[AG-TECH] Various topics
    Eric Olson
    eolson at mcs.anl.gov
    Fri Sep  3 12:18:57 CDT 2004
On Fri, 3 Sep 2004, Jeremy Mann wrote:
> I'm giving the OS X build of 2.3 a try today. Major problem is it won't
> import my user certificate. It seems to only work with an Anonymous
> certificate, but that's fine for testing right now. Another thing I just
> noticed is that it doesn't save the Anonymous certificate when exiting the
> program. Start it up again and the Anonymous certificate is gone.
I've noticed similar things too on OSX only and don't know the cause yet.
If you're interesting in debugging it more, moving your certRepo directory
(from ~/.AccessGrid/certRepo) will help you start from a clean slate.
> The other subject is Anonymous certificates. For some reason our
> venueserver is not allowing Anonymous certificates to be used. The server
> is running 2.2. When trying to connect using Anonymous I get an error
> message saying the time is wrong on my computer. However, when I set my
> user cert to default, it connects with no problem.
This probably means your server doesn't have the Anonymous CA cert
installed.  I don't believe it was included in the 2.2 release, but it is
in the 2.3 betas and final.  It is possible to load the Anonymous CA cert
files (available in our cvs repository) into your 2.2 server with the
certmgr.py command-line application.  If you decide to do this and need
help with process just ask.
Eric
> Jeremy Mann
> jeremy at biochem.uthscsa.edu
> University of Texas Health Science Center
> Bioinformatics Core Facility
> http://www.bioinformatics.uthscsa.edu
> Phone: (210) 567-2672
