise ex
12/14/05 16:31:25 3492 VenueManagement venuemanagement.py:238 DEBUG There is no my servers file to load.
12/14/05 16:31:25 3492 Toolkit toolkit.py:96 DEBUG Initializing AG Toolkit version 2.4 (build 1)
12/14/05 16:31:26 3492 Toolkit toolkit.py:138 INFO Logfile Name: VenueManagement.log
12/14/05 16:31:26 3492 Toolkit toolkit.py:205 WARNING Toolkit.__CheckForValidClock: The machine clock is incorrect on
12/14/05 16:31:26 3492 Toolkit config.py:219 ERROR Error setting globus hostname.
File "C:\Python23\Lib\site-packages\AccessGrid\Config.py", line 212, in SetHostname
sock.bind((hostname, 0))
File "<string>", line 1, in bind
gaierror: (7, 'getaddrinfo failed')
12/14/05 16:31:26 3492 Toolkit config.py:348 DEBUG retrieved local IP address 64.54.29.247
12/14/05 16:31:26 3492 CertificateManager certificatemanager.py:269 DEBUG Opened repository C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo
12/14/05 16:31:26 3492 Toolkit toolkit.py:404 DEBUG looking in system ca dir: C:\Program Files\AGTk-2.4\Config\CAcertificates
12/14/05 16:31:26 3492 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\1c3f2ca8.0 might be a cert
12/14/05 16:31:26 3492 Toolkit toolkit.py:440 INFO Certificate 1c3f2ca8.0 already in repository
12/14/05 16:31:26 3492 Toolkit toolkit.py:456 INFO Marking cert as CA cert
12/14/05 16:31:26 3492 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\a82c3f1c4b096b896061778ee79efeff\9c8df64aa35ebf832613413527bc073d\user_files\signing_policy
12/14/05 16:31:26 3492 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\45cc9e80.0 might be a cert
12/14/05 16:31:26 3492 Toolkit toolkit.py:440 INFO Certificate 45cc9e80.0 already in repository
12/14/05 16:31:26 3492 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\809ecc45460c1482e61e26bdfbf9e18c\9f380c9a586af2bb913ace809d5badfe\user_files\signing_policy
12/14/05 16:31:26 3492 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\d1b603c3.0 might be a cert
12/14/05 16:31:26 3492 Toolkit toolkit.py:440 INFO Certificate d1b603c3.0 already in repository
12/14/05 16:31:26 3492 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\c303b6d10c962b37482e68ca64d383a0\05a2039fe10ed1b4195d9f9d35b32c68\user_files\signing_policy
12/14/05 16:31:26 3492 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\f18fa857.0 might be a cert
12/14/05 16:31:26 3492 Toolkit toolkit.py:440 INFO Certificate f18fa857.0 already in repository
12/14/05 16:31:26 3492 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\57a88ff1707d87e926f2287c702a8466\eff65f03366cb8e20247f831ccc87fd5\user_files\signing_policy
12/14/05 16:31:26 3492 Toolkit toolkit.py:478 DEBUG Init'ing globus.
12/14/05 16:31:26 3492 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
12/14/05 16:31:26 3492 CertificateManager certificatemanager.py:827 DEBUG Using default identity /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:31:26 3492 CertificateManager certificatemanager.py:1083 DEBUG Initializing environment with unencrypted cert /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:31:26 3492 CertificateManager certificatemanager.py:1098 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\191c8500c5d893d758250b70098c95ce\38d6622212820902ad92145aa0bb0932\cert.pem to 644
12/14/05 16:31:26 3492 CertificateManager certificatemanager.py:1109 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\privatekeys\60fef24d87f80145a55c7bb89691fde6.pem to 600
12/14/05 16:31:26 3492 CertificateManagerWXGUI certificatemanagerwxgui.py:422 DEBUG done, success=1
12/14/05 16:31:26 3492 Toolkit toolkit.py:482 DEBUG Done with globus.
12/14/05 16:31:39 3492 VenueManagement venuemanagement.py:430 DEBUG VenueManagementClient.ConnectToServer: Connect to server https://localhost/VenueServer
12/14/05 16:31:39 3492 VenueManagement venuemanagement.py:438 DEBUG VenueManagementClient.ConnectToServer: Connect to server
12/14/05 16:31:39 3492 VenueManagement venuemanagement.py:440 DEBUG VenueManagementClient.ConnectToServer: Get venues from server
12/14/05 16:31:39 3492 VenueManagement venuemanagement.py:462 DEBUG VenueManagementClient.ConnectToServer: Add venue UCSF Lab Med Lobby
12/14/05 16:31:39 3492 VenueManagement venuemanagement.py:462 DEBUG VenueManagementClient.ConnectToServer: Add venue Test Room
12/14/05 16:31:39 3492 VenueManagement venuemanagement.py:462 DEBUG VenueManagementClient.ConnectToServer: Add venue Conferences
12/14/05 16:31:39 3492 VenueManagement venuemanagement.py:462 DEBUG VenueManagementClient.ConnectToServer: Add venue ID Rounds
12/14/05 16:31:39 3492 VenueManagement venuemanagement.py:541 DEBUG VenueManagementClient.SetCurrentVenue: Set current venue to: Conferences, https://64.54.29.247:8000/Venues/000001067b15fcfc00400036001d00f7ea5
12/14/05 16:31:40 3492 VenueManagement venuemanagement.py:486 DEBUG VenueManagementClient.ConnectToServer: Set multicast address to: RANDOM
12/14/05 16:31:40 3492 VenueManagement venuemanagement.py:503 DEBUG VenueManagementClient.ConnectToServer: Set server encryption key: 1
12/14/05 16:31:46 3492 VenueManagement venuemanagement.py:857 DEBUG VenueListPanel: EvtListBox: Change current venue
12/14/05 16:31:46 3492 VenueManagement venuemanagement.py:541 DEBUG VenueManagementClient.SetCurrentVenue: Set current venue to: ID Rounds, https://64.54.29.247:8000/Venues/000001067b154e9c00400036001d00f7385
12/14/05 16:32:06 3492 VenueManagement venuemanagement.py:1205 DEBUG DetailPanel.ClickedOnInterval: Set multicast address to interval
12/14/05 16:32:06 3492 VenueManagement venuemanagement.py:578 DEBUG VenueManagementClient.SetInterval: Set interval address allocation method with address: 224.2.128.0, mask: 17
12/14/05 16:32:07 3492 VenueManagement venuemanagement.py:1174 DEBUG DetailPanel.ClickedOnRandom: Set multicast address to random
12/14/05 16:32:07 3492 VenueManagement venuemanagement.py:574 DEBUG VenueManagementClient.SetRandom: Set random address allocation method
12/14/05 16:32:15 3492 VenueManagement venuemanagement.py:2199 DEBUG ModifyVenueFrame.__loadCurrentVenueInfo: Get venue information
12/14/05 16:32:16 3492 VenueManagement venuemanagement.py:2214 DEBUG ModifyVenueFrame.__loadCurrentVenueInfo: We have a key Rijndael/bfdb0b8
12/14/05 16:32:16 3492 VenueManagement venuemanagement.py:2225 DEBUG ModifyVenueFrame.__loadCurrentVenueInfo: No static streams to load
12/14/05 16:32:16 3492 VenueManagement venuemanagement.py:1587 DEBUG VenueParamFrame.__LoadVenues: Load venues from: https://localhost/VenueServer
12/15/05 15:13:30 3680 VenueManagement venuemanagement.py:238 DEBUG There is no my servers file to load.
12/15/05 15:13:30 3680 Toolkit toolkit.py:96 DEBUG Initializing AG Toolkit version 2.4 (build 1)
12/15/05 15:13:30 3680 Toolkit toolkit.py:138 INFO Logfile Name: VenueManagement.log
12/15/05 15:13:30 3680 Toolkit toolkit.py:205 WARNING Toolkit.__CheckForValidClock: The machine clock is incorrect on
12/15/05 15:13:30 3680 Toolkit config.py:219 ERROR Error setting globus hostname.
12/15/05 15:13:30 3680 Toolkit config.py:348 DEBUG retrieved local IP address 64.54.29.247
12/15/05 15:13:30 3680 CertificateManager certificatemanager.py:269 DEBUG Opened repository C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo
12/15/05 15:13:30 3680 Toolkit toolkit.py:404 DEBUG looking in system ca dir: C:\Program Files\AGTk-2.4\Config\CAcertificates
12/15/05 15:13:30 3680 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\1c3f2ca8.0 might be a cert
12/15/05 15:13:30 3680 Toolkit toolkit.py:440 INFO Certificate 1c3f2ca8.0 already in repository
12/15/05 15:13:30 3680 Toolkit toolkit.py:456 INFO Marking cert as CA cert
12/15/05 15:13:30 3680 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\a82c3f1c4b096b896061778ee79efeff\9c8df64aa35ebf832613413527bc073d\user_files\signing_policy
12/15/05 15:13:30 3680 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\45cc9e80.0 might be a cert
12/15/05 15:13:30 3680 Toolkit toolkit.py:440 INFO Certificate 45cc9e80.0 already in repository
12/15/05 15:13:30 3680 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\809ecc45460c1482e61e26bdfbf9e18c\9f380c9a586af2bb913ace809d5badfe\user_files\signing_policy
12/15/05 15:13:30 3680 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\d1b603c3.0 might be a cert
12/15/05 15:13:30 3680 Toolkit toolkit.py:440 INFO Certificate d1b603c3.0 already in repository
12/15/05 15:13:30 3680 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\c303b6d10c962b37482e68ca64d383a0\05a2039fe10ed1b4195d9f9d35b32c68\user_files\signing_policy
12/15/05 15:13:30 3680 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\f18fa857.0 might be a cert
12/15/05 15:13:30 3680 Toolkit toolkit.py:440 INFO Certificate f18fa857.0 already in repository
12/15/05 15:13:30 3680 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\57a88ff1707d87e926f2287c702a8466\eff65f03366cb8e20247f831ccc87fd5\user_files\signing_policy
12/15/05 15:13:30 3680 Toolkit toolkit.py:478 DEBUG Init'ing globus.
12/15/05 15:13:30 3680 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
12/15/05 15:13:30 3680 CertificateManager certificatemanager.py:827 DEBUG Using default identity /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:13:30 3680 CertificateManager certificatemanager.py:1083 DEBUG Initializing environment with unencrypted cert /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:13:30 3680 CertificateManager certificatemanager.py:1098 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\191c8500c5d893d758250b70098c95ce\38d6622212820902ad92145aa0bb0932\cert.pem to 644
12/15/05 15:13:30 3680 CertificateManager certificatemanager.py:1109 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\privatekeys\60fef24d87f80145a55c7bb89691fde6.pem to 600
12/15/05 15:13:30 3680 CertificateManagerWXGUI certificatemanagerwxgui.py:422 DEBUG done, success=1
12/15/05 15:13:30 3680 Toolkit toolkit.py:482 DEBUG Done with globus.
12/15/05 15:14:04 3680 VenueManagement venuemanagement.py:430 DEBUG VenueManagementClient.ConnectToServer: Connect to server https://localhost/VenueServer
12/15/05 15:14:04 3680 VenueManagement venuemanagement.py:438 DEBUG VenueManagementClient.ConnectToServer: Connect to server
12/15/05 15:14:04 3680 VenueManagement venuemanagement.py:440 DEBUG VenueManagementClient.ConnectToServer: Get venues from server
12/15/05 15:14:05 3680 VenueManagement venuemanagement.py:462 DEBUG VenueManagementClient.ConnectToServer: Add venue UCSF Lab Med Lobby
12/15/05 15:14:05 3680 VenueManagement venuemanagement.py:462 DEBUG VenueManagementClient.ConnectToServer: Add venue Test Room
12/15/05 15:14:05 3680 VenueManagement venuemanagement.py:462 DEBUG VenueManagementClient.ConnectToServer: Add venue Conferences
12/15/05 15:14:05 3680 VenueManagement venuemanagement.py:462 DEBUG VenueManagementClient.ConnectToServer: Add venue ID Rounds
12/15/05 15:14:05 3680 VenueManagement venuemanagement.py:541 DEBUG VenueManagementClient.SetCurrentVenue: Set current venue to: Conferences, https://64.54.29.247:8000/Venues/000001067b15fcfc00400036001d00f7ea5
12/15/05 15:14:05 3680 VenueManagement venuemanagement.py:486 DEBUG VenueManagementClient.ConnectToServer: Set multicast address to: RANDOM
12/15/05 15:14:05 3680 VenueManagement venuemanagement.py:503 DEBUG VenueManagementClient.ConnectToServer: Set server encryption key: 1
12/15/05 15:14:14 3680 VenueManagement venuemanagement.py:857 DEBUG VenueListPanel: EvtListBox: Change current venue
12/15/05 15:14:14 3680 VenueManagement venuemanagement.py:541 DEBUG VenueManagementClient.SetCurrentVenue: Set current venue to: UCSF Lab Med Lobby, https://64.54.29.247:8000/Venues/000001067ae47fbc00400036001d00f70cc
12/15/05 15:14:46 3680 VenueManagement venuemanagement.py:857 DEBUG VenueListPanel: EvtListBox: Change current venue
12/15/05 15:14:46 3680 VenueManagement venuemanagement.py:541 DEBUG VenueManagementClient.SetCurrentVenue: Set current venue to: Conferences, https://64.54.29.247:8000/Venues/000001067b15fcfc00400036001d00f7ea5
12/15/05 15:14:50 3680 VenueManagement venuemanagement.py:857 DEBUG VenueListPanel: EvtListBox: Change current venue
12/15/05 15:14:50 3680 VenueManagement venuemanagement.py:541 DEBUG VenueManagementClient.SetCurrentVenue: Set current venue to: ID Rounds, https://64.54.29.247:8000/Venues/000001067b154e9c00400036001d00f7385
12/15/05 15:14:56 3680 VenueManagement venuemanagement.py:857 DEBUG VenueListPanel: EvtListBox: Change current venue
12/15/05 15:14:56 3680 VenueManagement venuemanagement.py:541 DEBUG VenueManagementClient.SetCurrentVenue: Set current venue to: Test Room, https://64.54.29.247:8000/Venues/000001067b135e4500400036001d00f7021
12/15/05 15:15:01 3680 VenueManagement venuemanagement.py:857 DEBUG VenueListPanel: EvtListBox: Change current venue
12/15/05 15:15:01 3680 VenueManagement venuemanagement.py:541 DEBUG VenueManagementClient.SetCurrentVenue: Set current venue to: UCSF Lab Med Lobby, https://64.54.29.247:8000/Venues/000001067ae47fbc00400036001d00f70cc
12/15/05 15:15:02 3680 VenueManagement venuemanagement.py:2199 DEBUG ModifyVenueFrame.__loadCurrentVenueInfo: Get venue information
12/15/05 15:15:02 3680 VenueManagement venuemanagement.py:2218 DEBUG ModifyVenueFrame.__loadCurrentVenueInfo: Key is None
12/15/05 15:15:02 3680 VenueManagement venuemanagement.py:2225 DEBUG ModifyVenueFrame.__loadCurrentVenueInfo: No static streams to load
12/15/05 15:15:02 3680 VenueManagement venuemanagement.py:1587 DEBUG VenueParamFrame.__LoadVenues: Load venues from: https://localhost/VenueServer
12/15/05 15:18:05 3680 VenueManagement venuemanagement.py:430 DEBUG VenueManagementClient.ConnectToServer: Connect to server https://localhost/VenueServer
12/15/05 15:18:05 3680 VenueManagement venuemanagement.py:438 DEBUG VenueManagementClient.ConnectToServer: Connect to server
12/15/05 15:18:05 3680 VenueManagement venuemanagement.py:440 DEBUG VenueManagementClient.ConnectToServer: Get venues from server
12/15/05 15:18:06 3680 VenueManagement venuemanagement.py:462 DEBUG VenueManagementClient.ConnectToServer: Add venue UCSF Lab Med Lobby
12/15/05 15:18:06 3680 VenueManagement venuemanagement.py:462 DEBUG VenueManagementClient.ConnectToServer: Add venue Test Room
12/15/05 15:18:06 3680 VenueManagement venuemanagement.py:462 DEBUG VenueManagementClient.ConnectToServer: Add venue Conferences
12/15/05 15:18:06 3680 VenueManagement venuemanagement.py:462 DEBUG VenueManagementClient.ConnectToServer: Add venue ID Rounds
12/15/05 15:18:06 3680 VenueManagement venuemanagement.py:541 DEBUG VenueManagementClient.SetCurrentVenue: Set current venue to: Conferences, https://64.54.29.247:8000/Venues/000001067b15fcfc00400036001d00f7ea5
12/15/05 15:18:07 3680 VenueManagement venuemanagement.py:486 DEBUG VenueManagementClient.ConnectToServer: Set multicast address to: RANDOM
12/15/05 15:18:07 3680 VenueManagement venuemanagement.py:503 DEBUG VenueManagementClient.ConnectToServer: Set server encryption key: 1
12/15/05 15:18:50 3680 VenueManagement venuemanagement.py:430 DEBUG VenueManagementClient.ConnectToServer: Connect to server https://l64.54.29.247:8000/Venues/default
12/15/05 15:18:50 3680 VenueManagement venuemanagement.py:438 DEBUG VenueManagementClient.ConnectToServer: Connect to server
12/15/05 15:18:50 3680 VenueManagement venuemanagement.py:440 DEBUG VenueManagementClient.ConnectToServer: Get venues from server
12/15/05 15:18:52 3680 VenueManagement venuemanagement.py:520 ERROR VenueManagementClient.ConnectToServer: Can not connect.:
File "C:\Program Files\AGTk-2.4\bin\VenueManagement.py", line 442, in ConnectToServer
vl = self.server.GetVenues()
File "C:\Python23\Lib\site-packages\AccessGrid\VenueServer.py", line 1683, in GetVenues
vl = self.proxy.GetVenues()
r.endheaders()
self._send_output()
self.send(msg)
self.connect()
raise ex
GSITCPSocketException: the name l64.54.29.247 could not be resolved
12/15/05 15:19:24 3680 VenueManagement venuemanagement.py:430 DEBUG VenueManagementClient.ConnectToServer: Connect to server https://64.54.29.247:8000/Venues/default
12/15/05 15:19:24 3680 VenueManagement venuemanagement.py:438 DEBUG VenueManagementClient.ConnectToServer: Connect to server
12/15/05 15:19:24 3680 VenueManagement venuemanagement.py:440 DEBUG VenueManagementClient.ConnectToServer: Get venues from server
12/15/05 15:19:24 3680 VenueManagement venuemanagement.py:520 ERROR VenueManagementClient.ConnectToServer: Can not connect.:
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 389, in __call
raise p
faultType: <Fault SOAP-ENV:Client: Method Not Found: Venues:default:GetVenues : exceptions.AttributeError VenueI instance has no attribute 'GetVenues' <traceback object at 0x011ADAA8>>
12/15/05 15:19:30 3680 VenueManagement venuemanagement.py:430 DEBUG VenueManagementClient.ConnectToServer: Connect to server https://64.54.29.247:8000/Venues/default
12/15/05 15:19:30 3680 VenueManagement venuemanagement.py:438 DEBUG VenueManagementClient.ConnectToServer: Connect to server
12/15/05 15:19:30 3680 VenueManagement venuemanagement.py:440 DEBUG VenueManagementClient.ConnectToServer: Get venues from server
12/15/05 15:19:30 3680 VenueManagement venuemanagement.py:520 ERROR VenueManagementClient.ConnectToServer: Can not connect.:
raise p
faultType: <Fault SOAP-ENV:Client: Method Not Found: Venues:default:GetVenues : exceptions.AttributeError VenueI instance has no attribute 'GetVenues' <traceback object at 0x011ADCB0>>
12/15/05 15:19:40 3680 VenueManagement venuemanagement.py:430 DEBUG VenueManagementClient.ConnectToServer: Connect to server https://localhost/VenueServer
12/15/05 15:19:40 3680 VenueManagement venuemanagement.py:438 DEBUG VenueManagementClient.ConnectToServer: Connect to server
12/15/05 15:19:40 3680 VenueManagement venuemanagement.py:440 DEBUG VenueManagementClient.ConnectToServer: Get venues from server
12/15/05 15:19:41 3680 VenueManagement venuemanagement.py:462 DEBUG VenueManagementClient.ConnectToServer: Add venue UCSF Lab Med Lobby
12/15/05 15:19:41 3680 VenueManagement venuemanagement.py:462 DEBUG VenueManagementClient.ConnectToServer: Add venue Test Room
12/15/05 15:19:41 3680 VenueManagement venuemanagement.py:462 DEBUG VenueManagementClient.ConnectToServer: Add venue Conferences
12/15/05 15:19:41 3680 VenueManagement venuemanagement.py:462 DEBUG VenueManagementClient.ConnectToServer: Add venue ID Rounds
12/15/05 15:19:41 3680 VenueManagement venuemanagement.py:486 DEBUG VenueManagementClient.ConnectToServer: Set multicast address to: RANDOM
12/15/05 15:19:41 3680 VenueManagement venuemanagement.py:503 DEBUG VenueManagementClient.ConnectToServer: Set server encryption key: 1
12/15/05 15:19:45 3680 VenueManagement venuemanagement.py:857 DEBUG VenueListPanel: EvtListBox: Change current venue
12/15/05 15:19:45 3680 VenueManagement venuemanagement.py:541 DEBUG VenueManagementClient.SetCurrentVenue: Set current venue to: UCSF Lab Med Lobby, https://64.54.29.247:8000/Venues/000001067ae47fbc00400036001d00f70cc
12/15/05 15:24:57 3680 VenueManagement venuemanagement.py:430 DEBUG VenueManagementClient.ConnectToServer: Connect to server https://l64.54.29.247/Venue/default
12/15/05 15:24:57 3680 VenueManagement venuemanagement.py:438 DEBUG VenueManagementClient.ConnectToServer: Connect to server
12/15/05 15:24:57 3680 VenueManagement venuemanagement.py:440 DEBUG VenueManagementClient.ConnectToServer: Get venues from server
12/15/05 15:25:00 3680 VenueManagement venuemanagement.py:520 ERROR VenueManagementClient.ConnectToServer: Can not connect.:
r.endheaders()
self._send_output()
self.send(msg)
self.connect()
raise ex
12/15/05 15:25:58 3680 UIUtilities uiutilities.py:867 DEBUG Selected 64.54.29.247
12/15/05 15:26:10 3680 VenueManagement venuemanagement.py:857 DEBUG VenueListPanel: EvtListBox: Change current venue
12/15/05 15:26:10 3680 VenueManagement venuemanagement.py:541 DEBUG VenueManagementClient.SetCurrentVenue: Set current venue to: Conferences, https://64.54.29.247:8000/Venues/000001067b15fcfc00400036001d00f7ea5
12/15/05 15:26:12 3680 VenueManagement venuemanagement.py:536 DEBUG VenueManagementClient.SetCurrentVenue: Set current venue to none
12/15/05 15:26:12 3680 VenueManagement venuemanagement.py:1587 DEBUG VenueParamFrame.__LoadVenues: Load venues from: https://localhost/VenueServer
12/15/05 15:26:13 3680 VenueManagement venuemanagement.py:1611 ERROR VenueParamFrame.__LoadVenues: Could not load exits from server at https://localhost/VenueServer
File "C:\Program Files\AGTk-2.4\bin\VenueManagement.py", line 1590, in __loadVenues
vl = server.GetVenues()
r.endheaders()
self._send_output()
self.send(msg)
self.connect()
raise ex
12/15/05 15:26:28 3680 VenueManagement venuemanagement.py:857 DEBUG VenueListPanel: EvtListBox: Change current venue
12/15/05 15:26:28 3680 VenueManagement venuemanagement.py:541 DEBUG VenueManagementClient.SetCurrentVenue: Set current venue to: ID Rounds, https://64.54.29.247:8000/Venues/000001067b154e9c00400036001d00f7385
12/15/05 15:26:31 3680 VenueManagement venuemanagement.py:857 DEBUG VenueListPanel: EvtListBox: Change current venue
12/15/05 15:26:31 3680 VenueManagement venuemanagement.py:541 DEBUG VenueManagementClient.SetCurrentVenue: Set current venue to: Conferences, https://64.54.29.247:8000/Venues/000001067b15fcfc00400036001d00f7ea5
12/15/05 15:26:33 3680 VenueManagement venuemanagement.py:430 DEBUG VenueManagementClient.ConnectToServer: Connect to server https://64.54.29.247/Venue/default
12/15/05 15:26:33 3680 VenueManagement venuemanagement.py:438 DEBUG VenueManagementClient.ConnectToServer: Connect to server
12/15/05 15:26:33 3680 VenueManagement venuemanagement.py:440 DEBUG VenueManagementClient.ConnectToServer: Get venues from server
12/15/05 15:26:34 3680 VenueManagement venuemanagement.py:520 ERROR VenueManagementClient.ConnectToServer: Can not connect.:
r.endheaders()
self._send_output()
self.send(msg)
self.connect()
raise ex
12/15/05 15:26:50 3680 VenueManagement venuemanagement.py:430 DEBUG VenueManagementClient.ConnectToServer: Connect to server https://64.54.29.247/Venue/default
12/15/05 15:26:50 3680 VenueManagement venuemanagement.py:438 DEBUG VenueManagementClient.ConnectToServer: Connect to server
12/15/05 15:26:50 3680 VenueManagement venuemanagement.py:440 DEBUG VenueManagementClient.ConnectToServer: Get venues from server
12/15/05 15:26:50 3680 VenueManagement venuemanagement.py:520 ERROR VenueManagementClient.ConnectToServer: Can not connect.:
raise p
faultType: <Fault SOAP-ENV:Client: Method Not Found: Venue:default:GetVenues : exceptions.KeyError 'Venue:default' <traceback object at 0x012B4D50>>
12/15/05 15:27:10 3680 UIUtilities uiutilities.py:867 DEBUG Selected 64.54.29.247
12/15/05 15:27:12 3680 UIUtilities uiutilities.py:867 DEBUG Selected 64.54.29.247
12/15/05 15:27:21 3680 UIUtilities uiutilities.py:888 DEBUG before creating my urls server
12/15/05 15:27:41 3680 UIUtilities uiutilities.py:867 DEBUG Selected 64.54.29.247:8000
12/15/05 15:27:45 3680 UIUtilities uiutilities.py:888 DEBUG before creating my urls server
12/15/05 15:27:58 3680 UIUtilities uiutilities.py:867 DEBUG Selected 64.54.29.247
12/15/05 15:28:01 3680 UIUtilities uiutilities.py:888 DEBUG before creating my urls server
12/15/05 15:28:18 3680 UIUtilities uiutilities.py:867 DEBUG Selected 64.54.29.247:8000
12/15/05 15:28:25 3680 UIUtilities uiutilities.py:888 DEBUG before creating my urls server
12/15/05 15:30:15 3680 UIUtilities uiutilities.py:867 DEBUG Selected 64.54.29.247
12/15/05 15:30:19 3680 UIUtilities uiutilities.py:888 DEBUG before creating my urls server
12/15/05 15:30:50 3680 UIUtilities uiutilities.py:867 DEBUG Selected 64.54.29.247:8000
12/15/05 15:31:05 3680 VenueManagement venuemanagement.py:430 DEBUG VenueManagementClient.ConnectToServer: Connect to server https://64.54.29.247/Venue/default
12/15/05 15:31:05 3680 VenueManagement venuemanagement.py:438 DEBUG VenueManagementClient.ConnectToServer: Connect to server
