[AG-TECH] 2.3 Toolkit install problem on XP
Jeffrey Bary
Jeffrey.Bary at nyu.edu
Tue Sep 21 15:59:34 CDT 2004
The key was to delete all the Python directories after the uninstall.
I just did the uninstall and the directories were not deleted and the
install procedure must infer wrongly the proper place for certain
files.
-Jeff
>On Mon, Sep 20, 2004 at 03:17PM, Jeffrey Bary said:
>> When I try to start the toolkit from the shortcut on the desktop
>> nothing happens. The hourglass show for a moment and then it exits.
>> The debug option produces the same result and no log files are to be
>> found in C:\Program Files\AGTk-2.3\Logs.
>> When I run it manually from the command prompt I get this:
>> C:\DOCUME~1\JEFF\APPLIC~1>C:\Python23\python.exe "C:\Program
>> Files\AGTk-2.3\bin\
>> VenueClient.py" -d --personalNode
>> Traceback (most recent call last):
>> File "C:\Program Files\AGTk-2.3\bin\VenueClient.py", line 28, in ?
>> from AccessGrid.Toolkit import WXGUIApplication
>> ImportError: No module named Toolkit
>on my first XP install of 2.3 i was in a hurry and distracted and got a
>python error that wasn't the same as yours, but similar. some Python
>script that was in the XXX/site_packages/AccessGrid/ wasn't being located
>causing VenueClient.py to bail.
>i de-installed more carefully (removing Python23 directory after uninstall)
>and re-installed more carefully. problem solved.
>--fred
