[AG-TECH] 2.3 & Winnov Videum
Fred Dech
fdech at uchicago.edu
Fri Sep 24 14:07:07 CDT 2004
On Fri, Sep 24, 2004 at 01:04PM, Marcus Christie said:
> Fred,
> I've got the same video card here, and I was having a lot of trouble
> with it. I upgraded to 2.3, but I'm still having some problems,
> although not as many. In particular, sometimes when I add a
> VideoProducerService, the video is "jumpy" and after a while it goes to
> a black screen. It also takes a bit of fiddling to get any video. I
hi Marcus.
the flaky stream you describe is something i've not experienced.
you might want to first check your video cable on both ends and maybe swap
cables to see if that problem goes away.
> Any advice you have is most welcome. I also saw in an earlier message
> something about registry settings. Did you have to do that with 2.3?
well... i have it from a very reliable *inside* source that 2.3 VIC is
supposed to handle the registry issues for this card correctly. however,
when i installed 2.3, i did not get all four streams until i fixed the source
values for vic.exe[0-3] using regedit. two or three were set to identical
values. at the same time i modded the source values for WnvConfig.exe[0-3],
although i suspect that those registry values aren't relevant to AG VIC. i
also had to modify height and width decimal values in the vic's to match h261
resolution.
good luck.
--fred