12/15/05 15:31:05 3680 VenueManagement venuemanagement.py:440 DEBUG VenueManagementClient.ConnectToServer: Get venues from server
12/15/05 15:31:06 3680 VenueManagement venuemanagement.py:520 ERROR VenueManagementClient.ConnectToServer: Can not connect.:
raise p
faultType: <Fault SOAP-ENV:Client: Method Not Found: Venue:default:GetVenues : exceptions.KeyError 'Venue:default' <traceback object at 0x012CBCB0>>
12/15/05 15:31:09 3680 VenueManagement venuemanagement.py:430 DEBUG VenueManagementClient.ConnectToServer: Connect to server https://64.54.29.247/Venue/default
12/15/05 15:31:09 3680 VenueManagement venuemanagement.py:438 DEBUG VenueManagementClient.ConnectToServer: Connect to server
12/15/05 15:31:09 3680 VenueManagement venuemanagement.py:440 DEBUG VenueManagementClient.ConnectToServer: Get venues from server
12/15/05 15:31:09 3680 VenueManagement venuemanagement.py:520 ERROR VenueManagementClient.ConnectToServer: Can not connect.:
Traceback (most recent call last):
raise p
faultType: <Fault SOAP-ENV:Client: Method Not Found: Venue:default:GetVenues : exceptions.KeyError 'Venue:default' <traceback object at 0x012CBBE8>>
12/15/05 15:31:24 3680 VenueManagement venuemanagement.py:857 DEBUG VenueListPanel: EvtListBox: Change current venue
12/15/05 15:31:24 3680 VenueManagement venuemanagement.py:541 DEBUG VenueManagementClient.SetCurrentVenue: Set current venue to: ID Rounds, https://64.54.29.247:8000/Venues/000001067b154e9c00400036001d00f7385
12/15/05 15:31:43 3680 VenueManagement venuemanagement.py:857 DEBUG VenueListPanel: EvtListBox: Change current venue
12/15/05 15:31:51 3680 VenueManagement venuemanagement.py:857 DEBUG VenueListPanel: EvtListBox: Change current venue
12/15/05 15:31:51 3680 VenueManagement venuemanagement.py:541 DEBUG VenueManagementClient.SetCurrentVenue: Set current venue to: UCSF Lab Med Lobby, https://64.54.29.247:8000/Venues/000001067ae47fbc00400036001d00f70cc
12/15/05 15:31:52 3680 VenueManagement venuemanagement.py:2199 DEBUG ModifyVenueFrame.__loadCurrentVenueInfo: Get venue information
12/15/05 15:31:52 3680 VenueManagement venuemanagement.py:2211 ERROR ModifyVenueFrame.__loadCurrentVenueInfo: SetDefaultVenue failed
File "C:\Program Files\AGTk-2.4\bin\VenueManagement.py", line 2204, in __loadCurrentVenueInfo
url = self.application.server.GetDefaultVenue()
File "C:\Python23\Lib\site-packages\AccessGrid\VenueServer.py", line 1699, in GetDefaultVenue
return self.proxy.GetDefaultVenue()
raise p
faultType: <Fault SOAP-ENV:Client: Method Not Found: Venue:default:GetDefaultVenue : exceptions.KeyError 'Venue:default' <traceback object at 0x0142AFA8>>
12/15/05 15:31:52 3680 VenueManagement venuemanagement.py:2218 DEBUG ModifyVenueFrame.__loadCurrentVenueInfo: Key is None
12/15/05 15:31:52 3680 VenueManagement venuemanagement.py:2225 DEBUG ModifyVenueFrame.__loadCurrentVenueInfo: No static streams to load
12/15/05 15:31:52 3680 VenueManagement venuemanagement.py:1587 DEBUG VenueParamFrame.__LoadVenues: Load venues from: https://localhost/VenueServer
12/15/05 15:32:27 3680 VenueManagement venuemanagement.py:2165 DEBUG ModifyVenueFrame.OnOk: Modify venue
12/15/05 15:32:28 3680 VenueManagement venuemanagement.py:2170 ERROR ModifyVenueFrame.OnOk: Modify venue failed
File "C:\Program Files\AGTk-2.4\bin\VenueManagement.py", line 2166, in OnOK
self.parent.ModifyVenue(self.venue)
File "C:\Program Files\AGTk-2.4\bin\VenueManagement.py", line 1020, in ModifyVenue
self.application.server.ModifyVenue(venue.uri, venue)
File "C:\Python23\Lib\site-packages\AccessGrid\VenueServer.py", line 1658, in ModifyVenue
return self.proxy.ModifyVenue(url, venueDescription)
raise p
faultType: <Fault SOAP-ENV:Client: Method Not Found: Venue:default:ModifyVenue : exceptions.KeyError 'Venue:default' <traceback object at 0x0142F0A8>>
12/15/05 15:32:32 3680 VenueManagement venuemanagement.py:2183 ERROR ModifyVenueFrame.OnOk: SetDefaultVenue failed
File "C:\Program Files\AGTk-2.4\bin\VenueManagement.py", line 2180, in OnOK
self.parent.SetDefaultVenue(self.venue)
File "C:\Program Files\AGTk-2.4\bin\VenueManagement.py", line 996, in SetDefaultVenue
self.application.server.SetDefaultVenue(venue.uri)
File "C:\Python23\Lib\site-packages\AccessGrid\VenueServer.py", line 1709, in SetDefaultVenue
return self.proxy.SetDefaultVenue(url)
raise p
faultType: <Fault SOAP-ENV:Client: Method Not Found: Venue:default:SetDefaultVenue : exceptions.KeyError 'Venue:default' <traceback object at 0x0142F210>>
12/15/05 15:32:44 3680 VenueManagement venuemanagement.py:430 DEBUG VenueManagementClient.ConnectToServer: Connect to server https://64.54.29.247:8000/Venue/default
12/15/05 15:32:44 3680 VenueManagement venuemanagement.py:438 DEBUG VenueManagementClient.ConnectToServer: Connect to server
12/15/05 15:32:44 3680 VenueManagement venuemanagement.py:440 DEBUG VenueManagementClient.ConnectToServer: Get venues from server
12/15/05 15:32:44 3680 VenueManagement venuemanagement.py:520 ERROR VenueManagementClient.ConnectToServer: Can not connect.:
raise p
faultType: <Fault SOAP-ENV:Client: Method Not Found: Venue:default:GetVenues : exceptions.KeyError 'Venue:default' <traceback object at 0x0142F328>>
12/15/05 15:32:52 3680 VenueManagement venuemanagement.py:889 ERROR VenueListPanel.DeleteVenue: Could not get default venue
File "C:\Program Files\AGTk-2.4\bin\VenueManagement.py", line 887, in DeleteVenue
defaultVenueUrl = self.application.server.GetDefaultVenue()
raise p
faultType: <Fault SOAP-ENV:Client: Method Not Found: Venue:default:GetDefaultVenue : exceptions.KeyError 'Venue:default' <traceback object at 0x0142F350>>
12/15/05 15:32:53 3680 VenueManagement venuemanagement.py:553 DEBUG VenueManagementClient.DeleteVenue: Delete venue: https://64.54.29.247:8000/Venues/000001067ae47fbc00400036001d00f70cc
12/15/05 15:32:54 3680 VenueManagement venuemanagement.py:921 ERROR VenueListPanel.DeleteVenue: Could not delete venue UCSF Lab Med Lobby
File "C:\Program Files\AGTk-2.4\bin\VenueManagement.py", line 907, in DeleteVenue
self.application.DeleteVenue(venueToDelete)
File "C:\Program Files\AGTk-2.4\bin\VenueManagement.py", line 554, in DeleteVenue
self.server.RemoveVenue(venue.uri)
File "C:\Python23\Lib\site-packages\AccessGrid\VenueServer.py", line 1671, in RemoveVenue
return self.proxy.RemoveVenue(url)
raise p
faultType: <Fault SOAP-ENV:Client: Method Not Found: Venue:default:RemoveVenue : exceptions.KeyError 'Venue:default' <traceback object at 0x0142F238>>
12/14/05 16:30:37 952 Toolkit toolkit.py:185 ERROR Toolkit.__CheckForValidClock: Connection to sntp server at ntp-1.accessgrid.org failed
File "C:\Python23\Lib\site-packages\AccessGrid\Toolkit.py", line 183, in __CheckForInvalidClock
serverTime = GetSNTPTime(timeserver, timeout)
File "C:\Python23\Lib\site-packages\AccessGrid\NetUtilities.py", line 43, in GetSNTPTime
client.sendto( data, (server, 123 ))
12/14/05 16:30:37 952 Toolkit toolkit.py:709 INFO Service init: have profile None
12/14/05 16:30:37 952 Toolkit config.py:219 ERROR Error setting globus hostname.
12/14/05 16:30:37 952 Toolkit config.py:348 DEBUG retrieved local IP address 64.54.29.247
12/14/05 16:30:37 952 CertificateManager certificatemanager.py:269 DEBUG Opened repository C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo
12/14/05 16:30:37 952 Toolkit toolkit.py:738 INFO Initialized cert mgmt.
12/14/05 16:30:37 952 Toolkit toolkit.py:753 INFO Loaded profile and configured with it.
12/14/05 16:30:37 952 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
12/14/05 16:30:37 952 CertificateManager certificatemanager.py:827 DEBUG Using default identity /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:30:37 952 CertificateManager certificatemanager.py:1083 DEBUG Initializing environment with unencrypted cert /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:30:37 952 CertificateManager certificatemanager.py:1098 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\191c8500c5d893d758250b70098c95ce\38d6622212820902ad92145aa0bb0932\cert.pem to 644
12/14/05 16:30:37 952 CertificateManager certificatemanager.py:1109 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\privatekeys\60fef24d87f80145a55c7bb89691fde6.pem to 600
12/14/05 16:30:37 952 CertificateManager certificatemanager.py:1572 DEBUG done, success=1
12/14/05 16:30:37 952 Toolkit toolkit.py:764 INFO Initialized Globus.
12/14/05 16:30:37 952 Toolkit toolkit.py:782 INFO Service Initialization Complete.
12/14/05 16:30:37 952 Toolkit venueserver.py:87 INFO VenueServer running using hostname: 64.54.29.247
12/14/05 16:30:37 952 VenueServer venueserver.py:179 DEBUG VenueServer initializing authorization manager.
12/14/05 16:30:37 952 VenueServer venueserver.py:557 DEBUG Reading authorization policy.
12/14/05 16:30:37 952 DataStore datastore.py:1537 DEBUG Creating thread 0
12/14/05 16:30:37 952 DataStore datastore.py:1542 DEBUG Starting thread 0
12/14/05 16:30:37 2016 DataStore datastore.py:1550 DEBUG Worker 0 starting
12/14/05 16:30:37 952 DataStore datastore.py:1544 DEBUG Waiting thread 0
12/14/05 16:30:37 952 DataStore datastore.py:1537 DEBUG Creating thread 1
12/14/05 16:30:37 952 DataStore datastore.py:1542 DEBUG Starting thread 1
12/14/05 16:30:37 952 DataStore datastore.py:1544 DEBUG Waiting thread 1
12/14/05 16:30:37 1300 DataStore datastore.py:1550 DEBUG Worker 1 starting
12/14/05 16:30:37 952 DataStore datastore.py:1537 DEBUG Creating thread 2
12/14/05 16:30:37 952 DataStore datastore.py:1542 DEBUG Starting thread 2
12/14/05 16:30:37 972 DataStore datastore.py:1550 DEBUG Worker 2 starting
12/14/05 16:30:37 952 DataStore datastore.py:1544 DEBUG Waiting thread 2
12/14/05 16:30:37 952 DataStore datastore.py:1537 DEBUG Creating thread 3
12/14/05 16:30:37 952 DataStore datastore.py:1542 DEBUG Starting thread 3
12/14/05 16:30:37 952 DataStore datastore.py:1544 DEBUG Waiting thread 3
12/14/05 16:30:37 4084 DataStore datastore.py:1550 DEBUG Worker 3 starting
12/14/05 16:30:37 952 DataStore datastore.py:1547 DEBUG Done creating workers
12/14/05 16:30:37 952 TextService textserviceasynch.py:413 DEBUG TextServiceAsynch: Text Service Started
12/14/05 16:30:37 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/14/05 16:30:37 952 TextService textserviceasynch.py:448 DEBUG TextServiceAsynch: Bound to 8004 (server_address=('64.54.29.247', 8004))
12/14/05 16:30:37 952 TextService textserviceasynch.py:467 DEBUG TextServiceAsynch: Text service start
12/14/05 16:30:37 952 TextService textserviceasynch.py:473 DEBUG TextServiceAsynch: register_listen returns '_f8b9cd00_p_callbackStruct'
12/14/05 16:30:37 952 VenueServer venueserver.py:394 DEBUG Reading persisted Venues from: VenueServer.dat
12/14/05 16:30:37 952 VenueServer venueserver.py:399 DEBUG Loading Venue: 000001067b154e9c00400036001d00f7385
12/14/05 16:30:37 952 VenueServer venue.py:382 DEBUG ------------ STARTING VENUE
12/14/05 16:30:37 952 VenueServer venue.py:422 INFO Venue URI https://64.54.29.247:8000/Venues/000001067b154e9c00400036001d00f7385
12/14/05 16:30:37 952 TextService textserviceasynch.py:751 DEBUG TextServiceAsynch: AddChannel 000001067b154e9c00400036001d00f7385
12/14/05 16:30:37 952 VenueServer venue.py:428 DEBUG Registering heartbeat for 000001067b154e9c00400036001d00f7385
12/14/05 16:30:37 952 VenueServer venue.py:442 DEBUG data store location: Data
12/14/05 16:30:37 952 DataStore datastore.py:278 DEBUG Reading persisted data from: Data\000001067b154e9c00400036001d00f7385\DataStore.dat
12/14/05 16:30:37 952 VenueServer venue.py:466 INFO Have upload url: https://64.54.29.247:8006/000001067b154e9c00400036001d00f7385
12/14/05 16:30:37 952 VenueServer venue.py:1138 DEBUG Calling SetConnections.
12/14/05 16:30:38 952 Security authorizationmanager.py:448 DEBUG Adding Subject: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f to Role: Administrators
12/14/05 16:30:38 952 Security authorizationmanager.py:461 WARNING Not adding subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f to role Administrators, it's already there.
12/14/05 16:30:38 952 VenueServer venueserver.py:399 DEBUG Loading Venue: 000001067ae47fbc00400036001d00f70cc
12/14/05 16:30:38 952 VenueServer venue.py:382 DEBUG ------------ STARTING VENUE
12/14/05 16:30:38 952 VenueServer venue.py:422 INFO Venue URI https://64.54.29.247:8000/Venues/000001067ae47fbc00400036001d00f70cc
12/14/05 16:30:38 952 TextService textserviceasynch.py:751 DEBUG TextServiceAsynch: AddChannel 000001067ae47fbc00400036001d00f70cc
12/14/05 16:30:38 952 VenueServer venue.py:428 DEBUG Registering heartbeat for 000001067ae47fbc00400036001d00f70cc
12/14/05 16:30:38 952 VenueServer venue.py:442 DEBUG data store location: Data
12/14/05 16:30:38 952 DataStore datastore.py:278 DEBUG Reading persisted data from: Data\000001067ae47fbc00400036001d00f70cc\DataStore.dat
12/14/05 16:30:38 952 VenueServer venue.py:466 INFO Have upload url: https://64.54.29.247:8006/000001067ae47fbc00400036001d00f70cc
12/14/05 16:30:38 952 VenueServer venue.py:1138 DEBUG Calling SetConnections.
12/14/05 16:30:38 952 VenueServer venueserver.py:399 DEBUG Loading Venue: 000001067b15fcfc00400036001d00f7ea5
12/14/05 16:30:38 952 VenueServer venue.py:422 INFO Venue URI https://64.54.29.247:8000/Venues/000001067b15fcfc00400036001d00f7ea5
12/14/05 16:30:38 952 TextService textserviceasynch.py:751 DEBUG TextServiceAsynch: AddChannel 000001067b15fcfc00400036001d00f7ea5
12/14/05 16:30:38 952 VenueServer venue.py:428 DEBUG Registering heartbeat for 000001067b15fcfc00400036001d00f7ea5
12/14/05 16:30:38 952 DataStore datastore.py:278 DEBUG Reading persisted data from: Data\000001067b15fcfc00400036001d00f7ea5\DataStore.dat
12/14/05 16:30:38 952 VenueServer venue.py:466 INFO Have upload url: https://64.54.29.247:8006/000001067b15fcfc00400036001d00f7ea5
12/14/05 16:30:38 952 VenueServer venueserver.py:399 DEBUG Loading Venue: 000001067b135e4500400036001d00f7021
12/14/05 16:30:38 952 VenueServer venue.py:422 INFO Venue URI https://64.54.29.247:8000/Venues/000001067b135e4500400036001d00f7021
12/14/05 16:30:38 952 TextService textserviceasynch.py:751 DEBUG TextServiceAsynch: AddChannel 000001067b135e4500400036001d00f7021
12/14/05 16:30:38 952 VenueServer venue.py:428 DEBUG Registering heartbeat for 000001067b135e4500400036001d00f7021
12/14/05 16:30:38 952 DataStore datastore.py:278 DEBUG Reading persisted data from: Data\000001067b135e4500400036001d00f7021\DataStore.dat
12/14/05 16:30:38 952 VenueServer venue.py:466 INFO Have upload url: https://64.54.29.247:8006/000001067b135e4500400036001d00f7021
12/14/05 16:30:38 952 VenueServer venueserver.py:273 DEBUG CFG: Default Venue: 000001067ae47fbc00400036001d00f70cc
12/14/05 16:30:38 952 VenueServer venueserver.py:275 DEBUG Setting default venue.
12/14/05 16:30:38 952 VenueServer venueserver.py:938 INFO Setting default venue; oid=000001067ae47fbc00400036001d00f70cc
12/14/05 16:30:38 952 VenueServer venueserver.py:319 WARNING Performance data configuration incorrect.
12/14/05 16:30:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 16:30:38 2005
12/14/05 16:30:38 952 VenueServer venueserver.py:352 DEBUG Using policy from config file.
12/14/05 16:30:38 952 VenueServer venueserver.py:358 DEBUG Default Subject: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:30:38 952 Toolkit venueserver.py:102 DEBUG Starting Hosting Environment.
12/14/05 16:30:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 16:30:38 2005
12/14/05 16:31:39 3832 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/14/05 16:31:39 3832 VenueServer venueserver.py:1138 INFO Authorizing action: GetVenues for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:31:39 3864 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/14/05 16:31:39 3864 VenueServer venueserver.py:1138 INFO Authorizing action: GetDefaultVenue for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:31:40 3872 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/14/05 16:31:40 3872 VenueServer venueserver.py:1138 INFO Authorizing action: GetBaseAddress for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:31:40 788 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/14/05 16:31:40 788 VenueServer venueserver.py:1138 INFO Authorizing action: GetAddressMask for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:31:40 3880 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/14/05 16:31:40 3880 VenueServer venueserver.py:1138 INFO Authorizing action: GetAddressAllocationMethod for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:31:40 2560 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/14/05 16:31:40 2560 VenueServer venueserver.py:1138 INFO Authorizing action: GetEncryptAllMedia for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:32:06 1644 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/14/05 16:32:06 1644 VenueServer venueserver.py:1138 INFO Authorizing action: SetBaseAddress for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:32:06 1488 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/14/05 16:32:06 1488 VenueServer venueserver.py:1138 INFO Authorizing action: SetAddressMask for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:32:07 1700 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/14/05 16:32:07 1700 VenueServer venueserver.py:1138 INFO Authorizing action: SetAddressAllocationMethod for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:32:08 1544 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/14/05 16:32:08 1544 VenueServer venueserver.py:1138 INFO Authorizing action: SetAddressAllocationMethod for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:32:16 2348 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/14/05 16:32:16 2348 VenueServer venueserver.py:1138 INFO Authorizing action: GetDefaultVenue for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:32:16 1716 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/14/05 16:32:16 1716 VenueServer venueserver.py:1138 INFO Authorizing action: GetVenues for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:32:16 4024 Security authorizationmanager.py:613 DEBUG Authorizing: () _SOAPContext
12/14/05 16:32:16 4024 Security authorizationmanager.py:618 INFO Authorizing action: ListRoles for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:32:16 1756 Security authorizationmanager.py:613 DEBUG Authorizing: () _SOAPContext
12/14/05 16:32:16 1756 Security authorizationmanager.py:618 INFO Authorizing action: ListActions for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:34:09 3008 VenueServer venue.py:2308 DEBUG Authorizing () _SOAPContext
12/14/05 16:34:09 3008 VenueServer venue.py:2316 INFO Authorizing action: Enter for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:34:09 3008 VenueServer venue.py:2348 DEBUG Interface Enter: Called.
12/14/05 16:34:09 3008 VenueServer venue.py:1254 DEBUG Enter called.
12/14/05 16:34:09 3008 VenueServer venue.py:1261 DEBUG Enter: Assigning private id: 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927
12/14/05 16:34:09 3008 VenueServer venue.py:850 DEBUG added user as producer of non-existent stream
12/14/05 16:34:09 3008 VenueServer venue.py:3984 DEBUG * * * Added stream producer 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927
12/14/05 16:34:09 3008 VenueServer venue.py:4095 DEBUG StreamDescriptionList.index Address 224.2.175.122 224.2.154.2
12/14/05 16:34:09 3008 VenueServer venue.py:4098 DEBUG StreamDescriptionList.index Port 56424 55730
12/14/05 16:34:09 3008 VenueServer venue.py:4095 DEBUG StreamDescriptionList.index Address 224.2.175.122 224.2.175.122
12/14/05 16:34:09 3008 VenueServer venue.py:4098 DEBUG StreamDescriptionList.index Port 56424 56424
12/14/05 16:34:09 3008 VenueServer venue.py:829 DEBUG added user as producer of existent stream
12/14/05 16:34:09 3008 VenueServer venue.py:1279 DEBUG Current users:
12/14/05 16:34:09 3008 VenueServer venue.py:1281 DEBUG VenueClientState(name=UCSF China Basin Microbilogy privateID=000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 lastHeartbeat=1134606849.19)
12/14/05 16:34:09 3008 VenueServer venue.py:1282 DEBUG Enter: Distribute enter event
12/14/05 16:34:09 3008 VenueServer venue.py:1289 INFO User already in venue users list: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:34:09 3008 TextService textserviceasynch.py:726 DEBUG TextServiceAsynch: GetLocation
12/14/05 16:34:09 3008 VenueServer venue.py:1293 DEBUG state: <AccessGrid.Descriptions.VenueState instance at 0x013840D0>
12/14/05 16:34:09 892 VenueServer venue.py:1175 DEBUG Venue gets channelAuthCallback, privateID=000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927
12/14/05 16:34:09 892 VenueServer venue.py:1179 DEBUG Private id is in client list, authorizing
12/14/05 16:34:09 892 VenueServer venue.py:258 DEBUG Set connection for UCSF China Basin Microbilogy
12/14/05 16:34:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606849.34.
12/14/05 16:34:09 3888 VenueServer venue.py:2308 DEBUG Authorizing () _SOAPContext
12/14/05 16:34:09 3888 VenueServer venue.py:2316 INFO Authorizing action: GetUploadDescriptor for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:34:09 456 TextService textserviceasynch.py:482 INFO Listen Callback 'None' '_68f2cd00_p_globus_io_handle_t' '(0, None, None)'
12/14/05 16:34:09 456 TextService textserviceasynch.py:72 INFO conn handler registering accept
12/14/05 16:34:09 456 TextService textserviceasynch.py:77 INFO register_accept returns socket=<pyGlobus.io.GSITCPSocket instance at 0x01394120> cb=_f8b9cd00_p_callbackStruct
12/14/05 16:34:09 456 TextService textserviceasynch.py:87 INFO Accept Callback 'None' '_8843ce00_p_globus_io_handle_t' '(0, None, None)'
12/14/05 16:34:09 456 TextService textserviceasynch.py:473 DEBUG TextServiceAsynch: register_listen returns '_f8b9cd00_p_callbackStruct'
12/14/05 16:34:09 456 TextService textserviceasynch.py:154 INFO Got read handle=_8843ce00_p_globus_io_handle_t ret=(0, None, None) n=4
12/14/05 16:34:09 456 TextService textserviceasynch.py:154 INFO Got read handle=_8843ce00_p_globus_io_handle_t ret=(0, None, None) n=230
12/14/05 16:34:09 456 TextService textserviceasynch.py:184 INFO finished reading packet, wait=230 buflen=230
12/14/05 16:34:09 456 TextService textserviceasynch.py:214 INFO TextConnection: Got Event Event:
Type: Connect Venue: 000001067ae47fbc00400036001d00f70cc
12/14/05 16:34:09 456 TextService textserviceasynch.py:558 INFO Enqueue event Connect for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x01373B20>...
12/14/05 16:34:09 2764 TextService textserviceasynch.py:575 INFO Queue handler received ('event', Event:
Type: Connect Venue: 000001067ae47fbc00400036001d00f70cc, <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x01373B20>)
12/14/05 16:34:09 2764 TextService textserviceasynch.py:619 INFO Handle event type Connect
12/14/05 16:34:09 2764 TextService textserviceasynch.py:300 DEBUG TextServiceAsynch: Attempting authorization on event Connect
12/14/05 16:34:09 2764 VenueServer venue.py:1215 DEBUG Venue gets channelAuthCallback, privateID=000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927
12/14/05 16:34:09 2764 VenueServer venue.py:1219 DEBUG Private id is in client list, authorizing
12/14/05 16:34:09 2764 TextService textserviceasynch.py:319 DEBUG TextServiceAsynch: Auth callback <bound method Venue.textChannelAuthCallback of Venue: name=UCSF Lab Med Lobby id=17441696 url=https://64.54.29.247:8000/Venues/000001067ae47fbc00400036001d00f70cc> returns 1
12/14/05 16:34:09 2764 TextService textserviceasynch.py:679 DEBUG TextServiceAsynch: Adding connObj 000001082bd695fb00400036001d00f73ba to channel 000001067ae47fbc00400036001d00f70cc
12/14/05 16:34:09 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/14/05 16:34:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606854.3.
