[AG-TECH] Winnov Quadro and AGtk 2.3
Dwight D.McKay
mckay at purdue.edu
Thu Nov 11 09:41:18 CST 2004
Tom,
I already have it fixed. I needed an updated VideoService.zip and
VideoProducerService.zip that I found mentioned in the ag-tech mailing
list archive. I've attached a pdf of the article from the archive that
describes the needed zip files.
On Nov 11, 2004, at 12:41 AM, Thomas D. Uram wrote:
> Dwight:
> I'd like to see what's wrong and help you get it set up. Could you
> send me your venue client log file so I could take a look?
> Thanks,
> Tom
> Dwight D.McKay wrote:
>> Can someone send me a pointer to the setup instructions for using a
>> Winnov Quadro with AGtk 2.3 under Windows XP? I'm getting just one
>> stream and its upside down in vic but OK in the Winnov Capture app.
>> I'd go get the instructions from the ag-tech archive, but the server
>> it is on appears to be down right... :-(
>> Dwight D. McKay, Technical Architect
>> Envision Center for Data Perceptualization, IT at P, Purdue University
>> mckay at purdue.edu / v: 765.494.4481 / f: 765.496.7264 / STEW B31
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20041111/bcca2cf7/attachment.pdf>
