[AG-TECH] AGTk 2.3 BETA 2 for Fedora Released
Todd Zimmerman
toddz at sfu.ca
Wed Sep 1 13:17:36 CDT 2004
Hi Doug,
Thanks a lot for your fedora releases - they are very useful.
I was wondering if there is a plan/roadmap for what will be happening
with the Fedora releases - especially since FC3 test 1 is out. Will FC2
be supported long term - or will we have to migrate to FC3 when it is
released?
Just trying to get a handle on whether Fedora is a long term solution
for some of our servers, or whether I would be better off selecting an
OS that is more stable.
Todd
Collaboration & Visualization Technician
WestGrid - www.westgrid.ca
IRMACS - www.irmacs.com
Ph. 604.268.6979
Todd Zimmerman - toddz at sfu.ca
Douglas Kosovic wrote:
> The Access Grid Toolkit 2.3 BETA 2 for Fedora is now available from:
> http://www.itee.uq.edu.au/~agn/ag_fedora/
> Experimental support for Shared Presentations using OpenOffice is now
> mostly working, requires the openoffice.org-pyuno RPM to be installed.
> The AccessGrid, globus-accessgrid and gpt RPMs have all been updated.
> For FC2, the xawtv RPMs have been deleted as xawtv's v4lctl is no longer
> required.
> If you are using an anonymous certificate as your default identity
> certificate and Node Management configuration actives don't work for
> you, try setting the default to a non-anonymous identity certificate.
> Doug
