[AG-TECH] Re: your mail
monika.k.rabarison at ccaix.jsums.edu
Mon Aug 8 10:26:47 CDT 2005
Same issue on a Gateway laptop running XP and AGTk 2.3 since
its release. Everything went fine until last month.
I uninstalled AGTk2.3 and deleted C:\Documents and
Settings\<user>\Application Data\Access Grid. After
reinstalling AGtk, RAT appears to behave properly again.
Notes: This laptop had AGTk 2.1.2 before. I am not sure if
the reinstallation solved the issue. So far I could not
reproduce it.
-Monika
> We've experienced the same problem here at NLM on our XP
> machine..............
> -----Original Message-----
> From: John Hodrien [mailto:johnh at comp.leeds.ac.uk]
> Sent: Monday, August 08, 2005 7:27 AM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] Re: your mail
> On Mon, 8 Aug 2005, Peter DeSantis wrote:
> > Hi,
> > has anyone come across an issue with the AG 2.3 software
> where you find that
> > you can not receive (hear) audio from any other
> > participants unless your local "talk" option is enabled.
> > Also i would have expected full duplex audio operation
> to allow one to speak and receive audio simultaneously,
> > but it also appears that when you speak locally and
> > start to transmit audio it cuts of the incoming audio.
> Is this normal ?
> Definitely not normal. Have you got the dodgy software
> based echo cancellation turned on in rat or something?
> > Ive come across this on two XP based machines now. It
> > dont appear to be a networking issue in that once talk
> > is enable others can be heard fine. In both cases the
> machines had different audio cards, and one is single Pc
> > the other a 3 pc system.
> Doesn't happen with any of our 2000 or linux based
> machines.
> jh
> "Computers are useless. They can only give you answers."
> Pablo Picasso
