[AG-TECH] Dual Boot PIG
Adam Hanson
hanson01 at scl.ameslab.gov
Tue Mar 30 11:18:26 CST 2004
Hey,
Alright, I spose I'm having a little difficulties with this. First, I
was able to transfer the cert files over to the linux platform easily. I
found the locations of where the files should be and replaced them. That
didn't work smoothly and I ended up having to import them. I imported my
windows Ident Cert, as well as both trusted CA Certs (Access Grid
Developers CA and Globus Certification Authority). As well note, I did
this through the VenueClient.py. Now, when I first start up the
VenueClient, It prompts me for a password. The Personal Ident password
does not work for this. As well when trying to start
AGServiceManager.py, the same problem occurs. This is a fresh install
and no other passwords have been declared. I tried starting from scratch
again, this time I requested a new certificate. The same thing occurs
here as well. If needed, I'm doing this install on a Debian Platform
Kernel 2.4.18, with python 2.2.1, AG 2.1.2. Anyone have any suggestions?
It would greatly be appreciated. Oh and on a side note, when everything
is set up and I bypass the first password that denies me access, I'll
try to join a server, it prompts for password which will accept ident
password, and then it specifies that the venue server is unavailable...
Adam
Bill Nickless wrote:
> You might also consider using a USB memory key to store your
> certificates. Some people only use USB memory devices to store key
> material (like SSH identities or PGP public keys) so that their
> exposure to compromise is reduced.
> At 01:53 PM 3/11/2004 -0600, Thomas D. Uram wrote:
>> Hi Adam:
>> My laptop is dual boot Redhat and XP. I've used utilities to access
>> the partition of the unbooted OS read-only to copy files back and forth.
>> Googling for 'debian ntfs' will get you a solution that direction;
>> I've used ext2fsd stuff from ext2.yeah.net to access the linux
>> partition from windows. You could, alternatively, just copy the cert
>> files to the network, and then copy them back when you've booted linux.
>> In any case, you are doing the right thing trying to use your single
>> certificate in both places.
>> Tom
>> Adam Hanson wrote:
>>> hey,
>>> I'm currently setting up a notebook to dual boot with debian and
>>> windows NT. I've currently already recieved a certificate through
>>> the win system, but was also curious if there would be a way to
>>> transfer the certificate from the NTFS partition to the Linux
>>> partition so that I could use this single certificate for both
>>> platforms. Any help would be aprreciated. Thanks
>>> Adam Hanson
> Bill Nickless http://www.mcs.anl.gov/people/nickless +1 630 252 7390
> PGP: 021D EB98 03B3 2E83 3D71 0397 251D 819A D0BE EA32
> nickless at mcs.anl.gov