12/14/05 16:34:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606859.3.
12/14/05 16:34:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606864.3.
12/14/05 16:34:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606869.3.
12/14/05 16:34:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606874.3.
12/14/05 16:34:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606879.3.
12/14/05 16:34:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606884.3.
12/14/05 16:34:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606889.3.
12/14/05 16:34:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606894.31.
12/14/05 16:34:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606899.3.
12/14/05 16:35:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606904.3.
12/14/05 16:35:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606909.3.
12/14/05 16:35:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606914.31.
12/14/05 16:35:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606919.3.
12/14/05 16:35:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606924.3.
12/14/05 16:35:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606929.3.
12/14/05 16:35:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606934.3.
12/14/05 16:35:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 16:35:38 2005
12/14/05 16:35:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 16:35:38 2005
12/14/05 16:35:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606939.3.
12/14/05 16:35:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606944.3.
12/14/05 16:35:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606949.31.
12/14/05 16:35:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606954.3.
12/14/05 16:35:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606959.3.
12/14/05 16:36:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606964.31.
12/14/05 16:36:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606969.3.
12/14/05 16:36:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606974.3.
12/14/05 16:36:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606979.3.
12/14/05 16:36:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606984.31.
12/14/05 16:36:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606989.3.
12/14/05 16:36:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606994.31.
12/14/05 16:36:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134606999.3.
12/14/05 16:36:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607004.3.
12/14/05 16:36:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607009.3.
12/14/05 16:36:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607014.3.
12/14/05 16:36:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607019.31.
12/14/05 16:37:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607024.3.
12/14/05 16:37:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607029.31.
12/14/05 16:37:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607034.3.
12/14/05 16:37:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607039.31.
12/14/05 16:37:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607044.3.
12/14/05 16:37:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607049.3.
12/14/05 16:37:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607054.3.
12/14/05 16:37:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607059.3.
12/14/05 16:37:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607064.3.
12/14/05 16:37:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607069.3.
12/14/05 16:37:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607074.3.
12/14/05 16:37:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607079.3.
12/14/05 16:38:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607084.3.
12/14/05 16:38:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607089.3.
12/14/05 16:38:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607094.3.
12/14/05 16:38:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607099.3.
12/14/05 16:38:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607104.31.
12/14/05 16:38:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607109.3.
12/14/05 16:38:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607114.3.
12/14/05 16:38:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607119.3.
12/14/05 16:38:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607124.3.
12/14/05 16:38:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607129.3.
12/14/05 16:38:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607134.3.
12/14/05 16:38:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607139.3.
12/14/05 16:39:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607144.3.
12/14/05 16:39:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607149.3.
12/14/05 16:39:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607154.3.
12/14/05 16:39:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607159.31.
12/14/05 16:39:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607164.31.
12/14/05 16:39:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607169.31.
12/14/05 16:39:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607174.3.
12/14/05 16:39:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607179.3.
12/14/05 16:39:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607184.3.
12/14/05 16:39:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607189.3.
12/14/05 16:39:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607194.3.
12/14/05 16:39:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607199.3.
12/14/05 16:40:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607204.3.
12/14/05 16:40:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607209.3.
12/14/05 16:40:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607214.31.
12/14/05 16:40:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607219.3.
12/14/05 16:40:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607224.31.
12/14/05 16:40:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607229.3.
12/14/05 16:40:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607234.31.
12/14/05 16:40:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 16:40:38 2005
12/14/05 16:40:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 16:40:38 2005
12/14/05 16:40:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607239.3.
12/14/05 16:40:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607244.31.
12/14/05 16:40:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607249.3.
12/14/05 16:40:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607254.3.
12/14/05 16:40:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607259.3.
12/14/05 16:41:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607264.31.
12/14/05 16:41:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607269.3.
12/14/05 16:41:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607274.3.
12/14/05 16:41:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607279.3.
12/14/05 16:41:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607284.3.
12/14/05 16:41:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607289.3.
12/14/05 16:41:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607294.3.
12/14/05 16:41:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607299.3.
12/14/05 16:41:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607304.3.
12/14/05 16:41:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607309.3.
12/14/05 16:41:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607314.31.
12/14/05 16:41:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607319.3.
12/14/05 16:42:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607324.3.
12/14/05 16:42:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607329.3.
12/14/05 16:42:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607334.3.
12/14/05 16:42:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607339.3.
12/14/05 16:42:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607344.3.
12/14/05 16:42:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607349.3.
12/14/05 16:42:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607354.31.
12/14/05 16:42:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607359.3.
12/14/05 16:42:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607364.31.
12/14/05 16:42:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607369.3.
12/14/05 16:42:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607374.31.
12/14/05 16:42:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607379.3.
12/14/05 16:43:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607384.31.
12/14/05 16:43:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607389.3.
12/14/05 16:43:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607394.3.
12/14/05 16:43:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607399.3.
12/14/05 16:43:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607404.3.
12/14/05 16:43:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607409.3.
12/14/05 16:43:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607414.3.
12/14/05 16:43:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607419.3.
12/14/05 16:43:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607424.3.
12/14/05 16:43:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607429.3.
12/14/05 16:43:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607434.3.
12/14/05 16:43:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607439.3.
12/14/05 16:44:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607444.3.
12/14/05 16:44:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607449.3.
12/14/05 16:44:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607454.3.
12/14/05 16:44:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607459.3.
12/14/05 16:44:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607464.3.
12/14/05 16:44:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607469.3.
12/14/05 16:44:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607474.3.
12/14/05 16:44:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607479.3.
12/14/05 16:44:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607484.3.
12/14/05 16:44:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607489.31.
12/14/05 16:44:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607494.31.
12/14/05 16:44:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607499.3.
12/14/05 16:45:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607504.3.
12/14/05 16:45:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607509.3.
12/14/05 16:45:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607514.31.
12/14/05 16:45:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607519.3.
12/14/05 16:45:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607524.31.
12/14/05 16:45:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607529.3.
12/14/05 16:45:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607534.3.
12/14/05 16:45:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 16:45:38 2005
12/14/05 16:45:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 16:45:38 2005
12/14/05 16:45:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607539.3.
12/14/05 16:45:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607544.3.
12/14/05 16:45:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607549.3.
12/14/05 16:45:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607554.3.
12/14/05 16:45:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607559.3.
12/14/05 16:46:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607564.31.
12/14/05 16:46:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607569.3.
12/14/05 16:46:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607574.3.
12/14/05 16:46:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607579.3.
12/14/05 16:46:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607584.3.
12/14/05 16:46:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607589.3.
12/14/05 16:46:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607594.3.
12/14/05 16:46:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607599.3.
12/14/05 16:46:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607604.3.
12/14/05 16:46:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607609.3.
12/14/05 16:46:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607614.3.
12/14/05 16:46:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607619.31.
12/14/05 16:47:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607624.3.
12/14/05 16:47:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607629.31.
12/14/05 16:47:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607634.3.
12/14/05 16:47:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607639.31.
12/14/05 16:47:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607644.3.
12/14/05 16:47:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607649.3.
12/14/05 16:47:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607654.3.
12/14/05 16:47:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607659.31.
12/14/05 16:47:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607664.3.
12/14/05 16:47:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607669.3.
12/14/05 16:47:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607674.3.
12/14/05 16:47:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607679.3.
12/14/05 16:48:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607684.3.
12/14/05 16:48:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607689.31.
12/14/05 16:48:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607694.3.
12/14/05 16:48:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607699.3.
12/14/05 16:48:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607704.3.
12/14/05 16:48:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607709.31.
12/14/05 16:48:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607714.3.
12/14/05 16:48:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607719.31.
12/14/05 16:48:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607724.3.
12/14/05 16:48:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607729.3.
12/14/05 16:48:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607734.3.
12/14/05 16:48:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607739.3.
12/14/05 16:49:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607744.31.
12/14/05 16:49:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607749.3.
12/14/05 16:49:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607754.31.
12/14/05 16:49:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607759.3.
12/14/05 16:49:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607764.3.
12/14/05 16:49:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607769.3.
12/14/05 16:49:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607774.3.
12/14/05 16:49:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607779.3.
12/14/05 16:49:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607784.31.
12/14/05 16:49:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607789.3.
12/14/05 16:49:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607794.31.
12/14/05 16:49:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607799.3.
12/14/05 16:50:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607804.3.
12/14/05 16:50:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607809.3.
12/14/05 16:50:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607814.3.
12/14/05 16:50:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607819.3.
12/14/05 16:50:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607824.3.
12/14/05 16:50:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607829.31.
12/14/05 16:50:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607834.3.
12/14/05 16:50:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 16:50:38 2005
12/14/05 16:50:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 16:50:38 2005
12/14/05 16:50:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607839.3.
12/14/05 16:50:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607844.31.
12/14/05 16:50:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607849.3.
12/14/05 16:50:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607854.31.
12/14/05 16:50:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607859.3.
12/14/05 16:51:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607864.31.
12/14/05 16:51:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607869.3.
12/14/05 16:51:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607874.31.
12/14/05 16:51:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607879.3.
12/14/05 16:51:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607884.3.
12/14/05 16:51:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607889.3.
12/14/05 16:51:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607894.3.
12/14/05 16:51:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607899.3.
12/14/05 16:51:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607904.31.
12/14/05 16:51:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607909.3.
12/14/05 16:51:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607914.31.
12/14/05 16:51:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607919.3.
12/14/05 16:52:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607924.31.
12/14/05 16:52:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607929.3.
12/14/05 16:52:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607934.31.
12/14/05 16:52:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607939.3.
12/14/05 16:52:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607944.3.
12/14/05 16:52:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607949.3.
12/14/05 16:52:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607954.3.
12/14/05 16:52:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607959.3.
12/14/05 16:52:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607964.3.
12/14/05 16:52:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607969.3.
12/14/05 16:52:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607974.31.
12/14/05 16:52:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607979.3.
12/14/05 16:53:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607984.31.
12/14/05 16:53:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607989.3.
12/14/05 16:53:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607994.3.
12/14/05 16:53:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134607999.3.
12/14/05 16:53:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608004.3.
12/14/05 16:53:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608009.3.
12/14/05 16:53:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608014.3.
12/14/05 16:53:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608019.3.
12/14/05 16:53:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608024.31.
12/14/05 16:53:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608029.3.
12/14/05 16:53:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608034.31.
12/14/05 16:53:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608039.3.
12/14/05 16:54:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608044.3.
12/14/05 16:54:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608049.3.
12/14/05 16:54:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608054.3.
12/14/05 16:54:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608059.3.
12/14/05 16:54:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608064.3.
12/14/05 16:54:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608069.3.
12/14/05 16:54:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608074.3.
12/14/05 16:54:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608079.3.
12/14/05 16:54:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608084.3.
12/14/05 16:54:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608089.3.
12/14/05 16:54:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608094.3.
12/14/05 16:54:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608099.3.
12/14/05 16:55:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608104.3.
12/14/05 16:55:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608109.31.
12/14/05 16:55:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608114.3.
12/14/05 16:55:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608119.3.
12/14/05 16:55:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608124.3.
12/14/05 16:55:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608129.3.
12/14/05 16:55:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608134.3.
12/14/05 16:55:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 16:55:38 2005
12/14/05 16:55:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 16:55:38 2005
12/14/05 16:55:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608139.3.
12/14/05 16:55:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608144.3.
12/14/05 16:55:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608149.3.
12/14/05 16:55:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608154.3.
12/14/05 16:55:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608159.31.
12/14/05 16:56:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608164.33.
12/14/05 16:56:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608169.3.
12/14/05 16:56:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608174.3.
12/14/05 16:56:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608179.3.
12/14/05 16:56:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608184.3.
12/14/05 16:56:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608189.3.
12/14/05 16:56:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608194.3.
12/14/05 16:56:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927 at 1134608199.3.
12/14/05 16:56:43 2552 VenueServer venue.py:2308 DEBUG Authorizing () _SOAPContext
12/14/05 16:56:43 2552 VenueServer venue.py:2316 INFO Authorizing action: Exit for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:56:43 2552 VenueServer venue.py:1761 DEBUG Called Venue Exit on 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927
12/14/05 16:56:43 2552 VenueServer venue.py:1031 DEBUG Called RemoveUser on 000001082bd694a300400036001d00f727c_000001082bd694a300400036001d00f7927
12/14/05 16:56:43 2552 VenueServer venue.py:4095 DEBUG StreamDescriptionList.index Address 224.2.154.2 224.2.154.2
12/14/05 16:56:43 2552 VenueServer venue.py:4098 DEBUG StreamDescriptionList.index Port 55730 55730
12/14/05 16:56:43 2552 VenueServer venue.py:4095 DEBUG StreamDescriptionList.index Address 224.2.175.122 224.2.154.2
12/14/05 16:56:43 2552 VenueServer venue.py:4098 DEBUG StreamDescriptionList.index Port 56424 55730
12/14/05 16:56:43 2552 VenueServer venue.py:4095 DEBUG StreamDescriptionList.index Address 224.2.175.122 224.2.175.122
12/14/05 16:56:43 2552 VenueServer venue.py:4098 DEBUG StreamDescriptionList.index Port 56424 56424
12/14/05 16:56:43 2552 VenueServer venue.py:1033 DEBUG Removed streams = [StreamDescription: {'description': None, 'encryptionKey': None, 'uri': None, 'encryptionFlag': 0, 'capability': producer audio, 'static': 0, 'location': multicast 224.2.154.2 55730 127, 'id': '000001082bd694b300400036001d00f779c', 'networkLocations': [multicast 224.2.154.2 55730 127], 'name': 'UCSF Lab Med Lobby'}]
12/14/05 16:56:43 2552 VenueServer venue.py:1075 DEBUG Removing single instance of user
12/14/05 16:56:43 2552 TextService textserviceasynch.py:511 DEBUG TextServiceAsynch: Removing connection 000001082bd695fb00400036001d00f73ba
12/14/05 16:56:43 356 EventService eventserviceasynch.py:242 ERROR writeMarshalledEvent write error!
Traceback (most recent call last):
File "C:\Python23\Lib\site-packages\AccessGrid\EventServiceAsynch.py", line 236, in writeMarshalledEvent
mEvent.Write(self.wfile)
File "C:\Python23\Lib\site-packages\AccessGrid\Events.py", line 243, in Write
fh.write(self.sizeStr)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 377, in write
self.sock.write(str, len(str))
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 253, in write
raise ex
IOBaseException: the handle 00CDF5E8 was already registered for closing
12/14/05 16:56:43 456 TextService textserviceasynch.py:154 INFO Got read handle=_8843ce00_p_globus_io_handle_t ret=(-1, 40, 'an I/O operation was cancelled') n=0
12/14/05 16:56:43 892 EventService eventserviceasynch.py:497 ERROR RemoveConnection: connection 000001082bd6950100400036001d00f77b0 not in connection list
12/14/05 16:56:43 456 TextService textserviceasynch.py:157 DEBUG TextServiceAsynch: readCallback returned failure: -1 40
12/14/05 16:56:43 356 EventService eventserviceasynch.py:497 ERROR RemoveConnection: connection 000001082bd6950100400036001d00f77b0 not in connection list
12/14/05 16:56:43 456 TextService textserviceasynch.py:199 ERROR TextServiceAsynch: IOBase exception on text service close (probably ok)
File "C:\Python23\Lib\site-packages\AccessGrid\TextServiceAsynch.py", line 196, in stop
self.wfile.close()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 391, in close
self.sock.close()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1020, in close
IOBase.close(self)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 176, in close
raise ex
IOBaseException: the handle 00CE4388 was already registered for closing
12/14/05 16:56:43 456 TextService textserviceasynch.py:562 INFO Enqueue EOF for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x01373B20>...
12/14/05 16:56:43 2764 TextService textserviceasynch.py:575 INFO Queue handler received ('eof', <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x01373B20>)
12/14/05 16:56:43 456 TextService textserviceasynch.py:124 ERROR readcallback failed
File "C:\Python23\Lib\site-packages\AccessGrid\TextServiceAsynch.py", line 122, in readCallbackWrap
self.registerForRead()
File "C:\Python23\Lib\site-packages\AccessGrid\TextServiceAsynch.py", line 109, in registerForRead
None)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 198, in register_read
raise ex
12/14/05 16:56:43 2764 TextService textserviceasynch.py:581 DEBUG TextServiceAsynch: EOF on connection 000001082bd695fb00400036001d00f73ba
self.wfile.close()
self.sock.close()
IOBase.close(self)
raise ex
12/14/05 16:56:43 2764 TextService textserviceasynch.py:511 DEBUG TextServiceAsynch: Removing connection 000001082bd695fb00400036001d00f73ba
12/14/05 16:56:43 2552 VenueServer venue.py:1113 DEBUG RemoveUser: Distribute EXIT event
12/14/05 16:56:43 2764 TextService textserviceasynch.py:199 ERROR TextServiceAsynch: IOBase exception on text service close (probably ok)
self.wfile.close()
self.sock.close()
IOBase.close(self)
raise ex
IOBaseException: an uninitialied data structure was passed as argument 1 to globus_io_register_close
12/14/05 16:56:43 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/14/05 17:00:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 17:00:38 2005
12/14/05 17:00:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 17:00:38 2005
12/14/05 17:05:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 17:05:38 2005
12/14/05 17:05:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 17:05:38 2005
12/14/05 17:10:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 17:10:38 2005
12/14/05 17:10:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 17:10:38 2005
12/14/05 17:15:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 17:15:38 2005
12/14/05 17:15:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 17:15:38 2005
12/14/05 17:20:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 17:20:38 2005
12/14/05 17:20:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 17:20:38 2005
12/14/05 17:25:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 17:25:38 2005
12/14/05 17:25:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 17:25:38 2005
12/14/05 17:30:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 17:30:38 2005
12/14/05 17:30:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 17:30:38 2005
12/14/05 17:35:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 17:35:38 2005
12/14/05 17:35:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 17:35:38 2005
12/14/05 17:40:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 17:40:38 2005
12/14/05 17:40:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 17:40:38 2005
12/14/05 17:45:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 17:45:38 2005
12/14/05 17:45:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 17:45:38 2005
12/14/05 17:50:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 17:50:38 2005
12/14/05 17:50:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 17:50:38 2005
12/14/05 17:55:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 17:55:38 2005
12/14/05 17:55:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 17:55:38 2005
12/14/05 18:00:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 18:00:38 2005
12/14/05 18:00:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 18:00:38 2005
12/14/05 18:05:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 18:05:38 2005
12/14/05 18:05:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 18:05:38 2005
12/14/05 18:10:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 18:10:38 2005
12/14/05 18:10:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 18:10:38 2005
12/14/05 18:15:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 18:15:38 2005
12/14/05 18:15:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 18:15:38 2005
12/14/05 18:20:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 18:20:38 2005
12/14/05 18:20:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 18:20:38 2005
12/14/05 18:25:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 18:25:38 2005
12/14/05 18:25:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 18:25:38 2005
12/14/05 18:30:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 18:30:38 2005
12/14/05 18:30:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 18:30:38 2005
12/14/05 18:35:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 18:35:38 2005
12/14/05 18:35:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 18:35:38 2005
12/14/05 18:40:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 18:40:38 2005
12/14/05 18:40:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 18:40:38 2005
12/14/05 18:45:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 18:45:38 2005
12/14/05 18:45:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 18:45:38 2005
12/14/05 18:50:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 18:50:38 2005
12/14/05 18:50:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 18:50:38 2005
12/14/05 18:55:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 18:55:38 2005
12/14/05 18:55:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 18:55:38 2005
12/14/05 19:00:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 19:00:38 2005
12/14/05 19:00:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 19:00:38 2005
12/14/05 19:05:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 19:05:38 2005
12/14/05 19:05:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 19:05:38 2005
12/14/05 19:10:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 19:10:38 2005
12/14/05 19:10:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 19:10:38 2005
12/14/05 19:15:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 19:15:38 2005
12/14/05 19:15:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 19:15:38 2005
12/14/05 19:20:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 19:20:38 2005
12/14/05 19:20:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 19:20:38 2005
12/14/05 19:25:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 19:25:38 2005
12/14/05 19:25:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 19:25:38 2005
12/14/05 19:30:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 19:30:38 2005
12/14/05 19:30:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 19:30:38 2005
12/14/05 19:35:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 19:35:38 2005
12/14/05 19:35:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 19:35:38 2005
12/14/05 19:40:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 19:40:38 2005
12/14/05 19:40:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 19:40:38 2005
12/14/05 19:45:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 19:45:38 2005
12/14/05 19:45:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 19:45:38 2005
12/14/05 19:50:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 19:50:38 2005
12/14/05 19:50:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 19:50:38 2005
12/14/05 19:55:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 19:55:38 2005
12/14/05 19:55:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 19:55:38 2005
12/14/05 20:00:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 20:00:38 2005
12/14/05 20:00:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 20:00:38 2005
12/14/05 20:05:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 20:05:38 2005
12/14/05 20:05:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 20:05:38 2005
12/14/05 20:10:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 20:10:38 2005
12/14/05 20:10:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 20:10:38 2005
12/14/05 20:15:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 20:15:38 2005
12/14/05 20:15:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 20:15:38 2005
12/14/05 20:20:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 20:20:38 2005
12/14/05 20:20:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 20:20:38 2005
12/14/05 20:25:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 20:25:38 2005
12/14/05 20:25:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 20:25:38 2005
12/14/05 20:30:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 20:30:38 2005
12/14/05 20:30:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 20:30:38 2005
12/14/05 20:35:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 20:35:38 2005
12/14/05 20:35:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 20:35:38 2005
12/14/05 20:40:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 20:40:38 2005
12/14/05 20:40:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 20:40:38 2005
12/14/05 20:45:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 20:45:38 2005
12/14/05 20:45:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 20:45:38 2005
12/14/05 20:50:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 20:50:38 2005
12/14/05 20:50:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 20:50:38 2005
12/14/05 20:55:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 20:55:38 2005
12/14/05 20:55:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 20:55:38 2005
12/14/05 21:00:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 21:00:38 2005
12/14/05 21:00:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 21:00:38 2005
12/14/05 21:05:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 21:05:38 2005
12/14/05 21:05:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 21:05:38 2005
12/14/05 21:10:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 21:10:38 2005
12/14/05 21:10:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 21:10:38 2005
12/14/05 21:15:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 21:15:38 2005
12/14/05 21:15:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 21:15:38 2005
12/14/05 21:20:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 21:20:38 2005
12/14/05 21:20:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 21:20:38 2005
12/14/05 21:25:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 21:25:38 2005
12/14/05 21:25:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 21:25:38 2005
12/14/05 21:30:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 21:30:38 2005
12/14/05 21:30:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 21:30:38 2005
12/14/05 21:35:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 21:35:38 2005
12/14/05 21:35:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 21:35:38 2005
12/14/05 21:40:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 21:40:38 2005
12/14/05 21:40:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 21:40:38 2005
12/14/05 21:45:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 21:45:38 2005
12/14/05 21:45:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 21:45:38 2005
12/14/05 21:50:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 21:50:38 2005
12/14/05 21:50:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 21:50:38 2005
12/14/05 21:55:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 21:55:38 2005
12/14/05 21:55:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 21:55:38 2005
12/14/05 22:00:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 22:00:38 2005
12/14/05 22:00:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 22:00:38 2005
12/14/05 22:05:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 22:05:38 2005
12/14/05 22:05:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 22:05:38 2005
12/14/05 22:10:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 22:10:38 2005
12/14/05 22:10:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 22:10:38 2005
12/14/05 22:15:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 22:15:38 2005
12/14/05 22:15:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 22:15:38 2005
12/14/05 22:20:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 22:20:38 2005
12/14/05 22:20:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 22:20:38 2005
12/14/05 22:25:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 22:25:38 2005
12/14/05 22:25:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 22:25:38 2005
12/14/05 22:30:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 22:30:38 2005
12/14/05 22:30:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 22:30:38 2005
12/14/05 22:35:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 22:35:38 2005
12/14/05 22:35:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 22:35:38 2005
12/14/05 22:40:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 22:40:38 2005
12/14/05 22:40:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 22:40:38 2005
12/14/05 22:45:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 22:45:38 2005
12/14/05 22:45:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 22:45:38 2005
12/14/05 22:50:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 22:50:38 2005
12/14/05 22:50:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 22:50:38 2005
12/14/05 22:55:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 22:55:38 2005
12/14/05 22:55:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 22:55:38 2005
12/14/05 23:00:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 23:00:38 2005
12/14/05 23:00:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 23:00:38 2005
12/14/05 23:05:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 23:05:38 2005
12/14/05 23:05:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 23:05:38 2005
12/14/05 23:10:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 23:10:38 2005
12/14/05 23:10:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 23:10:38 2005
12/14/05 23:15:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 23:15:38 2005
12/14/05 23:15:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 23:15:38 2005
12/14/05 23:20:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 23:20:38 2005
12/14/05 23:20:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 23:20:38 2005
12/14/05 23:25:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 23:25:38 2005
12/14/05 23:25:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 23:25:38 2005
12/14/05 23:30:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 23:30:38 2005
12/14/05 23:30:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 23:30:38 2005
12/14/05 23:35:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 23:35:38 2005
12/14/05 23:35:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 23:35:38 2005
12/14/05 23:40:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 23:40:38 2005
12/14/05 23:40:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 23:40:38 2005
12/14/05 23:45:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 23:45:38 2005
12/14/05 23:45:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 23:45:38 2005
12/14/05 23:50:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 23:50:38 2005
