[AG-TECH] Gnome launchers in FC2
Jim Miller
millerjw at psc.edu
Wed Sep 15 12:44:27 CDT 2004
Just tried that... didn't work. The AGServiceManager dies as soon as I
bring up the Venue Client on the control box.... Same issue.
Jim
Michael Miller wrote:
> Jim,
> Use gnome-session-properties to set up a "Startup Application". I just
> entered AGServiceManager.py in the command box and logged out/logged in
> and it works.
> Michael Miller
> NCSA
> At 03:36 PM 9/14/2004, Jim Miller wrote:
>> I am having problems with the launchers in Gnome. If I open an xterm
>> or a gnome-terminal and run Service Manager by physically typing
>> AGServiceManager.py everything works fine. However, If I try to run
>> servicemanager from the menu items or create a launcher myself, the
>> AGServiceManager will run and listen on port 11000, but as soon as the
>> VenueClient tries to communicate with the ServiceManager, the terminal
>> window disappears and the AGServiceManager.py script dies. I have
>> tried creating Gnome application launchers for the AGServiceManager.py
>> script as well as created a launcher to run just a basic xterm that
>> runs AGServiceManager (xterm -e AGServiceManager.py)
>> I get the same result for both.
>> Any Ideas?
>> Thanks,
>> Jim
> Thanx,
> Michael Miller
> System Engineer
> Visualization Technology Support
> Computing and Data Management
> National Center for Supercomputing Applications
> University of Illinois - UC
> 217-649-0747
> "If you're clear in your vision and trust the people in your team with
> clear objectives, they will invariably do their best to achieve
> everything desired, and usually deliver everything you could have hoped
> for and even more." -Paul Debevec
