[AG-TECH] Portal node listing update ...
Martin Polak
mpolak at gup.jku.at
Tue Aug 9 02:35:12 CDT 2005
Darran Edmundson wrote:
> Hi All,
> Thanks to all those who have taken the time to add
> a "Node Listing" to the portal. I've just finished a
> crude listings page that aggregates the data. http://agcentral.org/
> You'll find this under the new "nodes" tab on the main
> navigation bar. It's not pretty at the moment, but
> that'll change in the near future.
> I suspect that others will now want to start adding
> listings. To facilitate this, I've written up a How-To
> on "Adding a Node Listing":
> http://agcentral.org/help/how-to/node-listing
> Note, this document needs "reviewing" and
> "publishing" by one of the portal reviewers (you know
> who you are). Until then, it won't appear in the
> Help Center and is reachable only by logged-in
> members via the above link.
> I'm hoping to wake up tomorrow to vastly expanded
> node listings. Next will be a map of Access Grid
> nodes using the GPS coordinates ...
Hi Darran,
a minor issue I just found:
On entering my site I did not select "multicast enabled" because my site doesn't
support multicast. However when viewing my entry in the global listing, it says
I am multicast enabled..... So whatever the checkbox is, it is not being
evaluated correctly.
Cheers,
Martin
Dipl.-Ing. EGEE-Partner #2
Martin Polak
Institute of Graphics and Parallel Processing
Johannes Kepler University Linz
Altenbergerstrasse 69
A-4040 Linz, AUSTRIA, EUROPE ________ ______
T 644 / ____/ / / / __ \
phone: +43 732 2468 8884 / / __/ / / / /_/ /
fax: +43 732 2468 9496 / /_/ / /_/ / ____/
mobile: +43 699 112 02 493 \____/\____/_/
email: mpolak at gup.jku.at http://www.gup.uni-linz.ac.at/