12/14/05 23:50:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 23:50:38 2005
12/14/05 23:55:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Wed Dec 14 23:55:38 2005
12/14/05 23:55:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Wed Dec 14 23:55:38 2005
12/15/05 00:00:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 00:00:38 2005
12/15/05 00:00:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 00:00:38 2005
12/15/05 00:05:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 00:05:38 2005
12/15/05 00:05:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 00:05:38 2005
12/15/05 00:10:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 00:10:38 2005
12/15/05 00:10:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 00:10:38 2005
12/15/05 00:15:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 00:15:38 2005
12/15/05 00:15:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 00:15:38 2005
12/15/05 00:20:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 00:20:38 2005
12/15/05 00:20:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 00:20:38 2005
12/15/05 00:25:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 00:25:38 2005
12/15/05 00:25:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 00:25:38 2005
12/15/05 00:30:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 00:30:38 2005
12/15/05 00:30:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 00:30:38 2005
12/15/05 00:35:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 00:35:38 2005
12/15/05 00:35:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 00:35:38 2005
12/15/05 00:40:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 00:40:38 2005
12/15/05 00:40:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 00:40:38 2005
12/15/05 00:45:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 00:45:38 2005
12/15/05 00:45:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 00:45:38 2005
12/15/05 00:50:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 00:50:38 2005
12/15/05 00:50:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 00:50:38 2005
12/15/05 00:55:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 00:55:38 2005
12/15/05 00:55:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 00:55:38 2005
12/15/05 01:00:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 01:00:38 2005
12/15/05 01:00:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 01:00:38 2005
12/15/05 01:05:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 01:05:38 2005
12/15/05 01:05:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 01:05:38 2005
12/15/05 01:10:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 01:10:38 2005
12/15/05 01:10:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 01:10:38 2005
12/15/05 01:15:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 01:15:38 2005
12/15/05 01:15:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 01:15:38 2005
12/15/05 01:20:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 01:20:38 2005
12/15/05 01:20:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 01:20:38 2005
12/15/05 01:25:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 01:25:38 2005
12/15/05 01:25:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 01:25:38 2005
12/15/05 01:30:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 01:30:38 2005
12/15/05 01:30:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 01:30:38 2005
12/15/05 01:35:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 01:35:38 2005
12/15/05 01:35:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 01:35:38 2005
12/15/05 01:40:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 01:40:38 2005
12/15/05 01:40:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 01:40:38 2005
12/15/05 01:45:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 01:45:38 2005
12/15/05 01:45:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 01:45:38 2005
12/15/05 01:50:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 01:50:38 2005
12/15/05 01:50:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 01:50:38 2005
12/15/05 01:55:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 01:55:38 2005
12/15/05 01:55:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 01:55:38 2005
12/15/05 02:00:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 02:00:38 2005
12/15/05 02:00:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 02:00:38 2005
12/15/05 02:05:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 02:05:38 2005
12/15/05 02:05:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 02:05:38 2005
12/15/05 02:10:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 02:10:38 2005
12/15/05 02:10:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 02:10:38 2005
12/15/05 02:15:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 02:15:38 2005
12/15/05 02:15:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 02:15:38 2005
12/15/05 02:20:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 02:20:38 2005
12/15/05 02:20:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 02:20:38 2005
12/15/05 02:25:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 02:25:38 2005
12/15/05 02:25:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 02:25:38 2005
12/15/05 02:30:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 02:30:38 2005
12/15/05 02:30:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 02:30:38 2005
12/15/05 02:35:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 02:35:38 2005
12/15/05 02:35:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 02:35:38 2005
12/15/05 02:40:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 02:40:38 2005
12/15/05 02:40:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 02:40:38 2005
12/15/05 02:45:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 02:45:38 2005
12/15/05 02:45:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 02:45:38 2005
12/15/05 02:50:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 02:50:38 2005
12/15/05 02:50:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 02:50:38 2005
12/15/05 02:55:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 02:55:38 2005
12/15/05 02:55:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 02:55:38 2005
12/15/05 03:00:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 03:00:38 2005
12/15/05 03:00:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 03:00:38 2005
12/15/05 03:05:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 03:05:38 2005
12/15/05 03:05:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 03:05:38 2005
12/15/05 03:10:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 03:10:38 2005
12/15/05 03:10:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 03:10:38 2005
12/15/05 03:15:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 03:15:38 2005
12/15/05 03:15:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 03:15:38 2005
12/15/05 03:20:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 03:20:38 2005
12/15/05 03:20:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 03:20:38 2005
12/15/05 03:25:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 03:25:38 2005
12/15/05 03:25:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 03:25:38 2005
12/15/05 03:30:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 03:30:38 2005
12/15/05 03:30:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 03:30:38 2005
12/15/05 03:35:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 03:35:38 2005
12/15/05 03:35:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 03:35:38 2005
12/15/05 03:40:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 03:40:38 2005
12/15/05 03:40:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 03:40:38 2005
12/15/05 03:45:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 03:45:38 2005
12/15/05 03:45:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 03:45:38 2005
12/15/05 03:50:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 03:50:38 2005
12/15/05 03:50:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 03:50:38 2005
12/15/05 03:55:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 03:55:38 2005
12/15/05 03:55:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 03:55:38 2005
12/15/05 04:00:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 04:00:38 2005
12/15/05 04:00:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 04:00:38 2005
12/15/05 04:05:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 04:05:38 2005
12/15/05 04:05:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 04:05:38 2005
12/15/05 04:10:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 04:10:38 2005
12/15/05 04:10:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 04:10:38 2005
12/15/05 04:15:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 04:15:38 2005
12/15/05 04:15:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 04:15:38 2005
12/15/05 04:20:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 04:20:38 2005
12/15/05 04:20:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 04:20:38 2005
12/15/05 04:25:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 04:25:38 2005
12/15/05 04:25:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 04:25:38 2005
12/15/05 04:30:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 04:30:38 2005
12/15/05 04:30:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 04:30:38 2005
12/15/05 04:35:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 04:35:38 2005
12/15/05 04:35:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 04:35:38 2005
12/15/05 04:40:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 04:40:38 2005
12/15/05 04:40:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 04:40:38 2005
12/15/05 04:45:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 04:45:38 2005
12/15/05 04:45:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 04:45:38 2005
12/15/05 04:50:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 04:50:38 2005
12/15/05 04:50:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 04:50:38 2005
12/15/05 04:55:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 04:55:38 2005
12/15/05 04:55:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 04:55:38 2005
12/15/05 05:00:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 05:00:38 2005
12/15/05 05:00:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 05:00:38 2005
12/15/05 05:05:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 05:05:38 2005
12/15/05 05:05:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 05:05:38 2005
12/15/05 05:10:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 05:10:38 2005
12/15/05 05:10:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 05:10:38 2005
12/15/05 05:15:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 05:15:38 2005
12/15/05 05:15:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 05:15:38 2005
12/15/05 05:20:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 05:20:38 2005
12/15/05 05:20:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 05:20:38 2005
12/15/05 05:25:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 05:25:38 2005
12/15/05 05:25:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 05:25:38 2005
12/15/05 05:30:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 05:30:38 2005
12/15/05 05:30:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 05:30:38 2005
12/15/05 05:35:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 05:35:38 2005
12/15/05 05:35:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 05:35:38 2005
12/15/05 05:40:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 05:40:38 2005
12/15/05 05:40:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 05:40:38 2005
12/15/05 05:45:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 05:45:38 2005
12/15/05 05:45:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 05:45:38 2005
12/15/05 05:50:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 05:50:38 2005
12/15/05 05:50:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 05:50:38 2005
12/15/05 05:55:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 05:55:38 2005
12/15/05 05:55:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 05:55:38 2005
12/15/05 06:00:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 06:00:38 2005
12/15/05 06:00:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 06:00:38 2005
12/15/05 06:05:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 06:05:38 2005
12/15/05 06:05:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 06:05:38 2005
12/15/05 06:10:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 06:10:38 2005
12/15/05 06:10:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 06:10:38 2005
12/15/05 06:15:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 06:15:38 2005
12/15/05 06:15:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 06:15:38 2005
12/15/05 06:20:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 06:20:38 2005
12/15/05 06:20:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 06:20:38 2005
12/15/05 06:25:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 06:25:38 2005
12/15/05 06:25:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 06:25:38 2005
12/15/05 06:30:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 06:30:38 2005
12/15/05 06:30:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 06:30:38 2005
12/15/05 06:35:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 06:35:38 2005
12/15/05 06:35:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 06:35:38 2005
12/15/05 06:40:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 06:40:38 2005
12/15/05 06:40:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 06:40:38 2005
12/15/05 06:45:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 06:45:38 2005
12/15/05 06:45:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 06:45:38 2005
12/15/05 06:50:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 06:50:38 2005
12/15/05 06:50:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 06:50:38 2005
12/15/05 06:55:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 06:55:38 2005
12/15/05 06:55:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 06:55:38 2005
12/15/05 07:00:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 07:00:38 2005
12/15/05 07:00:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 07:00:38 2005
12/15/05 07:05:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 07:05:38 2005
12/15/05 07:05:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 07:05:38 2005
12/15/05 07:10:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 07:10:38 2005
12/15/05 07:10:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 07:10:38 2005
12/15/05 07:15:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 07:15:38 2005
12/15/05 07:15:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 07:15:38 2005
12/15/05 07:20:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 07:20:38 2005
12/15/05 07:20:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 07:20:38 2005
12/15/05 07:25:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 07:25:38 2005
12/15/05 07:25:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 07:25:38 2005
12/15/05 07:30:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 07:30:38 2005
12/15/05 07:30:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 07:30:38 2005
12/15/05 07:35:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 07:35:38 2005
12/15/05 07:35:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 07:35:38 2005
12/15/05 07:40:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 07:40:38 2005
12/15/05 07:40:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 07:40:38 2005
12/15/05 07:45:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 07:45:38 2005
12/15/05 07:45:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 07:45:38 2005
12/15/05 07:50:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 07:50:38 2005
12/15/05 07:50:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 07:50:38 2005
12/15/05 07:55:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 07:55:38 2005
12/15/05 07:55:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 07:55:38 2005
12/15/05 08:00:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 08:00:38 2005
12/15/05 08:00:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 08:00:38 2005
12/15/05 08:05:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 08:05:38 2005
12/15/05 08:05:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 08:05:38 2005
12/15/05 08:10:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 08:10:38 2005
12/15/05 08:10:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 08:10:38 2005
12/15/05 08:15:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 08:15:38 2005
12/15/05 08:15:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 08:15:38 2005
12/15/05 08:20:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 08:20:38 2005
12/15/05 08:20:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 08:20:38 2005
12/15/05 08:25:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 08:25:38 2005
12/15/05 08:25:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 08:25:38 2005
12/15/05 08:30:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 08:30:38 2005
12/15/05 08:30:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 08:30:38 2005
12/15/05 08:35:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 08:35:38 2005
12/15/05 08:35:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 08:35:38 2005
12/15/05 08:40:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 08:40:38 2005
12/15/05 08:40:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 08:40:38 2005
12/15/05 08:45:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 08:45:38 2005
12/15/05 08:45:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 08:45:38 2005
12/15/05 08:50:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 08:50:38 2005
12/15/05 08:50:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 08:50:38 2005
12/15/05 08:55:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 08:55:38 2005
12/15/05 08:55:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 08:55:38 2005
12/15/05 09:00:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 09:00:38 2005
12/15/05 09:00:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 09:00:38 2005
12/15/05 09:05:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 09:05:38 2005
12/15/05 09:05:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 09:05:38 2005
12/15/05 09:10:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 09:10:38 2005
12/15/05 09:10:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 09:10:38 2005
12/15/05 09:15:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 09:15:38 2005
12/15/05 09:15:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 09:15:38 2005
12/15/05 09:20:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 09:20:38 2005
12/15/05 09:20:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 09:20:38 2005
12/15/05 09:25:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 09:25:38 2005
12/15/05 09:25:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 09:25:38 2005
12/15/05 09:30:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 09:30:38 2005
12/15/05 09:30:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 09:30:38 2005
12/15/05 09:35:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 09:35:38 2005
12/15/05 09:35:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 09:35:38 2005
12/15/05 09:40:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 09:40:38 2005
12/15/05 09:40:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 09:40:38 2005
12/15/05 09:45:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 09:45:38 2005
12/15/05 09:45:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 09:45:38 2005
12/15/05 09:50:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 09:50:38 2005
12/15/05 09:50:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 09:50:38 2005
12/15/05 09:55:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 09:55:38 2005
12/15/05 09:55:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 09:55:38 2005
12/15/05 10:00:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 10:00:38 2005
12/15/05 10:00:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 10:00:38 2005
12/15/05 10:05:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 10:05:38 2005
12/15/05 10:05:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 10:05:38 2005
12/15/05 10:10:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 10:10:38 2005
12/15/05 10:10:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 10:10:38 2005
12/15/05 10:15:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 10:15:38 2005
12/15/05 10:15:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 10:15:38 2005
12/15/05 10:20:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 10:20:38 2005
12/15/05 10:20:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 10:20:38 2005
12/15/05 10:25:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 10:25:38 2005
12/15/05 10:25:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 10:25:38 2005
12/15/05 10:30:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 10:30:38 2005
12/15/05 10:30:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 10:30:38 2005
12/15/05 10:35:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 10:35:38 2005
12/15/05 10:35:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 10:35:38 2005
12/15/05 10:40:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 10:40:38 2005
12/15/05 10:40:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 10:40:38 2005
12/15/05 10:45:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 10:45:38 2005
12/15/05 10:45:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 10:45:38 2005
12/15/05 10:50:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 10:50:38 2005
12/15/05 10:50:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 10:50:38 2005
12/15/05 10:55:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 10:55:38 2005
12/15/05 10:55:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 10:55:38 2005
12/15/05 11:00:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 11:00:38 2005
12/15/05 11:00:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 11:00:38 2005
12/15/05 11:05:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 11:05:38 2005
12/15/05 11:05:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 11:05:38 2005
12/15/05 11:10:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 11:10:38 2005
12/15/05 11:10:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 11:10:38 2005
12/15/05 11:15:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 11:15:38 2005
12/15/05 11:15:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 11:15:38 2005
12/15/05 11:20:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 11:20:38 2005
12/15/05 11:20:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 11:20:38 2005
12/15/05 11:25:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 11:25:38 2005
12/15/05 11:25:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 11:25:38 2005
12/15/05 11:30:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 11:30:38 2005
12/15/05 11:30:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 11:30:38 2005
12/15/05 11:35:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 11:35:38 2005
12/15/05 11:35:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 11:35:38 2005
12/15/05 11:40:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 11:40:38 2005
12/15/05 11:40:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 11:40:38 2005
12/15/05 11:45:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 11:45:38 2005
12/15/05 11:45:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 11:45:38 2005
12/15/05 11:50:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 11:50:38 2005
12/15/05 11:50:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 11:50:38 2005
12/15/05 11:55:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 11:55:38 2005
12/15/05 11:55:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 11:55:38 2005
12/15/05 12:00:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 12:00:38 2005
12/15/05 12:00:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 12:00:38 2005
12/15/05 12:05:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 12:05:38 2005
12/15/05 12:05:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 12:05:38 2005
12/15/05 12:10:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 12:10:38 2005
12/15/05 12:10:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 12:10:38 2005
12/15/05 12:15:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 12:15:38 2005
12/15/05 12:15:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 12:15:38 2005
12/15/05 12:20:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 12:20:38 2005
12/15/05 12:20:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 12:20:38 2005
12/15/05 12:25:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 12:25:38 2005
12/15/05 12:25:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 12:25:38 2005
12/15/05 12:30:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 12:30:38 2005
12/15/05 12:30:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 12:30:38 2005
12/15/05 12:35:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 12:35:38 2005
12/15/05 12:35:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 12:35:38 2005
12/15/05 12:40:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 12:40:38 2005
12/15/05 12:40:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 12:40:38 2005
12/15/05 12:45:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 12:45:38 2005
12/15/05 12:45:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 12:45:38 2005
12/15/05 12:50:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 12:50:38 2005
12/15/05 12:50:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 12:50:38 2005
12/15/05 12:55:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 12:55:38 2005
12/15/05 12:55:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 12:55:38 2005
12/15/05 13:00:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 13:00:38 2005
12/15/05 13:00:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 13:00:38 2005
12/15/05 13:05:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 13:05:38 2005
12/15/05 13:05:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 13:05:38 2005
12/15/05 13:10:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 13:10:38 2005
12/15/05 13:10:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 13:10:38 2005
12/15/05 13:15:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 13:15:38 2005
12/15/05 13:15:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 13:15:38 2005
12/15/05 13:20:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 13:20:38 2005
12/15/05 13:20:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 13:20:38 2005
12/15/05 13:25:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 13:25:38 2005
12/15/05 13:25:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 13:25:38 2005
12/15/05 13:30:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 13:30:38 2005
12/15/05 13:30:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 13:30:38 2005
12/15/05 13:35:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 13:35:38 2005
12/15/05 13:35:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 13:35:38 2005
12/15/05 13:40:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 13:40:38 2005
12/15/05 13:40:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 13:40:38 2005
12/15/05 13:45:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 13:45:38 2005
12/15/05 13:45:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 13:45:38 2005
12/15/05 13:50:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 13:50:38 2005
12/15/05 13:50:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 13:50:38 2005
12/15/05 13:55:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 13:55:38 2005
12/15/05 13:55:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 13:55:38 2005
12/15/05 14:00:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 14:00:38 2005
12/15/05 14:00:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 14:00:38 2005
12/15/05 14:05:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 14:05:38 2005
12/15/05 14:05:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 14:05:38 2005
12/15/05 14:10:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 14:10:38 2005
12/15/05 14:10:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 14:10:38 2005
12/15/05 14:15:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 14:15:38 2005
12/15/05 14:15:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 14:15:38 2005
12/15/05 14:20:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 14:20:38 2005
12/15/05 14:20:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 14:20:38 2005
12/15/05 14:25:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 14:25:38 2005
12/15/05 14:25:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 14:25:38 2005
12/15/05 14:30:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 14:30:38 2005
12/15/05 14:30:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 14:30:38 2005
12/15/05 14:35:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 14:35:38 2005
12/15/05 14:35:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 14:35:38 2005
12/15/05 14:40:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 14:40:38 2005
12/15/05 14:40:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 14:40:38 2005
12/15/05 14:45:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 14:45:38 2005
12/15/05 14:45:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 14:45:38 2005
12/15/05 14:50:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 14:50:38 2005
12/15/05 14:50:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 14:50:38 2005
12/15/05 14:55:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 14:55:38 2005
12/15/05 14:55:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 14:55:38 2005
12/15/05 15:00:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 15:00:38 2005
12/15/05 15:00:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 15:00:38 2005
12/15/05 15:02:24 3600 VenueServer venue.py:2308 DEBUG Authorizing () _SOAPContext
12/15/05 15:02:24 3600 VenueServer venue.py:2316 INFO Authorizing action: Enter for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:02:24 3600 VenueServer venue.py:2348 DEBUG Interface Enter: Called.
12/15/05 15:02:24 3600 VenueServer venue.py:1254 DEBUG Enter called.
12/15/05 15:02:24 3600 VenueServer venue.py:1261 DEBUG Enter: Assigning private id: 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8
12/15/05 15:02:24 3600 VenueServer venue.py:850 DEBUG added user as producer of non-existent stream
12/15/05 15:02:24 3600 VenueServer venue.py:4095 DEBUG StreamDescriptionList.index Address 224.2.175.110 224.2.175.122
12/15/05 15:02:24 3600 VenueServer venue.py:4098 DEBUG StreamDescriptionList.index Port 54798 56424
12/15/05 15:02:24 3600 VenueServer venue.py:3984 DEBUG * * * Added stream producer 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8
12/15/05 15:02:24 3600 VenueServer venue.py:4095 DEBUG StreamDescriptionList.index Address 224.2.175.122 224.2.175.122
12/15/05 15:02:24 3600 VenueServer venue.py:4098 DEBUG StreamDescriptionList.index Port 56424 56424
12/15/05 15:02:24 3600 VenueServer venue.py:829 DEBUG added user as producer of existent stream
12/15/05 15:02:24 3600 VenueServer venue.py:1279 DEBUG Current users:
12/15/05 15:02:24 3600 VenueServer venue.py:1281 DEBUG VenueClientState(name=UCSF China Basin Microbilogy privateID=0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 lastHeartbeat=1134687744.23)
12/15/05 15:02:24 3600 VenueServer venue.py:1282 DEBUG Enter: Distribute enter event
12/15/05 15:02:24 3600 TextService textserviceasynch.py:726 DEBUG TextServiceAsynch: GetLocation
12/15/05 15:02:24 3600 VenueServer venue.py:1293 DEBUG state: <AccessGrid.Descriptions.VenueState instance at 0x013CD198>
12/15/05 15:02:24 892 VenueServer venue.py:1175 DEBUG Venue gets channelAuthCallback, privateID=0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8
12/15/05 15:02:24 892 VenueServer venue.py:1179 DEBUG Private id is in client list, authorizing
12/15/05 15:02:24 892 VenueServer venue.py:258 DEBUG Set connection for UCSF China Basin Microbilogy
12/15/05 15:02:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687744.38.
12/15/05 15:02:24 3352 VenueServer venue.py:2308 DEBUG Authorizing () _SOAPContext
12/15/05 15:02:24 3352 VenueServer venue.py:2316 INFO Authorizing action: GetUploadDescriptor for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:02:24 456 TextService textserviceasynch.py:482 INFO Listen Callback 'None' '_68f2cd00_p_globus_io_handle_t' '(0, None, None)'
12/15/05 15:02:24 456 TextService textserviceasynch.py:72 INFO conn handler registering accept
12/15/05 15:02:24 456 TextService textserviceasynch.py:77 INFO register_accept returns socket=<pyGlobus.io.GSITCPSocket instance at 0x01314580> cb=_f8b9cd00_p_callbackStruct
12/15/05 15:02:24 456 TextService textserviceasynch.py:87 INFO Accept Callback 'None' '_e8f5cd00_p_globus_io_handle_t' '(0, None, None)'
12/15/05 15:02:24 456 TextService textserviceasynch.py:473 DEBUG TextServiceAsynch: register_listen returns '_f8b9cd00_p_callbackStruct'
12/15/05 15:02:24 456 TextService textserviceasynch.py:154 INFO Got read handle=_e8f5cd00_p_globus_io_handle_t ret=(0, None, None) n=4
12/15/05 15:02:24 456 TextService textserviceasynch.py:154 INFO Got read handle=_e8f5cd00_p_globus_io_handle_t ret=(0, None, None) n=230
12/15/05 15:02:24 456 TextService textserviceasynch.py:184 INFO finished reading packet, wait=230 buflen=230
12/15/05 15:02:24 456 TextService textserviceasynch.py:214 INFO TextConnection: Got Event Event:
Type: Connect Venue: 000001067ae47fbc00400036001d00f70cc
12/15/05 15:02:24 456 TextService textserviceasynch.py:558 INFO Enqueue event Connect for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x013941C0>...
12/15/05 15:02:24 2764 TextService textserviceasynch.py:575 INFO Queue handler received ('event', Event:
Type: Connect Venue: 000001067ae47fbc00400036001d00f70cc, <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x013941C0>)
12/15/05 15:02:24 2764 TextService textserviceasynch.py:619 INFO Handle event type Connect
12/15/05 15:02:24 2764 TextService textserviceasynch.py:300 DEBUG TextServiceAsynch: Attempting authorization on event Connect
12/15/05 15:02:24 2764 VenueServer venue.py:1215 DEBUG Venue gets channelAuthCallback, privateID=0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8
12/15/05 15:02:24 2764 VenueServer venue.py:1219 DEBUG Private id is in client list, authorizing
12/15/05 15:02:24 2764 TextService textserviceasynch.py:319 DEBUG TextServiceAsynch: Auth callback <bound method Venue.textChannelAuthCallback of Venue: name=UCSF Lab Med Lobby id=17441696 url=https://64.54.29.247:8000/Venues/000001067ae47fbc00400036001d00f70cc> returns 1
12/15/05 15:02:24 2764 TextService textserviceasynch.py:679 DEBUG TextServiceAsynch: Adding connObj 0000010830a8f20300400036001d00f7c0c to channel 000001067ae47fbc00400036001d00f70cc
12/15/05 15:02:24 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:02:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687749.38.
12/15/05 15:02:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687754.38.
12/15/05 15:02:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687759.38.
12/15/05 15:02:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687764.38.
12/15/05 15:02:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687769.39.
12/15/05 15:02:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687774.38.
12/15/05 15:02:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687779.39.
12/15/05 15:03:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687784.38.
12/15/05 15:03:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687789.39.
12/15/05 15:03:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687794.38.
12/15/05 15:03:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687799.38.
12/15/05 15:03:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687804.38.
12/15/05 15:03:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687809.38.
12/15/05 15:03:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687814.39.
12/15/05 15:03:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687819.38.
12/15/05 15:03:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687824.39.
12/15/05 15:03:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687829.38.
12/15/05 15:03:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687834.39.
12/15/05 15:03:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687839.38.
12/15/05 15:04:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687844.39.
12/15/05 15:04:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687849.38.
12/15/05 15:04:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687854.38.
12/15/05 15:04:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687859.38.
12/15/05 15:04:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687864.38.
12/15/05 15:04:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687869.38.
12/15/05 15:04:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687874.39.
12/15/05 15:04:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687879.38.
12/15/05 15:04:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687884.38.
12/15/05 15:04:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687889.38.
12/15/05 15:04:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687894.38.
12/15/05 15:04:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687899.38.
12/15/05 15:05:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687904.38.
12/15/05 15:05:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687909.38.
12/15/05 15:05:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687914.39.
12/15/05 15:05:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687919.38.
12/15/05 15:05:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687924.38.
12/15/05 15:05:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687929.38.
12/15/05 15:05:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687934.38.
12/15/05 15:05:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 15:05:38 2005
12/15/05 15:05:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 15:05:38 2005
12/15/05 15:05:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687939.38.
12/15/05 15:05:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687944.38.
12/15/05 15:05:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687949.38.
12/15/05 15:05:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687954.38.
12/15/05 15:05:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687959.38.
12/15/05 15:06:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687964.39.
12/15/05 15:06:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687969.38.
12/15/05 15:06:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687974.38.
12/15/05 15:06:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687979.38.
12/15/05 15:06:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687984.38.
12/15/05 15:06:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687989.38.
12/15/05 15:06:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687994.38.
12/15/05 15:06:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134687999.38.
12/15/05 15:06:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688004.39.
12/15/05 15:06:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688009.38.
12/15/05 15:06:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688014.38.
12/15/05 15:06:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688019.38.
12/15/05 15:07:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688024.38.
12/15/05 15:07:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688029.38.
12/15/05 15:07:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688034.38.
12/15/05 15:07:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688039.38.
12/15/05 15:07:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688044.38.
12/15/05 15:07:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688049.38.
12/15/05 15:07:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688054.38.
12/15/05 15:07:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688059.38.
12/15/05 15:07:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688064.38.
12/15/05 15:07:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688069.38.
