[AG-TECH] Problems installing AG Toolkit 2.3
Judy L. Cox
jlcox at tlc2.uh.edu
Fri Nov 19 08:56:50 CST 2004
Hello,
I installed AG Toolkit 2.3 on an IBM Thinkpad laptop (WindowsXP O/S) for a
customer. The video camera is Logitech QuickCam Orbit and the microphone is
Plantronics w/ echo canceling. I successfully installed the appropriate
software. In addition I requested and loaded the certificate. When I
tried to start the NODE or SERVER MANAGER services the following error
message appears:
NODE Service error message:
'C:\Python23\lib\fcntl.py:7: DeprecationWarning: the FCNTL mode is
deprecated; please use fcntl.
C:\Python23\lib\termios:py:7: DeprecationWarning: the TERMIOS module is
deprecated; please use termios
Starting Node Service URL: https://my <https://my/> IP
address:11000/NodeService
Starting Service Manager URL: https://my <https://my/> IP
address:11000/ServiceManager
Traceback (most recent call last):
File "C:\Program Files\AGTk-2.3\bin\AGServiceManager.py", line 145, in ?
File "C:\Program Files\AGTk-2.3\bin\AGServiceManager.py", line 130, in
main
gNodeService.LoadDefaultConfig()
File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line 359
in
LoadDefaultConfig
Raise Exception ("Failed to load default configuration (%s)" %
Exception: Failed to load default configuration (defaultWindows)'
SERVICE MANAGE error message:
'C:\Python23\lib\fcntl.py:7: DeprecationWarning: the FCNTL module is
C:\Python23\lib\termios.py:7: DeprecationWarning: the TERMIOS module is
Starting Service Manager URL: https://129.7.249.136:11000/ServiceManager'
Of course, the service should be running before I can setup complete the
Node Wizard. I searched the internet for this error message and found an
article which stated the problem is due to "Windoze " which has a case
insensitive file system. I tried renaming FCNTL and TERMIOS. Also, I
renamed using the same name, but in lower case. Has anyone experiencing
this problem before? If so, what is the fix?
Thanks in advance for your reply.
Judy
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20041119/d1367607/attachment.htm>
