[Fwd: Re: [AG-TECH] Building AG-2.3 for Mandrake 10.X]
Steven Woolsey
woolsr at inel.gov
Thu Nov 18 14:53:29 CST 2004
Forgot to cc the list. sorry.
-------- Original Message --------
Subject: Re: [AG-TECH] Building AG-2.3 for Mandrake 10.X
Date: Thu, 18 Nov 2004 13:51:53 -0700
To: Eric Olson <eolson at mcs.anl.gov>
References: <419BA517.5080804 at inel.gov>
<Pine.LNX.4.58.0411171446580.9920 at terra.mcs.anl.gov>
<419BC32E.1070808 at inel.gov>
<Pine.LNX.4.58.0411171546390.9920 at terra.mcs.anl.gov>
Eric,
Thank you for the suggestions. I have tried them, and these are the
results:
32-bit:
I have looked for the file
~/.AccessGrid/Logs/AGServiceManager.log
but none exists. The file .aglog file in /tmp doesn't exist either.
Any other suggestions?
64-bit:
I tried the -cert and -key option with -debug. Here are the results:
[woolsr at aesir woolsr]$ grid-proxy-init -cert cert2.pem -key key2.pem
-debug
User Cert File: cert2.pem
User Key File: key2.pem
Trusted CA Cert Dir: (null)
Output File: /tmp/x509up_u501
Your identity: /O=Access
Grid/OU=agdev-ca.mcs.anl.gov/OU=inel.gov/CN=Steven Woolsey
Enter GRID pass phrase for this identity:
ERROR: Couldn't read user key: Bad passphrase
key file location: key2.pem
grid_proxy_init.c:794:
globus_gsi_credential.c:1092: globus_gsi_cred_read_key: Error
reading user credential: Can't
read credential's private key from PEM
OpenSSL Error: pem_lib.c:455: in library: PEM routines, function
PEM_do_header: bad decrypt
OpenSSL Error: evp_enc.c:277: in library: digital envelope routines,
function EVP_DecryptFinal: bad decrypt
OpenSSL Error: pem_lib.c:666: in library: PEM routines, function
PEM_read_bio: no start line
I am not sure what all of that means.
I tried an Anonymous Certificate and set it to the default, but the
grid-proxy-init still couldn't find it, so I used certmgr.py to export
the cert and key. Using the -cert and -key worked with the anonymous
certificate. So it appears to be something with the keys I have
imported. I requested a new key from this machine, and it still won't
accept my passphrase.
Steve
Eric Olson wrote:
>Steve,
>Good to hear there's some improvement. Here are a couple suggestions.
>32 bit:
>The AGServiceManager log file is normally in
>but if there's an error before initialization, you might find information
>in a .aglog file in /tmp.
>It looks like there's an exception calling AGTkConfig.instance(0) in
>Toolkit.py. If you want to debug that call, note that the AGTkConfig
>class being used is defined in Platform/unix/Config.py.
>It could be that the necessary toolkit directories don't exist -- they are
>usually created at install time or with CvsSetup.py:
> python tools/CvsSetup.py -a .
> . env-init.sh
>64 bit:
> I'm not sure what the real problem is, but if you use grid-proxy-init
>with -cert and -key options and the certificate files you exported, you
>should be able to tell if there is a problem with your globus environment.
> If that works, trying an anonymous certificate from within the AG
>Toolkit is another good (and quick) test.
>Eric
Steven Woolsey
woolsr at inel.gov
Senior Engineer/Scientist
Visualization Engineer
INEEL
Steven Woolsey
woolsr at inel.gov
INEEL