12/15/05 15:07:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688074.39.
12/15/05 15:07:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688079.38.
12/15/05 15:08:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688084.38.
12/15/05 15:08:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688089.38.
12/15/05 15:08:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688094.38.
12/15/05 15:08:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688099.38.
12/15/05 15:08:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688104.38.
12/15/05 15:08:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688109.38.
12/15/05 15:08:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688114.39.
12/15/05 15:08:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688119.38.
12/15/05 15:08:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688124.39.
12/15/05 15:08:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688129.38.
12/15/05 15:08:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688134.38.
12/15/05 15:08:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688139.38.
12/15/05 15:09:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688144.38.
12/15/05 15:09:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688149.38.
12/15/05 15:09:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688154.38.
12/15/05 15:09:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688159.38.
12/15/05 15:09:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688164.39.
12/15/05 15:09:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688169.38.
12/15/05 15:09:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688174.38.
12/15/05 15:09:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688179.38.
12/15/05 15:09:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688184.38.
12/15/05 15:09:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688189.38.
12/15/05 15:09:54 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688194.38.
12/15/05 15:09:59 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688199.38.
12/15/05 15:10:04 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688204.39.
12/15/05 15:10:09 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688209.38.
12/15/05 15:10:14 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688214.38.
12/15/05 15:10:19 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688219.38.
12/15/05 15:10:24 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688224.38.
12/15/05 15:10:29 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688229.38.
12/15/05 15:10:34 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688234.38.
12/15/05 15:10:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 15:10:38 2005
12/15/05 15:10:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 15:10:38 2005
12/15/05 15:10:39 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688239.38.
12/15/05 15:10:44 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688244.39.
12/15/05 15:10:49 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8 at 1134688249.38.
12/15/05 15:10:49 4060 VenueServer venue.py:2308 DEBUG Authorizing () _SOAPContext
12/15/05 15:10:49 4060 VenueServer venue.py:2316 INFO Authorizing action: Exit for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:10:49 4060 VenueServer venue.py:1761 DEBUG Called Venue Exit on 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8
12/15/05 15:10:49 4060 VenueServer venue.py:1031 DEBUG Called RemoveUser on 0000010830a8f0ea00400036001d00f73ae_0000010830a8f0ea00400036001d00f71e8
12/15/05 15:10:49 4060 VenueServer venue.py:4095 DEBUG StreamDescriptionList.index Address 224.2.175.122 224.2.175.122
12/15/05 15:10:49 4060 VenueServer venue.py:4098 DEBUG StreamDescriptionList.index Port 56424 56424
12/15/05 15:10:49 4060 VenueServer venue.py:4095 DEBUG StreamDescriptionList.index Address 224.2.175.110 224.2.175.122
12/15/05 15:10:49 4060 VenueServer venue.py:4098 DEBUG StreamDescriptionList.index Port 54798 56424
12/15/05 15:10:49 4060 VenueServer venue.py:4095 DEBUG StreamDescriptionList.index Address 224.2.175.110 224.2.175.110
12/15/05 15:10:49 4060 VenueServer venue.py:4098 DEBUG StreamDescriptionList.index Port 54798 54798
12/15/05 15:10:49 4060 VenueServer venue.py:1033 DEBUG Removed streams = [StreamDescription: {'description': None, 'encryptionKey': None, 'uri': None, 'encryptionFlag': 0, 'capability': producer audio, 'static': 0, 'location': multicast 224.2.175.110 54798 127, 'id': '0000010830a8f10900400036001d00f7284', 'networkLocations': [multicast 224.2.175.110 54798 127], 'name': 'UCSF Lab Med Lobby'}]
12/15/05 15:10:49 4060 VenueServer venue.py:1075 DEBUG Removing single instance of user
12/15/05 15:10:49 4060 EventService eventserviceasynch.py:497 ERROR RemoveConnection: connection 0000010830a8f15700400036001d00f7829 not in connection list
12/15/05 15:10:49 356 EventService eventserviceasynch.py:242 ERROR writeMarshalledEvent write error!
Traceback (most recent call last):
File "C:\Python23\Lib\site-packages\AccessGrid\EventServiceAsynch.py", line 236, in writeMarshalledEvent
mEvent.Write(self.wfile)
File "C:\Python23\Lib\site-packages\AccessGrid\Events.py", line 243, in Write
fh.write(self.sizeStr)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 377, in write
self.sock.write(str, len(str))
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 253, in write
raise ex
IOBaseException: an uninitialied data structure was passed as argument 1 to globus_io_try_write
12/15/05 15:10:49 4060 TextService textserviceasynch.py:511 DEBUG TextServiceAsynch: Removing connection 0000010830a8f20300400036001d00f7c0c
12/15/05 15:10:49 456 TextService textserviceasynch.py:154 INFO Got read handle=_e8f5cd00_p_globus_io_handle_t ret=(-1, 64, 'an I/O operation was cancelled') n=0
12/15/05 15:10:49 356 EventService eventserviceasynch.py:497 ERROR RemoveConnection: connection 0000010830a8f15700400036001d00f7829 not in connection list
12/15/05 15:10:49 456 TextService textserviceasynch.py:157 DEBUG TextServiceAsynch: readCallback returned failure: -1 64
12/15/05 15:10:49 456 TextService textserviceasynch.py:199 ERROR TextServiceAsynch: IOBase exception on text service close (probably ok)
File "C:\Python23\Lib\site-packages\AccessGrid\TextServiceAsynch.py", line 196, in stop
self.wfile.close()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 391, in close
self.sock.close()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1020, in close
IOBase.close(self)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 176, in close
raise ex
IOBaseException: the handle 00CDF5E8 was already registered for closing
12/15/05 15:10:49 456 TextService textserviceasynch.py:562 INFO Enqueue EOF for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x013941C0>...
12/15/05 15:10:49 2764 TextService textserviceasynch.py:575 INFO Queue handler received ('eof', <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x013941C0>)
12/15/05 15:10:49 456 TextService textserviceasynch.py:124 ERROR readcallback failed
File "C:\Python23\Lib\site-packages\AccessGrid\TextServiceAsynch.py", line 122, in readCallbackWrap
self.registerForRead()
File "C:\Python23\Lib\site-packages\AccessGrid\TextServiceAsynch.py", line 109, in registerForRead
None)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 198, in register_read
raise ex
12/15/05 15:10:49 2764 TextService textserviceasynch.py:581 DEBUG TextServiceAsynch: EOF on connection 0000010830a8f20300400036001d00f7c0c
self.wfile.close()
self.sock.close()
IOBase.close(self)
raise ex
12/15/05 15:10:49 2764 TextService textserviceasynch.py:511 DEBUG TextServiceAsynch: Removing connection 0000010830a8f20300400036001d00f7c0c
12/15/05 15:10:49 4060 VenueServer venue.py:1113 DEBUG RemoveUser: Distribute EXIT event
12/15/05 15:10:49 2764 TextService textserviceasynch.py:199 ERROR TextServiceAsynch: IOBase exception on text service close (probably ok)
self.wfile.close()
self.sock.close()
IOBase.close(self)
raise ex
IOBaseException: an uninitialied data structure was passed as argument 1 to globus_io_register_close
12/15/05 15:10:49 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:11:32 476 VenueServer venue.py:2308 DEBUG Authorizing () _SOAPContext
12/15/05 15:11:32 476 VenueServer venue.py:2316 INFO Authorizing action: Enter for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:11:32 476 VenueServer venue.py:2348 DEBUG Interface Enter: Called.
12/15/05 15:11:32 476 VenueServer venue.py:1254 DEBUG Enter called.
12/15/05 15:11:32 476 VenueServer venue.py:1261 DEBUG Enter: Assigning private id: 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168
12/15/05 15:11:32 476 VenueServer venue.py:850 DEBUG added user as producer of non-existent stream
12/15/05 15:11:32 476 VenueServer venue.py:4095 DEBUG StreamDescriptionList.index Address 224.2.231.110 224.2.175.122
12/15/05 15:11:32 476 VenueServer venue.py:4098 DEBUG StreamDescriptionList.index Port 52066 56424
12/15/05 15:11:32 476 VenueServer venue.py:3984 DEBUG * * * Added stream producer 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168
12/15/05 15:11:32 476 VenueServer venue.py:4095 DEBUG StreamDescriptionList.index Address 224.2.175.122 224.2.175.122
12/15/05 15:11:32 476 VenueServer venue.py:4098 DEBUG StreamDescriptionList.index Port 56424 56424
12/15/05 15:11:32 476 VenueServer venue.py:829 DEBUG added user as producer of existent stream
12/15/05 15:11:32 476 VenueServer venue.py:1279 DEBUG Current users:
12/15/05 15:11:32 476 VenueServer venue.py:1281 DEBUG VenueClientState(name=UCSF China Basin Microbilogy privateID=0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 lastHeartbeat=1134688292.3)
12/15/05 15:11:32 476 VenueServer venue.py:1282 DEBUG Enter: Distribute enter event
12/15/05 15:11:32 476 TextService textserviceasynch.py:726 DEBUG TextServiceAsynch: GetLocation
12/15/05 15:11:32 476 VenueServer venue.py:1293 DEBUG state: <AccessGrid.Descriptions.VenueState instance at 0x013CD8C8>
12/15/05 15:11:32 892 VenueServer venue.py:1175 DEBUG Venue gets channelAuthCallback, privateID=0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168
12/15/05 15:11:32 892 VenueServer venue.py:1179 DEBUG Private id is in client list, authorizing
12/15/05 15:11:32 892 VenueServer venue.py:258 DEBUG Set connection for UCSF China Basin Microbilogy
12/15/05 15:11:32 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688292.41.
12/15/05 15:11:32 3268 VenueServer venue.py:2308 DEBUG Authorizing () _SOAPContext
12/15/05 15:11:32 3268 VenueServer venue.py:2316 INFO Authorizing action: GetUploadDescriptor for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:11:32 456 TextService textserviceasynch.py:482 INFO Listen Callback 'None' '_68f2cd00_p_globus_io_handle_t' '(0, None, None)'
12/15/05 15:11:32 456 TextService textserviceasynch.py:72 INFO conn handler registering accept
12/15/05 15:11:32 456 TextService textserviceasynch.py:77 INFO register_accept returns socket=<pyGlobus.io.GSITCPSocket instance at 0x013CDF30> cb=_f8b9cd00_p_callbackStruct
12/15/05 15:11:32 456 TextService textserviceasynch.py:87 INFO Accept Callback 'None' '_109bce00_p_globus_io_handle_t' '(0, None, None)'
12/15/05 15:11:32 456 TextService textserviceasynch.py:473 DEBUG TextServiceAsynch: register_listen returns '_f8b9cd00_p_callbackStruct'
12/15/05 15:11:32 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=4
12/15/05 15:11:32 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=230
12/15/05 15:11:32 456 TextService textserviceasynch.py:184 INFO finished reading packet, wait=230 buflen=230
12/15/05 15:11:32 456 TextService textserviceasynch.py:214 INFO TextConnection: Got Event Event:
12/15/05 15:11:32 456 TextService textserviceasynch.py:558 INFO Enqueue event Connect for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>...
12/15/05 15:11:32 2764 TextService textserviceasynch.py:575 INFO Queue handler received ('event', Event:
Type: Connect Venue: 000001067ae47fbc00400036001d00f70cc, <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>)
12/15/05 15:11:32 2764 TextService textserviceasynch.py:619 INFO Handle event type Connect
12/15/05 15:11:32 2764 TextService textserviceasynch.py:300 DEBUG TextServiceAsynch: Attempting authorization on event Connect
12/15/05 15:11:32 2764 VenueServer venue.py:1215 DEBUG Venue gets channelAuthCallback, privateID=0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168
12/15/05 15:11:32 2764 VenueServer venue.py:1219 DEBUG Private id is in client list, authorizing
12/15/05 15:11:32 2764 TextService textserviceasynch.py:319 DEBUG TextServiceAsynch: Auth callback <bound method Venue.textChannelAuthCallback of Venue: name=UCSF Lab Med Lobby id=17441696 url=https://64.54.29.247:8000/Venues/000001067ae47fbc00400036001d00f70cc> returns 1
12/15/05 15:11:32 2764 TextService textserviceasynch.py:679 DEBUG TextServiceAsynch: Adding connObj 0000010830b14f0100400036001d00f770c to channel 000001067ae47fbc00400036001d00f70cc
12/15/05 15:11:32 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:11:37 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688297.41.
12/15/05 15:11:42 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688302.41.
12/15/05 15:11:47 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688307.41.
12/15/05 15:11:52 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688312.41.
12/15/05 15:11:57 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688317.41.
12/15/05 15:12:02 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688322.41.
12/15/05 15:12:07 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688327.41.
12/15/05 15:12:12 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688332.41.
12/15/05 15:12:17 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688337.41.
12/15/05 15:12:22 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688342.41.
12/15/05 15:12:27 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688347.41.
12/15/05 15:12:32 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688352.41.
12/15/05 15:12:37 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688357.41.
12/15/05 15:12:42 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688362.41.
12/15/05 15:12:47 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688367.41.
12/15/05 15:12:52 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688372.41.
12/15/05 15:12:57 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688377.41.
12/15/05 15:13:02 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688382.44.
12/15/05 15:13:07 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688387.42.
12/15/05 15:13:12 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688392.56.
12/15/05 15:13:17 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688397.41.
12/15/05 15:13:22 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688402.41.
12/15/05 15:13:27 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688407.42.
12/15/05 15:13:32 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688412.41.
12/15/05 15:13:37 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688417.41.
12/15/05 15:13:42 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688422.41.
12/15/05 15:13:47 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688427.41.
12/15/05 15:13:52 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688432.42.
12/15/05 15:13:57 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688437.41.
12/15/05 15:14:02 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688442.41.
12/15/05 15:14:04 2360 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/15/05 15:14:04 2360 VenueServer venueserver.py:1138 INFO Authorizing action: GetVenues for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:14:05 3924 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/15/05 15:14:05 3924 VenueServer venueserver.py:1138 INFO Authorizing action: GetDefaultVenue for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:14:05 2884 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/15/05 15:14:05 2884 VenueServer venueserver.py:1138 INFO Authorizing action: GetBaseAddress for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:14:05 3704 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/15/05 15:14:05 3704 VenueServer venueserver.py:1138 INFO Authorizing action: GetAddressMask for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:14:05 3112 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/15/05 15:14:05 3112 VenueServer venueserver.py:1138 INFO Authorizing action: GetAddressAllocationMethod for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:14:05 1704 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/15/05 15:14:05 1704 VenueServer venueserver.py:1138 INFO Authorizing action: GetEncryptAllMedia for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:14:07 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688447.41.
12/15/05 15:14:12 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688452.42.
12/15/05 15:14:17 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688457.41.
12/15/05 15:14:22 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688462.41.
12/15/05 15:14:27 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688467.41.
12/15/05 15:14:32 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688472.41.
12/15/05 15:14:37 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688477.41.
12/15/05 15:14:42 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688482.41.
12/15/05 15:14:47 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688487.41.
12/15/05 15:14:52 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688492.41.
12/15/05 15:14:57 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688497.41.
12/15/05 15:15:02 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688502.41.
12/15/05 15:15:02 3212 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/15/05 15:15:02 3212 VenueServer venueserver.py:1138 INFO Authorizing action: GetDefaultVenue for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:15:02 2528 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/15/05 15:15:02 2528 VenueServer venueserver.py:1138 INFO Authorizing action: GetVenues for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:15:03 1752 Security authorizationmanager.py:613 DEBUG Authorizing: () _SOAPContext
12/15/05 15:15:03 1752 Security authorizationmanager.py:618 INFO Authorizing action: ListRoles for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:15:03 3104 Security authorizationmanager.py:613 DEBUG Authorizing: () _SOAPContext
12/15/05 15:15:03 3104 Security authorizationmanager.py:618 INFO Authorizing action: ListActions for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:15:07 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688507.41.
12/15/05 15:15:12 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688512.42.
12/15/05 15:15:17 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688517.41.
12/15/05 15:15:22 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688522.42.
12/15/05 15:15:27 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688527.41.
12/15/05 15:15:32 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688532.41.
12/15/05 15:15:37 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688537.41.
12/15/05 15:15:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 15:15:38 2005
12/15/05 15:15:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 15:15:38 2005
12/15/05 15:15:42 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688542.41.
12/15/05 15:15:47 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688547.41.
12/15/05 15:15:52 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688552.42.
12/15/05 15:15:57 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688557.41.
12/15/05 15:16:02 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688562.41.
12/15/05 15:16:07 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688567.41.
12/15/05 15:16:12 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688572.41.
12/15/05 15:16:17 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688577.41.
12/15/05 15:16:22 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688582.41.
12/15/05 15:16:27 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688587.41.
12/15/05 15:16:32 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688592.41.
12/15/05 15:16:37 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688597.41.
12/15/05 15:16:42 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688602.41.
12/15/05 15:16:47 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688607.41.
12/15/05 15:16:52 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688612.41.
12/15/05 15:16:57 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688617.41.
12/15/05 15:17:02 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688622.41.
12/15/05 15:17:07 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688627.41.
12/15/05 15:17:12 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688632.41.
12/15/05 15:17:17 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688637.41.
12/15/05 15:17:22 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688642.41.
12/15/05 15:17:27 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688647.41.
12/15/05 15:17:32 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688652.41.
12/15/05 15:17:37 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688657.41.
12/15/05 15:17:42 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688662.41.
12/15/05 15:17:47 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688667.41.
12/15/05 15:17:52 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688672.41.
12/15/05 15:17:57 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688677.41.
12/15/05 15:18:02 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688682.41.
12/15/05 15:18:06 1488 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/15/05 15:18:06 1488 VenueServer venueserver.py:1138 INFO Authorizing action: GetVenues for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:18:06 3272 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/15/05 15:18:06 3272 VenueServer venueserver.py:1138 INFO Authorizing action: GetDefaultVenue for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:18:06 3480 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/15/05 15:18:06 3480 VenueServer venueserver.py:1138 INFO Authorizing action: GetBaseAddress for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:18:07 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688687.47.
12/15/05 15:18:07 3524 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/15/05 15:18:07 3524 VenueServer venueserver.py:1138 INFO Authorizing action: GetAddressMask for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:18:07 3884 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/15/05 15:18:07 3884 VenueServer venueserver.py:1138 INFO Authorizing action: GetAddressAllocationMethod for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:18:07 3156 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/15/05 15:18:07 3156 VenueServer venueserver.py:1138 INFO Authorizing action: GetEncryptAllMedia for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:18:12 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688692.41.
12/15/05 15:18:17 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688697.41.
12/15/05 15:18:22 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688702.41.
12/15/05 15:18:27 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688707.41.
12/15/05 15:18:32 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688712.41.
12/15/05 15:18:37 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688717.41.
12/15/05 15:18:42 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688722.41.
12/15/05 15:18:47 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688727.41.
12/15/05 15:18:52 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688732.41.
12/15/05 15:18:57 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688737.42.
12/15/05 15:19:02 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688742.41.
12/15/05 15:19:07 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688747.41.
12/15/05 15:19:12 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688752.41.
12/15/05 15:19:17 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688757.41.
12/15/05 15:19:22 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688762.41.
12/15/05 15:19:27 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688767.41.
12/15/05 15:19:32 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688772.41.
12/15/05 15:19:37 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688777.42.
12/15/05 15:19:40 1872 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/15/05 15:19:40 1872 VenueServer venueserver.py:1138 INFO Authorizing action: GetVenues for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:19:41 1924 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/15/05 15:19:41 1924 VenueServer venueserver.py:1138 INFO Authorizing action: GetDefaultVenue for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:19:41 3300 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/15/05 15:19:41 3300 VenueServer venueserver.py:1138 INFO Authorizing action: GetBaseAddress for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:19:41 3904 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/15/05 15:19:41 3904 VenueServer venueserver.py:1138 INFO Authorizing action: GetAddressMask for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:19:41 2104 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/15/05 15:19:41 2104 VenueServer venueserver.py:1138 INFO Authorizing action: GetAddressAllocationMethod for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:19:41 2824 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/15/05 15:19:41 2824 VenueServer venueserver.py:1138 INFO Authorizing action: GetEncryptAllMedia for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:19:42 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688782.41.
12/15/05 15:19:47 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688787.41.
12/15/05 15:19:52 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688792.41.
12/15/05 15:19:54 3576 VenueServer venue.py:2308 DEBUG Authorizing () _SOAPContext
12/15/05 15:19:54 3576 VenueServer venue.py:2316 INFO Authorizing action: Enter for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 2319335ffa01fed460f28b9a13addda4
12/15/05 15:19:54 3576 VenueServer venue.py:2348 DEBUG Interface Enter: Called.
12/15/05 15:19:54 3576 VenueServer venue.py:1254 DEBUG Enter called.
12/15/05 15:19:54 3576 VenueServer venue.py:1261 DEBUG Enter: Assigning private id: 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f
12/15/05 15:19:54 3576 VenueServer venue.py:248 DEBUG Send event of type Enter for UCSF China Basin Microbilogy
12/15/05 15:19:54 3576 VenueServer venue.py:1279 DEBUG Current users:
12/15/05 15:19:54 3576 VenueServer venue.py:1281 DEBUG VenueClientState(name=Enrique Terrazas privateID=0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f lastHeartbeat=1134688794.72)
12/15/05 15:19:54 3576 VenueServer venue.py:1281 DEBUG VenueClientState(name=UCSF China Basin Microbilogy privateID=0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 lastHeartbeat=1134688792.41)
12/15/05 15:19:54 3576 VenueServer venue.py:1282 DEBUG Enter: Distribute enter event
12/15/05 15:19:54 3576 TextService textserviceasynch.py:726 DEBUG TextServiceAsynch: GetLocation
12/15/05 15:19:54 3576 VenueServer venue.py:1293 DEBUG state: <AccessGrid.Descriptions.VenueState instance at 0x011AD940>
12/15/05 15:19:55 2516 VenueServer venue.py:2308 DEBUG Authorizing () _SOAPContext
12/15/05 15:19:55 2516 VenueServer venue.py:2316 INFO Authorizing action: GetStreams for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 2319335ffa01fed460f28b9a13addda4
12/15/05 15:19:55 892 VenueServer venue.py:1175 DEBUG Venue gets channelAuthCallback, privateID=0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f
12/15/05 15:19:55 892 VenueServer venue.py:1179 DEBUG Private id is in client list, authorizing
12/15/05 15:19:55 892 VenueServer venue.py:258 DEBUG Set connection for Enrique Terrazas
12/15/05 15:19:55 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688795.67.
12/15/05 15:19:56 3424 VenueServer venue.py:2308 DEBUG Authorizing () _SOAPContext
12/15/05 15:19:56 3424 VenueServer venue.py:2316 INFO Authorizing action: GetUploadDescriptor for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 2319335ffa01fed460f28b9a13addda4
12/15/05 15:19:56 456 TextService textserviceasynch.py:482 INFO Listen Callback 'None' '_68f2cd00_p_globus_io_handle_t' '(0, None, None)'
12/15/05 15:19:56 456 TextService textserviceasynch.py:72 INFO conn handler registering accept
12/15/05 15:19:56 456 TextService textserviceasynch.py:77 INFO register_accept returns socket=<pyGlobus.io.GSITCPSocket instance at 0x011ADBE8> cb=_f8b9cd00_p_callbackStruct
12/15/05 15:19:56 456 TextService textserviceasynch.py:87 INFO Accept Callback 'None' '_f8a2d200_p_globus_io_handle_t' '(0, None, None)'
12/15/05 15:19:56 456 TextService textserviceasynch.py:473 DEBUG TextServiceAsynch: register_listen returns '_f8b9cd00_p_callbackStruct'
12/15/05 15:19:56 456 TextService textserviceasynch.py:154 INFO Got read handle=_f8a2d200_p_globus_io_handle_t ret=(0, None, None) n=4
12/15/05 15:19:56 456 TextService textserviceasynch.py:154 INFO Got read handle=_f8a2d200_p_globus_io_handle_t ret=(0, None, None) n=230
12/15/05 15:19:56 456 TextService textserviceasynch.py:184 INFO finished reading packet, wait=230 buflen=230
12/15/05 15:19:56 456 TextService textserviceasynch.py:214 INFO TextConnection: Got Event Event:
12/15/05 15:19:56 456 TextService textserviceasynch.py:558 INFO Enqueue event Connect for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x011ADFA8>...
12/15/05 15:19:56 2764 TextService textserviceasynch.py:575 INFO Queue handler received ('event', Event:
Type: Connect Venue: 000001067ae47fbc00400036001d00f70cc, <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x011ADFA8>)
12/15/05 15:19:56 2764 TextService textserviceasynch.py:619 INFO Handle event type Connect
12/15/05 15:19:56 2764 TextService textserviceasynch.py:300 DEBUG TextServiceAsynch: Attempting authorization on event Connect
12/15/05 15:19:56 2764 VenueServer venue.py:1215 DEBUG Venue gets channelAuthCallback, privateID=0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f
12/15/05 15:19:56 2764 VenueServer venue.py:1219 DEBUG Private id is in client list, authorizing
12/15/05 15:19:56 2764 TextService textserviceasynch.py:319 DEBUG TextServiceAsynch: Auth callback <bound method Venue.textChannelAuthCallback of Venue: name=UCSF Lab Med Lobby id=17441696 url=https://64.54.29.247:8000/Venues/000001067ae47fbc00400036001d00f70cc> returns 1
12/15/05 15:19:56 2764 TextService textserviceasynch.py:679 DEBUG TextServiceAsynch: Adding connObj 0000010830b8ffe000400036001d00f7f00 to channel 000001067ae47fbc00400036001d00f70cc
12/15/05 15:19:56 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:19:57 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688797.41.
12/15/05 15:20:00 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688800.67.
12/15/05 15:20:02 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688802.41.
12/15/05 15:20:05 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688805.67.
12/15/05 15:20:07 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688807.41.
12/15/05 15:20:10 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688810.67.
12/15/05 15:20:12 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688812.41.
12/15/05 15:20:15 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688815.67.
12/15/05 15:20:17 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688817.41.
12/15/05 15:20:20 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688820.67.
12/15/05 15:20:22 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688822.41.
12/15/05 15:20:23 456 TextService textserviceasynch.py:154 INFO Got read handle=_f8a2d200_p_globus_io_handle_t ret=(0, None, None) n=4
12/15/05 15:20:23 456 TextService textserviceasynch.py:154 INFO Got read handle=_f8a2d200_p_globus_io_handle_t ret=(0, None, None) n=1506
12/15/05 15:20:23 456 TextService textserviceasynch.py:184 INFO finished reading packet, wait=1506 buflen=1506
12/15/05 15:20:23 456 TextService textserviceasynch.py:214 INFO TextConnection: Got Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('\nRick, are you there?', <AccessGrid.ClientProfile.ClientProfile instance at 0x018BEB70>)
12/15/05 15:20:23 456 TextService textserviceasynch.py:558 INFO Enqueue event Text Event for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x011ADFA8>...
