[AG-TECH] AG security and multicast ?
Derek Piper
dcpiper at indiana.edu
Wed Apr 13 09:48:24 CDT 2005
Since the 'brainstorming' appears to have died down a lot.. What about
a published API for interacting with the venue server? Then we can all
go write our tools/add-ons and be happy. Good ones can be incorporated
into the main AG software, i.e. pass codes etc.
Derek
Ivan R. Judson wrote:
> The beauty of Adam's suggestion is that it's exactly what the AG team has
> been trying to get enough time to build. This is the kind of work we'd like
> to see -- but I don't believe the NCSA scheduler has been released yet for
> others to hack on it. The work I believe is a small amount using the
> existing interfaces that are available.
> If this can't be done in short order, I support Brian's point that for most
> users a passcode/password -- similar to what is used by conference calls or
> web meeting software, should be sufficient _to gain access_ to the venue (to
> get past the bouncer), but it's really of *no* use if the communication
> within the venue isn't secure -- then as Jennifer points out, you're only
> relying on obscurity.
> Who wants to hack on the scheduling software (either NCSA's or a new one)?
> That's where the interesting "automation" is. It won't solve all the ad-hoc
> stuff, but it'd go a long way towards solving a lot of the mundane
> problems...
> --Ivan
>>-----Original Message-----
>>From: owner-ag-tech at mcs.anl.gov
>>[mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Adam Taylor
>>Sent: Monday, April 11, 2005 11:01 AM
>>To: ag-tech at mcs.anl.gov
>>Subject: RE: [AG-TECH] AG security and multicast ?
>>My two cents...
>>To bad there wasn't a way that when you go to confirm you
>>reservation in the AG Scheduler you must enter the DN of the
>>site you will be at to confirm your reservation. Then, 5 min
>>or so before the meeting starts, a background process
>>(something that can talk to the venue server and scheduler)
>>reads in the DNs from the scheduler for that room and time
>>and sets the ACL for that room for that given scheduled time
>>block. When that meeting is over, the background process
>>removes that ACL for that room and creates another one for
>>the next meeting in that room. If there is more then 30 min
>>or so between meetings then the background process just
>>removes the ACL for that period of time. Just make sure all
>>rooms are encrypted (different key per meeting or something
>>like that) and that should make it pretty secure.
>>At least in my head it does :-)
>>Adam Taylor
>>Computing Center
>>University of Louisiana at Monroe
Derek Piper - dcpiper at indiana.edu - (812) 856 0111
IRI 323, School of Informatics
Indiana University, Bloomington, Indiana
