[AG-TECH] Gnome launchers in FC2
Michael Miller
mimiller at ncsa.uiuc.edu
Wed Sep 15 15:30:16 CDT 2004
Then I must defer to the wisdom of the AG Dev team... ;-)
Michael
At 02:58 PM 9/15/2004, you wrote:
>Nope, the only thing running on the linux box is AGServiceManager.py. The
>VenueClient is running on the control(display windows xp) machine.
>Jim
>Michael Miller wrote:
>>So you are running the VenueClient on the same machine as the separate
>>AGServiceManager?
>>If so, then yes, you will have a problem running the VenueClient with the
>>--personalNode flag as that will cause an AGServiceManager.py instance to
>>attempt to use port 11000. Which will cause it to fail because the port
>>is already in use by the separate AGServiceManager.
>>Try setting the command in the startup app to:
>>AGServiceManager.py -p 12000
>>or whatever other port you want.
>>If you're not using the --personalNode flag when running the venue
>>client, I would file it as a bug because the venue client should not be
>>launching a service manager if the flag is not there.
>>Michael Miller
>>NCSA
>>At 12:44 PM 9/15/2004, Jim Miller wrote:
>>>Just tried that... didn't work. The AGServiceManager dies as soon as I
>>>bring up the Venue Client on the control box.... Same issue.
>>>Jim
>>>>Jim,
>>>>Use gnome-session-properties to set up a "Startup Application". I just
>>>>entered AGServiceManager.py in the command box and logged out/logged
>>>>in and it works.
>>>>Michael Miller
>>>>NCSA
>>>>At 03:36 PM 9/14/2004, Jim Miller wrote:
>>>>>I am having problems with the launchers in Gnome. If I open an xterm
>>>>>or a gnome-terminal and run Service Manager by physically typing
>>>>>AGServiceManager.py everything works fine. However, If I try to run
>>>>>servicemanager from the menu items or create a launcher myself, the
>>>>>AGServiceManager will run and listen on port 11000, but as soon as the
>>>>>VenueClient tries to communicate with the ServiceManager, the terminal
>>>>>window disappears and the AGServiceManager.py script dies. I have
>>>>>tried creating Gnome application launchers for the AGServiceManager.py
>>>>>script as well as created a launcher to run just a basic xterm that
>>>>>runs AGServiceManager (xterm -e AGServiceManager.py)
>>>>>I get the same result for both.
>>>>>Any Ideas?
>>>>>Thanks,
>>>>>Jim
>>>>Thanx,
>>>>Michael Miller
>>>>System Engineer
>>>>Visualization Technology Support
>>>>Computing and Data Management
>>>>National Center for Supercomputing Applications
>>>>University of Illinois - UC
>>>>217-649-0747
>>>>"If you're clear in your vision and trust the people in your team with
>>>>clear objectives, they will invariably do their best to achieve
>>>>everything desired, and usually deliver everything you could have hoped
>>>>for and even more." -Paul Debevec
>>Thanx,
>>Michael Miller
>>System Engineer
>>217-649-0747
Thanx,
Michael Miller
System Engineer
217-649-0747
clear objectives, they will invariably do their best to achieve everything
desired, and usually deliver everything you could have hoped for and even