12/15/05 15:20:23 2764 TextService textserviceasynch.py:575 INFO Queue handler received ('event', Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('\nRick, are you there?', <AccessGrid.ClientProfile.ClientProfile instance at 0x018BEB70>), <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x011ADFA8>)
12/15/05 15:20:23 2764 TextService textserviceasynch.py:619 INFO Handle event type Text Event
12/15/05 15:20:23 2764 TextService textserviceasynch.py:360 INFO HandleEvent returns
12/15/05 15:20:23 2764 TextService textserviceasynch.py:735 INFO TextServiceAsynch: Sending Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 2319335ffa01fed460f28b9a13addda4, Recipient: None, Private: 0, Data: ('\nRick, are you there?', <AccessGrid.ClientProfile.ClientProfile instance at 0x018BEB70>)
12/15/05 15:20:23 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.247
12/15/05 15:20:23 2764 TextService textserviceasynch.py:144 ERROR Error writing to connection: -1 a system call failed (Invalid argument)
12/15/05 15:20:23 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.118
12/15/05 15:20:23 2764 TextService textserviceasynch.py:389 DEBUG TextServiceAsynch: Removing connection 000001082bd695fb00400036001d00f73ba due to write error
12/15/05 15:20:23 2764 TextService textserviceasynch.py:389 DEBUG TextServiceAsynch: Removing connection 0000010830a8f20300400036001d00f7c0c due to write error
12/15/05 15:20:23 2764 TextService textserviceasynch.py:745 INFO TextServiceAsynch: Sent Event
12/15/05 15:20:23 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:20:25 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688825.67.
12/15/05 15:20:27 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688827.41.
12/15/05 15:20:30 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688830.67.
12/15/05 15:20:32 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688832.41.
12/15/05 15:20:33 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=4
12/15/05 15:20:33 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=2014
12/15/05 15:20:33 456 TextService textserviceasynch.py:184 INFO finished reading packet, wait=2014 buflen=2014
12/15/05 15:20:33 456 TextService textserviceasynch.py:214 INFO TextConnection: Got Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('yes!i see youin the list of participants', <AccessGrid.ClientProfile.ClientProfile instance at 0x018BEC10>)
12/15/05 15:20:33 456 TextService textserviceasynch.py:558 INFO Enqueue event Text Event for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>...
12/15/05 15:20:33 2764 TextService textserviceasynch.py:575 INFO Queue handler received ('event', Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('yes!i see youin the list of participants', <AccessGrid.ClientProfile.ClientProfile instance at 0x018BEC10>), <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>)
12/15/05 15:20:33 2764 TextService textserviceasynch.py:619 INFO Handle event type Text Event
12/15/05 15:20:33 2764 TextService textserviceasynch.py:360 INFO HandleEvent returns
12/15/05 15:20:33 2764 TextService textserviceasynch.py:735 INFO TextServiceAsynch: Sending Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f, Recipient: None, Private: 0, Data: ('yes!i see youin the list of participants', <AccessGrid.ClientProfile.ClientProfile instance at 0x018BEC10>)
12/15/05 15:20:33 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.247
12/15/05 15:20:33 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.118
12/15/05 15:20:33 2764 TextService textserviceasynch.py:745 INFO TextServiceAsynch: Sent Event
12/15/05 15:20:33 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:20:35 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688835.67.
12/15/05 15:20:37 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688837.41.
12/15/05 15:20:38 2768 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 15:20:38 2005
12/15/05 15:20:38 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=4
12/15/05 15:20:38 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=2011
12/15/05 15:20:38 456 TextService textserviceasynch.py:184 INFO finished reading packet, wait=2011 buflen=2011
12/15/05 15:20:38 456 TextService textserviceasynch.py:214 INFO TextConnection: Got Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('but no video or audio from you yet...', <AccessGrid.ClientProfile.ClientProfile instance at 0x0142E620>)
12/15/05 15:20:38 456 TextService textserviceasynch.py:558 INFO Enqueue event Text Event for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>...
12/15/05 15:20:38 2764 TextService textserviceasynch.py:575 INFO Queue handler received ('event', Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('but no video or audio from you yet...', <AccessGrid.ClientProfile.ClientProfile instance at 0x0142E620>), <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>)
12/15/05 15:20:38 2764 TextService textserviceasynch.py:619 INFO Handle event type Text Event
12/15/05 15:20:38 2764 TextService textserviceasynch.py:360 INFO HandleEvent returns
12/15/05 15:20:38 2764 TextService textserviceasynch.py:735 INFO TextServiceAsynch: Sending Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f, Recipient: None, Private: 0, Data: ('but no video or audio from you yet...', <AccessGrid.ClientProfile.ClientProfile instance at 0x0142E620>)
12/15/05 15:20:38 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.247
12/15/05 15:20:38 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.118
12/15/05 15:20:38 2764 TextService textserviceasynch.py:745 INFO TextServiceAsynch: Sent Event
12/15/05 15:20:38 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:20:38 2768 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 15:20:38 2005
12/15/05 15:20:40 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688840.67.
12/15/05 15:20:42 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688842.41.
12/15/05 15:20:45 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688845.67.
12/15/05 15:20:46 456 TextService textserviceasynch.py:154 INFO Got read handle=_f8a2d200_p_globus_io_handle_t ret=(0, None, None) n=4
12/15/05 15:20:46 456 TextService textserviceasynch.py:154 INFO Got read handle=_f8a2d200_p_globus_io_handle_t ret=(0, None, None) n=1513
12/15/05 15:20:46 456 TextService textserviceasynch.py:184 INFO finished reading packet, wait=1513 buflen=1513
12/15/05 15:20:46 456 TextService textserviceasynch.py:214 INFO TextConnection: Got Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('how do I see your video feed?', <AccessGrid.ClientProfile.ClientProfile instance at 0x01CAB5F8>)
12/15/05 15:20:46 456 TextService textserviceasynch.py:558 INFO Enqueue event Text Event for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x011ADFA8>...
12/15/05 15:20:46 2764 TextService textserviceasynch.py:575 INFO Queue handler received ('event', Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('how do I see your video feed?', <AccessGrid.ClientProfile.ClientProfile instance at 0x01CAB5F8>), <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x011ADFA8>)
12/15/05 15:20:46 2764 TextService textserviceasynch.py:619 INFO Handle event type Text Event
12/15/05 15:20:46 2764 TextService textserviceasynch.py:360 INFO HandleEvent returns
12/15/05 15:20:46 2764 TextService textserviceasynch.py:735 INFO TextServiceAsynch: Sending Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 2319335ffa01fed460f28b9a13addda4, Recipient: None, Private: 0, Data: ('how do I see your video feed?', <AccessGrid.ClientProfile.ClientProfile instance at 0x01CAB5F8>)
12/15/05 15:20:46 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.247
12/15/05 15:20:46 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.118
12/15/05 15:20:46 2764 TextService textserviceasynch.py:745 INFO TextServiceAsynch: Sent Event
12/15/05 15:20:46 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:20:47 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688847.41.
12/15/05 15:20:50 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688850.67.
12/15/05 15:20:52 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688852.41.
12/15/05 15:20:55 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688855.67.
12/15/05 15:20:56 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=4
12/15/05 15:20:56 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=2005
12/15/05 15:20:56 456 TextService textserviceasynch.py:184 INFO finished reading packet, wait=2005 buflen=2005
12/15/05 15:20:56 456 TextService textserviceasynch.py:214 INFO TextConnection: Got Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('ah -- vic did not just start???', <AccessGrid.ClientProfile.ClientProfile instance at 0x0142E850>)
12/15/05 15:20:56 456 TextService textserviceasynch.py:558 INFO Enqueue event Text Event for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>...
12/15/05 15:20:56 2764 TextService textserviceasynch.py:575 INFO Queue handler received ('event', Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('ah -- vic did not just start???', <AccessGrid.ClientProfile.ClientProfile instance at 0x0142E850>), <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>)
12/15/05 15:20:56 2764 TextService textserviceasynch.py:619 INFO Handle event type Text Event
12/15/05 15:20:56 2764 TextService textserviceasynch.py:360 INFO HandleEvent returns
12/15/05 15:20:56 2764 TextService textserviceasynch.py:735 INFO TextServiceAsynch: Sending Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f, Recipient: None, Private: 0, Data: ('ah -- vic did not just start???', <AccessGrid.ClientProfile.ClientProfile instance at 0x0142E850>)
12/15/05 15:20:56 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.247
12/15/05 15:20:56 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.118
12/15/05 15:20:56 2764 TextService textserviceasynch.py:745 INFO TextServiceAsynch: Sent Event
12/15/05 15:20:56 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:20:57 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688857.41.
12/15/05 15:21:00 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688860.67.
12/15/05 15:21:01 456 TextService textserviceasynch.py:154 INFO Got read handle=_f8a2d200_p_globus_io_handle_t ret=(0, None, None) n=4
12/15/05 15:21:01 456 TextService textserviceasynch.py:154 INFO Got read handle=_f8a2d200_p_globus_io_handle_t ret=(0, None, None) n=1486
12/15/05 15:21:01 456 TextService textserviceasynch.py:184 INFO finished reading packet, wait=1486 buflen=1486
12/15/05 15:21:01 456 TextService textserviceasynch.py:214 INFO TextConnection: Got Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('no', <AccessGrid.ClientProfile.ClientProfile instance at 0x01CABCB0>)
12/15/05 15:21:01 456 TextService textserviceasynch.py:558 INFO Enqueue event Text Event for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x011ADFA8>...
12/15/05 15:21:01 2764 TextService textserviceasynch.py:575 INFO Queue handler received ('event', Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('no', <AccessGrid.ClientProfile.ClientProfile instance at 0x01CABCB0>), <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x011ADFA8>)
12/15/05 15:21:01 2764 TextService textserviceasynch.py:619 INFO Handle event type Text Event
12/15/05 15:21:01 2764 TextService textserviceasynch.py:360 INFO HandleEvent returns
12/15/05 15:21:01 2764 TextService textserviceasynch.py:735 INFO TextServiceAsynch: Sending Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 2319335ffa01fed460f28b9a13addda4, Recipient: None, Private: 0, Data: ('no', <AccessGrid.ClientProfile.ClientProfile instance at 0x01CABCB0>)
12/15/05 15:21:01 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.247
12/15/05 15:21:01 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.118
12/15/05 15:21:01 2764 TextService textserviceasynch.py:745 INFO TextServiceAsynch: Sent Event
12/15/05 15:21:01 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:21:02 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688862.41.
12/15/05 15:21:03 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=4
12/15/05 15:21:03 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=2010
12/15/05 15:21:03 456 TextService textserviceasynch.py:184 INFO finished reading packet, wait=2010 buflen=2010
12/15/05 15:21:03 456 TextService textserviceasynch.py:214 INFO TextConnection: Got Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('it shoudl just start - as shoudl rat', <AccessGrid.ClientProfile.ClientProfile instance at 0x01CAB198>)
12/15/05 15:21:03 456 TextService textserviceasynch.py:558 INFO Enqueue event Text Event for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>...
12/15/05 15:21:03 2764 TextService textserviceasynch.py:575 INFO Queue handler received ('event', Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('it shoudl just start - as shoudl rat', <AccessGrid.ClientProfile.ClientProfile instance at 0x01CAB198>), <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>)
12/15/05 15:21:03 2764 TextService textserviceasynch.py:619 INFO Handle event type Text Event
12/15/05 15:21:03 2764 TextService textserviceasynch.py:360 INFO HandleEvent returns
12/15/05 15:21:03 2764 TextService textserviceasynch.py:735 INFO TextServiceAsynch: Sending Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f, Recipient: None, Private: 0, Data: ('it shoudl just start - as shoudl rat', <AccessGrid.ClientProfile.ClientProfile instance at 0x01CAB198>)
12/15/05 15:21:03 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.247
12/15/05 15:21:03 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.118
12/15/05 15:21:03 2764 TextService textserviceasynch.py:745 INFO TextServiceAsynch: Sent Event
12/15/05 15:21:03 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:21:05 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688865.67.
12/15/05 15:21:07 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688867.41.
12/15/05 15:21:10 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688870.67.
12/15/05 15:21:12 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688872.41.
12/15/05 15:21:13 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=4
12/15/05 15:21:13 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=2016
12/15/05 15:21:13 456 TextService textserviceasynch.py:184 INFO finished reading packet, wait=2016 buflen=2016
12/15/05 15:21:13 456 TextService textserviceasynch.py:214 INFO TextConnection: Got Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ("ok we've gotta figure that one out then :)", <AccessGrid.ClientProfile.ClientProfile instance at 0x01CAB4E0>)
12/15/05 15:21:13 456 TextService textserviceasynch.py:558 INFO Enqueue event Text Event for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>...
12/15/05 15:21:13 2764 TextService textserviceasynch.py:575 INFO Queue handler received ('event', Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ("ok we've gotta figure that one out then :)", <AccessGrid.ClientProfile.ClientProfile instance at 0x01CAB4E0>), <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>)
12/15/05 15:21:13 2764 TextService textserviceasynch.py:619 INFO Handle event type Text Event
12/15/05 15:21:13 2764 TextService textserviceasynch.py:360 INFO HandleEvent returns
12/15/05 15:21:13 2764 TextService textserviceasynch.py:735 INFO TextServiceAsynch: Sending Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f, Recipient: None, Private: 0, Data: ("ok we've gotta figure that one out then :)", <AccessGrid.ClientProfile.ClientProfile instance at 0x01CAB4E0>)
12/15/05 15:21:13 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.247
12/15/05 15:21:13 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.118
12/15/05 15:21:13 2764 TextService textserviceasynch.py:745 INFO TextServiceAsynch: Sent Event
12/15/05 15:21:13 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:21:15 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688875.67.
12/15/05 15:21:17 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688877.41.
12/15/05 15:21:20 456 TextService textserviceasynch.py:154 INFO Got read handle=_f8a2d200_p_globus_io_handle_t ret=(0, None, None) n=4
12/15/05 15:21:20 456 TextService textserviceasynch.py:154 INFO Got read handle=_f8a2d200_p_globus_io_handle_t ret=(0, None, None) n=1548
12/15/05 15:21:20 456 TextService textserviceasynch.py:184 INFO finished reading packet, wait=1548 buflen=1548
12/15/05 15:21:20 456 TextService textserviceasynch.py:214 INFO TextConnection: Got Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ("they didn't ... I wonder if I have to install the latest version", <AccessGrid.ClientProfile.ClientProfile instance at 0x01CAB030>)
12/15/05 15:21:20 456 TextService textserviceasynch.py:558 INFO Enqueue event Text Event for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x011ADFA8>...
12/15/05 15:21:20 2764 TextService textserviceasynch.py:575 INFO Queue handler received ('event', Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ("they didn't ... I wonder if I have to install the latest version", <AccessGrid.ClientProfile.ClientProfile instance at 0x01CAB030>), <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x011ADFA8>)
12/15/05 15:21:20 2764 TextService textserviceasynch.py:619 INFO Handle event type Text Event
12/15/05 15:21:20 2764 TextService textserviceasynch.py:360 INFO HandleEvent returns
12/15/05 15:21:20 2764 TextService textserviceasynch.py:735 INFO TextServiceAsynch: Sending Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 2319335ffa01fed460f28b9a13addda4, Recipient: None, Private: 0, Data: ("they didn't ... I wonder if I have to install the latest version", <AccessGrid.ClientProfile.ClientProfile instance at 0x01CAB030>)
12/15/05 15:21:20 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.247
12/15/05 15:21:20 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.118
12/15/05 15:21:20 2764 TextService textserviceasynch.py:745 INFO TextServiceAsynch: Sent Event
12/15/05 15:21:20 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:21:20 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688880.67.
12/15/05 15:21:22 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688882.41.
12/15/05 15:21:25 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688885.67.
12/15/05 15:21:27 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688887.41.
12/15/05 15:21:30 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688890.67.
12/15/05 15:21:31 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=4
12/15/05 15:21:31 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=2025
12/15/05 15:21:31 456 TextService textserviceasynch.py:184 INFO finished reading packet, wait=2025 buflen=2025
12/15/05 15:21:31 456 TextService textserviceasynch.py:214 INFO TextConnection: Got Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('do you have 2.4 insdtalle? iwoudl do that for sure', <AccessGrid.ClientProfile.ClientProfile instance at 0x01B1F238>)
12/15/05 15:21:31 456 TextService textserviceasynch.py:558 INFO Enqueue event Text Event for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>...
12/15/05 15:21:31 2764 TextService textserviceasynch.py:575 INFO Queue handler received ('event', Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('do you have 2.4 insdtalle? iwoudl do that for sure', <AccessGrid.ClientProfile.ClientProfile instance at 0x01B1F238>), <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>)
12/15/05 15:21:31 2764 TextService textserviceasynch.py:619 INFO Handle event type Text Event
12/15/05 15:21:31 2764 TextService textserviceasynch.py:360 INFO HandleEvent returns
12/15/05 15:21:31 2764 TextService textserviceasynch.py:735 INFO TextServiceAsynch: Sending Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f, Recipient: None, Private: 0, Data: ('do you have 2.4 insdtalle? iwoudl do that for sure', <AccessGrid.ClientProfile.ClientProfile instance at 0x01B1F238>)
12/15/05 15:21:31 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.247
12/15/05 15:21:31 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.118
12/15/05 15:21:31 2764 TextService textserviceasynch.py:745 INFO TextServiceAsynch: Sent Event
12/15/05 15:21:31 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:21:32 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688892.41.
12/15/05 15:21:35 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688895.67.
12/15/05 15:21:37 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688897.41.
12/15/05 15:21:37 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=4
12/15/05 15:21:37 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=2010
12/15/05 15:21:37 456 TextService textserviceasynch.py:184 INFO finished reading packet, wait=2010 buflen=2010
12/15/05 15:21:37 456 TextService textserviceasynch.py:214 INFO TextConnection: Got Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('but i doubt it will fix this problem', <AccessGrid.ClientProfile.ClientProfile instance at 0x01B1F8A0>)
12/15/05 15:21:37 456 TextService textserviceasynch.py:558 INFO Enqueue event Text Event for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>...
12/15/05 15:21:37 2764 TextService textserviceasynch.py:575 INFO Queue handler received ('event', Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('but i doubt it will fix this problem', <AccessGrid.ClientProfile.ClientProfile instance at 0x01B1F8A0>), <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>)
12/15/05 15:21:37 2764 TextService textserviceasynch.py:619 INFO Handle event type Text Event
12/15/05 15:21:37 2764 TextService textserviceasynch.py:360 INFO HandleEvent returns
12/15/05 15:21:37 2764 TextService textserviceasynch.py:735 INFO TextServiceAsynch: Sending Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f, Recipient: None, Private: 0, Data: ('but i doubt it will fix this problem', <AccessGrid.ClientProfile.ClientProfile instance at 0x01B1F8A0>)
12/15/05 15:21:37 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.247
12/15/05 15:21:37 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.118
12/15/05 15:21:37 2764 TextService textserviceasynch.py:745 INFO TextServiceAsynch: Sent Event
12/15/05 15:21:37 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:21:39 456 TextService textserviceasynch.py:154 INFO Got read handle=_f8a2d200_p_globus_io_handle_t ret=(0, None, None) n=4
12/15/05 15:21:39 456 TextService textserviceasynch.py:154 INFO Got read handle=_f8a2d200_p_globus_io_handle_t ret=(0, None, None) n=1487
12/15/05 15:21:39 456 TextService textserviceasynch.py:184 INFO finished reading packet, wait=1487 buflen=1487
12/15/05 15:21:39 456 TextService textserviceasynch.py:214 INFO TextConnection: Got Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('2.3', <AccessGrid.ClientProfile.ClientProfile instance at 0x01B1F7D8>)
12/15/05 15:21:39 456 TextService textserviceasynch.py:558 INFO Enqueue event Text Event for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x011ADFA8>...
12/15/05 15:21:39 2764 TextService textserviceasynch.py:575 INFO Queue handler received ('event', Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('2.3', <AccessGrid.ClientProfile.ClientProfile instance at 0x01B1F7D8>), <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x011ADFA8>)
12/15/05 15:21:39 2764 TextService textserviceasynch.py:619 INFO Handle event type Text Event
12/15/05 15:21:39 2764 TextService textserviceasynch.py:360 INFO HandleEvent returns
12/15/05 15:21:39 2764 TextService textserviceasynch.py:735 INFO TextServiceAsynch: Sending Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 2319335ffa01fed460f28b9a13addda4, Recipient: None, Private: 0, Data: ('2.3', <AccessGrid.ClientProfile.ClientProfile instance at 0x01B1F7D8>)
12/15/05 15:21:39 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.247
12/15/05 15:21:39 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.118
12/15/05 15:21:39 2764 TextService textserviceasynch.py:745 INFO TextServiceAsynch: Sent Event
12/15/05 15:21:39 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:21:40 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688900.67.
12/15/05 15:21:42 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688902.41.
12/15/05 15:21:45 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688905.67.
12/15/05 15:21:47 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688907.41.
12/15/05 15:21:47 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=4
12/15/05 15:21:47 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=1991
12/15/05 15:21:47 456 TextService textserviceasynch.py:184 INFO finished reading packet, wait=1991 buflen=1991
12/15/05 15:21:47 456 TextService textserviceasynch.py:214 INFO TextConnection: Got Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('wanna do 2.4 now?', <AccessGrid.ClientProfile.ClientProfile instance at 0x01B1FEE0>)
12/15/05 15:21:47 456 TextService textserviceasynch.py:558 INFO Enqueue event Text Event for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>...
12/15/05 15:21:47 2764 TextService textserviceasynch.py:575 INFO Queue handler received ('event', Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('wanna do 2.4 now?', <AccessGrid.ClientProfile.ClientProfile instance at 0x01B1FEE0>), <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>)
12/15/05 15:21:47 2764 TextService textserviceasynch.py:619 INFO Handle event type Text Event
12/15/05 15:21:47 2764 TextService textserviceasynch.py:360 INFO HandleEvent returns
12/15/05 15:21:47 2764 TextService textserviceasynch.py:735 INFO TextServiceAsynch: Sending Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f, Recipient: None, Private: 0, Data: ('wanna do 2.4 now?', <AccessGrid.ClientProfile.ClientProfile instance at 0x01B1FEE0>)
12/15/05 15:21:47 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.247
12/15/05 15:21:47 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.118
12/15/05 15:21:47 2764 TextService textserviceasynch.py:745 INFO TextServiceAsynch: Sent Event
12/15/05 15:21:47 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:21:50 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688910.67.
12/15/05 15:21:52 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688912.41.
12/15/05 15:21:55 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688915.67.
12/15/05 15:21:57 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688917.41.
12/15/05 15:22:00 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688920.67.
12/15/05 15:22:02 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=4
12/15/05 15:22:02 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=2018
12/15/05 15:22:02 456 TextService textserviceasynch.py:184 INFO finished reading packet, wait=2018 buflen=2018
12/15/05 15:22:02 456 TextService textserviceasynch.py:214 INFO TextConnection: Got Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('im still stuick with the server config. here', <AccessGrid.ClientProfile.ClientProfile instance at 0x01B1F788>)
12/15/05 15:22:02 456 TextService textserviceasynch.py:558 INFO Enqueue event Text Event for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>...
12/15/05 15:22:02 2764 TextService textserviceasynch.py:575 INFO Queue handler received ('event', Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('im still stuick with the server config. here', <AccessGrid.ClientProfile.ClientProfile instance at 0x01B1F788>), <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>)
12/15/05 15:22:02 2764 TextService textserviceasynch.py:619 INFO Handle event type Text Event
12/15/05 15:22:02 2764 TextService textserviceasynch.py:360 INFO HandleEvent returns
12/15/05 15:22:02 2764 TextService textserviceasynch.py:735 INFO TextServiceAsynch: Sending Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f, Recipient: None, Private: 0, Data: ('im still stuick with the server config. here', <AccessGrid.ClientProfile.ClientProfile instance at 0x01B1F788>)
12/15/05 15:22:02 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.247
12/15/05 15:22:02 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.118
12/15/05 15:22:02 2764 TextService textserviceasynch.py:745 INFO TextServiceAsynch: Sent Event
12/15/05 15:22:02 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:22:02 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688922.41.
12/15/05 15:22:05 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688925.67.
12/15/05 15:22:07 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688927.41.
12/15/05 15:22:10 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688930.67.
12/15/05 15:22:12 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688932.41.
12/15/05 15:22:15 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688935.67.
12/15/05 15:22:17 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688937.41.
12/15/05 15:22:20 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=4
12/15/05 15:22:20 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=2034
12/15/05 15:22:20 456 TextService textserviceasynch.py:184 INFO finished reading packet, wait=2034 buflen=2034
12/15/05 15:22:20 456 TextService textserviceasynch.py:214 INFO TextConnection: Got Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('seems we are not talking to the server that we configured :)', <AccessGrid.ClientProfile.ClientProfile instance at 0x01CD9EB8>)
12/15/05 15:22:20 456 TextService textserviceasynch.py:558 INFO Enqueue event Text Event for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>...
12/15/05 15:22:20 2764 TextService textserviceasynch.py:575 INFO Queue handler received ('event', Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('seems we are not talking to the server that we configured :)', <AccessGrid.ClientProfile.ClientProfile instance at 0x01CD9EB8>), <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>)
12/15/05 15:22:20 2764 TextService textserviceasynch.py:619 INFO Handle event type Text Event
12/15/05 15:22:20 2764 TextService textserviceasynch.py:360 INFO HandleEvent returns
12/15/05 15:22:20 2764 TextService textserviceasynch.py:735 INFO TextServiceAsynch: Sending Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f, Recipient: None, Private: 0, Data: ('seems we are not talking to the server that we configured :)', <AccessGrid.ClientProfile.ClientProfile instance at 0x01CD9EB8>)
12/15/05 15:22:20 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.247
12/15/05 15:22:20 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.118
12/15/05 15:22:20 2764 TextService textserviceasynch.py:745 INFO TextServiceAsynch: Sent Event
12/15/05 15:22:20 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:22:20 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688940.67.
12/15/05 15:22:22 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688942.41.
12/15/05 15:22:25 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688945.67.
12/15/05 15:22:27 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688947.41.
12/15/05 15:22:30 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688950.67.
12/15/05 15:22:32 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688952.41.
12/15/05 15:22:35 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688955.67.
12/15/05 15:22:37 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688957.41.
12/15/05 15:22:40 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688960.67.
12/15/05 15:22:42 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688962.42.
12/15/05 15:22:45 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688965.67.
12/15/05 15:22:45 456 TextService textserviceasynch.py:154 INFO Got read handle=_f8a2d200_p_globus_io_handle_t ret=(0, None, None) n=4
12/15/05 15:22:45 456 TextService textserviceasynch.py:154 INFO Got read handle=_f8a2d200_p_globus_io_handle_t ret=(0, None, None) n=1522
12/15/05 15:22:45 456 TextService textserviceasynch.py:184 INFO finished reading packet, wait=1522 buflen=1522
12/15/05 15:22:45 456 TextService textserviceasynch.py:214 INFO TextConnection: Got Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ("yes, I'll install ... what is the url?", <AccessGrid.ClientProfile.ClientProfile instance at 0x01CD9030>)
12/15/05 15:22:45 456 TextService textserviceasynch.py:558 INFO Enqueue event Text Event for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x011ADFA8>...
12/15/05 15:22:45 2764 TextService textserviceasynch.py:575 INFO Queue handler received ('event', Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ("yes, I'll install ... what is the url?", <AccessGrid.ClientProfile.ClientProfile instance at 0x01CD9030>), <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x011ADFA8>)
12/15/05 15:22:45 2764 TextService textserviceasynch.py:619 INFO Handle event type Text Event
12/15/05 15:22:45 2764 TextService textserviceasynch.py:360 INFO HandleEvent returns
12/15/05 15:22:45 2764 TextService textserviceasynch.py:735 INFO TextServiceAsynch: Sending Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 2319335ffa01fed460f28b9a13addda4, Recipient: None, Private: 0, Data: ("yes, I'll install ... what is the url?", <AccessGrid.ClientProfile.ClientProfile instance at 0x01CD9030>)
12/15/05 15:22:45 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.247
12/15/05 15:22:45 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.118
12/15/05 15:22:45 2764 TextService textserviceasynch.py:745 INFO TextServiceAsynch: Sent Event
12/15/05 15:22:45 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:22:47 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688967.41.
12/15/05 15:22:50 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688970.67.
12/15/05 15:22:52 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688972.41.
12/15/05 15:22:55 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688975.67.
12/15/05 15:22:57 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688977.41.
12/15/05 15:23:00 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688980.67.
12/15/05 15:23:02 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688982.41.
12/15/05 15:23:03 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=4
12/15/05 15:23:03 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=2017
12/15/05 15:23:03 456 TextService textserviceasynch.py:184 INFO finished reading packet, wait=2017 buflen=2017
12/15/05 15:23:03 456 TextService textserviceasynch.py:214 INFO TextConnection: Got Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('www.accessgrid.org - look for software link', <AccessGrid.ClientProfile.ClientProfile instance at 0x01CD95F8>)
12/15/05 15:23:03 456 TextService textserviceasynch.py:558 INFO Enqueue event Text Event for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>...
12/15/05 15:23:03 2764 TextService textserviceasynch.py:575 INFO Queue handler received ('event', Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('www.accessgrid.org - look for software link', <AccessGrid.ClientProfile.ClientProfile instance at 0x01CD95F8>), <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>)
12/15/05 15:23:03 2764 TextService textserviceasynch.py:619 INFO Handle event type Text Event
12/15/05 15:23:03 2764 TextService textserviceasynch.py:360 INFO HandleEvent returns
12/15/05 15:23:03 2764 TextService textserviceasynch.py:735 INFO TextServiceAsynch: Sending Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f, Recipient: None, Private: 0, Data: ('www.accessgrid.org - look for software link', <AccessGrid.ClientProfile.ClientProfile instance at 0x01CD95F8>)
12/15/05 15:23:03 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.247
12/15/05 15:23:03 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.118
12/15/05 15:23:03 2764 TextService textserviceasynch.py:745 INFO TextServiceAsynch: Sent Event
12/15/05 15:23:03 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:23:05 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688985.66.
12/15/05 15:23:07 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688987.41.
12/15/05 15:23:10 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688990.64.
12/15/05 15:23:12 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688992.42.
12/15/05 15:23:15 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134688995.64.
12/15/05 15:23:17 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134688997.41.
12/15/05 15:23:20 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134689000.64.
12/15/05 15:23:22 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134689002.41.
12/15/05 15:23:25 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134689005.64.
12/15/05 15:23:27 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134689007.41.
12/15/05 15:23:30 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134689010.63.
12/15/05 15:23:32 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134689012.42.
12/15/05 15:23:35 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134689015.63.
12/15/05 15:23:37 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134689017.41.
12/15/05 15:23:40 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134689020.64.
12/15/05 15:23:42 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134689022.41.
12/15/05 15:23:45 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134689025.63.
12/15/05 15:23:47 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134689027.41.
12/15/05 15:23:49 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=4
12/15/05 15:23:49 456 TextService textserviceasynch.py:154 INFO Got read handle=_109bce00_p_globus_io_handle_t ret=(0, None, None) n=2018
12/15/05 15:23:49 456 TextService textserviceasynch.py:184 INFO finished reading packet, wait=2018 buflen=2018
12/15/05 15:23:49 456 TextService textserviceasynch.py:214 INFO TextConnection: Got Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('im going to take server dowm for a min - brb', <AccessGrid.ClientProfile.ClientProfile instance at 0x01D18850>)
12/15/05 15:23:49 456 TextService textserviceasynch.py:558 INFO Enqueue event Text Event for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>...
12/15/05 15:23:49 2764 TextService textserviceasynch.py:575 INFO Queue handler received ('event', Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: None, Recipient: None, Private: 0, Data: ('im going to take server dowm for a min - brb', <AccessGrid.ClientProfile.ClientProfile instance at 0x01D18850>), <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x018B8F08>)
12/15/05 15:23:49 2764 TextService textserviceasynch.py:619 INFO Handle event type Text Event
12/15/05 15:23:49 2764 TextService textserviceasynch.py:360 INFO HandleEvent returns
12/15/05 15:23:49 2764 TextService textserviceasynch.py:735 INFO TextServiceAsynch: Sending Event Text Event: Venue: 000001067ae47fbc00400036001d00f70cc, Payload: Sender: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f, Recipient: None, Private: 0, Data: ('im going to take server dowm for a min - brb', <AccessGrid.ClientProfile.ClientProfile instance at 0x01D18850>)
12/15/05 15:23:49 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.247
12/15/05 15:23:49 2764 TextService textserviceasynch.py:140 DEBUG Writing text event to 64.54.29.118
12/15/05 15:23:49 2764 TextService textserviceasynch.py:745 INFO TextServiceAsynch: Sent Event
12/15/05 15:23:49 2764 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:23:50 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134689030.64.
12/15/05 15:23:52 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134689032.41.
12/15/05 15:23:55 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134689035.63.
12/15/05 15:23:57 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134689037.41.
12/15/05 15:24:00 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134689040.64.
12/15/05 15:24:02 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134689042.42.
12/15/05 15:24:05 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b8f85e00400036001d00f7038_0000010830b8f85e00400036001d00f794f at 1134689045.64.
12/15/05 15:24:07 892 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830b14dc800400036001d00f7e24_0000010830b14dc800400036001d00f7168 at 1134689047.41.
12/15/05 15:26:47 3728 Toolkit toolkit.py:205 WARNING Toolkit.__CheckForValidClock: The machine clock is incorrect on
your computer: it is 34 seconds fast with respect
to the time server at ntp-1.accessgrid.org.
12/15/05 15:26:47 3728 Toolkit toolkit.py:709 INFO Service init: have profile None
12/15/05 15:26:47 3728 Toolkit config.py:219 ERROR Error setting globus hostname.
Traceback (most recent call last):
File "C:\Python23\Lib\site-packages\AccessGrid\Config.py", line 212, in SetHostname
sock.bind((hostname, 0))
File "<string>", line 1, in bind
gaierror: (7, 'getaddrinfo failed')
12/15/05 15:26:47 3728 Toolkit config.py:348 DEBUG retrieved local IP address 64.54.29.247
12/15/05 15:26:47 3728 CertificateManager certificatemanager.py:269 DEBUG Opened repository C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo
12/15/05 15:26:47 3728 Toolkit toolkit.py:738 INFO Initialized cert mgmt.
12/15/05 15:26:47 3728 Toolkit toolkit.py:753 INFO Loaded profile and configured with it.
12/15/05 15:26:47 3728 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
12/15/05 15:26:47 3728 CertificateManager certificatemanager.py:827 DEBUG Using default identity /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:26:47 3728 CertificateManager certificatemanager.py:1083 DEBUG Initializing environment with unencrypted cert /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:26:47 3728 CertificateManager certificatemanager.py:1098 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\191c8500c5d893d758250b70098c95ce\38d6622212820902ad92145aa0bb0932\cert.pem to 644
12/15/05 15:26:47 3728 CertificateManager certificatemanager.py:1109 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\privatekeys\60fef24d87f80145a55c7bb89691fde6.pem to 600
12/15/05 15:26:47 3728 CertificateManager certificatemanager.py:1572 DEBUG done, success=1
12/15/05 15:26:47 3728 Toolkit toolkit.py:764 INFO Initialized Globus.
12/15/05 15:26:47 3728 Toolkit toolkit.py:782 INFO Service Initialization Complete.
12/15/05 15:26:47 3728 Toolkit venueserver.py:87 INFO VenueServer running using hostname: 64.54.29.247
12/15/05 15:26:47 3728 VenueServer venueserver.py:179 DEBUG VenueServer initializing authorization manager.
12/15/05 15:26:47 3728 VenueServer venueserver.py:557 DEBUG Reading authorization policy.
12/15/05 15:26:47 3728 DataStore datastore.py:1537 DEBUG Creating thread 0
12/15/05 15:26:47 3728 DataStore datastore.py:1542 DEBUG Starting thread 0
12/15/05 15:26:47 3728 DataStore datastore.py:1544 DEBUG Waiting thread 0
12/15/05 15:26:47 3996 DataStore datastore.py:1550 DEBUG Worker 0 starting
12/15/05 15:26:47 3728 DataStore datastore.py:1537 DEBUG Creating thread 1
12/15/05 15:26:47 3728 DataStore datastore.py:1542 DEBUG Starting thread 1
12/15/05 15:26:47 3736 DataStore datastore.py:1550 DEBUG Worker 1 starting
12/15/05 15:26:47 3728 DataStore datastore.py:1544 DEBUG Waiting thread 1
12/15/05 15:26:47 3728 DataStore datastore.py:1537 DEBUG Creating thread 2
12/15/05 15:26:47 3728 DataStore datastore.py:1542 DEBUG Starting thread 2
12/15/05 15:26:47 3728 DataStore datastore.py:1544 DEBUG Waiting thread 2
12/15/05 15:26:47 1784 DataStore datastore.py:1550 DEBUG Worker 2 starting
12/15/05 15:26:47 3728 DataStore datastore.py:1537 DEBUG Creating thread 3
12/15/05 15:26:47 3728 DataStore datastore.py:1542 DEBUG Starting thread 3
12/15/05 15:26:47 3728 DataStore datastore.py:1544 DEBUG Waiting thread 3
12/15/05 15:26:47 2484 DataStore datastore.py:1550 DEBUG Worker 3 starting
12/15/05 15:26:47 3728 DataStore datastore.py:1547 DEBUG Done creating workers
12/15/05 15:26:47 3728 TextService textserviceasynch.py:413 DEBUG TextServiceAsynch: Text Service Started
12/15/05 15:26:47 1576 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:26:47 3728 TextService textserviceasynch.py:448 DEBUG TextServiceAsynch: Bound to 8004 (server_address=('64.54.29.247', 8004))
12/15/05 15:26:47 3728 TextService textserviceasynch.py:467 DEBUG TextServiceAsynch: Text service start
12/15/05 15:26:47 3728 TextService textserviceasynch.py:473 DEBUG TextServiceAsynch: register_listen returns '_f8b9cd00_p_callbackStruct'
12/15/05 15:26:47 3728 VenueServer venueserver.py:394 DEBUG Reading persisted Venues from: VenueServer.dat
12/15/05 15:26:47 3728 VenueServer venueserver.py:399 DEBUG Loading Venue: 000001067b154e9c00400036001d00f7385
12/15/05 15:26:47 3728 VenueServer venue.py:382 DEBUG ------------ STARTING VENUE
12/15/05 15:26:47 3728 VenueServer venue.py:422 INFO Venue URI https://64.54.29.247:8000/Venues/000001067b154e9c00400036001d00f7385
12/15/05 15:26:47 3728 TextService textserviceasynch.py:751 DEBUG TextServiceAsynch: AddChannel 000001067b154e9c00400036001d00f7385
12/15/05 15:26:47 3728 VenueServer venue.py:428 DEBUG Registering heartbeat for 000001067b154e9c00400036001d00f7385
12/15/05 15:26:47 3728 VenueServer venue.py:442 DEBUG data store location: Data
12/15/05 15:26:47 3728 DataStore datastore.py:278 DEBUG Reading persisted data from: Data\000001067b154e9c00400036001d00f7385\DataStore.dat
12/15/05 15:26:47 3728 VenueServer venue.py:466 INFO Have upload url: https://64.54.29.247:8006/000001067b154e9c00400036001d00f7385
12/15/05 15:26:47 3728 VenueServer venue.py:1138 DEBUG Calling SetConnections.
12/15/05 15:26:47 3728 Security authorizationmanager.py:448 DEBUG Adding Subject: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f to Role: Administrators
12/15/05 15:26:47 3728 Security authorizationmanager.py:461 WARNING Not adding subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f to role Administrators, it's already there.
12/15/05 15:26:47 3728 VenueServer venueserver.py:399 DEBUG Loading Venue: 000001067ae47fbc00400036001d00f70cc
12/15/05 15:26:47 3728 VenueServer venue.py:422 INFO Venue URI https://64.54.29.247:8000/Venues/000001067ae47fbc00400036001d00f70cc
12/15/05 15:26:47 3728 TextService textserviceasynch.py:751 DEBUG TextServiceAsynch: AddChannel 000001067ae47fbc00400036001d00f70cc
12/15/05 15:26:47 3728 VenueServer venue.py:428 DEBUG Registering heartbeat for 000001067ae47fbc00400036001d00f70cc
12/15/05 15:26:47 3728 DataStore datastore.py:278 DEBUG Reading persisted data from: Data\000001067ae47fbc00400036001d00f70cc\DataStore.dat
12/15/05 15:26:47 3728 VenueServer venue.py:466 INFO Have upload url: https://64.54.29.247:8006/000001067ae47fbc00400036001d00f70cc
12/15/05 15:26:47 3728 VenueServer venueserver.py:399 DEBUG Loading Venue: 000001067b15fcfc00400036001d00f7ea5
12/15/05 15:26:47 3728 VenueServer venue.py:422 INFO Venue URI https://64.54.29.247:8000/Venues/000001067b15fcfc00400036001d00f7ea5
12/15/05 15:26:47 3728 TextService textserviceasynch.py:751 DEBUG TextServiceAsynch: AddChannel 000001067b15fcfc00400036001d00f7ea5
12/15/05 15:26:47 3728 VenueServer venue.py:428 DEBUG Registering heartbeat for 000001067b15fcfc00400036001d00f7ea5
12/15/05 15:26:47 3728 DataStore datastore.py:278 DEBUG Reading persisted data from: Data\000001067b15fcfc00400036001d00f7ea5\DataStore.dat
12/15/05 15:26:47 3728 VenueServer venue.py:466 INFO Have upload url: https://64.54.29.247:8006/000001067b15fcfc00400036001d00f7ea5
12/15/05 15:26:47 3728 VenueServer venueserver.py:399 DEBUG Loading Venue: 000001067b135e4500400036001d00f7021
12/15/05 15:26:47 3728 VenueServer venue.py:422 INFO Venue URI https://64.54.29.247:8000/Venues/000001067b135e4500400036001d00f7021
12/15/05 15:26:47 3728 TextService textserviceasynch.py:751 DEBUG TextServiceAsynch: AddChannel 000001067b135e4500400036001d00f7021
12/15/05 15:26:47 3728 VenueServer venue.py:428 DEBUG Registering heartbeat for 000001067b135e4500400036001d00f7021
12/15/05 15:26:47 3728 DataStore datastore.py:278 DEBUG Reading persisted data from: Data\000001067b135e4500400036001d00f7021\DataStore.dat
12/15/05 15:26:47 3728 VenueServer venue.py:466 INFO Have upload url: https://64.54.29.247:8006/000001067b135e4500400036001d00f7021
12/15/05 15:26:47 3728 VenueServer venueserver.py:273 DEBUG CFG: Default Venue: 000001067ae47fbc00400036001d00f70cc
12/15/05 15:26:47 3728 VenueServer venueserver.py:275 DEBUG Setting default venue.
12/15/05 15:26:47 3728 VenueServer venueserver.py:938 INFO Setting default venue; oid=000001067ae47fbc00400036001d00f70cc
12/15/05 15:26:47 3728 VenueServer venueserver.py:319 WARNING Performance data configuration incorrect.
12/15/05 15:26:47 1228 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 15:26:47 2005
12/15/05 15:26:47 3728 VenueServer venueserver.py:352 DEBUG Using policy from config file.
12/15/05 15:26:47 3728 VenueServer venueserver.py:358 DEBUG Default Subject: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:26:47 3728 Toolkit venueserver.py:102 DEBUG Starting Hosting Environment.
12/15/05 15:26:47 1228 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 15:26:47 2005
12/15/05 15:28:54 2736 VenueServer venue.py:2308 DEBUG Authorizing () _SOAPContext
12/15/05 15:28:54 2736 VenueServer venue.py:2316 INFO Authorizing action: Enter for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 2319335ffa01fed460f28b9a13addda4
12/15/05 15:28:54 2736 VenueServer venue.py:2348 DEBUG Interface Enter: Called.
12/15/05 15:28:54 2736 VenueServer venue.py:1254 DEBUG Enter called.
12/15/05 15:28:54 2736 VenueServer venue.py:1261 DEBUG Enter: Assigning private id: 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10
12/15/05 15:28:54 2736 VenueServer venue.py:850 DEBUG added user as producer of non-existent stream
12/15/05 15:28:54 2736 VenueServer venue.py:3984 DEBUG * * * Added stream producer 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10
12/15/05 15:28:54 2736 VenueServer venue.py:1279 DEBUG Current users:
12/15/05 15:28:54 2736 VenueServer venue.py:1281 DEBUG VenueClientState(name=Enrique Terrazas privateID=0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 lastHeartbeat=1134689334.81)
12/15/05 15:28:54 2736 VenueServer venue.py:1282 DEBUG Enter: Distribute enter event
12/15/05 15:28:54 2736 VenueServer venue.py:1289 INFO User already in venue users list: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 2319335ffa01fed460f28b9a13addda4
12/15/05 15:28:54 2736 TextService textserviceasynch.py:726 DEBUG TextServiceAsynch: GetLocation
12/15/05 15:28:54 2736 VenueServer venue.py:1293 DEBUG state: <AccessGrid.Descriptions.VenueState instance at 0x012CB030>
12/15/05 15:28:54 1556 VenueServer venue.py:1175 DEBUG Venue gets channelAuthCallback, privateID=0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10
12/15/05 15:28:54 1556 VenueServer venue.py:1179 DEBUG Private id is in client list, authorizing
12/15/05 15:28:54 1556 VenueServer venue.py:258 DEBUG Set connection for Enrique Terrazas
12/15/05 15:28:54 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689334.92.
12/15/05 15:28:55 3840 VenueServer venue.py:2308 DEBUG Authorizing () _SOAPContext
12/15/05 15:28:55 3840 VenueServer venue.py:2316 INFO Authorizing action: GetUploadDescriptor for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 2319335ffa01fed460f28b9a13addda4
12/15/05 15:28:55 2776 TextService textserviceasynch.py:482 INFO Listen Callback 'None' '_68f2cd00_p_globus_io_handle_t' '(0, None, None)'
12/15/05 15:28:55 2776 TextService textserviceasynch.py:72 INFO conn handler registering accept
12/15/05 15:28:55 2776 TextService textserviceasynch.py:77 INFO register_accept returns socket=<pyGlobus.io.GSITCPSocket instance at 0x012B4A30> cb=_f8b9cd00_p_callbackStruct
12/15/05 15:28:55 2776 TextService textserviceasynch.py:87 INFO Accept Callback 'None' '_786acf00_p_globus_io_handle_t' '(0, None, None)'
12/15/05 15:28:55 2776 TextService textserviceasynch.py:473 DEBUG TextServiceAsynch: register_listen returns '_f8b9cd00_p_callbackStruct'
12/15/05 15:28:55 2776 TextService textserviceasynch.py:154 INFO Got read handle=_786acf00_p_globus_io_handle_t ret=(0, None, None) n=4
12/15/05 15:28:55 2776 TextService textserviceasynch.py:154 INFO Got read handle=_786acf00_p_globus_io_handle_t ret=(0, None, None) n=230
12/15/05 15:28:55 2776 TextService textserviceasynch.py:184 INFO finished reading packet, wait=230 buflen=230
12/15/05 15:28:55 2776 TextService textserviceasynch.py:214 INFO TextConnection: Got Event Event:
Type: Connect Venue: 000001067ae47fbc00400036001d00f70cc
12/15/05 15:28:55 2776 TextService textserviceasynch.py:558 INFO Enqueue event Connect for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x012B95F8>...
12/15/05 15:28:55 1576 TextService textserviceasynch.py:575 INFO Queue handler received ('event', Event:
Type: Connect Venue: 000001067ae47fbc00400036001d00f70cc, <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x012B95F8>)
12/15/05 15:28:55 1576 TextService textserviceasynch.py:619 INFO Handle event type Connect
12/15/05 15:28:55 1576 TextService textserviceasynch.py:300 DEBUG TextServiceAsynch: Attempting authorization on event Connect
12/15/05 15:28:55 1576 VenueServer venue.py:1215 DEBUG Venue gets channelAuthCallback, privateID=0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10
12/15/05 15:28:55 1576 VenueServer venue.py:1219 DEBUG Private id is in client list, authorizing
12/15/05 15:28:55 1576 TextService textserviceasynch.py:319 DEBUG TextServiceAsynch: Auth callback <bound method Venue.textChannelAuthCallback of Venue: name=UCSF Lab Med Lobby id=18911280 url=https://64.54.29.247:8000/Venues/000001067ae47fbc00400036001d00f70cc> returns 1
12/15/05 15:28:55 1576 TextService textserviceasynch.py:679 DEBUG TextServiceAsynch: Adding connObj 0000010830c13a8100400036001d00f7712 to channel 000001067ae47fbc00400036001d00f70cc
12/15/05 15:28:55 1576 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:28:59 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689339.92.
12/15/05 15:29:04 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689344.92.
12/15/05 15:29:09 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689349.92.
12/15/05 15:29:14 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689354.92.
12/15/05 15:29:19 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689359.92.
12/15/05 15:29:24 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689364.92.
12/15/05 15:29:29 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689369.92.
12/15/05 15:29:34 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689374.92.
12/15/05 15:29:39 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689379.92.
12/15/05 15:29:44 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689384.92.
12/15/05 15:29:49 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689389.92.
12/15/05 15:29:54 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689394.92.
12/15/05 15:29:59 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689399.92.
12/15/05 15:30:04 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689404.92.
12/15/05 15:30:09 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689409.92.
12/15/05 15:30:14 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689414.92.
12/15/05 15:30:19 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689419.92.
12/15/05 15:30:24 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689424.92.
12/15/05 15:30:29 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689429.92.
12/15/05 15:30:34 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689434.92.
12/15/05 15:30:39 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689439.92.
12/15/05 15:30:44 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689444.92.
12/15/05 15:30:49 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689449.92.
12/15/05 15:30:54 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689454.92.
12/15/05 15:30:59 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689459.92.
12/15/05 15:31:04 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689464.92.
12/15/05 15:31:09 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689469.92.
12/15/05 15:31:14 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10 at 1134689474.92.
12/15/05 15:31:17 2912 VenueServer venue.py:2308 DEBUG Authorizing () _SOAPContext
12/15/05 15:31:17 2912 VenueServer venue.py:2316 INFO Authorizing action: Exit for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 2319335ffa01fed460f28b9a13addda4
12/15/05 15:31:17 2912 VenueServer venue.py:1761 DEBUG Called Venue Exit on 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10
12/15/05 15:31:17 2912 VenueServer venue.py:1031 DEBUG Called RemoveUser on 0000010830c1361c00400036001d00f7b52_0000010830c1361c00400036001d00f7c10
12/15/05 15:31:17 2912 VenueServer venue.py:4095 DEBUG StreamDescriptionList.index Address 224.2.135.88 224.2.135.88
12/15/05 15:31:17 2912 VenueServer venue.py:4098 DEBUG StreamDescriptionList.index Port 51466 51466
12/15/05 15:31:17 2912 VenueServer venue.py:1033 DEBUG Removed streams = [StreamDescription: {'description': None, 'encryptionKey': None, 'uri': None, 'encryptionFlag': 0, 'capability': producer audio, 'static': 0, 'location': multicast 224.2.135.88 51466 127, 'id': '0000010830c1362c00400036001d00f70ce', 'networkLocations': [multicast 224.2.135.88 51466 127], 'name': 'UCSF Lab Med Lobby'}]
12/15/05 15:31:17 2912 VenueServer venue.py:1075 DEBUG Removing single instance of user
12/15/05 15:31:17 2912 TextService textserviceasynch.py:511 DEBUG TextServiceAsynch: Removing connection 0000010830c13a8100400036001d00f7712
12/15/05 15:31:17 484 EventService eventserviceasynch.py:242 ERROR writeMarshalledEvent write error!
File "C:\Python23\Lib\site-packages\AccessGrid\EventServiceAsynch.py", line 236, in writeMarshalledEvent
mEvent.Write(self.wfile)
File "C:\Python23\Lib\site-packages\AccessGrid\Events.py", line 243, in Write
fh.write(self.sizeStr)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 377, in write
self.sock.write(str, len(str))
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 253, in write
raise ex
IOBaseException: the handle 00CDF5E8 was already registered for closing
12/15/05 15:31:17 2776 TextService textserviceasynch.py:154 INFO Got read handle=_786acf00_p_globus_io_handle_t ret=(-1, 18, 'an I/O operation was cancelled') n=0
12/15/05 15:31:17 2776 TextService textserviceasynch.py:157 DEBUG TextServiceAsynch: readCallback returned failure: -1 18
12/15/05 15:31:17 1556 EventService eventserviceasynch.py:497 ERROR RemoveConnection: connection 0000010830c1366a00400036001d00f7a68 not in connection list
12/15/05 15:31:17 484 EventService eventserviceasynch.py:497 ERROR RemoveConnection: connection 0000010830c1366a00400036001d00f7a68 not in connection list
12/15/05 15:31:17 2776 TextService textserviceasynch.py:199 ERROR TextServiceAsynch: IOBase exception on text service close (probably ok)
File "C:\Python23\Lib\site-packages\AccessGrid\TextServiceAsynch.py", line 196, in stop
self.wfile.close()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 391, in close
self.sock.close()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1020, in close
IOBase.close(self)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 176, in close
raise ex
IOBaseException: the handle 00CF6A78 was already registered for closing
12/15/05 15:31:17 2776 TextService textserviceasynch.py:562 INFO Enqueue EOF for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x012B95F8>...
12/15/05 15:31:17 1576 TextService textserviceasynch.py:575 INFO Queue handler received ('eof', <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x012B95F8>)
12/15/05 15:31:17 2776 TextService textserviceasynch.py:124 ERROR readcallback failed
File "C:\Python23\Lib\site-packages\AccessGrid\TextServiceAsynch.py", line 122, in readCallbackWrap
self.registerForRead()
File "C:\Python23\Lib\site-packages\AccessGrid\TextServiceAsynch.py", line 109, in registerForRead
None)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 198, in register_read
raise ex
12/15/05 15:31:17 1576 TextService textserviceasynch.py:581 DEBUG TextServiceAsynch: EOF on connection 0000010830c13a8100400036001d00f7712
self.wfile.close()
self.sock.close()
IOBase.close(self)
raise ex
12/15/05 15:31:17 1576 TextService textserviceasynch.py:511 DEBUG TextServiceAsynch: Removing connection 0000010830c13a8100400036001d00f7712
12/15/05 15:31:17 2912 VenueServer venue.py:1113 DEBUG RemoveUser: Distribute EXIT event
12/15/05 15:31:17 1576 TextService textserviceasynch.py:199 ERROR TextServiceAsynch: IOBase exception on text service close (probably ok)
self.wfile.close()
self.sock.close()
IOBase.close(self)
raise ex
IOBaseException: an uninitialied data structure was passed as argument 1 to globus_io_register_close
12/15/05 15:31:17 1576 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:31:36 3404 VenueServer venue.py:2308 DEBUG Authorizing () _SOAPContext
12/15/05 15:31:36 3404 VenueServer venue.py:2316 INFO Authorizing action: Enter for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 2319335ffa01fed460f28b9a13addda4
12/15/05 15:31:36 3404 VenueServer venue.py:2348 DEBUG Interface Enter: Called.
12/15/05 15:31:36 3404 VenueServer venue.py:1254 DEBUG Enter called.
12/15/05 15:31:36 3404 VenueServer venue.py:1261 DEBUG Enter: Assigning private id: 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852
12/15/05 15:31:36 3404 VenueServer venue.py:850 DEBUG added user as producer of non-existent stream
12/15/05 15:31:36 3404 VenueServer venue.py:3984 DEBUG * * * Added stream producer 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852
12/15/05 15:31:36 3404 VenueServer venue.py:1279 DEBUG Current users:
12/15/05 15:31:36 3404 VenueServer venue.py:1281 DEBUG VenueClientState(name=Enrique Terrazas privateID=0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 lastHeartbeat=1134689496.14)
12/15/05 15:31:36 3404 VenueServer venue.py:1282 DEBUG Enter: Distribute enter event
12/15/05 15:31:36 3404 TextService textserviceasynch.py:726 DEBUG TextServiceAsynch: GetLocation
12/15/05 15:31:36 3404 VenueServer venue.py:1293 DEBUG state: <AccessGrid.Descriptions.VenueState instance at 0x012B9F58>
12/15/05 15:31:36 1556 VenueServer venue.py:1175 DEBUG Venue gets channelAuthCallback, privateID=0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852
12/15/05 15:31:36 1556 VenueServer venue.py:1179 DEBUG Private id is in client list, authorizing
12/15/05 15:31:36 1556 VenueServer venue.py:258 DEBUG Set connection for Enrique Terrazas
12/15/05 15:31:36 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689496.23.
12/15/05 15:31:37 3916 VenueServer venue.py:2308 DEBUG Authorizing () _SOAPContext
12/15/05 15:31:37 3916 VenueServer venue.py:2316 INFO Authorizing action: GetUploadDescriptor for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 2319335ffa01fed460f28b9a13addda4
12/15/05 15:31:37 2776 TextService textserviceasynch.py:482 INFO Listen Callback 'None' '_68f2cd00_p_globus_io_handle_t' '(0, None, None)'
12/15/05 15:31:37 2776 TextService textserviceasynch.py:72 INFO conn handler registering accept
12/15/05 15:31:37 2776 TextService textserviceasynch.py:77 INFO register_accept returns socket=<pyGlobus.io.GSITCPSocket instance at 0x012B4878> cb=_f8b9cd00_p_callbackStruct
12/15/05 15:31:37 2776 TextService textserviceasynch.py:87 INFO Accept Callback 'None' '_e8f5cd00_p_globus_io_handle_t' '(0, None, None)'
12/15/05 15:31:37 2776 TextService textserviceasynch.py:473 DEBUG TextServiceAsynch: register_listen returns '_f8b9cd00_p_callbackStruct'
12/15/05 15:31:37 2776 TextService textserviceasynch.py:154 INFO Got read handle=_e8f5cd00_p_globus_io_handle_t ret=(0, None, None) n=4
12/15/05 15:31:37 2776 TextService textserviceasynch.py:154 INFO Got read handle=_e8f5cd00_p_globus_io_handle_t ret=(0, None, None) n=230
12/15/05 15:31:37 2776 TextService textserviceasynch.py:184 INFO finished reading packet, wait=230 buflen=230
12/15/05 15:31:37 2776 TextService textserviceasynch.py:214 INFO TextConnection: Got Event Event:
12/15/05 15:31:37 2776 TextService textserviceasynch.py:558 INFO Enqueue event Connect for <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x01388E68>...
12/15/05 15:31:37 1576 TextService textserviceasynch.py:575 INFO Queue handler received ('event', Event:
Type: Connect Venue: 000001067ae47fbc00400036001d00f70cc, <AccessGrid.TextServiceAsynch.ConnectionHandler instance at 0x01388E68>)
12/15/05 15:31:37 1576 TextService textserviceasynch.py:619 INFO Handle event type Connect
12/15/05 15:31:37 1576 TextService textserviceasynch.py:300 DEBUG TextServiceAsynch: Attempting authorization on event Connect
12/15/05 15:31:37 1576 VenueServer venue.py:1215 DEBUG Venue gets channelAuthCallback, privateID=0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852
12/15/05 15:31:37 1576 VenueServer venue.py:1219 DEBUG Private id is in client list, authorizing
12/15/05 15:31:37 1576 TextService textserviceasynch.py:319 DEBUG TextServiceAsynch: Auth callback <bound method Venue.textChannelAuthCallback of Venue: name=UCSF Lab Med Lobby id=18911280 url=https://64.54.29.247:8000/Venues/000001067ae47fbc00400036001d00f70cc> returns 1
12/15/05 15:31:37 1576 TextService textserviceasynch.py:679 DEBUG TextServiceAsynch: Adding connObj 0000010830c3b10f00400036001d00f7f8a to channel 000001067ae47fbc00400036001d00f70cc
12/15/05 15:31:37 1576 TextService textserviceasynch.py:573 INFO Queue handler waiting for data
12/15/05 15:31:41 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689501.23.
12/15/05 15:31:46 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689506.22.
12/15/05 15:31:47 1228 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 15:31:47 2005
12/15/05 15:31:47 1228 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 15:31:47 2005
12/15/05 15:31:51 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689511.23.
12/15/05 15:31:52 2248 VenueServer venueserver.py:1130 DEBUG Authorizing with (), _SOAPContext
12/15/05 15:31:52 2248 VenueServer venueserver.py:1138 INFO Authorizing action: GetVenues for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:31:53 2980 Security authorizationmanager.py:613 DEBUG Authorizing: () _SOAPContext
12/15/05 15:31:53 2980 Security authorizationmanager.py:618 INFO Authorizing action: ListRoles for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:31:53 1600 Security authorizationmanager.py:613 DEBUG Authorizing: () _SOAPContext
12/15/05 15:31:53 1600 Security authorizationmanager.py:618 INFO Authorizing action: ListActions for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:31:56 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689516.22.
12/15/05 15:32:01 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689521.23.
12/15/05 15:32:06 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689526.22.
12/15/05 15:32:11 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689531.23.
12/15/05 15:32:16 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689536.22.
12/15/05 15:32:21 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689541.23.
12/15/05 15:32:26 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689546.22.
12/15/05 15:32:31 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689551.23.
12/15/05 15:32:33 3376 Security authorizationmanager.py:613 DEBUG Authorizing: () _SOAPContext
12/15/05 15:32:33 3376 Security authorizationmanager.py:618 INFO Authorizing action: ImportPolicy for subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:32:36 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689556.22.
12/15/05 15:32:41 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689561.23.
12/15/05 15:32:46 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689566.22.
12/15/05 15:32:51 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689571.23.
12/15/05 15:32:56 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689576.22.
12/15/05 15:33:01 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689581.23.
12/15/05 15:33:06 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689586.22.
12/15/05 15:33:11 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689591.23.
12/15/05 15:33:16 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689596.22.
12/15/05 15:33:21 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689601.23.
12/15/05 15:33:26 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689606.22.
12/15/05 15:33:31 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689611.23.
12/15/05 15:33:36 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689616.22.
12/15/05 15:33:41 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689621.23.
12/15/05 15:33:46 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689626.22.
12/15/05 15:33:51 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689631.23.
12/15/05 15:33:56 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689636.22.
12/15/05 15:34:01 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689641.23.
12/15/05 15:34:06 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689646.22.
12/15/05 15:34:11 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689651.23.
12/15/05 15:34:16 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689656.22.
12/15/05 15:34:21 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689661.23.
12/15/05 15:34:26 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689666.22.
12/15/05 15:34:31 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689671.23.
12/15/05 15:34:36 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689676.22.
12/15/05 15:34:41 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689681.23.
12/15/05 15:34:46 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689686.22.
12/15/05 15:34:51 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689691.23.
12/15/05 15:34:56 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689696.22.
12/15/05 15:35:01 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689701.23.
12/15/05 15:35:06 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689706.22.
12/15/05 15:35:11 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689711.23.
12/15/05 15:35:16 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689716.22.
12/15/05 15:35:21 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689721.23.
12/15/05 15:35:26 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689726.22.
12/15/05 15:35:31 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689731.23.
12/15/05 15:35:36 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689736.22.
12/15/05 15:35:41 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689741.23.
12/15/05 15:35:46 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689746.22.
12/15/05 15:35:51 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689751.23.
12/15/05 15:35:56 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689756.22.
12/15/05 15:36:01 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689761.23.
12/15/05 15:36:06 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689766.22.
12/15/05 15:36:11 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689771.23.
12/15/05 15:36:16 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689776.22.
12/15/05 15:36:21 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689781.23.
12/15/05 15:36:26 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689786.22.
12/15/05 15:36:31 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689791.23.
12/15/05 15:36:36 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689796.22.
12/15/05 15:36:41 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689801.23.
12/15/05 15:36:46 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689806.22.
12/15/05 15:36:47 1228 VenueServer venueserver.py:667 INFO Checkpoint starting at: Thu Dec 15 15:36:47 2005
12/15/05 15:36:47 1228 VenueServer venueserver.py:710 INFO Checkpointing completed at: Thu Dec 15 15:36:47 2005
12/15/05 15:36:51 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689811.23.
12/15/05 15:36:56 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689816.22.
12/15/05 15:37:01 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689821.23.
12/15/05 15:37:06 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689826.22.
12/15/05 15:37:11 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689831.23.
12/15/05 15:37:16 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689836.22.
12/15/05 15:37:21 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689841.23.
12/15/05 15:37:26 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689846.22.
12/15/05 15:37:31 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689851.23.
12/15/05 15:37:36 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689856.22.
12/15/05 15:37:41 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689861.23.
12/15/05 15:37:46 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689866.22.
12/15/05 15:37:51 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689871.23.
12/15/05 15:37:56 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689876.22.
12/15/05 15:38:01 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689881.23.
12/15/05 15:38:06 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689886.22.
12/15/05 15:38:11 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689891.23.
12/15/05 15:38:16 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689896.22.
12/15/05 15:38:21 1556 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 0000010830c3ac4c00400036001d00f77b3_0000010830c3ac4c00400036001d00f7852 at 1134689901.23.
12/14/05 16:33:31 4016 Toolkit toolkit.py:96 DEBUG Initializing AG Toolkit version 2.4 (build 1)
12/14/05 16:33:31 4016 Toolkit config.py:1130 INFO Found 2 processors; setting affinity
12/14/05 16:33:31 4016 Toolkit toolkit.py:138 INFO Logfile Name: VideoConsumerService.log
12/14/05 16:33:31 4016 Toolkit toolkit.py:205 WARNING Toolkit.__CheckForValidClock: The machine clock is incorrect on
your computer: it is 33 seconds fast with respect
12/14/05 16:33:31 4016 Toolkit toolkit.py:709 INFO Service init: have profile None
12/14/05 16:33:31 4016 Toolkit config.py:196 DEBUG Using GLOBUS_HOSTNAME=64.54.29.247 as set in the environment
12/14/05 16:33:31 4016 CertificateManager certificatemanager.py:269 DEBUG Opened repository C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo
12/14/05 16:33:32 4016 Toolkit toolkit.py:738 INFO Initialized cert mgmt.
12/14/05 16:33:32 4016 Toolkit toolkit.py:753 INFO Loaded profile and configured with it.
12/14/05 16:33:32 4016 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
12/14/05 16:33:32 4016 CertificateManager certificatemanager.py:827 DEBUG Using default identity /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:33:32 4016 CertificateManager certificatemanager.py:1083 DEBUG Initializing environment with unencrypted cert /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/14/05 16:33:32 4016 CertificateManager certificatemanager.py:1098 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\191c8500c5d893d758250b70098c95ce\38d6622212820902ad92145aa0bb0932\cert.pem to 644
12/14/05 16:33:32 4016 CertificateManager certificatemanager.py:1109 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\privatekeys\60fef24d87f80145a55c7bb89691fde6.pem to 600
12/14/05 16:33:32 4016 CertificateManager certificatemanager.py:1572 DEBUG done, success=1
12/14/05 16:33:32 4016 Toolkit toolkit.py:764 INFO Initialized Globus.
12/14/05 16:33:32 4016 Toolkit toolkit.py:782 INFO Service Initialization Complete.
12/14/05 16:33:32 4016 Toolkit agservice.py:442 INFO Starting Service URI: https://64.54.29.247:55765/Service
12/14/05 16:34:10 3052 Toolkit videoconsumerservice.py:200 INFO SetIdentity: UCSF China Basin Microbilogy terrazas at labmed2.ucsf.edu
12/14/05 16:34:13 3176 Toolkit agservice.py:136 INFO ConfigureStream: video 224.2.175.122 56424
12/14/05 16:34:13 3176 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoConsumerService\vic.exe
File "C:\Python23\Lib\site-packages\AccessGrid\Platform\win32\Config.py", line 1087, in __AppFirewallConfig
_winreg.KEY_ALL_ACCESS)
WindowsError: [Errno 5] Access is denied
12/14/05 16:34:14 3176 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoConsumerService\vic.exe
12/14/05 16:34:14 3176 Toolkit videoconsumerservice.py:163 INFO Starting VideoConsumerService
12/14/05 16:34:14 3176 Toolkit videoconsumerservice.py:164 INFO executable = C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoConsumerService\vic.exe
12/14/05 16:34:14 3176 Toolkit videoconsumerservice.py:165 INFO options = ['-C', 'UCSF Lab Med Lobby', '-t', '127', '-XrtpName=UCSF China Basin Microbilogy', '-XrtpEmail=terrazas at labmed2.ucsf.edu', '-XrecvOnly=1', '224.2.175.122/56424']
12/14/05 16:34:14 3176 ProcessManager processmanager.py:59 DEBUG Creating process: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoConsumerService\vic.exe -C "UCSF Lab Med Lobby" -t 127 "-XrtpName=UCSF China Basin Microbilogy" -XrtpEmail=terrazas at labmed2.ucsf.edu -XrecvOnly=1 224.2.175.122/56424
12/14/05 16:34:14 3176 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x01274244>, <PyHANDLE object at 0x01280FA4>, 3172, 3180)
12/14/05 16:56:41 3440 ProcessManager processmanager.py:135 ERROR couldn't shutdown process <PyHANDLE:732>: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
File "C:\Python23\Lib\site-packages\AccessGrid\Platform\win32\ProcessManager.py", line 128, in TerminateProcess
win32api.PostThreadMessage(self.threadid[pid], 18, 0, 0)
error: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
12/14/05 16:56:41 3440 ProcessManager processmanager.py:142 ERROR couldn't terminate process <PyHANDLE:732>: (5, 'TerminateProcess', 'Access is denied.')
File "C:\Python23\Lib\site-packages\AccessGrid\Platform\win32\ProcessManager.py", line 139, in TerminateProcess
win32process.TerminateProcess(pid, 0)
error: (5, 'TerminateProcess', 'Access is denied.')
12/14/05 16:56:41 3440 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoConsumerService\vic.exe
12/14/05 16:56:44 3104 Toolkit agservice.py:190 INFO Shut service down
12/14/05 16:56:44 3104 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoConsumerService\vic.exe
12/14/05 16:56:44 3484 Hosting server.py:65 ERROR Exception in SOAP server main loop
File "C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py", line 63, in Run
self._server.handle_request()
File "C:\Python23\lib\SocketServer.py", line 217, in handle_request
request, client_address = self.get_request()
File "C:\Python23\Lib\site-packages\SOAPpy\GSIServer.py", line 140, in get_request
sock, addr = ThreadingGSITCPSocketServer.get_request(self)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 525, in get_request
self.socket.listen()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 857, in listen
raise ex
GSITCPSocketException: an I/O operation was cancelled
12/15/05 15:02:07 4048 Toolkit toolkit.py:96 DEBUG Initializing AG Toolkit version 2.4 (build 1)
12/15/05 15:02:07 4048 Toolkit config.py:1130 INFO Found 2 processors; setting affinity
12/15/05 15:02:07 4048 Toolkit toolkit.py:138 INFO Logfile Name: VideoConsumerService.log
12/15/05 15:02:07 4048 Toolkit toolkit.py:205 WARNING Toolkit.__CheckForValidClock: The machine clock is incorrect on
12/15/05 15:02:07 4048 Toolkit toolkit.py:709 INFO Service init: have profile None
12/15/05 15:02:07 4048 Toolkit config.py:196 DEBUG Using GLOBUS_HOSTNAME=64.54.29.247 as set in the environment
12/15/05 15:02:07 4048 CertificateManager certificatemanager.py:269 DEBUG Opened repository C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo
12/15/05 15:02:07 4048 Toolkit toolkit.py:738 INFO Initialized cert mgmt.
12/15/05 15:02:07 4048 Toolkit toolkit.py:753 INFO Loaded profile and configured with it.
12/15/05 15:02:07 4048 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
12/15/05 15:02:07 4048 CertificateManager certificatemanager.py:827 DEBUG Using default identity /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:02:07 4048 CertificateManager certificatemanager.py:1083 DEBUG Initializing environment with unencrypted cert /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:02:07 4048 CertificateManager certificatemanager.py:1098 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\191c8500c5d893d758250b70098c95ce\38d6622212820902ad92145aa0bb0932\cert.pem to 644
12/15/05 15:02:07 4048 CertificateManager certificatemanager.py:1109 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\privatekeys\60fef24d87f80145a55c7bb89691fde6.pem to 600
12/15/05 15:02:07 4048 CertificateManager certificatemanager.py:1572 DEBUG done, success=1
12/15/05 15:02:07 4048 Toolkit toolkit.py:764 INFO Initialized Globus.
12/15/05 15:02:07 4048 Toolkit toolkit.py:782 INFO Service Initialization Complete.
12/15/05 15:02:07 4048 Toolkit agservice.py:442 INFO Starting Service URI: https://64.54.29.247:62117/Service
12/15/05 15:02:25 3736 Toolkit videoconsumerservice.py:200 INFO SetIdentity: UCSF China Basin Microbilogy terrazas at labmed2.ucsf.edu
12/15/05 15:02:27 3032 Toolkit agservice.py:136 INFO ConfigureStream: video 224.2.175.122 56424
12/15/05 15:02:27 3032 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoConsumerService\vic.exe
12/15/05 15:02:27 3032 Toolkit videoconsumerservice.py:163 INFO Starting VideoConsumerService
12/15/05 15:02:27 3032 Toolkit videoconsumerservice.py:164 INFO executable = C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoConsumerService\vic.exe
12/15/05 15:02:27 3032 Toolkit videoconsumerservice.py:165 INFO options = ['-C', 'UCSF Lab Med Lobby', '-t', '127', '-XrtpName=UCSF China Basin Microbilogy', '-XrtpEmail=terrazas at labmed2.ucsf.edu', '-XrecvOnly=1', '224.2.175.122/56424']
12/15/05 15:02:27 3032 ProcessManager processmanager.py:59 DEBUG Creating process: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoConsumerService\vic.exe -C "UCSF Lab Med Lobby" -t 127 "-XrtpName=UCSF China Basin Microbilogy" -XrtpEmail=terrazas at labmed2.ucsf.edu -XrecvOnly=1 224.2.175.122/56424
12/15/05 15:02:28 3032 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x01274244>, <PyHANDLE object at 0x01280FA4>, 3680, 3588)
12/15/05 15:10:47 1752 ProcessManager processmanager.py:133 WARNING Couldn't terminate process <PyHANDLE:732> cleanly (258)
12/15/05 15:10:47 1752 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoConsumerService\vic.exe
12/15/05 15:10:51 3668 Toolkit agservice.py:190 INFO Shut service down
12/15/05 15:10:51 3668 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoConsumerService\vic.exe
12/15/05 15:10:51 3772 Hosting server.py:65 ERROR Exception in SOAP server main loop
raise ex
12/15/05 15:11:15 3412 Toolkit toolkit.py:96 DEBUG Initializing AG Toolkit version 2.4 (build 1)
12/15/05 15:11:15 3412 Toolkit config.py:1130 INFO Found 2 processors; setting affinity
12/15/05 15:11:15 3412 Toolkit toolkit.py:138 INFO Logfile Name: VideoConsumerService.log
12/15/05 15:11:15 3412 Toolkit toolkit.py:205 WARNING Toolkit.__CheckForValidClock: The machine clock is incorrect on
12/15/05 15:11:15 3412 Toolkit toolkit.py:709 INFO Service init: have profile None
12/15/05 15:11:15 3412 Toolkit config.py:196 DEBUG Using GLOBUS_HOSTNAME=64.54.29.247 as set in the environment
12/15/05 15:11:15 3412 CertificateManager certificatemanager.py:269 DEBUG Opened repository C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo
12/15/05 15:11:15 3412 Toolkit toolkit.py:738 INFO Initialized cert mgmt.
12/15/05 15:11:15 3412 Toolkit toolkit.py:753 INFO Loaded profile and configured with it.
12/15/05 15:11:15 3412 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
12/15/05 15:11:15 3412 CertificateManager certificatemanager.py:827 DEBUG Using default identity /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:11:15 3412 CertificateManager certificatemanager.py:1083 DEBUG Initializing environment with unencrypted cert /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 5b8db30b09bce08995b9640473d6743f
12/15/05 15:11:15 3412 CertificateManager certificatemanager.py:1098 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\certificates\191c8500c5d893d758250b70098c95ce\38d6622212820902ad92145aa0bb0932\cert.pem to 644
12/15/05 15:11:15 3412 CertificateManager certificatemanager.py:1109 INFO Setting permissions on certificate C:\Documents and Settings\mvideo\Application Data\AccessGrid\Config\certRepo\privatekeys\60fef24d87f80145a55c7bb89691fde6.pem to 600
12/15/05 15:11:15 3412 CertificateManager certificatemanager.py:1572 DEBUG done, success=1
12/15/05 15:11:15 3412 Toolkit toolkit.py:764 INFO Initialized Globus.
12/15/05 15:11:15 3412 Toolkit toolkit.py:782 INFO Service Initialization Complete.
12/15/05 15:11:15 3412 Toolkit agservice.py:442 INFO Starting Service URI: https://64.54.29.247:52200/Service
12/15/05 15:11:33 1076 Toolkit videoconsumerservice.py:200 INFO SetIdentity: UCSF China Basin Microbilogy terrazas at labmed2.ucsf.edu
12/15/05 15:11:35 3728 Toolkit agservice.py:136 INFO ConfigureStream: video 224.2.175.122 56424
12/15/05 15:11:35 3728 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoConsumerService\vic.exe
12/15/05 15:11:35 3728 Toolkit videoconsumerservice.py:163 INFO Starting VideoConsumerService
12/15/05 15:11:35 3728 Toolkit videoconsumerservice.py:164 INFO executable = C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoConsumerService\vic.exe
12/15/05 15:11:35 3728 Toolkit videoconsumerservice.py:165 INFO options = ['-C', 'UCSF Lab Med Lobby', '-t', '127', '-XrtpName=UCSF China Basin Microbilogy', '-XrtpEmail=terrazas at labmed2.ucsf.edu', '-XrecvOnly=1', '224.2.175.122/56424']
12/15/05 15:11:35 3728 ProcessManager processmanager.py:59 DEBUG Creating process: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoConsumerService\vic.exe -C "UCSF Lab Med Lobby" -t 127 "-XrtpName=UCSF China Basin Microbilogy" -XrtpEmail=terrazas at labmed2.ucsf.edu -XrecvOnly=1 224.2.175.122/56424
12/15/05 15:11:35 3728 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE object at 0x01274244>, <PyHANDLE object at 0x01280FA4>, 1688, 1128)
12/15/05 15:24:16 4076 Toolkit agservice.py:190 INFO Shut service down
12/15/05 15:24:16 4076 ProcessManager processmanager.py:133 WARNING Couldn't terminate process <PyHANDLE:732> cleanly (258)
12/15/05 15:24:16 4076 Toolkit config.py:1116 ERROR Exception configuring firewall for application: C:\Documents and Settings\mvideo\Application Data\AccessGrid\local_services\VideoConsumerService\vic.exe
